Date/Time: Sun, 05 May 2024 13:58:23 +0000
ES session times issue
View Count: 806
[2018-06-10 22:20:51] |
User283129 - Posts: 30 |
Hi there support team engineers, I am currently trying to get my ES 2h chart looking as the Thinkorswim chart. Please find attached the comparison of the 2 hours ES chart for both platforms. I need to have the ES 2h chart of Sierra looking the same as the 2h chart of TOS. Any idea about how to get it? I already tried to play with the session start time settings of Sierra but there was no way to get the chart equal to TOS. Do you know if there is a way to obtain the same 2h chart of TOS in Sierra? Date Time Of Last Edit: 2018-06-14 15:25:06
ES_2h_TOS.png / V - Attached On 2018-06-10 22:19:57 UTC - Size: 63.6 KB - 280 views ES_2h_Sierra.png / V - Attached On 2018-06-10 22:20:04 UTC - Size: 44.12 KB - 292 views |
[2018-06-14 15:33:06] |
Any feedback from you experts? This topic is of paramount importance for the application of my methodology
[2018-06-14 19:05:38] |
We apologize for the delay with this. The problem is we do not know the starting time of the bars in the chart from the other program. Do you know? For an understanding of the bar starting times in Sierra Chart, refer to: Working With Charts: Time Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-14 19:06:17
[2018-06-14 20:18:39] |
Yes, Thinkorswim ES chart is a 180 days chart, the first bar of the 2h chart is 9/26/17 at 1:00 AM. The second bar of the chart is 9/26/17 at 3:00 AM
[2018-06-15 16:48:55] |
Therefore, you need to make sure that the Session Times >> Start Time and Evening Start Time if being used, in the chart is set to the beginning of an hour. Refer to: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-15 16:51:08
