Date/Time: Sun, 19 May 2024 03:48:28 +0000
Chart Data Load Error
View Count: 768
[2018-04-27 12:18:13] |
zippyzip - Posts: 293 |
i use small charts for scalping , but new versions of SC i can open them for some reason , some times they work some times they dont , here is little video of me trying to open a 1 day chart with 1-10 sec
Date Time Of Last Edit: 2018-05-03 18:20:55
Private File |
[2018-05-03 18:28:59] |
You need to check the Window >> Message Log for an error. Most likely you are getting an out of memory condition: Working With Charts: Out of Memory Condition This is not some kind of Sierra Chart problem. There must be an error occurring. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-03 18:30:21
[2018-05-04 11:42:23] |
yes i am getting this every time i log on now , never happened before , please advise
2018-05-04_07h40_52.png / V - Attached On 2018-05-04 11:42:16 UTC - Size: 101.85 KB - 276 views |
[2018-05-04 15:21:51] |
Something is not right on your side. We have no other user reporting this. And we do not observe this and it makes no sense. We want you to run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode And open just one chart and no other chart and let us know if you still see that error. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-04 15:22:28
