Date/Time: Tue, 07 May 2024 01:30:11 +0000
Updating to current version
View Count: 3102
[2018-04-09 15:42:40] |
User245327 - Posts: 1 |
I have tried for several weeks to update to the current version without success. It says "The software update has been downloaded." I click Yes to close the program. I am then asked if I want to reinstall the program and I click Yes and then it just goes away and doesn't reinstall.
Date Time Of Last Edit: 2018-04-09 15:46:56
[2018-04-09 18:18:42] |
This issue is explained here along with instructions to update: Unable to Update Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
