Date/Time: Sat, 27 Apr 2024 06:01:27 +0000
unable to display a
View Count: 530
[2018-03-28 17:34:11] |
Glenn Infinity - Posts: 103 |
below is from customer, is there something specific he needs to do? I'm unable to display a "200 Simple MA" study on a Daily chart on the YM only...all other instruments I can display it on. However for some reason the YM will not show up on the screen. I've updated the software and that didn't work. Please advise. |
[2018-03-28 19:22:11] |
Check in Chart >> Chart Settings that either the Use Number of Days to Load or the Use Date Range (whichever is selected) is loading more than 200 days of data, otherwise there is not enough data to create the Moving Average. Refer to: Chart Studies: Resolving Study Not Visible Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-28 19:22:29
[2018-03-29 13:26:11] |
thank you but this did not work either...any other suggestions?
[2018-03-29 17:15:50] |
There are no other suggestions other than what is documented here: Chart Studies: Resolving Study Not Visible Issue It must be one of the items explained in that section: Resolving Study Not Visible Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-29 17:20:16
[2018-03-29 17:20:39] |
Make sure the chart is set to use the Continuous Futures Contract feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
