Date/Time: Tue, 14 May 2024 13:04:27 +0000
Tools
View Count: 823
[2018-02-19 12:38:29] |
bwasi - Posts: 34 |
How I can still can usee actively HAND tool to drag my chart easier AfteR selecting a line tool ? I found that I cant drag chart after I selected a line tool. I want bOTH active at the same time (line and hand tools ) to save valuable time |
[2018-02-19 18:26:00] |
You cannot have them both available at the same time, as they both use the same pointer device left-click to perform their tasks. What you want to do is go to Global Settings >> Tool Settings and set the option After Single Tool Use Change To to Hand. This will then switch automatically to the Hand Tool after you have finished drawing a line. The documentation for this setting can be found here: Chart Drawing Tools: General Tool Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-20 11:23:28] |
bwasi - Posts: 34 |
tq for your response . I'm aware of the setting and documentation. After single use of line , it will auto to hand tool, BUT I need to click again the line tool (or other tool) For user like me, when I select a line tool, usually I want to draw more than one line (subconciusly) PLs reconsider my request as this is very old issue for me , I tried it more than 50++ times to get both active but only now I let SC know. |
