Date/Time: Thu, 09 May 2024 05:36:46 +0000
where is the Add Additional Symbol study link
View Count: 1180
[2018-02-06 16:03:47] |
Marc P - Posts: 29 |
I would like to add NISS-NYSE and TICK-NYSE to my ES chart. I have all three symbols in the same custom study window but would like to have the NISS and TICK as subgraphs to the ES chart. I have done this before, so I know it is possible, but I forgot how I did it. Thanks, Marc |
[2018-02-06 18:08:56] |
Refer to: Sierra Chart Market Statistics: Overlaying a Chart on Another Chart as a Study https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=400&Name=Add_Additional_Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-06 18:09:59] |
The Add Additional Symbol option is a study. To add it to the graph, follow the instructions here: Chart Studies: Adding/Modifying Chart Studies The documentation for the Add Additional Symbol study is found here: Add Additional Symbol If, however, what you really want is to actually overlay the NISS-NYSE and TICK-NYSE to the ES chart, so they are all displayed in the same graph window, then you will want to use the Overlay - Bar study. The information can be found here: Overlay - Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-02-06 19:04:48] |
Thank you. That was exactly the information I needed.
