Date/Time: Sat, 04 May 2024 01:42:29 +0000
Lost Global settings
View Count: 748
[2018-01-08 16:02:08] |
User136641 - Posts: 3 |
Last week I lost all Tech Studies from my charts. Got Studies back but lost Global settings. Today got message to download pre-release 1684. Did that, messed up my main chart and lost Global settings again. Main chart is back but still working on getting global settings back to the way I want them. Any suggestions on how to update without changing global settings?
[2018-01-08 20:14:51] |
Today got message to download pre-release 1684. Did that, messed up my main chart and lost Global settings again. What problem did you have with your main chart? In regards to losing global settings, that makes no sense. Maybe you have made an incorrect conclusion.How did you update Sierra Chart? Any suggestions on how to update without changing global settings? There should never be a problem like this. And we mean never.The global settings are contained in the file Sierra3.CFG. There are backups of this file in the Backups subfolder in the folder Sierra Chart is installed to. Exit from Sierra Chart and take one of these backup files with a date a few days ago, and remove the Number in front of it and put it into the main Sierra Chart folder. If you need more detailed instructions, we can put those together for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-08 20:15:45
[2018-01-08 23:18:17] |
Here are the detailed instructions for restoring a backup global configuration file: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File: Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-01-08 23:18:57
[2018-01-09 02:07:42] |
ok. Thanks. Will do this coming weekend.
