Date/Time: Sun, 28 Apr 2024 15:24:50 +0000
Version 1658 and Spreadsheets
View Count: 1201
[2017-12-05 22:54:03] |
Version 1658 had unexpected issues where Spreadsheet files when opened, would not read the data from the file and would indicate an error in the Message Log. This is now resolved in 1659. We do apologize for this issue. We wanted to get 1658 out as quickly as possible because it resolved a problem where there was a window handle leak. Even though this problem should not have existed anyway no matter what the release schedule is. We often get releases out quickly without any problem. This type of serious issue is not normal. If you have lost any spreadsheet data do not be concerned because there are automatically backups of spreadsheets made. Here are the instructions to restore spreadsheet files: Working with Spreadsheets: Accessing a Backup Spreadsheet File If you need further help, just let us know here. And here are the instructions to update to 1659: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-05 23:15:56
