Date/Time: Sun, 28 Apr 2024 10:59:09 +0000
BitMEX ETH Futures DOM
View Count: 1897
[2017-11-24 17:00:06] |
User891094 - Posts: 11 |
In addition to the DOM issue with BCH (BITMEX BCH Futures DOM messed up) ETH has the same issue XBT futures and the swap work flawlessly, but some of the small digits seem to have market depth issues. It looks like the old quotes aren't deleted and each time a new quote comes up, it's just added to an existing one. This way it seems as if there are 200 contracts on old prices altough there are just a hand full in reality. |
ETHZ17.png / V - Attached On 2017-11-24 16:53:35 UTC - Size: 113.24 KB - 387 views |
[2017-11-24 18:31:01] |
This will be resolved.
[2017-11-24 20:41:56] |
This will be resolved before the end of the day today.
[2017-11-26 02:15:48] |
We apologize for the delay. We got behind on this but we are going to be working on it right now.
[2017-11-30 10:56:28] |
bitmexdiable - Posts: 1 |
Nothing new ?
[2017-11-30 17:25:03] |
We apologize for this. We were not able to get this done. Allow another day or two.
[2021-06-30 15:27:13] |
User381557 - Posts: 12 |
Hello, I seem to be having a similar problem with the ETHUSDU21 contract on Bitmex. Do you know if it would be an issue or setting I need to change on my end or is this an issue that would have to be resolved on Sierrachart's end? I have attached a screenshot showing the Sierrachart market depth and DOM for ETHUSDU21 and Bitmex's market depth for ETHUSDU21. Thanks for your time. EDIT* I found out the issue I'm having with the market depth data is happening with any symbol I need to press (Get BitMex Symbols) for. The symbols listed in the main "Find Symbol" window all have perfectly working market depth data. Date Time Of Last Edit: 2021-06-30 18:56:50
Screenshot (48).png / V - Attached On 2021-06-30 15:24:18 UTC - Size: 734.38 KB - 185 views |
[2021-06-30 19:01:18] |
What are the following settings for your chart: - Chart >> Chart Settings >> Main Settings >> Tick Size - Chart >> Chart Settings >> Main Settings >> Volume at Price Multiplier - Chart >> Chart Settings >> Advanced Settings 3 >> Market Depth Combine Increment in Ticks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-30 19:07:47] |
On ETHUSDU21 for the screenshot I attached I am using the following. Tick Size = 0.05 Volume at Price Multiplier = 1 Market Depth Combine Increment in Ticks = 0 |
[2021-07-01 20:21:39] |
Sierra_Chart Engineering - Posts: 14111 |
This definitely looks like an issue with the market depth not being correct and we have to reset the connection to BitMex. We are going to do daily resets with BitMex. We will get that done today. That should not normally happen if depth data is provided properly from the BitMex server but sometimes we do see issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-27 16:44:58] |
I have still noticed the same issue since my previous post around 3 weeks ago. I am hoping this is something SierraChart will be able to get resolved.
[2021-07-28 14:51:18] |
We had to set up the Symbol Settings for this symbol and it has now been done. A reconnection to the data feed was not enough to resolve it. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-28 14:51:35
[2021-07-28 16:04:23] |
Perfect it has been fixed on ETHUSDU21, thankyou. Would it be possible to do the same for XBTEUR and XBTEURU21?
[2021-08-02 10:09:37] |
We have to set this up.
[2021-09-30 09:48:05] |
We have set up the necessary symbol settings for the XBTEUR contracts. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
