Date/Time: Mon, 05 Oct 2026 21:15:46 +0000
[User Discussion] - Linux
View Count: 122689
| [2024-12-03 06:54:43] |
| Tony - Posts: 725 |
@allons_trading, sorry for bugging you, rarely see Manjaro users, I am currently running Manjaro XFCE on my 2016 MacBook, wonder if you have used the system zoom function? (Alt + Mouse Wheel), I couldn't find settings for zooming anywhere... Date Time Of Last Edit: 2024-12-03 06:55:03
| [2024-12-03 13:39:47] |
| allons_trading - Posts: 50 |
@Tony I have not used the system zoom function, and not really seeing an option in XFCE to enable it, unless it's behind some other option that needs to be enabled first. |
| [2024-12-05 04:15:36] |
| ertrader - Posts: 698 |
So far 2713 has had no issues with the updated chart refresh interval settings. Just the first time that I mentioned. Once set, I'm seeing lower cpu usage and good refreshes and trade entries. Updating to 2716 to see if there are any new issues.
Date Time Of Last Edit: 2024-12-05 04:16:58
| [2024-12-05 22:04:05] |
| d9e5c763 - Posts: 112 |
with version 2716, I can see a significant reduction in CPU usage (~90% droped to ~55%) and I don't see any new issues with it
| [2024-12-05 22:52:23] |
Been running 2716 last couple of days. Previously I had all my short time frame charts set to a 150ms update interval. Currently been running the three main charts I watch at 40ms interval with no issues with the rest set to 150ms. Any charts I don't watch regularly are set to 1000ms.
| [2024-12-06 12:56:31] |
I'm having a similar experience. So far 2716 is working really well for me. lower %CPU, less memory and responsive. I'm staying on this version that uses the sc timers rather than update to 2718 which reverted back to windows timers. trading chart is at 30ms, global is 600ms. it looks like they are working on a more comprehensive solution.
| [2025-03-03 01:22:05] |
| Cesium - Posts: 179 |
Is anyone on wine 10? and on latest sierrachart? 2744 Currently im having some issue updating sc, want to make sure wine isnt causing it im on wine 8.0 |
| [2025-03-03 08:27:53] |
| ticinotrader - Posts: 431 |
@cesium I run SC 2744 with Wine 10.2. Zero issues, everything works fine. |
| [2025-03-03 16:46:58] |
Yes, same here. I'm on 10.0 and all is working. I did have an issue prior to 10 being fully released and submitted a bug report. by the time the stable version came out all is working.
| [2025-03-04 00:23:48] |
ertrader ticinotrader thank you guys, on wine 10.0 now, culprit of sound issues (not mentioned, sound being killed by wine) was pulseaudio. Purged Pulseaudio completely and installed pipewire, everything is now nominal on sc v2732. not able to complete update to 2744, odd timeout / md5 mismatch errors |
| [2025-03-04 01:22:30] |
| User900285 - Posts: 101 |
wine 10.1 on Fedora running smoothly. Some time ago I had audio issues when I had an experimental setting enabled in wine regarding VAAPI backend. Recommend keeping that setting (and other experimental settings) off in winecfg especially if you record your screen using VAAPI.
Date Time Of Last Edit: 2025-03-04 01:22:55
| [2025-03-12 18:54:42] |
| R1sk - Posts: 259 |
Hello, Is there anyone who compiles their own indicators (DLLs) for Linux? I would like to ask you to try the following test DLL file and see if it gives the following error message in the sierrachart log when you add this indicator to your chart? "Failed to get the function address for scsf_VolatilityE4test in C:\SierraChart\Data\test.dll. Error: Windows error code 127: Procedure not found. *" This is what is happening on SierraChart's Add Study List https://imgur.com/gvx3vuf.png Here is the indicator code: #include "sierrachart.h" SCDLLName("Test") template <typename T> class Test { std::deque<T> data; }; SCSFExport scsf_Volatility(SCStudyInterfaceRef sc) { static Test<float> test; } Btw. This is intentionally made this simple for testing purposes, and therefore lacks all the normal configurations required by the indicator. In my experience, they (by their absence) have no effect. Date Time Of Last Edit: 2025-03-13 05:07:28
| [2025-03-20 16:23:27] |
is anyone having issues with Chat Window? https://www.sierrachart.com/SupportBoard.php?ThreadID=98858 tldr: the parts of chat window that causes issue is chats selection and send chat, attach,. menu bar works fine until that inner section is clicked. Date Time Of Last Edit: 2025-03-20 17:53:40
| [2025-03-21 00:38:45] |
| Sierra_Chart Engineering - Posts: 25065 |
The chat is known to not work on Linux/Wine. When opened it freezes under Linux/Wine.
| [2025-05-19 10:10:36] |
| User687917 - Posts: 84 |
Hi I have been using SierraChart for 5 years, although it works under Linux, but I was hoping that they would release a native version for Linux. I understand that it is not an overnight process, but I would like to know if they are working on it or not, or some form of multiplatform. In the post "What's Sierra chart working on" I don't see that it is updated since the end of 2024, it would be interesting for the community to be informed. Also looking at the thread "[Locked] - Microsoft Windows Is Truly Garbage.", it seems that Sierra Chart engineers don't like Windows, so we could expect that they will work more in depth on an alternative to it (and possibly based on Linux) Sierra_Chart Engineering could you give to the community information about what you are working on? or next goals? Thanks for your job! |
| [2025-05-19 15:07:15] |
| Tony - Posts: 725 |
@User687917, just curious, what are the specific reasons to release a native Linux version, I don't see any. I can actually see a very good reason NOT to do so, that I don't have to deal with all the pains/bugs during Linux version development. I really just want to focus on my trades.
Date Time Of Last Edit: 2025-05-20 02:32:27
| [2025-05-23 10:02:49] |
Apart from the ease of installation on the system, the fact of not having to rely on Windows libraries (which are usually full of bloatware and other resource-consuming garbage) |
| [2025-05-23 10:04:42] |
| R1sk - Posts: 259 |
A Linux executable would be a truly great thing — especially if it were implemented as a Docker or Flatpak package, making installation easy and ensuring good compatibility across different Linux distributions. It could even be a virtual machine image including everything from kernel to application. It would allow the software to run in an environment where the users and developers are in control (Linux), instead of one where external parties dictate how things work (Windows). At the same time, it would eliminate the need for Wine workarounds, which always tend to have some minor issues. Given the financial realities, maintaining a separate Linux version probably isn't feasible, but if the implementation were cross-platform — which is certainly possible in a C++ environment — that would work. |
| [2025-06-10 11:17:42] |
| icebrian - Posts: 1 |
New user here, not paying yet, still on trial, have been testing 2763 on a Debian 12/rodete, with kernel 6.12.20-1, wine 9.0. Everything seems to be working fine, CPU (4 cores) usage at aprox 3-5%, zooming with SHIFT+scroll works. If anyone would like me to test anything in particular, let me know.
| [2025-07-15 21:35:19] |
Anyone seeing issues with Wine 10.11? Just updated and charts within the instance load up black. Charts external to the instance load up just fine. Downgraded back to 10.9 for now.
Date Time Of Last Edit: 2025-07-15 21:41:15
| [2025-08-11 11:34:01] |
| R1sk - Posts: 259 |
My DLL problem described in the Linux | Post: 411591 is now solved as follows, 1. Template Symbol Generation: When I use static Test<float> test; inside a function, the compiler generates symbols for the template instantiation that can interfere with Sierra Chart's dynamic loading. 2. Static Local Variables: Static variables inside exported functions can create additional symbols that the DLL loader tries to resolve. 3. Template Mangling: The compiler creates mangled names for template instantiations that may not be properly handled by Sierra Chart's loading mechanism. To fix the problem I stopped using 'static' variables and instead utilized the Get/SetPersistentPointers() methods as shown below: #include "sierrachart.h"
SCDLLName("Test") template <typename T> class Test { public: std::deque<T> data; }; SCSFExport scsf_Volatility(SCStudyInterfaceRef sc) { auto test = static_cast<Test<float>*>(sc.GetPersistentPointer(0)); if (sc.LastCallToFunction) { if (test) { delete test; test = nullptr; } return; } if (test == nullptr) { test = new Test<float>(); sc.SetPersistentPointer(0, test); } } Btw. This is intentionally made this simple for testing purposes, and therefore lacks all the normal configurations required by the indicator. In my experience they (by their absence) have no effect. Date Time Of Last Edit: 2025-08-12 07:45:42
| [2025-09-10 06:15:00] |
| R1sk - Posts: 259 |
I have also encountered a similar issue with lambda expressions. This code will generate a carbage function reference into the DLL function list in SierraChart. include "sierrachart.h"
#include <algorithm> SCDLLName("Test") SCSFExport scsf_Test(SCStudyInterfaceRef sc) { std::vector<int> entries; std::sort(entries.begin(), entries.end(), [](int a, int b) { return a > b; }); } But doing this without lambdas will work as expected: #include "sierrachart.h"
#include <algorithm> SCDLLName("Test") bool compareInts(int a, int b) { return a > b; } SCSFExport scsf_Test(SCStudyInterfaceRef sc) { std::vector<int> entries; std::sort(entries.begin(), entries.end(), compareInts); } EDIT Forgot to say that this is a minGW cross-compiler/linker issue. MSVC works ok. Date Time Of Last Edit: 2025-09-10 07:17:43
| [2025-09-10 07:49:05] |
| R1sk - Posts: 259 |
I've found a fix for this issue. Prior to installation, I will now sanitize any new DLLs for SierraChart using this command: x86_64-w64-mingw32-strip --strip-all <DLL name> EDIT: Or just add -s option for the compiler Date Time Of Last Edit: 2025-09-10 09:38:17
| [2025-09-10 09:47:42] |
| R1sk - Posts: 259 |
If anyone is interested, the Makefile I'm now using is like this: APP=your_dll_name_without_dll_extension
DLL=$(APP)_64.dll OLD_DLL=include/acsil/../Data/$(DLL) MAKEFLAGS += --silent CC=x86_64-w64-mingw32-c++ CFLAGS=-D_WINDOWS -D_USRDLL -D_WINDLL -s -w -m64 -march=native -O2 -std=c++20 -I./include/acsil LFLAGS=-static -shared SRC=$(APP).cpp OBJ=$(SRC:.cpp=.o) LIBS= all: $(DLL) $(DLL): $(OBJ) $(info Linking $(APP)...) $(CC) $(LFLAGS) -o $@ $^ $(CFLAGS) $(LIBS) %.o: %.cpp $(info Compiling $(APP)...) $(CC) -c -o $@ $< $(CFLAGS) install: $(info Installing $(APP)...) ./setdll $(OLD_DLL) 0 sleep 2 cp $(DLL) $(OLD_DLL) ./setdll $(OLD_DLL) 1 uninstall: $(info Uninstalling $(APP)...) $(RM) -f $(OLD_DLL) clean: $(info Cleaning $(APP)...) $(RM) $(DLL) *.o build: $(MAKE) -f $(firstword $(MAKEFILE_LIST)) clean $(MAKE) -f $(firstword $(MAKEFILE_LIST)) all $(MAKE) -f $(firstword $(MAKEFILE_LIST)) install .PHONY: all clean uninstall install build My project directory contains an 'include' subdirectory. Within it, an 'acsil' symbolic link points to the SierraChart 'ACS_Source' directory. 'setdll' is a python script as follows, #!/bin/env python3
import sys import socket if (len(sys.argv) != 3): print('Usage: setdll [DLL path] [1=load, 0=release]') exit() dll_path = sys.argv[1] dll_cmd = int(sys.argv[2]) ip = '127.0.0.1' port = 22903 msg = 'ALLOW_LOAD_DLL' if dll_cmd else 'RELEASE_DLL' msg += '--' + dll_path #print(msg) with socket.socket(socket.AF_INET, socket.SOCK_DGRAM) as sock: sock.sendto(msg.encode(), (ip, port)) Date Time Of Last Edit: 2025-09-10 09:51:27
| [2025-09-28 20:05:16] |
| gtaranti - Posts: 99 |
Hey I'm running SC with Bottles. I've seen in the Message Log: 2025-09-28 15:52:29.416 | Local computer UTC time and Server UTC time difference: 6 seconds." 2025-09-28 15:52:29.416 | Notice: Your computer's clock is off by 6 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. I've activated the NTP client, set it to Europe servers, and I had several messages like : 2025-09-28 16:03:47.934 | NTPClient (3) | Ignored Send call. Socket is not connected. 2025-09-28 16:03:47.934 | NTPClient (4) | Ignored Send call. Socket is not connected. ... Anyone else has seen this? |
| [2025-09-29 00:18:01] |
| Tony - Posts: 725 |
@gtaranti, Which distro are you using? Couple of thoughts, 1, I think Bottles are totally unnecessarily, since Wine already works flawlessly. 2, I am using Linux Mint, under Date & Time settings, I always turn 'Network time' on, so, I won't have accuracy issues. |
