Date/Time: Tue, 28 May 2024 07:31:18 +0000
a couple of quick questions about a 3 region chart
View Count: 716
[2017-08-10 17:03:24] |
Glenn Infinity - Posts: 103 |
1. Reducing the size of zone 2 and 3 (not just the bar size – which I can do with scale on the right border). I do not see a horizontal line which I can grab and shrink the size of zone 2 and 3 and fee up more real estate in zone (i had him on the phone and it worked properly for me. it may be the same color as the background, what is the line called so we can change the color?) 2. I use Number bar with cumulative Delta bars in zone 2. For intraday charting of Cumulative Delta Bars, I have noticed that it resets itself at the beginning of session every day which of course distorts the picture in a 24 hour open market. Is it possible for it not to reset but continue (something like ADC) 3. On daily time frame of the Numbers bar chart (seen in profile view), I notice that the data is not updated in real time. Today’s data is not displayed till late afternoon early evening (do these update during the current session?) |
[2017-08-10 19:30:10] |
1. The color is controlled through the Chart Text color in Global Settings >> Graphics Settings. Also here is the documentation for this: Working With Charts: Chart Window and Regions 2. Cumulative Delta Bars has an Input to control whether there is a reset at the start of the trading day or not. You need to set that as required. Refer to: Chart Studies: Adding/Modifying Chart Studies 3. So we can understand this better, provide an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-10 19:31:01
