Date/Time: Fri, 03 May 2024 00:47:30 +0000
OHLC for overnight session only
View Count: 1603
[2017-03-13 07:44:29] |
AKR - Posts: 523 |
In the OHLC study I can set "use daysession only". Is there a way (or other study) to set "use overnight session only"? I would just like to have the overnight high and low drawn automatically. |
[2017-03-13 09:58:50] |
The only way to do this is to use the Study/Price Overlay study: Study/Price Overlay Study Also look at using the High/Low for Time Period-Extended study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.php#s313 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-18 10:18:13] |
NotIll - Posts: 118 |
There is the option in Daily OHLC: use Day Session Only (In:10) Why not simply add ''use ON session Only (in:11)? What would be the logic in adding an extra study to show some data over just adding another input to an existing study. Also using the study/price overlay study does not work correctly whilst trying to project OHLC data from a ON chart Date Time Of Last Edit: 2020-11-18 11:05:43
[2020-11-19 20:03:21] |
whats1thingnow - Posts: 407 |
+1 to post #3
[2020-11-20 10:44:43] |
User913007 - Posts: 1 |
+1
[2020-11-20 14:35:21] |
User369903 - Posts: 1 |
+1
[2020-11-20 17:05:39] |
AKR - Posts: 523 |
As initial starter of this thread in 2017 :-) - I can live quite good with the study overlay study. anyway I do use a full session and a RTH chart, so I just use the study overlay in the RTH chart.
[2020-11-23 23:19:24] |
i'm using the study overlay as well but it's getting too messy with the multiple charts in addition, it's not a good idea to have two charts referencing the same chart... so i have so many reference charts just to overlay studies would make things much cleaner to have study option as per above :) |
