Date/Time: Sat, 18 May 2024 20:36:42 +0000
Difference in Data presentation
View Count: 686
[2017-01-17 11:12:22] |
Icychemist - Posts: 8 |
Hi, I am using TOS platform. I compared the charting on TOS platform with Sierra Chart. I am using TICK chart. I noticed that the both of them DO NOT look identical. In this case, which side should I trust ? |
[2017-01-17 17:57:10] |
If you are referring to the TICK-NYSE market statistic, then refer to: Sierra Chart Market Statistics: Market Statistics Calculations Compared to Other Data Services What Sierra Chart provides is more accurate and stable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-17 18:23:07] |
Hi, I am not referring to the NYSE Tick Chart. I am referring to Minute, Bar, Range, Tick Chart. The tick over here. Since according to you, Sierra chart is more accurate and stable, would it be wise to be looking at Sierra Chart's data feed and trade on my broker's platform ? Will it have any negative effect ? |
[2017-01-17 18:38:03] |
Yes this will be fine. No negative effect. Also make sure Sierra Chart has a tick by tick data configuration: Tick by Tick Data Configuration If it is not, that can be the reason for some small differences. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
