Date/Time: Thu, 16 May 2024 00:13:26 +0000
Graphic Settings Adjustment Problem : candle outlines
View Count: 2295
[2016-11-24 13:06:46] |
isa74 - Posts: 54 |
Sir, I am attemtping to have: 1. black outlines for each candles over a soft grey background 2. green and red soft colors for each candles as filled colors all this on a footprint set-up. I do not succeed to reach this result. Please take acknoledgement of the attached .CHT file. Global settings > Graphic Settings > Candle Stick Up Outline : black > Candle Stick Down Fill : soft green > Candle Stick Up Fill : black > Candle Stick Down Fill : soft red I must observ that the soft colors choosed never appear on the graph and come back to a deep red and green color by default. There could be a transparency level feature on the graphic settings for the candles ? Regards. |
Chartbook_US30 - Footprint.cht - Attached On 2016-11-24 13:01:09 UTC - Size: 965.14 KB - 262 views |
[2016-11-25 23:02:10] |
We had a look at this and we see what the problem is. You are using the wrong Overlay study. You need to use this one: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s100 And make sure this option is enabled for the study: Chart Studies: Subgraphs Tab >> Use Chart Graphics Settings for Subgraph Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-26 18:29:05] |
isa74 - Posts: 54 |
Sir, I have used the Overlay Bar and choose the right chart number and region. 2 questions: > according to the height i decide to choose on my graph( by control+ left mouse click on the right vertical tab values), my footprint and the candle are not 'synchronised'. I might all the footprint datas to up or too down. How can I be sure that the candles and the values are placed perfectly ? > how can i change the fill colors of the candles ? can I set up a level of transparency ? If I want to have only the outlines of each candles and keep the fill the same color as background ? I have modified the colors on Global Settings > Graphic Settings, but nothing occurs. Thanks ! |
sc_Sierracharts_Interface_Footprint_Overlay.jpg / V - Attached On 2016-11-26 18:25:07 UTC - Size: 921.66 KB - 391 views |
[2016-11-26 20:07:22] |
Based upon what you want to do, remove the Overlay study from the chart. Follow the instructions here to open the Input Settings for the Numbers Bars study: Numbers Bars: Input Settings for Numbers Bars Set the Open and Close Marker Style to Candlestick Outline. Be sure to read the documentation for this particular Input setting to understand other related settings you need to set. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
