Date/Time: Sun, 19 May 2024 07:24:01 +0000
the link
View Count: 600
[2016-11-04 00:03:47] |
User256679 - Posts: 23 |
can you give me the link about activating for the "US Equities " Exchange with the Sierra Chart Exchange Data Feed? at the sametime ,i want to know how many US Equities are included in the Sierra Chart Exchange Data Feed and they are all real-time ? otherwise ,i cannot find the spy or iwm on the software and no US Equities list . |
[2016-11-04 04:13:46] |
This is done through this page here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures All of the issues on the NYSE, AMEX and NASDAQ are included in the US Equities exchange. They are all real-time. The symbols mentioned are not listed, you just manually type them in. Refer to: Getting Started, Opening Charts and Basic Trading: Open Chart You can also search for them. This is documented here: File Menu: Searching for Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
