Date/Time: Wed, 15 May 2024 16:10:16 +0000
angle calculation question
View Count: 1447
[2016-10-19 23:22:22] |
onnb - Posts: 661 |
I am trying to calculate the angle of a subgraph with ACSIL using this description - http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AutoColoring Say I have the angle unit set to 0.25 There is a study called Study Angle In the study angle, if I set the following Length = 1 Value Per Point = 0.25 Would it be computing the angle in the same way as the gradient is done? |
[2016-10-20 17:45:40] |
There was a problem with this and it has been fixed in the current version of Sierra Chart. Update following these instructions: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate On the current version, the calculation is the same. Although make sure the Value Increment per Bar in Ticks is set to 1: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ValueIncrementPerBarInTicks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-21 07:15:00] |
onnb - Posts: 661 |
I understand they were not computing the same? Which one was changed? The "Study Angle" or the subgraph gradient coloring? Date Time Of Last Edit: 2016-10-21 07:15:21
[2016-10-21 07:57:15] |
The subgraph gradient color was not exactly correct and that is what was changed.
[2016-10-22 03:09:18] |
onnb - Posts: 661 |
is this fix available in latest regular version or do I need latest pre-release?
Date Time Of Last Edit: 2016-10-22 03:10:02
[2016-10-22 05:09:43] |
This has been out for about a month now. So it is in the latest version.
