Date/Time: Wed, 28 Oct 2026 19:58:48 +0000
Connection Error - CQG
View Count: 2717
| [2016-03-31 18:35:11] |
| 100 - Posts: 147 |
I still have package 5, and I have tried both CQG data feed options (FIX Trading & webAPI). This is the error I'm getting: CQG FIX: Not connecting to trading server because Username is not specified. | 2016-03-31 14:27:05 CQG FIX Trading | Connecting to market data server api.cqg.com | 2016-03-31 14:27:05 CQG FIX Trading | Sending market data logon message. | 2016-03-31 14:27:05 CQG FIX Trading | Market data logon unsuccessful. Server message: Trader is not enabled to use SierraChartData. Please contact your FCM. | 2016-03-31 14:27:05 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-31 14:27:05 Should I put my CQG login credentials under "Data Connection Details", or "Fix Trading Connection Details"? Can you help me establish where I've gone wrong? Thanks, -100 |
| [2016-03-31 19:08:19] |
You need to enter your CQG Username and Password for both the Data Connection and the Trading Connection. And you need to tell your broker about this: CQG FIX Trading | Market data logon unsuccessful. Server message: Trader is not enabled to use SierraChartData. Please contact your FCM. | 2016-03-31 14:27:05 * Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-31 21:13:32] |
| 100 - Posts: 147 |
I checked with my broker, ADM, and they confirmed that I am enabled for Sierra. They say the issue is with Sierra Charts. I've already updated SC to current version. This is a larger excerpt of what I'm seeing... Received websocket handshake acknowledgment. | 2016-03-31 17:05:25 Web socket state is now open. | 2016-03-31 17:05:25 CQG FIX Trading | Websocket connected. | 2016-03-31 17:05:25 CQG FIX Trading | Sending market data logon message. | 2016-03-31 17:05:25 CQG FIX Trading | Market data logon unsuccessful. Server message: Trader is not enabled to use SierraChartData. Please contact your FCM. | 2016-03-31 17:05:25 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-03-31 17:05:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-03-31 17:05:25 CQG FIX: DisconnectFIX called. | 2016-03-31 17:05:25 CQG FIX: Sending a Logout message. | 2016-03-31 17:05:25 Socket (97) | SSL shutdown indicates not able to send 'close notify'. | 2016-03-31 17:05:25 Socket (97) | SSL has been shut down. | 2016-03-31 17:05:25 Socket (97) | SSL object has been freed. SSL state is now disconnected. | 2016-03-31 17:05:25 Socket (97) | Shutdown and closed. | 2016-03-31 17:05:25 CQG FIX Trading | Websocket closed. | 2016-03-31 17:05:25 CQG FIX Trading | Disconnected. | 2016-03-31 17:05:25 |
| [2016-03-31 21:59:26] |
There are 2 ways you can solve this. Contact your broker and have them contact CQG about this and resolve this problem for you: CQG FIX Trading | Market data logon unsuccessful. Server message: Trader is not enabled to use SierraChartData. Please contact your FCM. | 2016-03-31 17:05:25 *
Or instead of using the CQG data feed which your broker has not yet properly authorized your account for, you can use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed We explain this in the CQG setup instructions 3 and 8 here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
