Date/Time: Mon, 20 May 2024 04:20:58 +0000
User Question
View Count: 640
[2016-01-12 17:05:09] |
Sierra Chart - Max - Posts: 5618 |
so after cme changed the 6e to half ticks my charts don't load, the dom seems to work fine, but the charts are frozen and don't show half ticks. Also, when I pull up a new chart by clicking on open intraday chart, it shows little hyphens next to each other, like price is staying at one tick for the whole time. please help.
Sierra Chart Support |
[2016-01-12 18:39:34] |
Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Apply them to the chart as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps Re-download the data in the chart with Edit >Delete All Data and Download. Adjust the data from before 2016-01-09 using the Edit >> Adjust Data function: https://www.sierrachart.com/index.php?page=doc/doc_AdjustingData.html You will need to multiply the data by 10. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
