Date/Time: Sun, 19 May 2024 00:03:25 +0000
Transact - FX Quotes
View Count: 647
[2015-12-15 17:45:12] |
User79416 - Posts: 3 |
TransAct is my data service provider. Along with futures quotes, I get Forex spot quotes which is very handy when Im' looking at FX crosses. After I upgraded to SC v.1332 (my current version), I don't get real time Forex spot quotes (my futures quotes are ok) as I used to. Has anything changed in SC v.1332 that prevents FX real time quotes under TransactAct data service provider? Thanks Miguel H. |
[2015-12-15 18:30:56] |
The Forex data works with TransAct. This has been confirmed. However, make sure you are using TransAct using your own Sierra Chart account. Install another copy of Sierra Chart on your system: Using Multiple Data and Trading Services at the Same Time And Login with your Sierra Chart Account Name: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Set it to use TransAct: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
