Date/Time: Sat, 04 May 2024 02:11:02 +0000
TD Ameritrade Connection issue
View Count: 969
[2014-12-04 21:10:07] |
Seviah - Posts: 5 |
Good Day I have never had a problem connecting to TD Ameritrade until today; please would you assist me with the following: TD Ameritrade | Connecting. | 2014-12-04 13:04:40 TD Ameritrade | Logging in. (Step 1 of 3) | 2014-12-04 13:04:40 TD Ameritrade | Authorized for streamer data. | 2014-12-04 13:04:40 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2014-12-04 13:04:40 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2014-12-04 13:04:40 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2014-12-04 13:04:41 TD Ameritrade | OnAsyncHTTPRequestComplete did not process RequestID 12 | 2014-12-04 13:04:41 Connection timed out. Will disconnect and retry. | 2014-12-04 13:05:40 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-12-04 13:05:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-12-04 13:05:40 Disconnected from TD Ameritrade. | 2014-12-04 13:05:40 Kind Regards Steven |
[2014-12-04 22:15:56] |
This problem requires in-depth analysis as to the data that TD Ameritrade is sending back. Something is not right. When we do a test we do not see this problem Not sure if you are familiar with starting a program from the Command line and specifying a command line parameter to Sierra Chart. If so, we will give you instructions. If not, we would require your Ameritrade username and password so that we can test this. All we would do is login to see what the connection problem is due to and you can change your password after. We will provide you a secure means to send it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-04 22:25:53] |
Seviah - Posts: 5 |
Hello Thank you for your reply please send me the command line instructions. regards Steven |
[2014-12-04 23:52:00] |
Start Sierra Chart with this following commandline parameter: /dhttplog Try to connect to TD Ameritrade and wait about a minute. You will then notice this log file in the Sierra Chart Data subfolder: Async HTTP Ameritrade.log You will need to send this to support AT Sierra Chart.com. At the top of the file you will see your password and you can remove that or change the password on your TD Ameritrade account after sending the file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-04 23:52:28
[2014-12-05 02:14:36] |
Seviah - Posts: 5 |
Alright so I should tell you the following: Before sending you a support request I contacted TD Ameritrade and asked if there was a problem on their side. To which they answered that there was no problem on their side. The reason I am telling you this is that the connection seems to be working again, so it may have been their fault and they fixed it. I have the .log file that you requested and will still attach it to this reply. Please tell me if there is anything wrong with this .log file even though the connection seems to be working now, as I would not want this to happen again. Thank you for your help Kind Regards Steven |
Private File |
[2014-12-05 03:54:20] |
Being there is no problem currently, we will not look at the log. That takes time and is not easy. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-05 04:34:39] |
Seviah - Posts: 5 |
understood, thanks for the assist.
