Date/Time: Sat, 18 May 2024 04:37:38 +0000
historical intraday review
View Count: 1224
[2014-12-04 01:04:34] |
startledbymoth - Posts: 39 |
Here's what I want to do: review historical dailies and choose a particular segment for focused review -- for example, let's say the week of 2/13/12 through 2/17/12. In that segment, I want to review minute by minute (1 minute chart) data for each trading day, and I want to look at corresponding Market Stats for the same period. I've been reviewing your article on and Self-Help Topic 42.1 - Downloading/Viewing More Historical Intraday Data. If I understand, I will have to set the global settings Max Historical Intraday Days to Download to 1024 days (days between 2/13/14 and 12/3/14). Seems to me that would be huge and clog the functions, please confirm. So I guess the workaround is: when I want to do my review (as described in this message, and using the 2/13/12 to 2/17/12 week as an example), I set the Max Historical Intraday Days to Download to 1024 days. When I finish, I set the Max Historical Intraday Days to Download days back to 186. Please confirm I am on the right track. I send this message because I do not want to try something and then have to have support to undo some mess I've made ;). |
[2014-12-04 01:25:32] |
The main question is this for futures charts?
[2014-12-04 01:38:30] |
Yes (sorry!). The chart is Futures but the Market Stats I want to review for the corresponding historical period are TICK-NYSE and Niss NYSE. I'm using Rithmic intraday data through Optimus Futures.
[2014-12-04 02:07:47] |
In this case, we see no problem to set the Maximum Historical Intraday Days to Download to 1024. It does not have any practical consequence. You can specify a particular date range to load in the chart itself, through Chart >> Chart Settings. Also, the market statistics do not date back to 2012. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-04 02:08:39
[2014-12-04 02:35:05] |
When you say you see no problem, do you mean the Maximum Historical Intraday Days to Download can be way over 186 without slowing function? Or should I change it back to 186 when done? Also, do you mean I can set the particular date range directly into the Chart Settingts >> Date Range in File field without increasing the Maximum Historical Intraday Days to Download? Or do you mean setting the date range will make it easier to find? Finally, how far back do Market Stats go? |
[2014-12-04 18:49:47] |
Maximum Historical Intraday Days to Download can be way over 186 without slowing function? Yes. No need to change it back because once the data is downloaded it will not be downloaded again.Also, do you mean I can set the particular date range directly into the Chart Settingts >> Date Range in File field without increasing the Maximum Historical Intraday Days to Download No. You need to do both. Although if you do change the Date Range in the chart, you may be prompted to download more data for the symbol, in which case you do not need to increase the maximum number of days to download. Or do you mean setting the date range will make it easier to find? It will make the data easier to find and much more efficient by loading less data in the chart.If you want market statistics going back a far amount of time you can use the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html And use the symbols found on this page: http://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=MarketStats Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-12-04 18:51:26
[2014-12-06 19:04:49] |
Thank you, this is helpful, but I have further questions: 1. I am pretty sure that my package contains the SC Historical Data Service, how can I confirm? 2. I use SC platform with Rithmic real time feed. The directions for Using the Sierra Chart Historical Data Service at http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html#UsingSCHDS suggest installing "a second copy of Sierra Chart set to use this service specifically. . . ." and references the "instructions on the Multiple Services page before continuing with the below steps." I want to review historical market statistics outside of RTH and not while trading; eg on weekends, etc. In which case, it seems easier to me simply to select SC Historical Data in the Service list box at >> Global Settings >> Data/Trade Service Settings when I want to review, then switch back to Rithmic when I trade. Please advise, thanks. |
[2014-12-06 19:20:54] |
1. This is indicated at the top of the Sierra Chart Window >> Show/Hide Message Log. 2. This will be fine. Just make sure that you switch out of Trade Simulation Mode if it went into that mode when using another service that does not support trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-07 02:03:06] |
Thanks. O: but this all started with me wanting to view older intraday futures data, like e.g., a few years back, simultaneously with corresponding market statistics. It seems, therefore, that the first step would be that I set the Service list box at >> Global Settings >> Data/Trade Service Settings to SC Historical Data, and then proceed to increase the Maximum Historical Intraday Days to Download value to the appropriate amount, e.g., to 1024. Once these are set, then I'd set the particular date range into the Chart Settingts >> Date Range in File field; and add the market statistics into the chart; please confirm, thank you. |
[2014-12-07 03:10:07] |
Yes. You may need to also manually re-download the data in the chart to get data further back than the existing starting date in the file. More information about this is in help topic 42.1: Http://www.sierrachart.com/index.php?page=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-13 03:52:19] |
Thanks, this has been refreshingly awesome. One final question: I need 1 minute data, ie., I will be looking at futures charts and market stats in one minute periodicity. If I enter, e.g., 1024 as the Max Historical Intraday Days to download, what number should be entered in the field 1-Tick Data? This all at >> Global Settings >> Data/Trade Service Settings. |
[2014-12-14 01:08:34] |
You just enter the number of days of 1 Tick data that you require assuming the Intraday Data Storage Time Unit is set to 1 tick.
[2014-12-14 01:46:42] |
What number is that? Recall, in this hypothetical, I download 1024 days for review of 1 minute data. How many ticks is that? number of ticks per day x 1024? Ie, I realize that the field labeled "Maximum Historical Intraday Days to Download >> 1-Tick Data" should have the number of days of 1 Tick data that I require. That much I got. My question, therefore, is how do I calculate that value, given the number of days of data under review (in this hypothetical 1024), for review of data in 1 minute periodicity? Thank you |
[2014-12-16 00:34:53] |
I have not heard a reply to the last question, so I re-send: The field labeled "Maximum Historical Intraday Days to Download >> 1-Tick Data" should have the number of days of 1 Tick data that I require. How do I calculate that value, given the number of days of data under review (in this hypothetical 1024), for review of data in 1 minute periodicity? Thank you |
[2014-12-16 04:13:13] |
There is not anything to calculate. In your case, the setting is not relevant if you only require 1 minute historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-11 19:09:11] |
I am picking up on posts #9 and #10, wherein you confirmed my understanding of what to do to enable this historical review of 1 minute data. Here is the germane part of my post #9: It seems, therefore, that the first step would be that I set the Service list box at >> Global Settings >> Data/Trade Service Settings to SC Historical Data, and then proceed to increase the Maximum Historical Intraday Days to Download value to the appropriate amount, e.g., to 1024. Once these are set, then I'd set the particular date range into the Chart Settingts >> Date Range in File field; and add the market statistics into the chart; please confirm, thank you. I have finally had the time to undertake this process, with mixed results. The good news is, the market statistics came up seemingly as planned. The chart itself, however, failed. I have been patient and courteous with this limited forum for support that you provide. This is very frustrating. Please review what you detailed, in how I would review data on a one-minute basis for time periods starting 2012-08-01. I followed your instructions to the letter, and it worked to some extent, so you must be close. I need to know how to do this, please. (Log removed because it is not necessary) Date Time Of Last Edit: 2015-01-11 19:39:42
[2015-01-11 19:41:12] |
What do you mean by this?: The chart itself, however, failed.
You need to be more specific.What market statistic do you want to chart of? If there is not enough data in the chart, refer to help topic 42.1: http://www.sierrachart.com/index.php?page=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-11 20:48:11] |
Please review this thread. Everything I want is in this thread. You told me what to do. I did it. Your direction for viewing historical market statistics WORKED. I, therefore, do not now need to "chart of" a market statistic. Rather, I need to view the chart that corresponds with that market statistic, for that time period, all as set forth in this thread, above, and in the message log I sent. |
[2015-01-11 22:37:03] |
I attach a screenshot to illustrate and paste, here, as your instructions dictate: http://www.sierrachart.com/image.php?l=1421015640485.png This is for ES, set to continuous contract. I have selected Edit => Delete All Data And Download and indicated "No" in response to the prompt, "Do you want to re-download data for the current symbol only?" And I have a blank screen. Please advise, thank you. Software version: 1220 | 2015-01-11 13:14:24 Uses New Spreadsheets | 2015-01-11 13:14:24 Usage end date: 2015-01-13 | 2015-01-11 13:14:24 Enabled for: Advanced Features. | 2015-01-11 13:14:24 Enabled for: Advanced Features 2. | 2015-01-11 13:14:24 Enabled for: Sierra Chart Historical Data Service. | 2015-01-11 13:14:24 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-01-11 13:14:24 Active service: Rithmic Trading | 2015-01-11 13:14:24 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-01-11 13:14:24 2015-01-11 13:14:24 Local computer clock time | 2015-01-11 13:14:24 2015-01-11 18:14:24 GMT time | 2015-01-11 13:14:24 2015-01-11 13:14:24 Time zone adjusted time | 2015-01-11 13:14:24 Time difference to server time: 16 seconds. | 2015-01-11 13:14:24 Program path: C:\SierraChart\ | 2015-01-11 13:14:24 Data Files path: C:\SierraChart\Data\ | 2015-01-11 13:14:24 OS Version Number: 6.1 | 2015-01-11 13:14:24 Locale Information: C | 2015-01-11 13:14:24 Checking for new symbol settings for rim | 2015-01-11 13:14:24 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-01-11 13:14:24 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-01-11 13:14:24 Symbol settings are up-to-date for rim | 2015-01-11 13:14:24 Notice: 2 days of full use Remaining. To continue full use the software and services, | 2015-01-11 13:14:25 purchase more usage time by selecting 'Help >> Add Usage Credit' on the menu. | 2015-01-11 13:14:25 * Rithmic Trading | Port for executable: 49975 | 2015-01-11 13:14:29 Listening socket (892), port 49975 | Closed. | 2015-01-11 13:14:29 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-11 13:14:29 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-01-11 13:14:29 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-01-11 13:14:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49975 | 2015-01-11 13:14:31 Socket (2) | Connected. | 2015-01-11 13:14:31 Rithmic Trading | Connected to server. | 2015-01-11 13:14:31 Rithmic Trading | Sending logon request message. | 2015-01-11 13:14:31 Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-11 13:14:31 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-11 13:14:31 Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-11 13:14:31 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-01-11 13:14:32 Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-01-11 13:14:32 Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-01-11 13:14:33 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-01-11 13:14:33 Rithmic Trading | Server Alert: PnL Connection Opened | 2015-01-11 13:14:33 Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-01-11 13:14:33 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-01-11 13:14:33 Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-01-11 13:14:33 Rithmic Trading | Server Name: SC DTC Bridge. | 2015-01-11 13:14:34 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-11 13:14:34 Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2015-01-11 13:14:34 Rithmic Trading | Trading is supported. | 2015-01-11 13:14:34 Rithmic Trading | Order cancel and replace is supported. | 2015-01-11 13:14:34 Rithmic Trading | OCO Orders supported. | 2015-01-11 13:14:34 Rithmic Trading | Requesting Trade Positions data. | 2015-01-11 13:14:39 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:01 ESH5-CME [CB] 30 Min #4 | Symbols used for continuous contract chart: | 2015-01-11 13:24:01 ESH5-CME | 2015-01-11 13:24:01 ESH5-CME [CB] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:24:01 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:24:01 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-11 13:24:01 ESZ4-CME | 2015-01-11 13:24:01 ESH5-CME | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:24:01 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:24:01 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:24:01 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:24:01 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11 | Symbols used for continuous contract chart: | 2015-01-11 13:24:01 ESM4-CME | 2015-01-11 13:24:01 ESU4-CME | 2015-01-11 13:24:01 ESZ4-CME | 2015-01-11 13:24:01 ESH5-CME | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #11: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:24:01 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:01 * Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:24:01 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:24:01 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:24:01 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6 | Symbols used for continuous contract chart: | 2015-01-11 13:24:01 ESM4-CME | 2015-01-11 13:24:01 ESU4-CME | 2015-01-11 13:24:01 ESZ4-CME | 2015-01-11 13:24:01 ESH5-CME | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:24:01 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:24:01 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #17 | Symbols used for continuous contract chart: | 2015-01-11 13:24:01 ESZ4-CME | 2015-01-11 13:24:01 ESH5-CME | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #17: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #17: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #17: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #17: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:24:01 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:01 * Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:24:01 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:24:01 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:24:01 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18 | Symbols used for continuous contract chart: | 2015-01-11 13:24:01 ESM4-CME | 2015-01-11 13:24:01 ESU4-CME | 2015-01-11 13:24:01 ESZ4-CME | 2015-01-11 13:24:01 ESH5-CME | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #18: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:24:01 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:24:01 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:24:01 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:24:01 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:01 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:01 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5 | Symbols used for continuous contract chart: | 2015-01-11 13:24:01 ESM4-CME | 2015-01-11 13:24:01 ESU4-CME | 2015-01-11 13:24:01 ESZ4-CME | 2015-01-11 13:24:01 ESH5-CME | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:24:01 ESH5-CME [CB] 1 Min #5: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:24:01 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:24:02 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:02 ESH5-CME [C] 1 Min #3 | Symbols used for continuous contract chart: | 2015-01-11 13:24:02 ESH5-CME | 2015-01-11 13:24:02 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:24:02 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:24:02 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:24:02 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:24:02 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:24:02 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:24:02 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:24:02 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:24:02 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:24:02 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:24:02 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:24:02 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:24:02 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:02 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:02 ESH15/ESH5-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-01-11 13:24:02 ESH12 | 2015-01-11 13:24:02 ESM12 | 2015-01-11 13:24:02 ESU12 | 2015-01-11 13:24:02 ESZ12 | 2015-01-11 13:24:02 ESH13 | 2015-01-11 13:24:02 ESM13 | 2015-01-11 13:24:02 ESU13 | 2015-01-11 13:24:02 ESZ13 | 2015-01-11 13:24:02 ESH14 | 2015-01-11 13:24:02 ESM14 | 2015-01-11 13:24:02 ESU14 | 2015-01-11 13:24:02 ESZ14 | 2015-01-11 13:24:02 ESH15 | 2015-01-11 13:24:02 Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-01-11 13:24:02 Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-01-11 13:24:02 Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:02 Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 0. | 2015-01-11 13:24:02 TF FMH0015!-NYBOT [C] 1 Min #14 | Symbols used for continuous contract chart: | 2015-01-11 13:24:02 TF FMZ0014!-NYBOT | 2015-01-11 13:24:02 TF FMH0015!-NYBOT | 2015-01-11 13:24:02 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:02 * Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:03 * SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 1 | 2015-01-11 13:24:03 SC Market Stats | Connecting to the server ds3.sierracharts.com. Port 443 | 2015-01-11 13:24:03 Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-01-11 13:24:03 HD Request # 2 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-11 13:24:03 HD Request # 2 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:24:03 HD Request # 2 | Using server: ds5.sierracharts.com port 10149 | 2015-01-11 13:24:03 SC Market Stats | Starting real-time market data updates for: NISS-NYSE. ID: 2 | 2015-01-11 13:24:03 Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-11 13:24:03 Rithmic Trading | Starting real-time market data updates for: ESH5-CME. ID: 3 | 2015-01-11 13:24:03 Intraday data recording state for symbol ESH5-CME is set to download pending. | 2015-01-11 13:24:03 SC Market Stats | Starting real-time market data updates for: NISS-SP. ID: 4 | 2015-01-11 13:24:03 Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-11 13:24:03 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:03 * SC Market Stats | Starting real-time market data updates for: NISS-NQ. ID: 5 | 2015-01-11 13:24:03 Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-11 13:24:03 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-11 13:24:03 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:03 * Socket (3) | Connected. | 2015-01-11 13:24:03 SC Market Stats | Connected to server. | 2015-01-11 13:24:03 SC Market Stats | Sending logon request message. | 2015-01-11 13:24:03 HD Request # 3 | Downloading Historical Daily chart data for ESH15. Starting date: 2015-01-08. Service: rim | 2015-01-11 13:24:03 Historical data download counter reset. | 2015-01-11 13:24:03 HD Request # 3 | Requesting historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:24:03 Rithmic Trading | Starting real-time market data updates for: TF FMH0015!-NYBOT. ID: 7 | 2015-01-11 13:24:03 Intraday data recording state for symbol TF FMH0015!-NYBOT is set to download pending. | 2015-01-11 13:24:03 Rithmic Trading | Starting real-time market data updates for: NQH5-CME. ID: 8 | 2015-01-11 13:24:03 Intraday data recording state for symbol NQH5-CME is set to download pending. | 2015-01-11 13:24:03 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:03 * Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-11 13:24:03 Socket (4) | Connected. | 2015-01-11 13:24:04 HD Request # 2 | Sending historical data logon request message. | 2015-01-11 13:24:04 HD Request # 3 | Receiving historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:24:04 Writing historical Daily data for ESH15 to the file ESH15.dly | 2015-01-11 13:24:04 HD Request # 3 | Received 3 records from 2015-01-07 00:00:00 to 2015-01-09 00:00:00 (3.0 days) and wrote 2 records for ESH15 | 2015-01-11 13:24:04 HD Request # 3 | Daily download COMPLETE for ESH15. Completion time: 1s. Unique request ID: 6 | 2015-01-11 13:24:04 Removed historical data download ID 6 | 2015-01-11 13:24:04 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:24:04 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:24:04 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:24:04 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:24:04 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:24:04 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:24:04 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:24:04 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:24:04 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:24:04 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:24:04 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:24:04 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:24:04 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:24:04 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:24:04 ESH15/ESH5-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-01-11 13:24:04 ESH12 | 2015-01-11 13:24:04 ESM12 | 2015-01-11 13:24:04 ESU12 | 2015-01-11 13:24:04 ESZ12 | 2015-01-11 13:24:04 ESH13 | 2015-01-11 13:24:04 ESM13 | 2015-01-11 13:24:04 ESU13 | 2015-01-11 13:24:04 ESZ13 | 2015-01-11 13:24:04 ESH14 | 2015-01-11 13:24:04 ESM14 | 2015-01-11 13:24:04 ESU14 | 2015-01-11 13:24:04 ESZ14 | 2015-01-11 13:24:04 ESH15 | 2015-01-11 13:24:04 SC Market Stats | Server Name: SC Realtime Server. | 2015-01-11 13:24:04 SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-11 13:24:04 SC Market Stats | Successfully connected. | 2015-01-11 13:24:04 SC Market Stats | Restarting real-time data updates for symbol: NISS-NQ | 2015-01-11 13:24:04 SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2015-01-11 13:24:04 SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2015-01-11 13:24:04 SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2015-01-11 13:24:04 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: TICK-NYSE | 2015-01-11 13:24:04 HD Request # 2 | Decompressing data. | 2015-01-11 13:24:04 HD Request # 2 | Receiving Intraday data for TICK-NYSE starting at 2015-01-09 18:59:04 | 2015-01-11 13:24:04 HD Request # 2 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:24:04 Socket (4) | Shutdown and closed. | 2015-01-11 13:24:04 The network socket for historical data has been closed. | 2015-01-11 13:24:04 HD Request # 2 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2015-01-11 13:24:04 HD Request # 2 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 1 | 2015-01-11 13:24:04 Removed historical data download ID 1 | 2015-01-11 13:24:04 Real-time Intraday chart data file updates started for TICK-NYSE | 2015-01-11 13:24:04 HD Request # 4 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-11 13:24:04 HD Request # 4 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:24:04 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2015-01-11 13:24:04 Chart #10 has tagged chart #17 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-01-11 13:24:04 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-11 13:24:04 Socket (5) | Connected. | 2015-01-11 13:24:04 HD Request # 4 | Sending historical data logon request message. | 2015-01-11 13:24:04 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-01-11 13:24:04 Requesting market depth updates for: ESH5-CME if supported. | 2015-01-11 13:24:05 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-NYSE | 2015-01-11 13:24:05 HD Request # 4 | Decompressing data. | 2015-01-11 13:24:05 HD Request # 4 | Receiving Intraday data for NISS-NYSE starting at 2015-01-09 18:59:04 | 2015-01-11 13:24:05 HD Request # 4 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:24:05 Socket (5) | Shutdown and closed. | 2015-01-11 13:24:05 The network socket for historical data has been closed. | 2015-01-11 13:24:05 HD Request # 4 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-NYSE | 2015-01-11 13:24:05 HD Request # 4 | Intraday download COMPLETE for NISS-NYSE. Completion time: 1s. Unique request ID: 2 | 2015-01-11 13:24:05 Removed historical data download ID 2 | 2015-01-11 13:24:05 Real-time Intraday chart data file updates started for NISS-NYSE | 2015-01-11 13:24:05 HD Request # 5 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: rim | 2015-01-11 13:24:05 HD Request # 5 | Download start Date-Time: 2015-01-09 17:15:00.0 | 2015-01-11 13:24:05 HD Request # 5 | Using server: ds3.sierracharts.com port 10149 | 2015-01-11 13:24:05 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-11 13:24:05 Chart #7 has tagged chart #17 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-01-11 13:24:05 Socket (6) | Connected. | 2015-01-11 13:24:05 HD Request # 5 | Sending historical data logon request message. | 2015-01-11 13:24:05 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-01-11 13:24:05 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:24:05 * HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-01-09 17:15:00. Record interval: 60. Symbol: ESH5-CME | 2015-01-11 13:24:06 HD Request # 5 | Decompressing data. | 2015-01-11 13:24:06 HD Request # 5 | Receiving Intraday data for ESH5-CME starting at 2015-01-09 17:15:00 | 2015-01-11 13:24:06 HD Request # 5 | Timestamp of first Intraday data file record written: 2015-01-09 17:15:00 | 2015-01-11 13:24:06 Socket (6) | Shutdown and closed. | 2015-01-11 13:24:06 The network socket for historical data has been closed. | 2015-01-11 13:24:06 HD Request # 5 | Received 1 record from 2015-01-09 17:15:00 to 2015-01-09 17:15:00 (0.0 seconds) and wrote 1 record for ESH5-CME | 2015-01-11 13:24:06 HD Request # 5 | Intraday download COMPLETE for ESH5-CME. Completion time: 0s. Unique request ID: 3 | 2015-01-11 13:24:06 Removed historical data download ID 3 | 2015-01-11 13:24:06 Real-time Intraday chart data file updates started for ESH5-CME | 2015-01-11 13:24:06 HD Request # 6 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-11 13:24:06 HD Request # 6 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:24:06 HD Request # 6 | Using server: ds5.sierracharts.com port 10149 | 2015-01-11 13:24:06 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-11 13:24:06 Socket (7) | Connected. | 2015-01-11 13:24:06 HD Request # 6 | Sending historical data logon request message. | 2015-01-11 13:24:06 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-SP | 2015-01-11 13:24:06 HD Request # 6 | Decompressing data. | 2015-01-11 13:24:06 HD Request # 6 | Receiving Intraday data for NISS-SP starting at 2015-01-09 18:59:04 | 2015-01-11 13:24:06 HD Request # 6 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:24:06 Socket (7) | Shutdown and closed. | 2015-01-11 13:24:06 The network socket for historical data has been closed. | 2015-01-11 13:24:06 HD Request # 6 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-SP | 2015-01-11 13:24:06 HD Request # 6 | Intraday download COMPLETE for NISS-SP. Completion time: 0s. Unique request ID: 4 | 2015-01-11 13:24:06 Removed historical data download ID 4 | 2015-01-11 13:24:06 Real-time Intraday chart data file updates started for NISS-SP | 2015-01-11 13:24:06 HD Request # 7 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-11 13:24:06 HD Request # 7 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:24:06 HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2015-01-11 13:24:06 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-11 13:24:06 Chart #4 has tagged chart #9 for full recalculation. Chartbook: TaylorTransformational.cht | 2015-01-11 13:24:06 Chart #9 is performing a full recalculation because it has been tagged. Chartbook: TaylorTransformational.cht | 2015-01-11 13:24:06 Socket (8) | Connected. | 2015-01-11 13:24:06 HD Request # 7 | Sending historical data logon request message. | 2015-01-11 13:24:06 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-NQ | 2015-01-11 13:24:06 HD Request # 7 | Decompressing data. | 2015-01-11 13:24:06 HD Request # 7 | Receiving Intraday data for NISS-NQ starting at 2015-01-09 18:59:04 | 2015-01-11 13:24:06 HD Request # 7 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:24:06 Socket (8) | Shutdown and closed. | 2015-01-11 13:24:06 The network socket for historical data has been closed. | 2015-01-11 13:24:06 HD Request # 7 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-NQ | 2015-01-11 13:24:06 HD Request # 7 | Intraday download COMPLETE for NISS-NQ. Completion time: 0s. Unique request ID: 5 | 2015-01-11 13:24:06 Removed historical data download ID 5 | 2015-01-11 13:24:06 Real-time Intraday chart data file updates started for NISS-NQ | 2015-01-11 13:24:06 HD Request # 8 | Downloading Intraday chart data for TF FMH0015!-NYBOT to the file TF FMH0015!-NYBOT.scid. Service: rim | 2015-01-11 13:24:06 HD Request # 8 | Download start Date-Time: 2015-01-09 17:56:01.0 | 2015-01-11 13:24:06 HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2015-01-11 13:24:06 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-11 13:24:06 Socket (9) | Connected. | 2015-01-11 13:24:06 HD Request # 8 | Sending historical data logon request message. | 2015-01-11 13:24:06 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-01-09 17:56:01. Record interval: 60. Symbol: TF FMH0015!-NYBOT | 2015-01-11 13:24:06 HD Request # 8 | Decompressing data. | 2015-01-11 13:24:06 HD Request # 8 | Receiving Intraday data for TF FMH0015!-NYBOT starting at 2015-01-09 17:56:01 | 2015-01-11 13:24:06 HD Request # 8 | Timestamp of first Intraday data file record written: 2015-01-09 17:56:01 | 2015-01-11 13:24:06 Socket (9) | Shutdown and closed. | 2015-01-11 13:24:06 The network socket for historical data has been closed. | 2015-01-11 13:24:06 HD Request # 8 | Received 1 record from 2015-01-09 17:56:01 to 2015-01-09 17:56:01 (0.0 seconds) and wrote 1 record for TF FMH0015!-NYBOT | 2015-01-11 13:24:06 HD Request # 8 | Intraday download COMPLETE for TF FMH0015!-NYBOT. Completion time: 0s. Unique request ID: 7 | 2015-01-11 13:24:06 Removed historical data download ID 7 | 2015-01-11 13:24:06 Real-time Intraday chart data file updates started for TF FMH0015!-NYBOT | 2015-01-11 13:24:06 HD Request # 9 | Downloading Intraday chart data for NQH5-CME to the file NQH5-CME.scid. Service: rim | 2015-01-11 13:24:06 HD Request # 9 | Download start Date-Time: 2015-01-09 17:14:00.0 | 2015-01-11 13:24:06 HD Request # 9 | Using server: ds5.sierracharts.com port 10149 | 2015-01-11 13:24:06 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-11 13:24:06 Socket (10) | Connected. | 2015-01-11 13:24:06 HD Request # 9 | Sending historical data logon request message. | 2015-01-11 13:24:06 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2015-01-09 17:14:00. Record interval: 60. Symbol: NQH5-CME | 2015-01-11 13:24:07 HD Request # 9 | Decompressing data. | 2015-01-11 13:24:07 HD Request # 9 | Receiving Intraday data for NQH5-CME starting at 2015-01-09 17:14:00 | 2015-01-11 13:24:07 HD Request # 9 | Timestamp of first Intraday data file record written: 2015-01-09 17:14:00 | 2015-01-11 13:24:07 Socket (10) | Shutdown and closed. | 2015-01-11 13:24:07 The network socket for historical data has been closed. | 2015-01-11 13:24:07 HD Request # 9 | Received 1 record from 2015-01-09 17:14:00 to 2015-01-09 17:14:00 (0.0 seconds) and wrote 1 record for NQH5-CME | 2015-01-11 13:24:07 HD Request # 9 | Intraday download COMPLETE for NQH5-CME. Completion time: 1s. Unique request ID: 8 | 2015-01-11 13:24:07 Removed historical data download ID 8 | 2015-01-11 13:24:07 Real-time Intraday chart data file updates started for NQH5-CME | 2015-01-11 13:24:07 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:25:02 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:25:02 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:25:02 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:25:02 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:25:02 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:25:02 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:25:02 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:25:02 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:25:02 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5 | Symbols used for continuous contract chart: | 2015-01-11 13:25:02 ESH14 | 2015-01-11 13:25:02 ESM14 | 2015-01-11 13:25:02 ESU14 | 2015-01-11 13:25:02 ESZ14 | 2015-01-11 13:25:02 ESH15 | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:25:02 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:25:02 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:25:29 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:25:29 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:25:29 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:25:29 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:25:29 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:25:29 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:25:29 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:25:29 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:25:29 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11 | Symbols used for continuous contract chart: | 2015-01-11 13:25:29 ESH14 | 2015-01-11 13:25:29 ESM14 | 2015-01-11 13:25:29 ESU14 | 2015-01-11 13:25:29 ESZ14 | 2015-01-11 13:25:29 ESH15 | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:25:29 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:25:29 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:26:30 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:26:30 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:26:30 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:26:30 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:26:30 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:26:30 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:26:30 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:26:30 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:26:30 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6 | Symbols used for continuous contract chart: | 2015-01-11 13:26:30 ESH14 | 2015-01-11 13:26:30 ESM14 | 2015-01-11 13:26:30 ESU14 | 2015-01-11 13:26:30 ESZ14 | 2015-01-11 13:26:30 ESH15 | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:26:30 ESH15/ESH5-CME [CB] Daily #6: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:26:31 ESH15/ESH5-CME [CB] Daily #6: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:26:31 ESH15/ESH5-CME [CB] Daily #6: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:26:31 ESH15/ESH5-CME [CB] Daily #6: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:26:31 ESH15/ESH5-CME [CB] Daily #6: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:26:31 ESH15/ESH5-CME [CB] Daily #6: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:26:31 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:27:14 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:27:14 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:27:14 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:27:14 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:27:14 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:27:14 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:27:14 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:27:14 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:27:14 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:27:14 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:27:14 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6 | Symbols used for continuous contract chart: | 2015-01-11 13:27:14 ESM4-CME | 2015-01-11 13:27:14 ESU4-CME | 2015-01-11 13:27:14 ESZ4-CME | 2015-01-11 13:27:14 ESH5-CME | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:27:14 ESH5-CME [CB] 10 Min #6: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:27:14 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:27:34 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:27:34 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:27:34 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:27:34 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:27:34 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:27:34 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:27:34 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:27:34 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:27:34 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:27:34 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:27:34 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6 | Symbols used for continuous contract chart: | 2015-01-11 13:27:34 ESM4-CME | 2015-01-11 13:27:34 ESU4-CME | 2015-01-11 13:27:34 ESZ4-CME | 2015-01-11 13:27:34 ESH5-CME | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:27:34 ESH5-CME [CB] 60 Min #6: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:27:34 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:27:38 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:27:38 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:27:38 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:27:38 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:27:38 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:27:38 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:27:38 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:27:38 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:27:38 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:27:38 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:27:38 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6 | Symbols used for continuous contract chart: | 2015-01-11 13:27:38 ESM4-CME | 2015-01-11 13:27:38 ESU4-CME | 2015-01-11 13:27:38 ESZ4-CME | 2015-01-11 13:27:38 ESH5-CME | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:27:38 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:27:38 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:28:18 ESH5-CME [CB] 30 Min #4 | Symbols used for continuous contract chart: | 2015-01-11 13:28:18 ESH5-CME | 2015-01-11 13:28:18 ESH5-CME [CB] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:28:18 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-01-11 13:28:18 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:28:18 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:28:18 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-09. | 2015-01-11 13:28:18 Performing historical Daily data download for symbol ESZ14 starting at 0. | 2015-01-11 13:28:18 ESZ4-CME [CB] 1 Min #11 | Symbols used for continuous contract chart: | 2015-01-11 13:28:18 ESH4-CME | 2015-01-11 13:28:18 ESM4-CME | 2015-01-11 13:28:18 ESU4-CME | 2015-01-11 13:28:18 ESZ4-CME | 2015-01-11 13:28:18 ESZ4-CME [CB] 1 Min #11 | Waiting for historical downloads to complete with the IDs: 9, | 2015-01-11 13:28:18 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:28:18 * Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-01-11 13:28:18 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:28:18 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:28:18 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-09. | 2015-01-11 13:28:18 Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6 | Symbols used for continuous contract chart: | 2015-01-11 13:28:18 ESH4-CME | 2015-01-11 13:28:18 ESM4-CME | 2015-01-11 13:28:18 ESU4-CME | 2015-01-11 13:28:18 ESZ4-CME | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: Back adjust amount for symbol ESH4-CME is -22. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: Back adjust amount for symbol ESM4-CME is -14.75. | 2015-01-11 13:28:18 ESZ4-CME [CB] 10 Min #6: Back adjust amount for symbol ESU4-CME is -7.75. | 2015-01-11 13:28:18 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-09. | 2015-01-11 13:28:18 Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2015-01-11 13:28:18 ESZ4-CME [CB] 1 Min #17 | Symbols used for continuous contract chart: | 2015-01-11 13:28:18 ESZ4-CME | 2015-01-11 13:28:18 ESZ4-CME [CB] 1 Min #17: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:28:18 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:28:18 * Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:28:18 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:28:18 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:28:18 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:28:18 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:28:18 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18 | Symbols used for continuous contract chart: | 2015-01-11 13:28:18 ESM4-CME | 2015-01-11 13:28:18 ESU4-CME | 2015-01-11 13:28:18 ESZ4-CME | 2015-01-11 13:28:18 ESH5-CME | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:28:18 ESH5-CME [CB] 15 Min #18: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:28:18 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-01-11 13:28:19 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:28:19 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:28:19 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:28:19 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:19 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:19 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:19 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-09. | 2015-01-11 13:28:19 Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5 | Symbols used for continuous contract chart: | 2015-01-11 13:28:19 ESH4-CME | 2015-01-11 13:28:19 ESM4-CME | 2015-01-11 13:28:19 ESU4-CME | 2015-01-11 13:28:19 ESZ4-CME | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: Back adjust amount for symbol ESH4-CME is -22. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: Back adjust amount for symbol ESM4-CME is -14.75. | 2015-01-11 13:28:19 ESZ4-CME [CB] 1 Min #5: Back adjust amount for symbol ESU4-CME is -7.75. | 2015-01-11 13:28:19 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:28:19 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2015-01-11 13:28:19 ESZ4-CME [C] 60 Min #3 | Symbols used for continuous contract chart: | 2015-01-11 13:28:19 ESZ4-CME | 2015-01-11 13:28:19 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2015-01-11 13:28:19 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:28:19 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:28:19 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:28:19 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:28:19 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:28:19 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:28:19 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:28:19 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:28:19 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:28:19 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:28:19 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:28:19 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:19 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-09. | 2015-01-11 13:28:19 Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2015-01-11 13:28:19 ESZ14/ESZ4-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-01-11 13:28:19 ESZ11 | 2015-01-11 13:28:19 ESH12 | 2015-01-11 13:28:19 ESM12 | 2015-01-11 13:28:19 ESU12 | 2015-01-11 13:28:19 ESZ12 | 2015-01-11 13:28:19 ESH13 | 2015-01-11 13:28:19 ESM13 | 2015-01-11 13:28:19 ESU13 | 2015-01-11 13:28:19 ESZ13 | 2015-01-11 13:28:19 ESH14 | 2015-01-11 13:28:19 ESM14 | 2015-01-11 13:28:19 ESU14 | 2015-01-11 13:28:19 ESZ14 | 2015-01-11 13:28:19 ESZ14/ESZ4-CME [C] Daily #8 | Waiting for historical downloads to complete with the IDs: 9, | 2015-01-11 13:28:19 Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-01-11 13:28:19 Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-01-11 13:28:19 Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:28:19 Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 0. | 2015-01-11 13:28:19 TF FMH0015!-NYBOT [C] 1 Min #14 | Symbols used for continuous contract chart: | 2015-01-11 13:28:19 TF FMZ0014!-NYBOT | 2015-01-11 13:28:19 TF FMH0015!-NYBOT | 2015-01-11 13:28:19 HD Request # 10 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-12-18. Service: rim | 2015-01-11 13:28:19 HD Request # 10 | Requesting historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:28:19 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:28:19 * Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:28:19 * HD Request # 10 | Receiving historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:28:20 Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2015-01-11 13:28:20 HD Request # 10 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-19 00:00:00 (3.0 days) and wrote 2 records for ESZ14 | 2015-01-11 13:28:20 HD Request # 10 | Daily download COMPLETE for ESZ14. Completion time: 1s. Unique request ID: 9 | 2015-01-11 13:28:20 Removed historical data download ID 9 | 2015-01-11 13:28:20 Rithmic Trading | Starting real-time market data updates for: ESZ4-CME. ID: 10 | 2015-01-11 13:28:20 Intraday data recording state for symbol ESZ4-CME is set to download pending. | 2015-01-11 13:28:20 HD Request # 11 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: cme | 2015-01-11 13:28:20 HD Request # 11 | Download start Date-Time: 2014-12-19 09:29:00.0 | 2015-01-11 13:28:20 HD Request # 11 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-11 13:28:20 Rithmic Trading | Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2015-01-11 13:28:20 Symbol Error - ESZ4-CME is unknown, unavailable, or improperly formatted. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: Download is complete for all contract months in chart. Proceeding with data load. | 2015-01-11 13:28:20 Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: Back adjust amount for symbol ESH4-CME is -22. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: Back adjust amount for symbol ESM4-CME is -14.75. | 2015-01-11 13:28:20 ESZ4-CME [CB] 1 Min #11: Back adjust amount for symbol ESU4-CME is -7.75. | 2015-01-11 13:28:20 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:28:20 * Socket (11) | Connected. | 2015-01-11 13:28:20 HD Request # 11 | Sending historical data logon request message. | 2015-01-11 13:28:20 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:28:20 * HD Request # 11 | Requesting Intraday data. Start Date-Time: 2014-12-19 09:29:00. Record interval: 60. Symbol: ESZ4 | 2015-01-11 13:28:20 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2015-01-11 13:28:20 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:28:20 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:28:20 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:28:20 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:28:20 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:28:20 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:28:20 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:28:20 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:28:20 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:28:20 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:28:20 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:28:20 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:28:20 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-09. | 2015-01-11 13:28:20 Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2015-01-11 13:28:20 ESZ14/ESZ4-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-01-11 13:28:20 ESZ11 | 2015-01-11 13:28:20 ESH12 | 2015-01-11 13:28:20 ESM12 | 2015-01-11 13:28:20 ESU12 | 2015-01-11 13:28:20 ESZ12 | 2015-01-11 13:28:20 ESH13 | 2015-01-11 13:28:20 ESM13 | 2015-01-11 13:28:20 ESU13 | 2015-01-11 13:28:20 ESZ13 | 2015-01-11 13:28:20 ESH14 | 2015-01-11 13:28:20 ESM14 | 2015-01-11 13:28:20 ESU14 | 2015-01-11 13:28:20 ESZ14 | 2015-01-11 13:28:20 HD Request # 11 | Decompressing data. | 2015-01-11 13:28:20 HD Request # 11 | Receiving Intraday data for ESZ4-CME starting at 2014-12-19 09:29:00 | 2015-01-11 13:28:20 HD Request # 11 | Timestamp of first Intraday data file record written: 2014-12-19 09:29:00 | 2015-01-11 13:28:20 Socket (11) | Shutdown and closed. | 2015-01-11 13:28:20 The network socket for historical data has been closed. | 2015-01-11 13:28:20 HD Request # 11 | Received 1 record from 2014-12-19 09:29:00 to 2014-12-19 09:29:00 (0.0 seconds) and wrote 1 record for ESZ4-CME | 2015-01-11 13:28:20 HD Request # 11 | Intraday download COMPLETE for ESZ4-CME. Completion time: 0s. Unique request ID: 10 | 2015-01-11 13:28:20 Removed historical data download ID 10 | 2015-01-11 13:28:20 Real-time Intraday chart data file updates started for ESZ4-CME | 2015-01-11 13:28:20 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:28:20 * Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:30:59 * Unsubscribed from market depth data for ESH5-CME | 2015-01-11 13:31:01 Current selected Data/Trading service: SC Historical Data | 2015-01-11 13:33:17 Checking for new symbol settings for ddf | 2015-01-11 13:33:17 Socket (2) | Shutdown and closed. | 2015-01-11 13:33:17 Rithmic Trading | Disconnected from the server. | 2015-01-11 13:33:17 Socket (3) | Shutdown and closed. | 2015-01-11 13:33:17 SC Market Stats | Disconnected from the server. | 2015-01-11 13:33:17 SC Historical Data | Connected. Historical Intraday data will be requested. | 2015-01-11 13:33:17 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-01-11 13:33:17 HTTP connection to www.sierrachart.com:80 (12) | Connected. | 2015-01-11 13:33:17 Requesting symbol settings for ddf. Overwrite = on. | 2015-01-11 13:33:17 Symbol settings received. | 2015-01-11 13:33:20 Processed received symbol settings | 2015-01-11 13:33:20 HTTP connection to www.sierrachart.com:80 (12) | Closed. No error. | 2015-01-11 13:33:25 HTTP connection to www.sierrachart.com:80 (12) | Shutdown and closed. | 2015-01-11 13:33:25 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH5-CME [CB] 30 Min #4 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESH5-CME | 2015-01-11 13:34:42 ESH5-CME [CB] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:34:42 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESZ4-CME | 2015-01-11 13:34:42 ESH5-CME | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:34:42 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:34:42 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:34:42 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:34:42 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESH14 | 2015-01-11 13:34:42 ESM14 | 2015-01-11 13:34:42 ESU14 | 2015-01-11 13:34:42 ESZ14 | 2015-01-11 13:34:42 ESH15 | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:34:42 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:42 * Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:34:42 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:34:42 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESM4-CME | 2015-01-11 13:34:42 ESU4-CME | 2015-01-11 13:34:42 ESZ4-CME | 2015-01-11 13:34:42 ESH5-CME | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 5 Min #6: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:34:42 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #17 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESZ4-CME | 2015-01-11 13:34:42 ESH5-CME | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #17: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #17: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #17: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #17: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:34:42 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:42 * Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:34:42 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:34:42 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESM4-CME | 2015-01-11 13:34:42 ESU4-CME | 2015-01-11 13:34:42 ESZ4-CME | 2015-01-11 13:34:42 ESH5-CME | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:34:42 ESH5-CME [CB] 1 Min #18: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:34:42 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:34:42 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:34:42 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:34:42 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESH14 | 2015-01-11 13:34:42 ESM14 | 2015-01-11 13:34:42 ESU14 | 2015-01-11 13:34:42 ESZ14 | 2015-01-11 13:34:42 ESH15 | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:34:42 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:34:42 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:34:42 ESH5-CME [C] 1 Min #3 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESH5-CME | 2015-01-11 13:34:42 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:34:42 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:34:42 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:34:42 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:34:42 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:34:42 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:34:42 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:34:42 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:34:42 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:34:42 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:34:42 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:34:42 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:34:42 ESH15/ESH5-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 ESH12 | 2015-01-11 13:34:42 ESM12 | 2015-01-11 13:34:42 ESU12 | 2015-01-11 13:34:42 ESZ12 | 2015-01-11 13:34:42 ESH13 | 2015-01-11 13:34:42 ESM13 | 2015-01-11 13:34:42 ESU13 | 2015-01-11 13:34:42 ESZ13 | 2015-01-11 13:34:42 ESH14 | 2015-01-11 13:34:42 ESM14 | 2015-01-11 13:34:42 ESU14 | 2015-01-11 13:34:42 ESZ14 | 2015-01-11 13:34:42 ESH15 | 2015-01-11 13:34:42 Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-01-11 13:34:42 Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-01-11 13:34:42 Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:34:42 Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 0. | 2015-01-11 13:34:42 TF FMH0015!-NYBOT [C] 1 Min #14 | Symbols used for continuous contract chart: | 2015-01-11 13:34:42 TF FMZ0014!-NYBOT | 2015-01-11 13:34:42 TF FMH0015!-NYBOT | 2015-01-11 13:34:42 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:43 * Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:43 * SC Historical Data | Starting real-time market data updates for: ESH5-CME. ID: 1 | 2015-01-11 13:34:43 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: ESH5-CME | 2015-01-11 13:34:43 Requesting market depth updates for: ESH5-CME if supported. | 2015-01-11 13:34:43 SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 2 | 2015-01-11 13:34:43 SC Market Stats | Connecting to the server ds4.sierracharts.com. Port 443 | 2015-01-11 13:34:43 Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-01-11 13:34:43 HD Request # 12 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-11 13:34:43 HD Request # 12 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:43 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-11 13:34:43 HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2015-01-11 13:34:43 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-11 13:34:43 SC Market Stats | Starting real-time market data updates for: NISS-NYSE. ID: 3 | 2015-01-11 13:34:43 Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-11 13:34:43 Socket (14) | Connected. | 2015-01-11 13:34:43 HD Request # 12 | Sending historical data logon request message. | 2015-01-11 13:34:43 Intraday data recording state for symbol ESH5-CME is set to download pending. | 2015-01-11 13:34:43 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: TICK-NYSE | 2015-01-11 13:34:43 HD Request # 13 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: ddf | 2015-01-11 13:34:43 HD Request # 13 | Download start Date-Time: 2015-01-09 17:15:00.0 | 2015-01-11 13:34:43 HD Request # 13 | Requesting historical Intraday Minute data for ESH5-CME starting at 2015-01-09 17:15:00 (Exchange time). | 2015-01-11 13:34:43 SC Market Stats | Starting real-time market data updates for: NISS-SP. ID: 4 | 2015-01-11 13:34:43 Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-11 13:34:43 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:43 * HD Request # 12 | Decompressing data. | 2015-01-11 13:34:43 HD Request # 12 | Receiving Intraday data for TICK-NYSE starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:43 HD Request # 12 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:43 SC Market Stats | Starting real-time market data updates for: NISS-NQ. ID: 5 | 2015-01-11 13:34:43 Socket (14) | Shutdown and closed. | 2015-01-11 13:34:43 Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-11 13:34:43 The network socket for historical data has been closed. | 2015-01-11 13:34:43 HD Request # 12 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2015-01-11 13:34:43 HD Request # 12 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 11 | 2015-01-11 13:34:43 Removed historical data download ID 11 | 2015-01-11 13:34:43 Real-time Intraday chart data file updates started for TICK-NYSE | 2015-01-11 13:34:43 HD Request # 14 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-11 13:34:43 HD Request # 14 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:43 HD Request # 14 | Using server: ds5.sierracharts.com port 10149 | 2015-01-11 13:34:43 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-11 13:34:43 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:43 * Socket (15) | Connected. | 2015-01-11 13:34:43 HD Request # 14 | Sending historical data logon request message. | 2015-01-11 13:34:43 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-NYSE | 2015-01-11 13:34:43 HD Request # 13 | Error downloading historical Intraday data for ESH5-CME. Error executing query: Invalid symbol | 2015-01-11 13:34:43 * HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH5-CME | 2015-01-11 13:34:43 HD Request # 13 | Intraday download COMPLETE for ESH5-CME. Completion time: 0s. Unique request ID: 13 | 2015-01-11 13:34:43 Removed historical data download ID 13 | 2015-01-11 13:34:43 Real-time Intraday chart data file updates started for ESH5-CME | 2015-01-11 13:34:43 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:34:43 SC Historical Data | Starting real-time market data updates for: TF FMH0015!-NYBOT. ID: 6 | 2015-01-11 13:34:43 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: TF FMH0015!-NYBOT | 2015-01-11 13:34:43 Intraday data recording state for symbol TF FMH0015!-NYBOT is set to download pending. | 2015-01-11 13:34:43 HD Request # 15 | Downloading Intraday chart data for TF FMH0015!-NYBOT to the file TF FMH0015!-NYBOT.scid. Service: ddf | 2015-01-11 13:34:43 HD Request # 15 | Download start Date-Time: 2015-01-09 17:56:01.0 | 2015-01-11 13:34:43 HD Request # 15 | Requesting historical Intraday Minute data for TF FMH0015!-NYBOT starting at 2015-01-09 17:56:01 (Exchange time). | 2015-01-11 13:34:43 SC Historical Data | Starting real-time market data updates for: NQH5-CME. ID: 7 | 2015-01-11 13:34:43 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: NQH5-CME | 2015-01-11 13:34:43 Intraday data recording state for symbol NQH5-CME is set to download pending. | 2015-01-11 13:34:43 Chart #10 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:43 Chart #4 has tagged chart #9 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:43 Chart #9 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:43 HD Request # 15 | Error downloading historical Intraday data for TF FMH0015!-NYBOT. Error executing query: Invalid symbol | 2015-01-11 13:34:44 * HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0015!-NYBOT | 2015-01-11 13:34:44 HD Request # 15 | Intraday download COMPLETE for TF FMH0015!-NYBOT. Completion time: 1s. Unique request ID: 16 | 2015-01-11 13:34:44 Removed historical data download ID 16 | 2015-01-11 13:34:44 Real-time Intraday chart data file updates started for TF FMH0015!-NYBOT | 2015-01-11 13:34:44 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:34:44 HD Request # 14 | Decompressing data. | 2015-01-11 13:34:44 HD Request # 14 | Receiving Intraday data for NISS-NYSE starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:44 HD Request # 16 | Downloading Intraday chart data for NQH5-CME to the file NQH5-CME.scid. Service: ddf | 2015-01-11 13:34:44 HD Request # 14 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:44 Socket (15) | Shutdown and closed. | 2015-01-11 13:34:44 The network socket for historical data has been closed. | 2015-01-11 13:34:44 HD Request # 16 | Download start Date-Time: 2015-01-09 17:14:00.0 | 2015-01-11 13:34:44 HD Request # 16 | Requesting historical Intraday Minute data for NQH5-CME starting at 2015-01-09 17:14:00 (Exchange time). | 2015-01-11 13:34:44 HD Request # 14 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-NYSE | 2015-01-11 13:34:44 HD Request # 14 | Intraday download COMPLETE for NISS-NYSE. Completion time: 1s. Unique request ID: 12 | 2015-01-11 13:34:44 Removed historical data download ID 12 | 2015-01-11 13:34:44 Real-time Intraday chart data file updates started for NISS-NYSE | 2015-01-11 13:34:44 HD Request # 17 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-11 13:34:44 HD Request # 17 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:44 HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2015-01-11 13:34:44 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-11 13:34:44 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:44 * Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:44 Socket (16) | Connected. | 2015-01-11 13:34:44 HD Request # 17 | Sending historical data logon request message. | 2015-01-11 13:34:44 HD Request # 16 | Error downloading historical Intraday data for NQH5-CME. Error executing query: Invalid symbol | 2015-01-11 13:34:44 * HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH5-CME | 2015-01-11 13:34:44 HD Request # 16 | Intraday download COMPLETE for NQH5-CME. Completion time: 0s. Unique request ID: 17 | 2015-01-11 13:34:44 Removed historical data download ID 17 | 2015-01-11 13:34:44 Real-time Intraday chart data file updates started for NQH5-CME | 2015-01-11 13:34:44 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:34:44 Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-11 13:34:44 * HD Request # 17 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-SP | 2015-01-11 13:34:44 HD Request # 17 | Decompressing data. | 2015-01-11 13:34:44 HD Request # 17 | Receiving Intraday data for NISS-SP starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:44 HD Request # 17 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:44 Socket (16) | Shutdown and closed. | 2015-01-11 13:34:44 The network socket for historical data has been closed. | 2015-01-11 13:34:44 HD Request # 17 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-SP | 2015-01-11 13:34:44 HD Request # 17 | Intraday download COMPLETE for NISS-SP. Completion time: 0s. Unique request ID: 14 | 2015-01-11 13:34:44 Removed historical data download ID 14 | 2015-01-11 13:34:44 Real-time Intraday chart data file updates started for NISS-SP | 2015-01-11 13:34:44 HD Request # 18 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-11 13:34:44 HD Request # 18 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:44 HD Request # 18 | Using server: ds3.sierracharts.com port 10149 | 2015-01-11 13:34:44 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-11 13:34:44 Chart #7 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:44 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:44 Socket (17) | Connected. | 2015-01-11 13:34:44 HD Request # 18 | Sending historical data logon request message. | 2015-01-11 13:34:44 HD Request # 18 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-NQ | 2015-01-11 13:34:44 HD Request # 18 | Decompressing data. | 2015-01-11 13:34:44 HD Request # 18 | Receiving Intraday data for NISS-NQ starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:44 HD Request # 18 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:44 Socket (17) | Shutdown and closed. | 2015-01-11 13:34:44 The network socket for historical data has been closed. | 2015-01-11 13:34:44 HD Request # 18 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-NQ | 2015-01-11 13:34:44 HD Request # 18 | Intraday download COMPLETE for NISS-NQ. Completion time: 0s. Unique request ID: 15 | 2015-01-11 13:34:44 Removed historical data download ID 15 | 2015-01-11 13:34:44 Real-time Intraday chart data file updates started for NISS-NQ | 2015-01-11 13:34:44 Socket (13) | Connected. | 2015-01-11 13:34:46 SC Market Stats | Connected to server. | 2015-01-11 13:34:46 SC Market Stats | Sending logon request message. | 2015-01-11 13:34:46 SC Market Stats | Server Name: SC Realtime Server. | 2015-01-11 13:34:47 SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-11 13:34:47 SC Market Stats | Successfully connected. | 2015-01-11 13:34:47 Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-11 13:34:47 SC Market Stats | Restarting real-time data updates for symbol: NISS-NQ | 2015-01-11 13:34:47 Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-11 13:34:47 SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2015-01-11 13:34:47 Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-11 13:34:47 SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2015-01-11 13:34:47 Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-01-11 13:34:47 SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2015-01-11 13:34:47 HD Request # 19 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-11 13:34:47 HD Request # 19 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:47 HD Request # 19 | Using server: ds5.sierracharts.com port 10149 | 2015-01-11 13:34:47 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-11 13:34:47 Socket (18) | Connected. | 2015-01-11 13:34:47 HD Request # 19 | Sending historical data logon request message. | 2015-01-11 13:34:47 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-NQ | 2015-01-11 13:34:47 HD Request # 19 | Decompressing data. | 2015-01-11 13:34:47 HD Request # 19 | Receiving Intraday data for NISS-NQ starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:47 HD Request # 19 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:47 Socket (18) | Shutdown and closed. | 2015-01-11 13:34:47 The network socket for historical data has been closed. | 2015-01-11 13:34:47 HD Request # 19 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-NQ | 2015-01-11 13:34:47 HD Request # 19 | Intraday download COMPLETE for NISS-NQ. Completion time: 0s. Unique request ID: 18 | 2015-01-11 13:34:47 Removed historical data download ID 18 | 2015-01-11 13:34:47 Real-time Intraday chart data file updates started for NISS-NQ | 2015-01-11 13:34:47 HD Request # 20 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-11 13:34:47 HD Request # 20 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:47 HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2015-01-11 13:34:47 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-11 13:34:47 Socket (19) | Connected. | 2015-01-11 13:34:50 HD Request # 20 | Sending historical data logon request message. | 2015-01-11 13:34:50 HD Request # 20 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-NYSE | 2015-01-11 13:34:50 HD Request # 20 | Decompressing data. | 2015-01-11 13:34:50 HD Request # 20 | Receiving Intraday data for NISS-NYSE starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:50 HD Request # 20 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:50 Socket (19) | Shutdown and closed. | 2015-01-11 13:34:50 The network socket for historical data has been closed. | 2015-01-11 13:34:50 HD Request # 20 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-NYSE | 2015-01-11 13:34:50 HD Request # 20 | Intraday download COMPLETE for NISS-NYSE. Completion time: 3s. Unique request ID: 19 | 2015-01-11 13:34:50 Removed historical data download ID 19 | 2015-01-11 13:34:50 Real-time Intraday chart data file updates started for NISS-NYSE | 2015-01-11 13:34:50 HD Request # 21 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-11 13:34:50 HD Request # 21 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:50 HD Request # 21 | Using server: ds3.sierracharts.com port 10149 | 2015-01-11 13:34:50 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-11 13:34:50 Socket (20) | Connected. | 2015-01-11 13:34:50 HD Request # 21 | Sending historical data logon request message. | 2015-01-11 13:34:50 Chart #7 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:50 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: NISS-SP | 2015-01-11 13:34:50 HD Request # 21 | Decompressing data. | 2015-01-11 13:34:50 HD Request # 21 | Receiving Intraday data for NISS-SP starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:50 HD Request # 21 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:50 Socket (20) | Shutdown and closed. | 2015-01-11 13:34:50 The network socket for historical data has been closed. | 2015-01-11 13:34:50 HD Request # 21 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for NISS-SP | 2015-01-11 13:34:50 HD Request # 21 | Intraday download COMPLETE for NISS-SP. Completion time: 0s. Unique request ID: 20 | 2015-01-11 13:34:50 Removed historical data download ID 20 | 2015-01-11 13:34:50 Real-time Intraday chart data file updates started for NISS-SP | 2015-01-11 13:34:50 HD Request # 22 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-11 13:34:50 HD Request # 22 | Download start Date-Time: 2015-01-09 18:59:04.0 | 2015-01-11 13:34:50 HD Request # 22 | Using server: ds5.sierracharts.com port 10149 | 2015-01-11 13:34:50 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-11 13:34:50 Socket (21) | Connected. | 2015-01-11 13:34:50 HD Request # 22 | Sending historical data logon request message. | 2015-01-11 13:34:50 HD Request # 22 | Requesting Intraday data. Start Date-Time: 2015-01-09 18:59:04. Record interval: 60. Symbol: TICK-NYSE | 2015-01-11 13:34:50 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:50 HD Request # 22 | Decompressing data. | 2015-01-11 13:34:50 HD Request # 22 | Receiving Intraday data for TICK-NYSE starting at 2015-01-09 18:59:04 | 2015-01-11 13:34:50 HD Request # 22 | Timestamp of first Intraday data file record written: 2015-01-09 18:59:04 | 2015-01-11 13:34:50 Socket (21) | Shutdown and closed. | 2015-01-11 13:34:50 The network socket for historical data has been closed. | 2015-01-11 13:34:50 HD Request # 22 | Received 1 record from 2015-01-09 18:59:04 to 2015-01-09 18:59:04 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2015-01-11 13:34:50 HD Request # 22 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 21 | 2015-01-11 13:34:50 Removed historical data download ID 21 | 2015-01-11 13:34:50 Real-time Intraday chart data file updates started for TICK-NYSE | 2015-01-11 13:34:50 Chart #10 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:51 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:34:51 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:35:29 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:35:29 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:35:29 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:35:29 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:35:29 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:35:29 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:35:29 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:35:29 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:35:29 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6 | Symbols used for continuous contract chart: | 2015-01-11 13:35:29 ESH14 | 2015-01-11 13:35:29 ESM14 | 2015-01-11 13:35:29 ESU14 | 2015-01-11 13:35:29 ESZ14 | 2015-01-11 13:35:29 ESH15 | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:35:29 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:35:29 SC Historical Data | Starting real-time market data updates for: ESH15. ID: 8 | 2015-01-11 13:35:30 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: ESH15 | 2015-01-11 13:35:30 Chart #10 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:36:05 Chart #7 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:36:05 Chart #4 has tagged chart #9 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:36:05 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:36:05 Chart #9 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:36:05 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:36:31 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:36:31 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:36:31 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:36:31 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:36:31 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:36:31 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:36:31 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:36:31 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:36:31 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:36:31 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:36:31 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6 | Symbols used for continuous contract chart: | 2015-01-11 13:36:31 ESU12 | 2015-01-11 13:36:31 ESZ12 | 2015-01-11 13:36:31 ESH13 | 2015-01-11 13:36:31 ESM13 | 2015-01-11 13:36:31 ESU13 | 2015-01-11 13:36:31 ESZ13 | 2015-01-11 13:36:31 ESH14 | 2015-01-11 13:36:31 ESM14 | 2015-01-11 13:36:31 ESU14 | 2015-01-11 13:36:31 ESZ14 | 2015-01-11 13:36:31 ESH15 | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU12 Open price on 2012-09-13 is 1438.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ12 Open price on 2012-09-13 is 1431.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU12 price difference to ESZ12 is -6.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ12 Open price on 2012-12-13 is 1425.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESH13 Open price on 2012-12-13 is 1419.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ12 price difference to ESH13 is -6. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESH13 Open price on 2013-03-07 is 1539.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESM13 Open price on 2013-03-07 is 1535. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESH13 price difference to ESM13 is -4.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESM13 Open price on 2013-06-13 is 1610.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU13 Open price on 2013-06-13 is 1605. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESM13 price difference to ESU13 is -5.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU13 Open price on 2013-09-12 is 1689.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ13 Open price on 2013-09-12 is 1683.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU13 price difference to ESZ13 is -6.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ13 Open price on 2013-12-12 is 1780.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESH14 Open price on 2013-12-12 is 1774.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ13 price difference to ESH14 is -6.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU12 is -64.75. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ12 is -58. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESH13 is -52. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESM13 is -47.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU13 is -41.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ13 is -35. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:36:31 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:36:31 Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2015-01-11 13:40:24 Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2015-01-11 13:40:24 Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2015-01-11 13:40:24 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2015-01-11 13:40:24 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2015-01-11 13:40:24 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2015-01-11 13:40:24 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-01-11 13:40:24 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:40:24 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:40:24 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:40:24 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESU2-CME for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESZ2-CME for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESH3-CME for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESM3-CME for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:40:24 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:40:24 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-11 13:40:24 ESU2-CME | 2015-01-11 13:40:24 ESZ2-CME | 2015-01-11 13:40:24 ESH3-CME | 2015-01-11 13:40:24 ESM3-CME | 2015-01-11 13:40:24 ESU3-CME | 2015-01-11 13:40:24 ESZ3-CME | 2015-01-11 13:40:24 ESH4-CME | 2015-01-11 13:40:24 ESM4-CME | 2015-01-11 13:40:24 ESU4-CME | 2015-01-11 13:40:24 ESZ4-CME | 2015-01-11 13:40:24 ESH5-CME | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9 | Waiting for historical downloads to complete with the IDs: 22, 23, 24, 25, | 2015-01-11 13:40:24 HD Request # 23 | Downloading Intraday chart data for ESU2-CME to the file ESU2-CME.scid. Service: ddf | 2015-01-11 13:40:24 Compressing file: C:\SierraChart\Data\ESU2-CME.scid. This may take a while. | 2015-01-11 13:40:24 HD Request # 23 | Download start Date-Time: 2012-06-04 20:00:00.0 | 2015-01-11 13:40:24 HD Request # 23 | Requesting historical Intraday Minute data for ESU2-CME starting at 2012-06-04 20:00:00 (Exchange time). | 2015-01-11 13:40:24 HD Request # 23 | Error downloading historical Intraday data for ESU2-CME. Error executing query: Invalid symbol | 2015-01-11 13:40:24 * HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU2-CME | 2015-01-11 13:40:24 HD Request # 23 | Intraday download COMPLETE for ESU2-CME. Completion time: 0s. Unique request ID: 22 | 2015-01-11 13:40:24 Removed historical data download ID 22 | 2015-01-11 13:40:24 Real-time Intraday chart data file updates started for ESU2-CME | 2015-01-11 13:40:24 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:40:24 HD Request # 24 | Downloading Intraday chart data for ESZ2-CME to the file ESZ2-CME.scid. Service: ddf | 2015-01-11 13:40:24 Compressing file: C:\SierraChart\Data\ESZ2-CME.scid. This may take a while. | 2015-01-11 13:40:24 HD Request # 24 | Download start Date-Time: 2012-09-10 20:00:00.0 | 2015-01-11 13:40:24 HD Request # 24 | Requesting historical Intraday Minute data for ESZ2-CME starting at 2012-09-10 20:00:00 (Exchange time). | 2015-01-11 13:40:24 HD Request # 24 | Error downloading historical Intraday data for ESZ2-CME. Error executing query: Invalid symbol | 2015-01-11 13:40:24 * HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ2-CME | 2015-01-11 13:40:24 HD Request # 24 | Intraday download COMPLETE for ESZ2-CME. Completion time: 0s. Unique request ID: 23 | 2015-01-11 13:40:24 Removed historical data download ID 23 | 2015-01-11 13:40:24 Real-time Intraday chart data file updates started for ESZ2-CME | 2015-01-11 13:40:24 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:40:24 HD Request # 25 | Downloading Intraday chart data for ESH3-CME to the file ESH3-CME.scid. Service: ddf | 2015-01-11 13:40:24 Compressing file: C:\SierraChart\Data\ESH3-CME.scid. This may take a while. | 2015-01-11 13:40:24 HD Request # 25 | Download start Date-Time: 2012-12-10 19:00:00.0 | 2015-01-11 13:40:24 HD Request # 25 | Requesting historical Intraday Minute data for ESH3-CME starting at 2012-12-10 19:00:00 (Exchange time). | 2015-01-11 13:40:24 HD Request # 25 | Error downloading historical Intraday data for ESH3-CME. Error executing query: Invalid symbol | 2015-01-11 13:40:24 * HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH3-CME | 2015-01-11 13:40:24 HD Request # 25 | Intraday download COMPLETE for ESH3-CME. Completion time: 0s. Unique request ID: 24 | 2015-01-11 13:40:24 Removed historical data download ID 24 | 2015-01-11 13:40:24 Real-time Intraday chart data file updates started for ESH3-CME | 2015-01-11 13:40:24 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:40:24 HD Request # 26 | Downloading Intraday chart data for ESM3-CME to the file ESM3-CME.scid. Service: ddf | 2015-01-11 13:40:24 Compressing file: C:\SierraChart\Data\ESM3-CME.scid. This may take a while. | 2015-01-11 13:40:24 HD Request # 26 | Download start Date-Time: 2013-03-04 19:00:00.0 | 2015-01-11 13:40:24 HD Request # 26 | Requesting historical Intraday Minute data for ESM3-CME starting at 2013-03-04 19:00:00 (Exchange time). | 2015-01-11 13:40:24 HD Request # 26 | Error downloading historical Intraday data for ESM3-CME. Error executing query: Invalid symbol | 2015-01-11 13:40:24 * HD Request # 26 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM3-CME | 2015-01-11 13:40:24 HD Request # 26 | Intraday download COMPLETE for ESM3-CME. Completion time: 0s. Unique request ID: 25 | 2015-01-11 13:40:24 Removed historical data download ID 25 | 2015-01-11 13:40:24 Real-time Intraday chart data file updates started for ESM3-CME | 2015-01-11 13:40:24 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Download is complete for all contract months in chart. Proceeding with data load. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU2-CME Open price on 2012-09-13 is 1438.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ2-CME Open price on 2012-09-13 is 1431.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU2-CME price difference to ESZ2-CME is -6.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ2-CME Open price on 2012-12-13 is 1425.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESH3-CME Open price on 2012-12-13 is 1419.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ2-CME price difference to ESH3-CME is -6. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESH3-CME Open price on 2013-03-07 is 1539.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESM3-CME Open price on 2013-03-07 is 1535. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESH3-CME price difference to ESM3-CME is -4.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU3-CME Open price on 2013-06-13 is 1605. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESM3-CME price difference to ESU3-CME is -5.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU3-CME price difference to ESZ3-CME is -6.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ3-CME price difference to ESH4-CME is -6.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU2-CME is -64.75. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ2-CME is -58. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESH3-CME is -52. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESM3-CME is -47.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU3-CME is -41.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ3-CME is -35. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESH4-CME is -28.5. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:40:24 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:40:24 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH5-CME.scid | 2015-01-11 13:40:25 HD Request # 27 | Downloading Historical Daily chart data for ESU12. Starting date: 2012-09-20. Service: ddf | 2015-01-11 13:44:01 HD Request # 27 | Requesting historical Daily data for ESU12 starting at 2012-09-19 | 2015-01-11 13:44:01 HD Request # 27 | Receiving historical Daily data for ESU12 starting at 2012-09-19 | 2015-01-11 13:44:01 Writing historical Daily data for ESU12 to the file ESU12.dly | 2015-01-11 13:44:01 HD Request # 27 | Received 3 records from 2012-09-19 00:00:00 to 2012-09-21 00:00:00 (3.0 days) and wrote 2 records for ESU12 | 2015-01-11 13:44:01 HD Request # 27 | Daily download COMPLETE for ESU12. Completion time: 0s. Unique request ID: 26 | 2015-01-11 13:44:01 Removed historical data download ID 26 | 2015-01-11 13:44:01 HD Request # 28 | Downloading Historical Daily chart data for ESZ12. Starting date: 2012-12-20. Service: ddf | 2015-01-11 13:44:05 HD Request # 28 | Requesting historical Daily data for ESZ12 starting at 2012-12-19 | 2015-01-11 13:44:05 HD Request # 28 | Receiving historical Daily data for ESZ12 starting at 2012-12-19 | 2015-01-11 13:44:05 Writing historical Daily data for ESZ12 to the file ESZ12.dly | 2015-01-11 13:44:05 HD Request # 28 | Received 3 records from 2012-12-19 00:00:00 to 2012-12-21 00:00:00 (3.0 days) and wrote 2 records for ESZ12 | 2015-01-11 13:44:05 HD Request # 28 | Daily download COMPLETE for ESZ12. Completion time: 0s. Unique request ID: 27 | 2015-01-11 13:44:05 Removed historical data download ID 27 | 2015-01-11 13:44:05 HD Request # 29 | Downloading Historical Daily chart data for ESH13. Starting date: 2013-03-14. Service: ddf | 2015-01-11 13:44:06 HD Request # 29 | Requesting historical Daily data for ESH13 starting at 2013-03-13 | 2015-01-11 13:44:06 HD Request # 29 | Receiving historical Daily data for ESH13 starting at 2013-03-13 | 2015-01-11 13:44:06 Writing historical Daily data for ESH13 to the file ESH13.dly | 2015-01-11 13:44:06 HD Request # 29 | Received 3 records from 2013-03-13 00:00:00 to 2013-03-15 00:00:00 (3.0 days) and wrote 2 records for ESH13 | 2015-01-11 13:44:06 HD Request # 29 | Daily download COMPLETE for ESH13. Completion time: 0s. Unique request ID: 28 | 2015-01-11 13:44:06 Removed historical data download ID 28 | 2015-01-11 13:44:06 HD Request # 30 | Downloading Historical Daily chart data for ESM13. Starting date: 2013-06-20. Service: ddf | 2015-01-11 13:44:06 HD Request # 30 | Requesting historical Daily data for ESM13 starting at 2013-06-19 | 2015-01-11 13:44:06 HD Request # 30 | Receiving historical Daily data for ESM13 starting at 2013-06-19 | 2015-01-11 13:44:06 Writing historical Daily data for ESM13 to the file ESM13.dly | 2015-01-11 13:44:06 HD Request # 30 | Received 3 records from 2013-06-19 00:00:00 to 2013-06-21 00:00:00 (3.0 days) and wrote 2 records for ESM13 | 2015-01-11 13:44:06 HD Request # 30 | Daily download COMPLETE for ESM13. Completion time: 0s. Unique request ID: 29 | 2015-01-11 13:44:06 Removed historical data download ID 29 | 2015-01-11 13:44:06 HD Request # 31 | Downloading Historical Daily chart data for ESU13. Starting date: 2013-09-19. Service: ddf | 2015-01-11 13:44:07 HD Request # 31 | Requesting historical Daily data for ESU13 starting at 2013-09-18 | 2015-01-11 13:44:07 HD Request # 31 | Receiving historical Daily data for ESU13 starting at 2013-09-18 | 2015-01-11 13:44:07 Writing historical Daily data for ESU13 to the file ESU13.dly | 2015-01-11 13:44:07 HD Request # 31 | Received 3 records from 2013-09-18 00:00:00 to 2013-09-20 00:00:00 (3.0 days) and wrote 2 records for ESU13 | 2015-01-11 13:44:07 HD Request # 31 | Daily download COMPLETE for ESU13. Completion time: 0s. Unique request ID: 30 | 2015-01-11 13:44:07 Removed historical data download ID 30 | 2015-01-11 13:44:07 HD Request # 32 | Downloading Historical Daily chart data for ESZ13. Starting date: 2013-12-19. Service: ddf | 2015-01-11 13:44:07 HD Request # 32 | Requesting historical Daily data for ESZ13 starting at 2013-12-18 | 2015-01-11 13:44:07 HD Request # 32 | Receiving historical Daily data for ESZ13 starting at 2013-12-18 | 2015-01-11 13:44:07 Writing historical Daily data for ESZ13 to the file ESZ13.dly | 2015-01-11 13:44:07 HD Request # 32 | Received 3 records from 2013-12-18 00:00:00 to 2013-12-20 00:00:00 (3.0 days) and wrote 2 records for ESZ13 | 2015-01-11 13:44:07 HD Request # 32 | Daily download COMPLETE for ESZ13. Completion time: 0s. Unique request ID: 31 | 2015-01-11 13:44:07 Removed historical data download ID 31 | 2015-01-11 13:44:07 HD Request # 33 | Downloading Historical Daily chart data for ESH14. Starting date: 2014-03-20. Service: ddf | 2015-01-11 13:44:08 HD Request # 33 | Requesting historical Daily data for ESH14 starting at 2014-03-19 | 2015-01-11 13:44:08 HD Request # 33 | Receiving historical Daily data for ESH14 starting at 2014-03-19 | 2015-01-11 13:44:08 Writing historical Daily data for ESH14 to the file ESH14.dly | 2015-01-11 13:44:08 HD Request # 33 | Received 3 records from 2014-03-19 00:00:00 to 2014-03-21 00:00:00 (3.0 days) and wrote 2 records for ESH14 | 2015-01-11 13:44:08 HD Request # 33 | Daily download COMPLETE for ESH14. Completion time: 0s. Unique request ID: 32 | 2015-01-11 13:44:08 Removed historical data download ID 32 | 2015-01-11 13:44:08 HD Request # 34 | Downloading Historical Daily chart data for ESM14. Starting date: 2014-06-19. Service: ddf | 2015-01-11 13:44:09 HD Request # 34 | Requesting historical Daily data for ESM14 starting at 2014-06-18 | 2015-01-11 13:44:09 HD Request # 34 | Receiving historical Daily data for ESM14 starting at 2014-06-18 | 2015-01-11 13:44:09 Writing historical Daily data for ESM14 to the file ESM14.dly | 2015-01-11 13:44:09 HD Request # 34 | Received 3 records from 2014-06-18 00:00:00 to 2014-06-20 00:00:00 (3.0 days) and wrote 2 records for ESM14 | 2015-01-11 13:44:09 HD Request # 34 | Daily download COMPLETE for ESM14. Completion time: 0s. Unique request ID: 33 | 2015-01-11 13:44:09 Removed historical data download ID 33 | 2015-01-11 13:44:09 HD Request # 35 | Downloading Historical Daily chart data for ESU14. Starting date: 2014-09-18. Service: ddf | 2015-01-11 13:44:09 HD Request # 35 | Requesting historical Daily data for ESU14 starting at 2014-09-17 | 2015-01-11 13:44:09 HD Request # 35 | Receiving historical Daily data for ESU14 starting at 2014-09-17 | 2015-01-11 13:44:09 Writing historical Daily data for ESU14 to the file ESU14.dly | 2015-01-11 13:44:10 HD Request # 35 | Received 3 records from 2014-09-17 00:00:00 to 2014-09-19 00:00:00 (3.0 days) and wrote 2 records for ESU14 | 2015-01-11 13:44:10 HD Request # 35 | Daily download COMPLETE for ESU14. Completion time: 1s. Unique request ID: 34 | 2015-01-11 13:44:10 Removed historical data download ID 34 | 2015-01-11 13:44:10 HD Request # 36 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-12-18. Service: ddf | 2015-01-11 13:44:10 HD Request # 36 | Requesting historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:44:10 HD Request # 36 | Receiving historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:44:10 Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2015-01-11 13:44:10 HD Request # 36 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-19 00:00:00 (3.0 days) and wrote 2 records for ESZ14 | 2015-01-11 13:44:10 HD Request # 36 | Daily download COMPLETE for ESZ14. Completion time: 0s. Unique request ID: 35 | 2015-01-11 13:44:10 Removed historical data download ID 35 | 2015-01-11 13:44:10 HD Request # 37 | Downloading Historical Daily chart data for ESH15. Starting date: 2015-01-08. Service: ddf | 2015-01-11 13:44:11 HD Request # 37 | Requesting historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:44:11 HD Request # 37 | Receiving historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:44:11 Writing historical Daily data for ESH15 to the file ESH15.dly | 2015-01-11 13:44:11 HD Request # 37 | Received 3 records from 2015-01-07 00:00:00 to 2015-01-09 00:00:00 (3.0 days) and wrote 2 records for ESH15 | 2015-01-11 13:44:11 HD Request # 37 | Daily download COMPLETE for ESH15. Completion time: 0s. Unique request ID: 36 | 2015-01-11 13:44:11 Removed historical data download ID 36 | 2015-01-11 13:44:11 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:44:11 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:44:11 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:44:11 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:44:11 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5 | Symbols used for continuous contract chart: | 2015-01-11 13:44:11 ESH14 | 2015-01-11 13:44:11 ESM14 | 2015-01-11 13:44:11 ESU14 | 2015-01-11 13:44:11 ESZ14 | 2015-01-11 13:44:11 ESH15 | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Download is complete for all contract months in chart. Proceeding with data load. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU2-CME Open price on 2012-09-13 is 1438.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ2-CME Open price on 2012-09-13 is 1431.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU2-CME price difference to ESZ2-CME is -6.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ2-CME Open price on 2012-12-13 is 1425.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESH3-CME Open price on 2012-12-13 is 1419.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ2-CME price difference to ESH3-CME is -6. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESH3-CME Open price on 2013-03-07 is 1539.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESM3-CME Open price on 2013-03-07 is 1535. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESH3-CME price difference to ESM3-CME is -4.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU3-CME Open price on 2013-06-13 is 1605. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESM3-CME price difference to ESU3-CME is -5.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU3-CME price difference to ESZ3-CME is -6.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ3-CME price difference to ESH4-CME is -6.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU2-CME is -64.75. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ2-CME is -58. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESH3-CME is -52. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESM3-CME is -47.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU3-CME is -41.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ3-CME is -35. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESH4-CME is -28.5. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:44:11 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:44:11 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:44:11 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:44:11 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:44:11 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:44:11 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:44:11 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:44:11 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:44:11 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:44:11 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:44:11 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:44:11 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:44:11 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:44:11 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:44:11 ESH15/ESH5-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-01-11 13:44:11 ESH12 | 2015-01-11 13:44:11 ESM12 | 2015-01-11 13:44:11 ESU12 | 2015-01-11 13:44:11 ESZ12 | 2015-01-11 13:44:11 ESH13 | 2015-01-11 13:44:11 ESM13 | 2015-01-11 13:44:11 ESU13 | 2015-01-11 13:44:11 ESZ13 | 2015-01-11 13:44:11 ESH14 | 2015-01-11 13:44:11 ESM14 | 2015-01-11 13:44:11 ESU14 | 2015-01-11 13:44:11 ESZ14 | 2015-01-11 13:44:11 ESH15 | 2015-01-11 13:44:11 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH5-CME.scid | 2015-01-11 13:44:11 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:44:11 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:44:11 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:44:11 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:44:11 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:44:11 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:44:11 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:44:11 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:44:11 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:44:11 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:44:11 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6 | Symbols used for continuous contract chart: | 2015-01-11 13:44:11 ESU12 | 2015-01-11 13:44:11 ESZ12 | 2015-01-11 13:44:11 ESH13 | 2015-01-11 13:44:11 ESM13 | 2015-01-11 13:44:11 ESU13 | 2015-01-11 13:44:11 ESZ13 | 2015-01-11 13:44:11 ESH14 | 2015-01-11 13:44:11 ESM14 | 2015-01-11 13:44:11 ESU14 | 2015-01-11 13:44:11 ESZ14 | 2015-01-11 13:44:11 ESH15 | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU12 Open price on 2012-09-13 is 1438.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ12 Open price on 2012-09-13 is 1431.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU12 price difference to ESZ12 is -6.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ12 Open price on 2012-12-13 is 1425.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESH13 Open price on 2012-12-13 is 1419.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ12 price difference to ESH13 is -6. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESH13 Open price on 2013-03-07 is 1539.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESM13 Open price on 2013-03-07 is 1535. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESH13 price difference to ESM13 is -4.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESM13 Open price on 2013-06-13 is 1610.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU13 Open price on 2013-06-13 is 1605. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESM13 price difference to ESU13 is -5.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU13 Open price on 2013-09-12 is 1689.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ13 Open price on 2013-09-12 is 1683.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU13 price difference to ESZ13 is -6.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ13 Open price on 2013-12-12 is 1780.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESH14 Open price on 2013-12-12 is 1774.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ13 price difference to ESH14 is -6.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU12 is -64.75. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ12 is -58. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESH13 is -52. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESM13 is -47.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU13 is -41.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ13 is -35. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:44:11 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:44:11 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:44:11 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:44:11 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:44:11 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:44:11 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:44:11 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11 | Symbols used for continuous contract chart: | 2015-01-11 13:44:11 ESH14 | 2015-01-11 13:44:11 ESM14 | 2015-01-11 13:44:11 ESU14 | 2015-01-11 13:44:11 ESZ14 | 2015-01-11 13:44:11 ESH15 | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:44:11 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:44:11 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$TICK.scid | 2015-01-11 13:46:15 SC Historical Data | Starting real-time market data updates for: $TICK. ID: 23 | 2015-01-11 13:46:16 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: $TICK | 2015-01-11 13:46:16 Intraday data recording state for symbol $TICK is set to download pending. | 2015-01-11 13:46:16 HD Request # 38 | Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2015-01-11 13:46:16 Compressing file: C:\SierraChart\Data\$TICK.scid. This may take a while. | 2015-01-11 13:46:16 HD Request # 38 | Download start Date-Time: 2012-07-31 14:46:16.0 | 2015-01-11 13:46:16 HD Request # 38 | Requesting historical Intraday Minute data for $TICK starting at 2012-07-31 14:46:16 (Exchange time). | 2015-01-11 13:46:16 HD Request # 38 | Receiving Intraday data for $TICK starting at 2012-07-31 14:47:00 | 2015-01-11 13:46:16 HD Request # 38 | Timestamp of first Intraday data file record written: 2012-07-31 14:47:00 | 2015-01-11 13:46:16 Chart #10 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:46:18 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:46:18 HD Request # 38 | Received 242491 records from 2012-07-31 14:47:00 to 2015-01-09 16:04:00 (2.4 years) and wrote 242491 records for $TICK | 2015-01-11 13:46:22 HD Request # 38 | Intraday download COMPLETE for $TICK. Completion time: 6s. Unique request ID: 37 | 2015-01-11 13:46:22 Removed historical data download ID 37 | 2015-01-11 13:46:22 Real-time Intraday chart data file updates started for $TICK | 2015-01-11 13:46:22 Chart #10 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:46:23 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:46:23 Chart #10 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:46:25 Chart #10 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:46:25 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:46:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\$NSHF.scid | 2015-01-11 13:48:10 SC Historical Data | Starting real-time market data updates for: $NSHF. ID: 24 | 2015-01-11 13:48:10 SC Historical Data | Subscribing to market data in the service client is not supported. Symbol: $NSHF | 2015-01-11 13:48:10 Intraday data recording state for symbol $NSHF is set to download pending. | 2015-01-11 13:48:10 HD Request # 39 | Downloading Intraday chart data for $NSHF to the file $NSHF.scid. Service: ddf | 2015-01-11 13:48:10 Compressing file: C:\SierraChart\Data\$NSHF.scid. This may take a while. | 2015-01-11 13:48:10 HD Request # 39 | Download start Date-Time: 2012-07-31 14:48:10.0 | 2015-01-11 13:48:10 HD Request # 39 | Requesting historical Intraday Minute data for $NSHF starting at 2012-07-31 14:48:10 (Exchange time). | 2015-01-11 13:48:10 HD Request # 39 | Receiving Intraday data for $NSHF starting at 2012-07-31 14:49:00 | 2015-01-11 13:48:11 HD Request # 39 | Timestamp of first Intraday data file record written: 2012-07-31 14:49:00 | 2015-01-11 13:48:11 Chart #7 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:48:12 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:48:12 HD Request # 39 | Received 270567 records from 2012-07-31 14:49:00 to 2015-01-09 19:50:00 (2.4 years) and wrote 270567 records for $NSHF | 2015-01-11 13:48:15 HD Request # 39 | Intraday download COMPLETE for $NSHF. Completion time: 5s. Unique request ID: 38 | 2015-01-11 13:48:15 Removed historical data download ID 38 | 2015-01-11 13:48:15 Real-time Intraday chart data file updates started for $NSHF | 2015-01-11 13:48:15 Chart #7 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:48:15 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:48:15 Chart #7 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:48:19 Chart #7 has tagged chart #17 for full recalculation. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:48:19 Chart #17 is performing a full recalculation because it has been tagged. Chartbook: HxTaylorTransformational.cht | 2015-01-11 13:48:20 Date rule based rollover from ESU2-CME to next contract occurs at 2012-09-13. | 2015-01-11 13:49:30 Date rule based rollover from ESZ2-CME to next contract occurs at 2012-12-13. | 2015-01-11 13:49:30 Date rule based rollover from ESH3-CME to next contract occurs at 2013-03-07. | 2015-01-11 13:49:30 Date rule based rollover from ESM3-CME to next contract occurs at 2013-06-13. | 2015-01-11 13:49:30 Date rule based rollover from ESU3-CME to next contract occurs at 2013-09-12. | 2015-01-11 13:49:30 Date rule based rollover from ESZ3-CME to next contract occurs at 2013-12-12. | 2015-01-11 13:49:30 Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-01-11 13:49:30 Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-11 13:49:30 Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-11 13:49:30 Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-11 13:49:30 Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-11 13:49:30 Intraday data file for ESU2-CME exists and is empty. Skipping Intraday data download. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:49:30 Intraday data file for ESZ2-CME exists and is empty. Skipping Intraday data download. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:49:30 Intraday data file for ESH3-CME exists and is empty. Skipping Intraday data download. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:49:30 Intraday data file for ESM3-CME exists and is empty. Skipping Intraday data download. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:49:30 Checking Intraday data file for symbol ESU3-CME for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:49:30 Checking Intraday data file for symbol ESZ3-CME for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:49:30 Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:49:30 Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:49:30 Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:49:30 Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:49:30 Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-11 13:49:30 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17 | Symbols used for continuous contract chart: | 2015-01-11 13:49:30 ESU2-CME | 2015-01-11 13:49:30 ESZ2-CME | 2015-01-11 13:49:30 ESH3-CME | 2015-01-11 13:49:30 ESM3-CME | 2015-01-11 13:49:30 ESU3-CME | 2015-01-11 13:49:30 ESZ3-CME | 2015-01-11 13:49:30 ESH4-CME | 2015-01-11 13:49:30 ESM4-CME | 2015-01-11 13:49:30 ESU4-CME | 2015-01-11 13:49:30 ESZ4-CME | 2015-01-11 13:49:30 ESH5-CME | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU2-CME Open price on 2012-09-13 is 1438.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ2-CME Open price on 2012-09-13 is 1431.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU2-CME price difference to ESZ2-CME is -6.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ2-CME Open price on 2012-12-13 is 1425.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESH3-CME Open price on 2012-12-13 is 1419.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ2-CME price difference to ESH3-CME is -6. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESH3-CME Open price on 2013-03-07 is 1539.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESM3-CME Open price on 2013-03-07 is 1535. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESH3-CME price difference to ESM3-CME is -4.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU3-CME Open price on 2013-06-13 is 1605. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESM3-CME price difference to ESU3-CME is -5.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU3-CME price difference to ESZ3-CME is -6.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ3-CME price difference to ESH4-CME is -6.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESU2-CME is -64.75. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESZ2-CME is -58. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESH3-CME is -52. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESM3-CME is -47.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESU3-CME is -41.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESZ3-CME is -35. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESH4-CME is -28.5. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:49:30 ESH5-CME [CB] 1 Min #17: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:49:30 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH5-CME.scid | 2015-01-11 13:49:30 Intraday data recording state for symbol ESU2-CME is set to download pending. | 2015-01-11 13:55:28 Reloading all charts with filename: ESU2-CME.scid | 2015-01-11 13:55:28 HD Request # 40 | Downloading Intraday chart data for ESU2-CME to the file ESU2-CME.scid. Service: ddf | 2015-01-11 13:55:28 HD Request # 40 | Download start Date-Time: 2012-06-04 20:00:00.0 | 2015-01-11 13:55:28 HD Request # 40 | Requesting historical Intraday Minute data for ESU2-CME starting at 2012-06-04 20:00:00 (Exchange time). | 2015-01-11 13:55:28 HD Request # 40 | Error downloading historical Intraday data for ESU2-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:29 * HD Request # 40 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU2-CME | 2015-01-11 13:55:29 HD Request # 40 | Intraday download COMPLETE for ESU2-CME. Completion time: 1s. Unique request ID: 39 | 2015-01-11 13:55:29 Removed historical data download ID 39 | 2015-01-11 13:55:29 Real-time Intraday chart data file updates started for ESU2-CME | 2015-01-11 13:55:29 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:29 HD Request # 41 | Downloading Historical Daily chart data for ESU12. Starting date: 2012-09-20. Service: ddf | 2015-01-11 13:55:29 HD Request # 41 | Requesting historical Daily data for ESU12 starting at 2012-09-19 | 2015-01-11 13:55:29 HD Request # 41 | Receiving historical Daily data for ESU12 starting at 2012-09-19 | 2015-01-11 13:55:29 Writing historical Daily data for ESU12 to the file ESU12.dly | 2015-01-11 13:55:29 HD Request # 41 | Received 3 records from 2012-09-19 00:00:00 to 2012-09-21 00:00:00 (3.0 days) and wrote 2 records for ESU12 | 2015-01-11 13:55:29 HD Request # 41 | Daily download COMPLETE for ESU12. Completion time: 0s. Unique request ID: 40 | 2015-01-11 13:55:29 Removed historical data download ID 40 | 2015-01-11 13:55:29 Intraday data recording state for symbol ESZ2-CME is set to download pending. | 2015-01-11 13:55:30 Reloading all charts with filename: ESZ2-CME.scid | 2015-01-11 13:55:30 HD Request # 42 | Downloading Intraday chart data for ESZ2-CME to the file ESZ2-CME.scid. Service: ddf | 2015-01-11 13:55:30 HD Request # 42 | Download start Date-Time: 2012-09-10 20:00:00.0 | 2015-01-11 13:55:30 HD Request # 42 | Requesting historical Intraday Minute data for ESZ2-CME starting at 2012-09-10 20:00:00 (Exchange time). | 2015-01-11 13:55:30 HD Request # 42 | Error downloading historical Intraday data for ESZ2-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:30 * HD Request # 42 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ2-CME | 2015-01-11 13:55:30 HD Request # 42 | Intraday download COMPLETE for ESZ2-CME. Completion time: 0s. Unique request ID: 41 | 2015-01-11 13:55:30 Removed historical data download ID 41 | 2015-01-11 13:55:30 Real-time Intraday chart data file updates started for ESZ2-CME | 2015-01-11 13:55:30 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:30 HD Request # 43 | Downloading Historical Daily chart data for ESZ12. Starting date: 2012-12-20. Service: ddf | 2015-01-11 13:55:30 HD Request # 43 | Requesting historical Daily data for ESZ12 starting at 2012-12-19 | 2015-01-11 13:55:30 HD Request # 43 | Receiving historical Daily data for ESZ12 starting at 2012-12-19 | 2015-01-11 13:55:30 Writing historical Daily data for ESZ12 to the file ESZ12.dly | 2015-01-11 13:55:30 HD Request # 43 | Received 3 records from 2012-12-19 00:00:00 to 2012-12-21 00:00:00 (3.0 days) and wrote 2 records for ESZ12 | 2015-01-11 13:55:30 HD Request # 43 | Daily download COMPLETE for ESZ12. Completion time: 0s. Unique request ID: 42 | 2015-01-11 13:55:30 Removed historical data download ID 42 | 2015-01-11 13:55:30 Intraday data recording state for symbol ESH3-CME is set to download pending. | 2015-01-11 13:55:31 Reloading all charts with filename: ESH3-CME.scid | 2015-01-11 13:55:31 HD Request # 44 | Downloading Intraday chart data for ESH3-CME to the file ESH3-CME.scid. Service: ddf | 2015-01-11 13:55:31 HD Request # 44 | Download start Date-Time: 2012-12-10 19:00:00.0 | 2015-01-11 13:55:31 HD Request # 44 | Requesting historical Intraday Minute data for ESH3-CME starting at 2012-12-10 19:00:00 (Exchange time). | 2015-01-11 13:55:31 HD Request # 44 | Error downloading historical Intraday data for ESH3-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:31 * HD Request # 44 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH3-CME | 2015-01-11 13:55:31 HD Request # 44 | Intraday download COMPLETE for ESH3-CME. Completion time: 0s. Unique request ID: 43 | 2015-01-11 13:55:31 Removed historical data download ID 43 | 2015-01-11 13:55:31 Real-time Intraday chart data file updates started for ESH3-CME | 2015-01-11 13:55:31 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:31 HD Request # 45 | Downloading Historical Daily chart data for ESH13. Starting date: 2013-03-14. Service: ddf | 2015-01-11 13:55:31 HD Request # 45 | Requesting historical Daily data for ESH13 starting at 2013-03-13 | 2015-01-11 13:55:31 HD Request # 45 | Receiving historical Daily data for ESH13 starting at 2013-03-13 | 2015-01-11 13:55:31 Writing historical Daily data for ESH13 to the file ESH13.dly | 2015-01-11 13:55:31 HD Request # 45 | Received 3 records from 2013-03-13 00:00:00 to 2013-03-15 00:00:00 (3.0 days) and wrote 2 records for ESH13 | 2015-01-11 13:55:31 HD Request # 45 | Daily download COMPLETE for ESH13. Completion time: 0s. Unique request ID: 44 | 2015-01-11 13:55:31 Removed historical data download ID 44 | 2015-01-11 13:55:31 Intraday data recording state for symbol ESM3-CME is set to download pending. | 2015-01-11 13:55:32 Reloading all charts with filename: ESM3-CME.scid | 2015-01-11 13:55:32 HD Request # 46 | Downloading Intraday chart data for ESM3-CME to the file ESM3-CME.scid. Service: ddf | 2015-01-11 13:55:32 HD Request # 46 | Download start Date-Time: 2013-03-04 19:00:00.0 | 2015-01-11 13:55:32 HD Request # 46 | Requesting historical Intraday Minute data for ESM3-CME starting at 2013-03-04 19:00:00 (Exchange time). | 2015-01-11 13:55:32 HD Request # 46 | Error downloading historical Intraday data for ESM3-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:32 * HD Request # 46 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM3-CME | 2015-01-11 13:55:32 HD Request # 46 | Intraday download COMPLETE for ESM3-CME. Completion time: 0s. Unique request ID: 45 | 2015-01-11 13:55:32 Removed historical data download ID 45 | 2015-01-11 13:55:32 Real-time Intraday chart data file updates started for ESM3-CME | 2015-01-11 13:55:32 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:32 HD Request # 47 | Downloading Historical Daily chart data for ESM13. Starting date: 2013-06-20. Service: ddf | 2015-01-11 13:55:32 HD Request # 47 | Requesting historical Daily data for ESM13 starting at 2013-06-19 | 2015-01-11 13:55:32 HD Request # 47 | Receiving historical Daily data for ESM13 starting at 2013-06-19 | 2015-01-11 13:55:32 Writing historical Daily data for ESM13 to the file ESM13.dly | 2015-01-11 13:55:32 HD Request # 47 | Received 3 records from 2013-06-19 00:00:00 to 2013-06-21 00:00:00 (3.0 days) and wrote 2 records for ESM13 | 2015-01-11 13:55:32 HD Request # 47 | Daily download COMPLETE for ESM13. Completion time: 0s. Unique request ID: 46 | 2015-01-11 13:55:32 Removed historical data download ID 46 | 2015-01-11 13:55:32 Reloading all charts with filename: ESU3-CME.scid | 2015-01-11 13:55:33 HD Request # 48 | Downloading Intraday chart data for ESU3-CME to the file ESU3-CME.scid. Service: ddf | 2015-01-11 13:55:33 HD Request # 48 | Download start Date-Time: 2013-06-10 20:00:00.0 | 2015-01-11 13:55:33 HD Request # 48 | Requesting historical Intraday Minute data for ESU3-CME starting at 2013-06-10 20:00:00 (Exchange time). | 2015-01-11 13:55:33 HD Request # 48 | Error downloading historical Intraday data for ESU3-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:33 * HD Request # 48 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU3-CME | 2015-01-11 13:55:33 HD Request # 48 | Intraday download COMPLETE for ESU3-CME. Completion time: 0s. Unique request ID: 47 | 2015-01-11 13:55:33 Removed historical data download ID 47 | 2015-01-11 13:55:33 Real-time Intraday chart data file updates started for ESU3-CME | 2015-01-11 13:55:33 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:33 HD Request # 49 | Downloading Historical Daily chart data for ESU13. Starting date: 2013-09-19. Service: ddf | 2015-01-11 13:55:33 HD Request # 49 | Requesting historical Daily data for ESU13 starting at 2013-09-18 | 2015-01-11 13:55:33 HD Request # 49 | Receiving historical Daily data for ESU13 starting at 2013-09-18 | 2015-01-11 13:55:33 Writing historical Daily data for ESU13 to the file ESU13.dly | 2015-01-11 13:55:33 HD Request # 49 | Received 3 records from 2013-09-18 00:00:00 to 2013-09-20 00:00:00 (3.0 days) and wrote 2 records for ESU13 | 2015-01-11 13:55:33 HD Request # 49 | Daily download COMPLETE for ESU13. Completion time: 0s. Unique request ID: 48 | 2015-01-11 13:55:33 Removed historical data download ID 48 | 2015-01-11 13:55:33 Reloading all charts with filename: ESZ3-CME.scid | 2015-01-11 13:55:34 HD Request # 50 | Downloading Intraday chart data for ESZ3-CME to the file ESZ3-CME.scid. Service: ddf | 2015-01-11 13:55:34 HD Request # 50 | Download start Date-Time: 2013-09-09 20:00:00.0 | 2015-01-11 13:55:34 HD Request # 50 | Requesting historical Intraday Minute data for ESZ3-CME starting at 2013-09-09 20:00:00 (Exchange time). | 2015-01-11 13:55:34 HD Request # 50 | Error downloading historical Intraday data for ESZ3-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:34 * HD Request # 50 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ3-CME | 2015-01-11 13:55:34 HD Request # 50 | Intraday download COMPLETE for ESZ3-CME. Completion time: 0s. Unique request ID: 49 | 2015-01-11 13:55:34 Removed historical data download ID 49 | 2015-01-11 13:55:34 Real-time Intraday chart data file updates started for ESZ3-CME | 2015-01-11 13:55:34 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:34 HD Request # 51 | Downloading Historical Daily chart data for ESZ13. Starting date: 2013-12-19. Service: ddf | 2015-01-11 13:55:34 HD Request # 51 | Requesting historical Daily data for ESZ13 starting at 2013-12-18 | 2015-01-11 13:55:34 HD Request # 51 | Receiving historical Daily data for ESZ13 starting at 2013-12-18 | 2015-01-11 13:55:34 Writing historical Daily data for ESZ13 to the file ESZ13.dly | 2015-01-11 13:55:34 HD Request # 51 | Received 3 records from 2013-12-18 00:00:00 to 2013-12-20 00:00:00 (3.0 days) and wrote 2 records for ESZ13 | 2015-01-11 13:55:34 HD Request # 51 | Daily download COMPLETE for ESZ13. Completion time: 0s. Unique request ID: 50 | 2015-01-11 13:55:34 Removed historical data download ID 50 | 2015-01-11 13:55:34 Reloading all charts with filename: ESH4-CME.scid | 2015-01-11 13:55:34 HD Request # 52 | Downloading Intraday chart data for ESH4-CME to the file ESH4-CME.scid. Service: ddf | 2015-01-11 13:55:34 HD Request # 52 | Download start Date-Time: 2013-12-09 19:00:00.0 | 2015-01-11 13:55:34 HD Request # 52 | Requesting historical Intraday Minute data for ESH4-CME starting at 2013-12-09 19:00:00 (Exchange time). | 2015-01-11 13:55:34 HD Request # 52 | Error downloading historical Intraday data for ESH4-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:34 * HD Request # 52 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4-CME | 2015-01-11 13:55:34 HD Request # 52 | Intraday download COMPLETE for ESH4-CME. Completion time: 0s. Unique request ID: 51 | 2015-01-11 13:55:34 Removed historical data download ID 51 | 2015-01-11 13:55:34 Real-time Intraday chart data file updates started for ESH4-CME | 2015-01-11 13:55:34 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:34 HD Request # 53 | Downloading Historical Daily chart data for ESH14. Starting date: 2014-03-20. Service: ddf | 2015-01-11 13:55:34 HD Request # 53 | Requesting historical Daily data for ESH14 starting at 2014-03-19 | 2015-01-11 13:55:34 HD Request # 53 | Receiving historical Daily data for ESH14 starting at 2014-03-19 | 2015-01-11 13:55:35 Writing historical Daily data for ESH14 to the file ESH14.dly | 2015-01-11 13:55:35 HD Request # 53 | Received 3 records from 2014-03-19 00:00:00 to 2014-03-21 00:00:00 (3.0 days) and wrote 2 records for ESH14 | 2015-01-11 13:55:35 HD Request # 53 | Daily download COMPLETE for ESH14. Completion time: 1s. Unique request ID: 52 | 2015-01-11 13:55:35 Removed historical data download ID 52 | 2015-01-11 13:55:35 Reloading all charts with filename: ESM4-CME.scid | 2015-01-11 13:55:35 HD Request # 54 | Downloading Intraday chart data for ESM4-CME to the file ESM4-CME.scid. Service: ddf | 2015-01-11 13:55:35 HD Request # 54 | Download start Date-Time: 2014-03-10 20:00:00.0 | 2015-01-11 13:55:35 HD Request # 54 | Requesting historical Intraday Minute data for ESM4-CME starting at 2014-03-10 20:00:00 (Exchange time). | 2015-01-11 13:55:35 HD Request # 54 | Error downloading historical Intraday data for ESM4-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:35 * HD Request # 54 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM4-CME | 2015-01-11 13:55:35 HD Request # 54 | Intraday download COMPLETE for ESM4-CME. Completion time: 0s. Unique request ID: 53 | 2015-01-11 13:55:35 Removed historical data download ID 53 | 2015-01-11 13:55:35 Real-time Intraday chart data file updates started for ESM4-CME | 2015-01-11 13:55:35 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:35 HD Request # 55 | Downloading Historical Daily chart data for ESM14. Starting date: 2014-06-19. Service: ddf | 2015-01-11 13:55:35 HD Request # 55 | Requesting historical Daily data for ESM14 starting at 2014-06-18 | 2015-01-11 13:55:35 HD Request # 55 | Receiving historical Daily data for ESM14 starting at 2014-06-18 | 2015-01-11 13:55:35 Writing historical Daily data for ESM14 to the file ESM14.dly | 2015-01-11 13:55:35 HD Request # 55 | Received 3 records from 2014-06-18 00:00:00 to 2014-06-20 00:00:00 (3.0 days) and wrote 2 records for ESM14 | 2015-01-11 13:55:35 HD Request # 55 | Daily download COMPLETE for ESM14. Completion time: 0s. Unique request ID: 54 | 2015-01-11 13:55:35 Removed historical data download ID 54 | 2015-01-11 13:55:35 Reloading all charts with filename: ESU4-CME.scid | 2015-01-11 13:55:36 HD Request # 56 | Downloading Intraday chart data for ESU4-CME to the file ESU4-CME.scid. Service: ddf | 2015-01-11 13:55:36 HD Request # 56 | Download start Date-Time: 2014-06-09 20:00:00.0 | 2015-01-11 13:55:36 HD Request # 56 | Requesting historical Intraday Minute data for ESU4-CME starting at 2014-06-09 20:00:00 (Exchange time). | 2015-01-11 13:55:36 HD Request # 56 | Error downloading historical Intraday data for ESU4-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:36 * HD Request # 56 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU4-CME | 2015-01-11 13:55:36 HD Request # 56 | Intraday download COMPLETE for ESU4-CME. Completion time: 0s. Unique request ID: 55 | 2015-01-11 13:55:36 Removed historical data download ID 55 | 2015-01-11 13:55:36 Real-time Intraday chart data file updates started for ESU4-CME | 2015-01-11 13:55:36 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:36 HD Request # 57 | Downloading Historical Daily chart data for ESU14. Starting date: 2014-09-18. Service: ddf | 2015-01-11 13:55:36 HD Request # 57 | Requesting historical Daily data for ESU14 starting at 2014-09-17 | 2015-01-11 13:55:36 HD Request # 57 | Receiving historical Daily data for ESU14 starting at 2014-09-17 | 2015-01-11 13:55:36 Writing historical Daily data for ESU14 to the file ESU14.dly | 2015-01-11 13:55:36 HD Request # 57 | Received 3 records from 2014-09-17 00:00:00 to 2014-09-19 00:00:00 (3.0 days) and wrote 2 records for ESU14 | 2015-01-11 13:55:36 HD Request # 57 | Daily download COMPLETE for ESU14. Completion time: 0s. Unique request ID: 56 | 2015-01-11 13:55:36 Removed historical data download ID 56 | 2015-01-11 13:55:36 Reloading all charts with filename: ESZ4-CME.scid | 2015-01-11 13:55:37 HD Request # 58 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: ddf | 2015-01-11 13:55:37 HD Request # 58 | Download start Date-Time: 2014-09-08 20:00:00.0 | 2015-01-11 13:55:37 HD Request # 58 | Requesting historical Intraday Minute data for ESZ4-CME starting at 2014-09-08 20:00:00 (Exchange time). | 2015-01-11 13:55:37 HD Request # 58 | Error downloading historical Intraday data for ESZ4-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:37 * HD Request # 58 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ4-CME | 2015-01-11 13:55:37 HD Request # 58 | Intraday download COMPLETE for ESZ4-CME. Completion time: 0s. Unique request ID: 57 | 2015-01-11 13:55:37 Removed historical data download ID 57 | 2015-01-11 13:55:37 Real-time Intraday chart data file updates started for ESZ4-CME | 2015-01-11 13:55:37 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:37 HD Request # 59 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-12-18. Service: ddf | 2015-01-11 13:55:37 HD Request # 59 | Requesting historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:55:37 HD Request # 59 | Receiving historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:55:37 Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2015-01-11 13:55:37 HD Request # 59 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-19 00:00:00 (3.0 days) and wrote 2 records for ESZ14 | 2015-01-11 13:55:37 HD Request # 59 | Daily download COMPLETE for ESZ14. Completion time: 0s. Unique request ID: 58 | 2015-01-11 13:55:37 Removed historical data download ID 58 | 2015-01-11 13:55:37 Intraday data recording state for symbol ESH5-CME is set to download pending. | 2015-01-11 13:55:38 HD Request # 60 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: ddf | 2015-01-11 13:55:38 HD Request # 60 | Download start Date-Time: 2014-12-08 19:00:00.0 | 2015-01-11 13:55:38 HD Request # 60 | Requesting historical Intraday Minute data for ESH5-CME starting at 2014-12-08 19:00:00 (Exchange time). | 2015-01-11 13:55:38 HD Request # 60 | Error downloading historical Intraday data for ESH5-CME. Error executing query: Invalid symbol | 2015-01-11 13:55:38 * HD Request # 60 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH5-CME | 2015-01-11 13:55:38 HD Request # 60 | Intraday download COMPLETE for ESH5-CME. Completion time: 0s. Unique request ID: 59 | 2015-01-11 13:55:38 Removed historical data download ID 59 | 2015-01-11 13:55:38 Real-time Intraday chart data file updates started for ESH5-CME | 2015-01-11 13:55:38 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:55:38 HD Request # 61 | Downloading Historical Daily chart data for ESH15. Starting date: 2015-01-08. Service: ddf | 2015-01-11 13:55:38 HD Request # 61 | Requesting historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:55:38 HD Request # 61 | Receiving historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:55:38 Writing historical Daily data for ESH15 to the file ESH15.dly | 2015-01-11 13:55:38 HD Request # 61 | Received 3 records from 2015-01-07 00:00:00 to 2015-01-09 00:00:00 (3.0 days) and wrote 2 records for ESH15 | 2015-01-11 13:55:38 HD Request # 61 | Daily download COMPLETE for ESH15. Completion time: 0s. Unique request ID: 60 | 2015-01-11 13:55:38 Removed historical data download ID 60 | 2015-01-11 13:55:38 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:55:38 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:55:38 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:55:38 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:55:38 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:55:38 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:55:38 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:55:38 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:55:38 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:55:38 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:55:38 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:55:38 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:55:38 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:55:38 ESH15/ESH5-CME [C] Daily #8 | Symbols used for continuous contract chart: | 2015-01-11 13:55:38 ESH12 | 2015-01-11 13:55:38 ESM12 | 2015-01-11 13:55:38 ESU12 | 2015-01-11 13:55:38 ESZ12 | 2015-01-11 13:55:38 ESH13 | 2015-01-11 13:55:38 ESM13 | 2015-01-11 13:55:38 ESU13 | 2015-01-11 13:55:38 ESZ13 | 2015-01-11 13:55:38 ESH14 | 2015-01-11 13:55:38 ESM14 | 2015-01-11 13:55:38 ESU14 | 2015-01-11 13:55:38 ESZ14 | 2015-01-11 13:55:38 ESH15 | 2015-01-11 13:55:38 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:55:38 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:55:38 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:55:38 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:55:38 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5 | Symbols used for continuous contract chart: | 2015-01-11 13:55:38 ESH14 | 2015-01-11 13:55:38 ESM14 | 2015-01-11 13:55:38 ESU14 | 2015-01-11 13:55:38 ESZ14 | 2015-01-11 13:55:38 ESH15 | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #5: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:55:38 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:55:38 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:55:38 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:55:38 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:55:38 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:55:38 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:55:38 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:55:38 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:55:38 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:55:38 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:55:38 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6 | Symbols used for continuous contract chart: | 2015-01-11 13:55:38 ESU12 | 2015-01-11 13:55:38 ESZ12 | 2015-01-11 13:55:38 ESH13 | 2015-01-11 13:55:38 ESM13 | 2015-01-11 13:55:38 ESU13 | 2015-01-11 13:55:38 ESZ13 | 2015-01-11 13:55:38 ESH14 | 2015-01-11 13:55:38 ESM14 | 2015-01-11 13:55:38 ESU14 | 2015-01-11 13:55:38 ESZ14 | 2015-01-11 13:55:38 ESH15 | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU12 Open price on 2012-09-13 is 1438.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ12 Open price on 2012-09-13 is 1431.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU12 price difference to ESZ12 is -6.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ12 Open price on 2012-12-13 is 1425.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESH13 Open price on 2012-12-13 is 1419.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ12 price difference to ESH13 is -6. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESH13 Open price on 2013-03-07 is 1539.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESM13 Open price on 2013-03-07 is 1535. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESH13 price difference to ESM13 is -4.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESM13 Open price on 2013-06-13 is 1610.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU13 Open price on 2013-06-13 is 1605. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESM13 price difference to ESU13 is -5.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU13 Open price on 2013-09-12 is 1689.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ13 Open price on 2013-09-12 is 1683.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU13 price difference to ESZ13 is -6.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ13 Open price on 2013-12-12 is 1780.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESH14 Open price on 2013-12-12 is 1774.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ13 price difference to ESH14 is -6.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU12 is -64.75. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ12 is -58. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESH13 is -52. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESM13 is -47.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU13 is -41.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ13 is -35. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:55:38 ESH15 [CB] Daily #6: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:55:38 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:55:38 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:55:38 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:55:38 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:55:38 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:55:38 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11 | Symbols used for continuous contract chart: | 2015-01-11 13:55:38 ESH14 | 2015-01-11 13:55:38 ESM14 | 2015-01-11 13:55:38 ESU14 | 2015-01-11 13:55:38 ESZ14 | 2015-01-11 13:55:38 ESH15 | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:55:38 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Download is complete for all contract months in chart. Proceeding with data load. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU2-CME Open price on 2012-09-13 is 1438.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ2-CME Open price on 2012-09-13 is 1431.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU2-CME price difference to ESZ2-CME is -6.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ2-CME Open price on 2012-12-13 is 1425.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESH3-CME Open price on 2012-12-13 is 1419.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ2-CME price difference to ESH3-CME is -6. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESH3-CME Open price on 2013-03-07 is 1539.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESM3-CME Open price on 2013-03-07 is 1535. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESH3-CME price difference to ESM3-CME is -4.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESM3-CME Open price on 2013-06-13 is 1610.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU3-CME Open price on 2013-06-13 is 1605. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESM3-CME price difference to ESU3-CME is -5.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU3-CME Open price on 2013-09-12 is 1689.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ3-CME Open price on 2013-09-12 is 1683.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU3-CME price difference to ESZ3-CME is -6.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ3-CME Open price on 2013-12-12 is 1780.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESH4-CME Open price on 2013-12-12 is 1774.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ3-CME price difference to ESH4-CME is -6.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU2-CME is -64.75. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ2-CME is -58. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESH3-CME is -52. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESM3-CME is -47.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU3-CME is -41.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ3-CME is -35. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESH4-CME is -28.5. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESM4-CME is -21.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESU4-CME is -14.25. | 2015-01-11 13:55:38 ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-11 13:55:38 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESH5-CME.scid | 2015-01-11 13:55:38 Intraday data recording state for symbol ESU2-CME is set to download pending. | 2015-01-11 13:56:52 Reloading all charts with filename: ESU2-CME.scid | 2015-01-11 13:56:52 HD Request # 62 | Downloading Intraday chart data for ESU2-CME to the file ESU2-CME.scid. Service: ddf | 2015-01-11 13:56:52 HD Request # 62 | Download start Date-Time: 2012-06-04 20:00:00.0 | 2015-01-11 13:56:52 HD Request # 62 | Requesting historical Intraday Minute data for ESU2-CME starting at 2012-06-04 20:00:00 (Exchange time). | 2015-01-11 13:56:52 HD Request # 62 | Error downloading historical Intraday data for ESU2-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:52 * HD Request # 62 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU2-CME | 2015-01-11 13:56:52 HD Request # 62 | Intraday download COMPLETE for ESU2-CME. Completion time: 0s. Unique request ID: 61 | 2015-01-11 13:56:52 Removed historical data download ID 61 | 2015-01-11 13:56:52 Real-time Intraday chart data file updates started for ESU2-CME | 2015-01-11 13:56:52 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:52 HD Request # 63 | Downloading Historical Daily chart data for ESU12. Starting date: 2012-09-20. Service: ddf | 2015-01-11 13:56:52 HD Request # 63 | Requesting historical Daily data for ESU12 starting at 2012-09-19 | 2015-01-11 13:56:52 HD Request # 63 | Receiving historical Daily data for ESU12 starting at 2012-09-19 | 2015-01-11 13:56:52 Writing historical Daily data for ESU12 to the file ESU12.dly | 2015-01-11 13:56:52 HD Request # 63 | Received 3 records from 2012-09-19 00:00:00 to 2012-09-21 00:00:00 (3.0 days) and wrote 2 records for ESU12 | 2015-01-11 13:56:52 HD Request # 63 | Daily download COMPLETE for ESU12. Completion time: 0s. Unique request ID: 62 | 2015-01-11 13:56:52 Removed historical data download ID 62 | 2015-01-11 13:56:52 Intraday data recording state for symbol ESZ2-CME is set to download pending. | 2015-01-11 13:56:52 Reloading all charts with filename: ESZ2-CME.scid | 2015-01-11 13:56:52 HD Request # 64 | Downloading Intraday chart data for ESZ2-CME to the file ESZ2-CME.scid. Service: ddf | 2015-01-11 13:56:52 HD Request # 64 | Download start Date-Time: 2012-09-10 20:00:00.0 | 2015-01-11 13:56:52 HD Request # 64 | Requesting historical Intraday Minute data for ESZ2-CME starting at 2012-09-10 20:00:00 (Exchange time). | 2015-01-11 13:56:52 HD Request # 64 | Error downloading historical Intraday data for ESZ2-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:52 * HD Request # 64 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ2-CME | 2015-01-11 13:56:52 HD Request # 64 | Intraday download COMPLETE for ESZ2-CME. Completion time: 0s. Unique request ID: 63 | 2015-01-11 13:56:52 Removed historical data download ID 63 | 2015-01-11 13:56:52 Real-time Intraday chart data file updates started for ESZ2-CME | 2015-01-11 13:56:52 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:52 HD Request # 65 | Downloading Historical Daily chart data for ESZ12. Starting date: 2012-12-20. Service: ddf | 2015-01-11 13:56:52 HD Request # 65 | Requesting historical Daily data for ESZ12 starting at 2012-12-19 | 2015-01-11 13:56:52 HD Request # 65 | Receiving historical Daily data for ESZ12 starting at 2012-12-19 | 2015-01-11 13:56:52 Writing historical Daily data for ESZ12 to the file ESZ12.dly | 2015-01-11 13:56:52 HD Request # 65 | Received 3 records from 2012-12-19 00:00:00 to 2012-12-21 00:00:00 (3.0 days) and wrote 2 records for ESZ12 | 2015-01-11 13:56:52 HD Request # 65 | Daily download COMPLETE for ESZ12. Completion time: 0s. Unique request ID: 64 | 2015-01-11 13:56:52 Removed historical data download ID 64 | 2015-01-11 13:56:52 Intraday data recording state for symbol ESH3-CME is set to download pending. | 2015-01-11 13:56:53 Reloading all charts with filename: ESH3-CME.scid | 2015-01-11 13:56:53 HD Request # 66 | Downloading Intraday chart data for ESH3-CME to the file ESH3-CME.scid. Service: ddf | 2015-01-11 13:56:53 HD Request # 66 | Download start Date-Time: 2012-12-10 19:00:00.0 | 2015-01-11 13:56:53 HD Request # 66 | Requesting historical Intraday Minute data for ESH3-CME starting at 2012-12-10 19:00:00 (Exchange time). | 2015-01-11 13:56:53 HD Request # 66 | Error downloading historical Intraday data for ESH3-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:53 * HD Request # 66 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH3-CME | 2015-01-11 13:56:53 HD Request # 66 | Intraday download COMPLETE for ESH3-CME. Completion time: 0s. Unique request ID: 65 | 2015-01-11 13:56:53 Removed historical data download ID 65 | 2015-01-11 13:56:53 Real-time Intraday chart data file updates started for ESH3-CME | 2015-01-11 13:56:53 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:53 HD Request # 67 | Downloading Historical Daily chart data for ESH13. Starting date: 2013-03-14. Service: ddf | 2015-01-11 13:56:53 HD Request # 67 | Requesting historical Daily data for ESH13 starting at 2013-03-13 | 2015-01-11 13:56:53 HD Request # 67 | Receiving historical Daily data for ESH13 starting at 2013-03-13 | 2015-01-11 13:56:53 Writing historical Daily data for ESH13 to the file ESH13.dly | 2015-01-11 13:56:53 HD Request # 67 | Received 3 records from 2013-03-13 00:00:00 to 2013-03-15 00:00:00 (3.0 days) and wrote 2 records for ESH13 | 2015-01-11 13:56:53 HD Request # 67 | Daily download COMPLETE for ESH13. Completion time: 0s. Unique request ID: 66 | 2015-01-11 13:56:53 Removed historical data download ID 66 | 2015-01-11 13:56:53 Intraday data recording state for symbol ESM3-CME is set to download pending. | 2015-01-11 13:56:53 Reloading all charts with filename: ESM3-CME.scid | 2015-01-11 13:56:53 HD Request # 68 | Downloading Intraday chart data for ESM3-CME to the file ESM3-CME.scid. Service: ddf | 2015-01-11 13:56:53 HD Request # 68 | Download start Date-Time: 2013-03-04 19:00:00.0 | 2015-01-11 13:56:53 HD Request # 68 | Requesting historical Intraday Minute data for ESM3-CME starting at 2013-03-04 19:00:00 (Exchange time). | 2015-01-11 13:56:53 HD Request # 68 | Error downloading historical Intraday data for ESM3-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:53 * HD Request # 68 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM3-CME | 2015-01-11 13:56:53 HD Request # 68 | Intraday download COMPLETE for ESM3-CME. Completion time: 0s. Unique request ID: 67 | 2015-01-11 13:56:53 Removed historical data download ID 67 | 2015-01-11 13:56:53 Real-time Intraday chart data file updates started for ESM3-CME | 2015-01-11 13:56:53 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:53 HD Request # 69 | Downloading Historical Daily chart data for ESM13. Starting date: 2013-06-20. Service: ddf | 2015-01-11 13:56:53 HD Request # 69 | Requesting historical Daily data for ESM13 starting at 2013-06-19 | 2015-01-11 13:56:53 HD Request # 69 | Receiving historical Daily data for ESM13 starting at 2013-06-19 | 2015-01-11 13:56:53 Writing historical Daily data for ESM13 to the file ESM13.dly | 2015-01-11 13:56:53 HD Request # 69 | Received 3 records from 2013-06-19 00:00:00 to 2013-06-21 00:00:00 (3.0 days) and wrote 2 records for ESM13 | 2015-01-11 13:56:53 HD Request # 69 | Daily download COMPLETE for ESM13. Completion time: 0s. Unique request ID: 68 | 2015-01-11 13:56:53 Removed historical data download ID 68 | 2015-01-11 13:56:53 Intraday data recording state for symbol ESU3-CME is set to download pending. | 2015-01-11 13:56:54 Reloading all charts with filename: ESU3-CME.scid | 2015-01-11 13:56:54 HD Request # 70 | Downloading Intraday chart data for ESU3-CME to the file ESU3-CME.scid. Service: ddf | 2015-01-11 13:56:54 HD Request # 70 | Download start Date-Time: 2013-06-10 20:00:00.0 | 2015-01-11 13:56:54 HD Request # 70 | Requesting historical Intraday Minute data for ESU3-CME starting at 2013-06-10 20:00:00 (Exchange time). | 2015-01-11 13:56:54 HD Request # 70 | Error downloading historical Intraday data for ESU3-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:54 * HD Request # 70 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU3-CME | 2015-01-11 13:56:54 HD Request # 70 | Intraday download COMPLETE for ESU3-CME. Completion time: 0s. Unique request ID: 69 | 2015-01-11 13:56:54 Removed historical data download ID 69 | 2015-01-11 13:56:54 Real-time Intraday chart data file updates started for ESU3-CME | 2015-01-11 13:56:54 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:54 HD Request # 71 | Downloading Historical Daily chart data for ESU13. Starting date: 2013-09-19. Service: ddf | 2015-01-11 13:56:54 HD Request # 71 | Requesting historical Daily data for ESU13 starting at 2013-09-18 | 2015-01-11 13:56:54 HD Request # 71 | Receiving historical Daily data for ESU13 starting at 2013-09-18 | 2015-01-11 13:56:54 Writing historical Daily data for ESU13 to the file ESU13.dly | 2015-01-11 13:56:54 HD Request # 71 | Received 3 records from 2013-09-18 00:00:00 to 2013-09-20 00:00:00 (3.0 days) and wrote 2 records for ESU13 | 2015-01-11 13:56:54 HD Request # 71 | Daily download COMPLETE for ESU13. Completion time: 0s. Unique request ID: 70 | 2015-01-11 13:56:54 Removed historical data download ID 70 | 2015-01-11 13:56:54 Intraday data recording state for symbol ESZ3-CME is set to download pending. | 2015-01-11 13:56:54 Reloading all charts with filename: ESZ3-CME.scid | 2015-01-11 13:56:54 HD Request # 72 | Downloading Intraday chart data for ESZ3-CME to the file ESZ3-CME.scid. Service: ddf | 2015-01-11 13:56:54 HD Request # 72 | Download start Date-Time: 2013-09-09 20:00:00.0 | 2015-01-11 13:56:54 HD Request # 72 | Requesting historical Intraday Minute data for ESZ3-CME starting at 2013-09-09 20:00:00 (Exchange time). | 2015-01-11 13:56:54 HD Request # 72 | Error downloading historical Intraday data for ESZ3-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:54 * HD Request # 72 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ3-CME | 2015-01-11 13:56:54 HD Request # 72 | Intraday download COMPLETE for ESZ3-CME. Completion time: 0s. Unique request ID: 71 | 2015-01-11 13:56:54 Removed historical data download ID 71 | 2015-01-11 13:56:54 Real-time Intraday chart data file updates started for ESZ3-CME | 2015-01-11 13:56:54 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:54 HD Request # 73 | Downloading Historical Daily chart data for ESZ13. Starting date: 2013-12-19. Service: ddf | 2015-01-11 13:56:54 HD Request # 73 | Requesting historical Daily data for ESZ13 starting at 2013-12-18 | 2015-01-11 13:56:54 HD Request # 73 | Receiving historical Daily data for ESZ13 starting at 2013-12-18 | 2015-01-11 13:56:54 Writing historical Daily data for ESZ13 to the file ESZ13.dly | 2015-01-11 13:56:54 HD Request # 73 | Received 3 records from 2013-12-18 00:00:00 to 2013-12-20 00:00:00 (3.0 days) and wrote 2 records for ESZ13 | 2015-01-11 13:56:54 HD Request # 73 | Daily download COMPLETE for ESZ13. Completion time: 0s. Unique request ID: 72 | 2015-01-11 13:56:54 Removed historical data download ID 72 | 2015-01-11 13:56:54 Intraday data recording state for symbol ESH4-CME is set to download pending. | 2015-01-11 13:56:54 Reloading all charts with filename: ESH4-CME.scid | 2015-01-11 13:56:54 HD Request # 74 | Downloading Intraday chart data for ESH4-CME to the file ESH4-CME.scid. Service: ddf | 2015-01-11 13:56:54 HD Request # 74 | Download start Date-Time: 2013-12-09 19:00:00.0 | 2015-01-11 13:56:54 HD Request # 74 | Requesting historical Intraday Minute data for ESH4-CME starting at 2013-12-09 19:00:00 (Exchange time). | 2015-01-11 13:56:54 HD Request # 74 | Error downloading historical Intraday data for ESH4-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:55 * HD Request # 74 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH4-CME | 2015-01-11 13:56:55 HD Request # 74 | Intraday download COMPLETE for ESH4-CME. Completion time: 1s. Unique request ID: 73 | 2015-01-11 13:56:55 Removed historical data download ID 73 | 2015-01-11 13:56:55 Real-time Intraday chart data file updates started for ESH4-CME | 2015-01-11 13:56:55 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:55 HD Request # 75 | Downloading Historical Daily chart data for ESH14. Starting date: 2014-03-20. Service: ddf | 2015-01-11 13:56:55 HD Request # 75 | Requesting historical Daily data for ESH14 starting at 2014-03-19 | 2015-01-11 13:56:55 HD Request # 75 | Receiving historical Daily data for ESH14 starting at 2014-03-19 | 2015-01-11 13:56:55 Writing historical Daily data for ESH14 to the file ESH14.dly | 2015-01-11 13:56:55 HD Request # 75 | Received 3 records from 2014-03-19 00:00:00 to 2014-03-21 00:00:00 (3.0 days) and wrote 2 records for ESH14 | 2015-01-11 13:56:55 HD Request # 75 | Daily download COMPLETE for ESH14. Completion time: 0s. Unique request ID: 74 | 2015-01-11 13:56:55 Removed historical data download ID 74 | 2015-01-11 13:56:55 Intraday data recording state for symbol ESM4-CME is set to download pending. | 2015-01-11 13:56:55 Reloading all charts with filename: ESM4-CME.scid | 2015-01-11 13:56:55 HD Request # 76 | Downloading Intraday chart data for ESM4-CME to the file ESM4-CME.scid. Service: ddf | 2015-01-11 13:56:55 HD Request # 76 | Download start Date-Time: 2014-03-10 20:00:00.0 | 2015-01-11 13:56:55 HD Request # 76 | Requesting historical Intraday Minute data for ESM4-CME starting at 2014-03-10 20:00:00 (Exchange time). | 2015-01-11 13:56:55 HD Request # 76 | Error downloading historical Intraday data for ESM4-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:55 * HD Request # 76 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESM4-CME | 2015-01-11 13:56:55 HD Request # 76 | Intraday download COMPLETE for ESM4-CME. Completion time: 0s. Unique request ID: 75 | 2015-01-11 13:56:55 Removed historical data download ID 75 | 2015-01-11 13:56:55 Real-time Intraday chart data file updates started for ESM4-CME | 2015-01-11 13:56:55 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:55 HD Request # 77 | Downloading Historical Daily chart data for ESM14. Starting date: 2014-06-19. Service: ddf | 2015-01-11 13:56:55 HD Request # 77 | Requesting historical Daily data for ESM14 starting at 2014-06-18 | 2015-01-11 13:56:55 HD Request # 77 | Receiving historical Daily data for ESM14 starting at 2014-06-18 | 2015-01-11 13:56:55 Writing historical Daily data for ESM14 to the file ESM14.dly | 2015-01-11 13:56:55 HD Request # 77 | Received 3 records from 2014-06-18 00:00:00 to 2014-06-20 00:00:00 (3.0 days) and wrote 2 records for ESM14 | 2015-01-11 13:56:55 HD Request # 77 | Daily download COMPLETE for ESM14. Completion time: 0s. Unique request ID: 76 | 2015-01-11 13:56:55 Removed historical data download ID 76 | 2015-01-11 13:56:55 Intraday data recording state for symbol ESU4-CME is set to download pending. | 2015-01-11 13:56:56 Reloading all charts with filename: ESU4-CME.scid | 2015-01-11 13:56:56 HD Request # 78 | Downloading Intraday chart data for ESU4-CME to the file ESU4-CME.scid. Service: ddf | 2015-01-11 13:56:56 HD Request # 78 | Download start Date-Time: 2014-06-09 20:00:00.0 | 2015-01-11 13:56:56 HD Request # 78 | Requesting historical Intraday Minute data for ESU4-CME starting at 2014-06-09 20:00:00 (Exchange time). | 2015-01-11 13:56:56 HD Request # 78 | Error downloading historical Intraday data for ESU4-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:56 * HD Request # 78 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU4-CME | 2015-01-11 13:56:56 HD Request # 78 | Intraday download COMPLETE for ESU4-CME. Completion time: 0s. Unique request ID: 77 | 2015-01-11 13:56:56 Removed historical data download ID 77 | 2015-01-11 13:56:56 Real-time Intraday chart data file updates started for ESU4-CME | 2015-01-11 13:56:56 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:56 HD Request # 79 | Downloading Historical Daily chart data for ESU14. Starting date: 2014-09-18. Service: ddf | 2015-01-11 13:56:56 HD Request # 79 | Requesting historical Daily data for ESU14 starting at 2014-09-17 | 2015-01-11 13:56:56 HD Request # 79 | Receiving historical Daily data for ESU14 starting at 2014-09-17 | 2015-01-11 13:56:56 Writing historical Daily data for ESU14 to the file ESU14.dly | 2015-01-11 13:56:56 HD Request # 79 | Received 3 records from 2014-09-17 00:00:00 to 2014-09-19 00:00:00 (3.0 days) and wrote 2 records for ESU14 | 2015-01-11 13:56:56 HD Request # 79 | Daily download COMPLETE for ESU14. Completion time: 0s. Unique request ID: 78 | 2015-01-11 13:56:56 Removed historical data download ID 78 | 2015-01-11 13:56:56 Intraday data recording state for symbol ESZ4-CME is set to download pending. | 2015-01-11 13:56:56 Reloading all charts with filename: ESZ4-CME.scid | 2015-01-11 13:56:56 HD Request # 80 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: ddf | 2015-01-11 13:56:56 HD Request # 80 | Download start Date-Time: 2014-09-08 20:00:00.0 | 2015-01-11 13:56:56 HD Request # 80 | Requesting historical Intraday Minute data for ESZ4-CME starting at 2014-09-08 20:00:00 (Exchange time). | 2015-01-11 13:56:56 HD Request # 80 | Error downloading historical Intraday data for ESZ4-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:56 * HD Request # 80 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ4-CME | 2015-01-11 13:56:56 HD Request # 80 | Intraday download COMPLETE for ESZ4-CME. Completion time: 0s. Unique request ID: 79 | 2015-01-11 13:56:56 Removed historical data download ID 79 | 2015-01-11 13:56:56 Real-time Intraday chart data file updates started for ESZ4-CME | 2015-01-11 13:56:56 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:56 HD Request # 81 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-12-18. Service: ddf | 2015-01-11 13:56:56 HD Request # 81 | Requesting historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:56:56 HD Request # 81 | Receiving historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-11 13:56:56 Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2015-01-11 13:56:56 HD Request # 81 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-19 00:00:00 (3.0 days) and wrote 2 records for ESZ14 | 2015-01-11 13:56:56 HD Request # 81 | Daily download COMPLETE for ESZ14. Completion time: 0s. Unique request ID: 80 | 2015-01-11 13:56:56 Removed historical data download ID 80 | 2015-01-11 13:56:56 Intraday data recording state for symbol ESH5-CME is set to download pending. | 2015-01-11 13:56:57 HD Request # 82 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: ddf | 2015-01-11 13:56:57 HD Request # 82 | Download start Date-Time: 2014-12-08 19:00:00.0 | 2015-01-11 13:56:57 HD Request # 82 | Requesting historical Intraday Minute data for ESH5-CME starting at 2014-12-08 19:00:00 (Exchange time). | 2015-01-11 13:56:57 HD Request # 82 | Error downloading historical Intraday data for ESH5-CME. Error executing query: Invalid symbol | 2015-01-11 13:56:57 * HD Request # 82 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH5-CME | 2015-01-11 13:56:57 HD Request # 82 | Intraday download COMPLETE for ESH5-CME. Completion time: 0s. Unique request ID: 81 | 2015-01-11 13:56:57 Removed historical data download ID 81 | 2015-01-11 13:56:57 Real-time Intraday chart data file updates started for ESH5-CME | 2015-01-11 13:56:57 Received HTTP data in DDF HD client for request ID that is not the current request. Ignoring. | 2015-01-11 13:56:57 HD Request # 83 | Downloading Historical Daily chart data for ESH15. Starting date: 2015-01-08. Service: ddf | 2015-01-11 13:56:57 HD Request # 83 | Requesting historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:56:57 HD Request # 83 | Receiving historical Daily data for ESH15 starting at 2015-01-07 | 2015-01-11 13:56:57 Writing historical Daily data for ESH15 to the file ESH15.dly | 2015-01-11 13:56:57 HD Request # 83 | Received 3 records from 2015-01-07 00:00:00 to 2015-01-09 00:00:00 (3.0 days) and wrote 2 records for ESH15 | 2015-01-11 13:56:57 HD Request # 83 | Daily download COMPLETE for ESH15. Completion time: 0s. Unique request ID: 82 | 2015-01-11 13:56:57 Removed historical data download ID 82 | 2015-01-11 13:56:57 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:56:57 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:56:57 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:56:57 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:56:57 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:56:57 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-11 13:56:57 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-11 13:56:57 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-11 13:56:57 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-11 13:56:57 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-09. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11 | Symbols used for continuous contract chart: | 2015-01-11 13:56:57 ESH14 | 2015-01-11 13:56:57 ESM14 | 2015-01-11 13:56:57 ESU14 | 2015-01-11 13:56:57 ESZ14 | 2015-01-11 13:56:57 ESH15 | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: Performing continuous futures contract back adjustment calculations. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESH14 Open price on 2014-03-13 is 1868.75. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-03-13 is 1861.5. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESH14 price difference to ESM14 is -7.25. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESM14 Open price on 2014-06-12 is 1943.75. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-06-12 is 1936.75. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESM14 price difference to ESU14 is -7. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESU14 Open price on 2014-09-11 is 1994.5. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-09-11 is 1986.75. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESU14 price difference to ESZ14 is -7.75. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESZ14 Open price on 2014-12-11 is 2026.25. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESH15 Open price on 2014-12-11 is 2019.75. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: ESZ14 price difference to ESH15 is -6.5. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESH14 is -28.5. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESM14 is -21.25. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESU14 is -14.25. | 2015-01-11 13:56:57 ESH15/ESH5-CME [CB] Daily #11: Back adjust amount for symbol ESZ14 is -6.5. | 2015-01-11 13:56:57 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-01-11 13:56:57 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-01-11 13:56:57 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-01-11 13:56:57 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-01-11 13:56:57 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-01-11 13:56:57 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-01-11 13:56:57 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-01-11 13:56:57 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-01-11 13:56:57 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-01-11 13:56:57 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-01-11 13:56:57 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-01-11 13:56:57 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-01-11 13:56:57 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-01-11 13:56:57 Checking Daily data file f |
DateRangeFail.PNG / V - Attached On 2015-01-11 22:36:30 UTC - Size: 82.7 KB - 298 views |
[2015-01-12 06:25:33] |
The problem is you are not using the correct symbol. Only use the symbols found in File >> Find Symbol: https://www.sierrachart.com/index.php?page=doc/helpdetails1.html#h1.3 Unless it is a stock symbol, in which case you have to manually enter the symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-12 06:26:11
[2015-01-12 16:35:10] |
startledbymoth - Posts: 39 |
Right. Thank you. That worked. Thanks for your patience with me; this was very challenging for me, but it works just as I had wanted, thanks to your support. |
[2015-01-24 23:04:24] |
I need more information about this: I am getting a confused jumble of continuous futures data. Depending on the chart, I either get the actual historical prices for the ES when traded on that day; or I get some kind of contiunous rollover average. Compare this chart, which graphs data with the actual points (prices) traded in April 2013: http://www.sierrachart.com/image.php?l=1422138967723.png with this, supposedly same data and same settings, but with about 49 points different. http://www.sierrachart.com/image.php?l=142214052590.png Each chart is supposedly driven by the same data, same chart settings, but different results. Please advise how I can 1) have uniform presentation of the same Futures contract data (i.e, the points trading) in all historical charts of the same time periods; and 2) have the uniform data conform with the actual points of the time (e.g., if ES closed at 1547.5 on 4/19/13, I'd like the historical chart to show that number, and not 1500). |
[2015-01-25 05:12:45] |
Select Chart >> Chart Settings >> Advanced Settings. Set the Continuous Contract option to Continuous Futures Contract-Date Rule Rollover for any chart that has incorrect prices.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-25 05:13:26
[2015-01-25 16:45:46] |
Of course. I knew that, but overlooked that the problem charts were set to Continuous Futures Contract-Date Rule Rollover, Back Adjusted, which created the problem. Now all set to generic Continuous Futures Contract-Date Rule Rollover, and all is A-OK. Thank you very much. Sorry to have taken your time for something I should have noticed myself. Have a great week. |
