Date/Time: Sun, 29 Nov 2026 14:31:49 +0000
Denali data started to be delayed without any reason
View Count: 384
| [2026-10-12 12:50:36] |
| ANTARES - Posts: 15 |
Hello, I have funded account, sierra 11 package, subscribed to CME quotes (denali). 1 day ago I had normal real time data, just now started my PC and has delayed data, without any changes in my Sierra terminal or subscriptions. Have no idea what's wrong, please help. Thank you |
| [2026-10-12 15:42:41] |
| Sierra_Chart Engineering - Posts: 25523 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-12 16:09:23] |
2026-10-12 07:46:53.490 | Trade activity files set size: 257 2026-10-12 07:46:53.521 | Reading Internal Order ID file. 2026-10-12 07:46:53.560 | Reading Trade Orders file. 2026-10-12 07:46:53.560 | Reading Trade Positions file. 2026-10-12 07:46:53.560 | Reading Trade Account Data files. 2026-10-12 07:46:53.561 | Software version: 2947 64-bit 2026-10-12 07:46:53.561 | Primary Thread ID: 7816 2026-10-12 07:46:53.561 | Usage end date: 2026-11-21 2026-10-12 07:46:53.561 | Enabled for: Advanced Features 2. 2026-10-12 07:46:53.561 | Enabled for: Sierra Chart Historical Data Service. 2026-10-12 07:46:53.561 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-10-12 07:46:53.561 | Enabled for: Delayed Denali Exchange Data Feed. 2026-10-12 07:46:53.561 | Enabled for exchange2: CME (Trading Account Required) 2026-10-12 07:46:53.561 | Enabled for exchange2: CBOT (Trading Account Required) 2026-10-12 07:46:53.561 | Enabled for exchange2: COMEX (Trading Account Required) 2026-10-12 07:46:53.561 | Enabled for exchange2: NYMEX (Trading Account Required) 2026-10-12 07:46:53.561 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-10-12 07:46:53.561 | Current selected Data/Trading service: Teton CME Routing 2026-10-12 07:46:53.561 | Custom symbol settings values: disabled 2026-10-12 07:46:53.561 | Chart Update Interval: 10 2026-10-12 07:46:53.561 | Intraday Data Storage Time Unit: 0 2026-10-12 07:46:53.561 | Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-10-12 07:46:53.561 | 2026-10-12 12:46:53 Local computer time in UTC 2026-10-12 07:46:53.561 | 2026-10-12 07:46:53 Local computer time in SC Time Zone 2026-10-12 07:46:53.561 | 2026-10-12 12:45:45 Server time in UTC 2026-10-12 07:46:53.561 | Local computer UTC time and Server UTC time difference: 68 seconds. 2026-10-12 07:46:53.561 | Notice: Your computer's clock is off by 68 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. 2026-10-12 07:46:53.561 | Program path: C:\SierraChart\ 2026-10-12 07:46:53.561 | Data Files path: C:\SierraChart\Data\ 2026-10-12 07:46:53.562 | OS Version Number: 10.0 2026-10-12 07:46:53.562 | Locale Setting: C 2026-10-12 07:46:53.562 | Crash reporter started: true 2026-10-12 07:46:53.562 | 2026-10-12 07:46:53.573 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2026-10-12 07:46:53.631 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-10-12 07:46:53.676 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-10-12 07:46:53.676 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-10-12 07:46:53.744 | Received 5 login tokens. 2026-10-12 07:46:53.894 | Symbol settings MD5 received. Request ID: 1. 2026-10-12 07:46:53.894 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2026-10-12 07:46:56.092 | Requested user files to download. 2026-10-12 07:46:56.524 | File to download: corn.wav. Action: 0 2026-10-12 07:46:56.524 | File to download: wheat.wav. Action: 0 2026-10-12 07:46:56.524 | File to download: nasdaq.wav. Action: 0 2026-10-12 07:46:56.524 | User files to download complete 2026-10-12 07:46:58.098 | 2026-10-12 07:46:58.098 | Teton CME Routing | Firm: Phillip Capital 2026-10-12 07:46:58.098 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 2026-10-12 07:46:58.099 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-10-12 07:46:58.099 | DTC Client socket (1) | New receive buffer size: 0 2026-10-12 07:46:58.099 | DTC Client socket (1) | Connecting to IP: 216.200.108.154 Port: 11089. 2026-10-12 07:46:58.136 | Teton CME Routing | Network connection to server complete. 2026-10-12 07:46:58.136 | Teton CME Routing | Starting socket receive thread. 2026-10-12 07:46:58.136 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-10-12 07:46:58.256 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-10-12 07:46:58.256 | Teton CME Routing | Sending logon request message. 2026-10-12 07:46:58.344 | Teton CME Routing | Received logon response. 2026-10-12 07:46:58.344 | Teton CME Routing | Server Name: SC DTC Server. Build=58073. 2026-10-12 07:46:58.344 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-10-12 07:46:58.344 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-10-12 07:46:58.344 | Teton CME Routing | Trading is supported. 2026-10-12 07:46:58.344 | Teton CME Routing | Order cancel and replace is supported. 2026-10-12 07:46:58.344 | Teton CME Routing | OCO Orders supported. 2026-10-12 07:46:58.344 | Teton CME Routing | Bracket Orders supported. 2026-10-12 07:46:58.344 | Teton CME Routing | MarketDepthIsSupported: 1 2026-10-12 07:46:58.344 | Teton CME Routing | Connection to server complete. 2026-10-12 07:46:58.344 | No download requests in the queue to start downloads for. | Number times message added: 4 2026-10-12 07:46:58.344 | Subscribing to symbol for symbol alert. CLV25_FUT_CME 2026-10-12 07:46:58.344 | Mapping CLV25_FUT_CME to CLV25. Service code: nymex 2026-10-12 07:46:58.344 | Using symbol data fast lookup vector 2026-10-12 07:46:58.344 | Denali Data Feed | Starting real-time market data updates for: CLV25_FUT_CME (CLV25). ID: 1 Service code: nymex 2026-10-12 07:46:58.345 | Denali Data Feed | Connecting to the server ds7.sierracharts.com. Port 443 2026-10-12 07:46:58.345 | Denali Data Feed | Requesting security definition data for: CLV25_FUT_CME (CLV25). ID: 1 2026-10-12 07:46:58.345 | Subscribing to symbol for symbol alert. RTYZ25_FUT_CME 2026-10-12 07:46:58.345 | Mapping RTYZ25_FUT_CME to RTYZ25. Service code: cme 2026-10-12 07:46:58.345 | Denali Data Feed | Starting real-time market data updates for: RTYZ25_FUT_CME (RTYZ25). ID: 2 Service code: cme 2026-10-12 07:46:58.345 | Denali Data Feed | Requesting security definition data for: RTYZ25_FUT_CME (RTYZ25). ID: 2 2026-10-12 07:46:58.345 | Subscribing to symbol for symbol alert. YMZ25_FUT_CME 2026-10-12 07:46:58.345 | Mapping YMZ25_FUT_CME to YMZ25. Service code: cbot 2026-10-12 07:46:58.345 | Denali Data Feed | Starting real-time market data updates for: YMZ25_FUT_CME (YMZ25). ID: 3 Service code: cbot 2026-10-12 07:46:58.345 | Denali Data Feed | Requesting security definition data for: YMZ25_FUT_CME (YMZ25). ID: 3 2026-10-12 07:46:58.345 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-10-12 07:46:58.346 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-10-10 02:21:38.024680 2026-10-12 07:46:58.381 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLV25_FUT_CME 2026-10-12 07:46:58.381 | Teton CME Routing | Setting external service identifier for symbol CLV25_FUT_CME to 4257 2026-10-12 07:46:58.381 | Teton CME Routing | Received security definition for symbol CLV25_FUT_CME 2026-10-12 07:46:58.381 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYZ25_FUT_CME 2026-10-12 07:46:58.381 | Teton CME Routing | Setting external service identifier for symbol RTYZ25_FUT_CME to 4258 2026-10-12 07:46:58.381 | Teton CME Routing | Received security definition for symbol RTYZ25_FUT_CME 2026-10-12 07:46:58.387 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMZ25_FUT_CME 2026-10-12 07:46:58.387 | Teton CME Routing | Setting external service identifier for symbol YMZ25_FUT_CME to 4259 2026-10-12 07:46:58.387 | Teton CME Routing | Received security definition for symbol YMZ25_FUT_CME 2026-10-12 07:46:58.387 | Updated verified funded futures trading account ending date to: 2026-11-11 12:46:58 2026-10-12 07:46:58.422 | DTC Client socket (2) | Creating socket. 2026-10-12 07:46:58.422 | DTC Client socket (2) | New receive buffer size: 0 2026-10-12 07:46:58.422 | DTC Client socket (2) | Connecting to IP: 69.39.70.253 Port: 443. 2026-10-12 07:46:58.466 | Denali Data Feed | Network connection to server complete. 2026-10-12 07:46:58.466 | Denali Data Feed | Starting socket receive thread. 2026-10-12 07:46:58.466 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-10-12 07:46:58.521 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-10-12 07:46:58.521 | Denali Data Feed | Sending logon request message. 2026-10-12 07:46:58.990 | Denali Data Feed | Received logon response. 2026-10-12 07:46:58.990 | Denali Data Feed | Server Name: SC Realtime Server. 2026-10-12 07:46:58.990 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-10-12 07:46:58.990 | Denali Data Feed | Successfully connected. 2026-10-12 07:46:58.990 | Denali Data Feed | Trading is not supported. 2026-10-12 07:46:58.990 | Denali Data Feed | MarketDepthIsSupported: 1 2026-10-12 07:46:58.990 | Denali Data Feed | Restarting real-time data updates for symbol: CLV25_FUT_CME -> CLV25 2026-10-12 07:46:58.990 | Denali Data Feed | Restarting real-time data updates for symbol: RTYZ25_FUT_CME -> RTYZ25 2026-10-12 07:46:58.990 | Denali Data Feed | Restarting real-time data updates for symbol: YMZ25_FUT_CME -> YMZ25 2026-10-12 07:46:59.115 | Denali Data Feed | Real-time data for symbol CLV25_FUT_CME is currently unavailable. 2026-10-12 07:46:59.115 | Denali Data Feed | Received security definition for symbol CLV25_FUT_CME 2026-10-12 07:46:59.115 | Denali Data Feed | Real-time data for symbol RTYZ25_FUT_CME is currently unavailable. 2026-10-12 07:46:59.115 | Denali Data Feed | Received security definition for symbol RTYZ25_FUT_CME 2026-10-12 07:46:59.115 | Denali Data Feed | Real-time data for symbol YMZ25_FUT_CME is currently unavailable. 2026-10-12 07:46:59.115 | Denali Data Feed | Received security definition for symbol YMZ25_FUT_CME 2026-10-12 07:47:01.331 | Files to Open on Startup | Opening file: Anton.cht 2026-10-12 07:47:01.337 | MESZ26_FUT_CME [CV] Monthly #1 | Reloading chart. 2026-10-12 07:47:01.641 | MESZ26_FUT_CME [CV] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME * 2026-10-12 07:47:01.641 | Unable to determine transition date based on volume from files: MESU05_FUT_CME.dly, MESZ05_FUT_CME.dly 2026-10-12 07:47:01.641 | The MESZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.641 | Unable to determine transition date based on volume from files: MESZ05_FUT_CME.dly, MESH06_FUT_CME.dly 2026-10-12 07:47:01.641 | The MESH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.641 | Unable to determine transition date based on volume from files: MESH06_FUT_CME.dly, MESM06_FUT_CME.dly 2026-10-12 07:47:01.641 | The MESM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.641 | Unable to determine transition date based on volume from files: MESM06_FUT_CME.dly, MESU06_FUT_CME.dly 2026-10-12 07:47:01.641 | The MESU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.641 | Unable to determine transition date based on volume from files: MESU06_FUT_CME.dly, MESZ06_FUT_CME.dly 2026-10-12 07:47:01.641 | The MESZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESZ06_FUT_CME.dly, MESH07_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESH07_FUT_CME.dly, MESM07_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESM07_FUT_CME.dly, MESU07_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESU07_FUT_CME.dly, MESZ07_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESZ07_FUT_CME.dly, MESH08_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESH08_FUT_CME.dly, MESM08_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESM08_FUT_CME.dly, MESU08_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESU08_FUT_CME.dly, MESZ08_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESZ08_FUT_CME.dly, MESH09_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESH09_FUT_CME.dly, MESM09_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESM09_FUT_CME.dly, MESU09_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.642 | Unable to determine transition date based on volume from files: MESU09_FUT_CME.dly, MESZ09_FUT_CME.dly 2026-10-12 07:47:01.642 | The MESZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESZ09_FUT_CME.dly, MESH10_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESH10_FUT_CME.dly, MESM10_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESM10_FUT_CME.dly, MESU10_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESU10_FUT_CME.dly, MESZ10_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESZ10_FUT_CME.dly, MESH11_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESH11_FUT_CME.dly, MESM11_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESM11_FUT_CME.dly, MESU11_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESU11_FUT_CME.dly, MESZ11_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESZ11_FUT_CME.dly, MESH12_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESH12_FUT_CME.dly, MESM12_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESM12_FUT_CME.dly, MESU12_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESU12_FUT_CME.dly, MESZ12_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.643 | Unable to determine transition date based on volume from files: MESZ12_FUT_CME.dly, MESH13_FUT_CME.dly 2026-10-12 07:47:01.643 | The MESH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESH13_FUT_CME.dly, MESM13_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESM13_FUT_CME.dly, MESU13_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESU13_FUT_CME.dly, MESZ13_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESZ13_FUT_CME.dly, MESH14_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESH14_FUT_CME.dly, MESM14_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESM14_FUT_CME.dly, MESU14_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESU14_FUT_CME.dly, MESZ14_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.644 | Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly 2026-10-12 07:47:01.644 | The MESH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.645 | Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly 2026-10-12 07:47:01.645 | The MESH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.646 | Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly 2026-10-12 07:47:01.646 | The MESH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:47:01.727 | MESZ26_FUT_CME Weekly #2 | Reloading chart. 2026-10-12 07:47:01.734 | MESZ26_FUT_CME Daily #3 | Reloading chart. 2026-10-12 07:47:01.741 | MESZ26_FUT_CME 240 Min #4 | Reloading chart. 2026-10-12 07:47:01.746 | MESZ26_FUT_CME 240 Min #5 | Reloading chart. 2026-10-12 07:47:01.753 | MESZ26_FUT_CME 15 Min #6 | Reloading chart. 2026-10-12 07:47:01.777 | MESZ26_FUT_CME 120 Min #7 | Reloading chart. 2026-10-12 07:47:01.801 | MESZ26_FUT_CME 15 Min #8 | Reloading chart. 2026-10-12 07:47:01.825 | MESZ26_FUT_CME 1 Min #9 | Reloading chart. 2026-10-12 07:47:01.854 | MESZ26_FUT_CME 100 Trades #10 | Reloading chart. 2026-10-12 07:47:01.989 | MESZ26_FUT_CME Daily #11 | Reloading chart. 2026-10-12 07:47:02.016 | MYMZ26_FUT_CME Daily #12 | Reloading chart. 2026-10-12 07:47:02.043 | MYMZ26_FUT_CME 120 Min #13 | Reloading chart. 2026-10-12 07:47:02.071 | MYMZ26_FUT_CME 15 Min #14 | Reloading chart. 2026-10-12 07:47:02.101 | MYMZ26_FUT_CME 1 Min #15 | Reloading chart. 2026-10-12 07:47:02.136 | MYMZ26_FUT_CME 15 Trades #16 | Reloading chart. 2026-10-12 07:47:02.305 | M2KZ26_FUT_CME Daily #17 | Reloading chart. 2026-10-12 07:47:02.337 | M2KZ26_FUT_CME 120 Min #18 | Reloading chart. 2026-10-12 07:47:02.368 | M2KZ26_FUT_CME 15 Min #19 | Reloading chart. 2026-10-12 07:47:02.405 | M2KZ26_FUT_CME 1 Min #20 | Reloading chart. 2026-10-12 07:47:02.440 | M2KZ26_FUT_CME 15 Trades #21 | Reloading chart. 2026-10-12 07:47:02.620 | MCLX26_FUT_CME 1 Min #22 | Reloading chart. 2026-10-12 07:47:02.656 | MCLX26_FUT_CME 15 Min #23 | Reloading chart. 2026-10-12 07:47:02.697 | MCLX26_FUT_CME 20 Trades #24 | Reloading chart. 2026-10-12 07:47:02.907 | MCLX26_FUT_CME 60 Min #25 | Reloading chart. 2026-10-12 07:47:02.934 | MCLX26_FUT_CME Daily #26 | Reloading chart. 2026-10-12 07:47:02.951 | Mapping MESZ26_FUT_CME to MESZ26. Service code: cme 2026-10-12 07:47:02.951 | Denali Data Feed | Starting real-time market data updates for: MESZ26_FUT_CME (MESZ26). ID: 4 Service code: cme 2026-10-12 07:47:02.951 | Denali Data Feed | Requesting security definition data for: MESZ26_FUT_CME (MESZ26). ID: 4 2026-10-12 07:47:02.951 | Mapping MESH27_FUT_CME to MESH27. Service code: cme 2026-10-12 07:47:02.951 | Denali Data Feed | Starting real-time market data updates for: MESH27_FUT_CME (MESH27). ID: 5 Service code: cme 2026-10-12 07:47:02.951 | Denali Data Feed | Requesting security definition data for: MESH27_FUT_CME (MESH27). ID: 5 2026-10-12 07:47:02.952 | Mapping MESM27_FUT_CME to MESM27. Service code: cme 2026-10-12 07:47:02.952 | Denali Data Feed | Starting real-time market data updates for: MESM27_FUT_CME (MESM27). ID: 6 Service code: cme 2026-10-12 07:47:02.952 | Denali Data Feed | Requesting security definition data for: MESM27_FUT_CME (MESM27). ID: 6 2026-10-12 07:47:02.952 | Mapping MESU27_FUT_CME to MESU27. Service code: cme 2026-10-12 07:47:02.952 | Denali Data Feed | Starting real-time market data updates for: MESU27_FUT_CME (MESU27). ID: 7 Service code: cme 2026-10-12 07:47:02.952 | Denali Data Feed | Requesting security definition data for: MESU27_FUT_CME (MESU27). ID: 7 2026-10-12 07:47:02.952 | Mapping MESZ27_FUT_CME to MESZ27. Service code: cme 2026-10-12 07:47:02.952 | Denali Data Feed | Starting real-time market data updates for: MESZ27_FUT_CME (MESZ27). ID: 8 Service code: cme 2026-10-12 07:47:02.952 | Denali Data Feed | Requesting security definition data for: MESZ27_FUT_CME (MESZ27). ID: 8 2026-10-12 07:47:02.952 | Mapping MYMZ26_FUT_CME to MYMZ26. Service code: cbot 2026-10-12 07:47:02.952 | Denali Data Feed | Starting real-time market data updates for: MYMZ26_FUT_CME (MYMZ26). ID: 9 Service code: cbot 2026-10-12 07:47:02.952 | Denali Data Feed | Requesting security definition data for: MYMZ26_FUT_CME (MYMZ26). ID: 9 2026-10-12 07:47:02.952 | Mapping MYMH27_FUT_CME to MYMH27. Service code: cbot 2026-10-12 07:47:02.952 | Denali Data Feed | Starting real-time market data updates for: MYMH27_FUT_CME (MYMH27). ID: 10 Service code: cbot 2026-10-12 07:47:02.952 | Denali Data Feed | Requesting security definition data for: MYMH27_FUT_CME (MYMH27). ID: 10 2026-10-12 07:47:02.952 | Mapping MYMM27_FUT_CME to MYMM27. Service code: cbot 2026-10-12 07:47:02.952 | Denali Data Feed | Starting real-time market data updates for: MYMM27_FUT_CME (MYMM27). ID: 11 Service code: cbot 2026-10-12 07:47:02.952 | Denali Data Feed | Requesting security definition data for: MYMM27_FUT_CME (MYMM27). ID: 11 2026-10-12 07:47:02.952 | Mapping MYMU27_FUT_CME to MYMU27. Service code: cbot 2026-10-12 07:47:02.953 | Denali Data Feed | Starting real-time market data updates for: MYMU27_FUT_CME (MYMU27). ID: 12 Service code: cbot 2026-10-12 07:47:02.953 | Denali Data Feed | Requesting security definition data for: MYMU27_FUT_CME (MYMU27). ID: 12 2026-10-12 07:47:02.953 | Mapping MYMZ27_FUT_CME to MYMZ27. Service code: cbot 2026-10-12 07:47:02.953 | Denali Data Feed | Starting real-time market data updates for: MYMZ27_FUT_CME (MYMZ27). ID: 13 Service code: cbot 2026-10-12 07:47:02.953 | Denali Data Feed | Requesting security definition data for: MYMZ27_FUT_CME (MYMZ27). ID: 13 2026-10-12 07:47:02.953 | Mapping M2KZ26_FUT_CME to M2KZ26. Service code: cme 2026-10-12 07:47:02.953 | Denali Data Feed | Starting real-time market data updates for: M2KZ26_FUT_CME (M2KZ26). ID: 14 Service code: cme 2026-10-12 07:47:02.953 | Denali Data Feed | Requesting security definition data for: M2KZ26_FUT_CME (M2KZ26). ID: 14 2026-10-12 07:47:02.953 | Mapping M2KH27_FUT_CME to M2KH27. Service code: cme 2026-10-12 07:47:02.953 | Denali Data Feed | Starting real-time market data updates for: M2KH27_FUT_CME (M2KH27). ID: 15 Service code: cme 2026-10-12 07:47:02.953 | Denali Data Feed | Requesting security definition data for: M2KH27_FUT_CME (M2KH27). ID: 15 2026-10-12 07:47:02.953 | Mapping M2KM27_FUT_CME to M2KM27. Service code: cme 2026-10-12 07:47:02.954 | Denali Data Feed | Starting real-time market data updates for: M2KM27_FUT_CME (M2KM27). ID: 16 Service code: cme 2026-10-12 07:47:02.954 | Denali Data Feed | Requesting security definition data for: M2KM27_FUT_CME (M2KM27). ID: 16 2026-10-12 07:47:02.954 | Mapping M2KU27_FUT_CME to M2KU27. Service code: cme 2026-10-12 07:47:02.954 | Denali Data Feed | Starting real-time market data updates for: M2KU27_FUT_CME (M2KU27). ID: 17 Service code: cme 2026-10-12 07:47:02.954 | Denali Data Feed | Requesting security definition data for: M2KU27_FUT_CME (M2KU27). ID: 17 2026-10-12 07:47:02.954 | Mapping M2KZ27_FUT_CME to M2KZ27. Service code: cme 2026-10-12 07:47:02.954 | Denali Data Feed | Starting real-time market data updates for: M2KZ27_FUT_CME (M2KZ27). ID: 18 Service code: cme 2026-10-12 07:47:02.954 | Denali Data Feed | Requesting security definition data for: M2KZ27_FUT_CME (M2KZ27). ID: 18 2026-10-12 07:47:02.954 | Mapping MCLX26_FUT_CME to MCLX26. Service code: nymex 2026-10-12 07:47:02.954 | Denali Data Feed | Starting real-time market data updates for: MCLX26_FUT_CME (MCLX26). ID: 19 Service code: nymex 2026-10-12 07:47:02.954 | Denali Data Feed | Requesting security definition data for: MCLX26_FUT_CME (MCLX26). ID: 19 2026-10-12 07:47:02.954 | Mapping MCLZ26_FUT_CME to MCLZ26. Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Starting real-time market data updates for: MCLZ26_FUT_CME (MCLZ26). ID: 20 Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Requesting security definition data for: MCLZ26_FUT_CME (MCLZ26). ID: 20 2026-10-12 07:47:02.955 | Mapping MCLF27_FUT_CME to MCLF27. Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Starting real-time market data updates for: MCLF27_FUT_CME (MCLF27). ID: 21 Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Requesting security definition data for: MCLF27_FUT_CME (MCLF27). ID: 21 2026-10-12 07:47:02.955 | Mapping MCLG27_FUT_CME to MCLG27. Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Starting real-time market data updates for: MCLG27_FUT_CME (MCLG27). ID: 22 Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Requesting security definition data for: MCLG27_FUT_CME (MCLG27). ID: 22 2026-10-12 07:47:02.955 | Mapping MCLH27_FUT_CME to MCLH27. Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Starting real-time market data updates for: MCLH27_FUT_CME (MCLH27). ID: 23 Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Requesting security definition data for: MCLH27_FUT_CME (MCLH27). ID: 23 2026-10-12 07:47:02.955 | Mapping MCLJ27_FUT_CME to MCLJ27. Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Starting real-time market data updates for: MCLJ27_FUT_CME (MCLJ27). ID: 24 Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Requesting security definition data for: MCLJ27_FUT_CME (MCLJ27). ID: 24 2026-10-12 07:47:02.955 | Mapping MCLK27_FUT_CME to MCLK27. Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Starting real-time market data updates for: MCLK27_FUT_CME (MCLK27). ID: 25 Service code: nymex 2026-10-12 07:47:02.955 | Denali Data Feed | Requesting security definition data for: MCLK27_FUT_CME (MCLK27). ID: 25 2026-10-12 07:47:02.955 | Mapping MGCZ26_FUT_CME to MGCZ26. Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Starting real-time market data updates for: MGCZ26_FUT_CME (MGCZ26). ID: 26 Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Requesting security definition data for: MGCZ26_FUT_CME (MGCZ26). ID: 26 2026-10-12 07:47:02.956 | Mapping MGCG27_FUT_CME to MGCG27. Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Starting real-time market data updates for: MGCG27_FUT_CME (MGCG27). ID: 27 Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Requesting security definition data for: MGCG27_FUT_CME (MGCG27). ID: 27 2026-10-12 07:47:02.956 | Mapping MGCJ27_FUT_CME to MGCJ27. Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Starting real-time market data updates for: MGCJ27_FUT_CME (MGCJ27). ID: 28 Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Requesting security definition data for: MGCJ27_FUT_CME (MGCJ27). ID: 28 2026-10-12 07:47:02.956 | Mapping MGCM27_FUT_CME to MGCM27. Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Starting real-time market data updates for: MGCM27_FUT_CME (MGCM27). ID: 29 Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Requesting security definition data for: MGCM27_FUT_CME (MGCM27). ID: 29 2026-10-12 07:47:02.956 | Mapping MGCQ27_FUT_CME to MGCQ27. Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Starting real-time market data updates for: MGCQ27_FUT_CME (MGCQ27). ID: 30 Service code: comex 2026-10-12 07:47:02.956 | Denali Data Feed | Requesting security definition data for: MGCQ27_FUT_CME (MGCQ27). ID: 30 2026-10-12 07:47:02.956 | Mapping MNGX26_FUT_CME to MNGX26. Service code: nymex 2026-10-12 07:47:02.956 | Denali Data Feed | Starting real-time market data updates for: MNGX26_FUT_CME (MNGX26). ID: 31 Service code: nymex 2026-10-12 07:47:02.956 | Denali Data Feed | Requesting security definition data for: MNGX26_FUT_CME (MNGX26). ID: 31 2026-10-12 07:47:02.956 | Mapping MNGZ26_FUT_CME to MNGZ26. Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Starting real-time market data updates for: MNGZ26_FUT_CME (MNGZ26). ID: 32 Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Requesting security definition data for: MNGZ26_FUT_CME (MNGZ26). ID: 32 2026-10-12 07:47:02.957 | Mapping MNGF27_FUT_CME to MNGF27. Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Starting real-time market data updates for: MNGF27_FUT_CME (MNGF27). ID: 33 Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Requesting security definition data for: MNGF27_FUT_CME (MNGF27). ID: 33 2026-10-12 07:47:02.957 | Mapping MNGG27_FUT_CME to MNGG27. Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Starting real-time market data updates for: MNGG27_FUT_CME (MNGG27). ID: 34 Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Requesting security definition data for: MNGG27_FUT_CME (MNGG27). ID: 34 2026-10-12 07:47:02.957 | Mapping MNGH27_FUT_CME to MNGH27. Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Starting real-time market data updates for: MNGH27_FUT_CME (MNGH27). ID: 35 Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Requesting security definition data for: MNGH27_FUT_CME (MNGH27). ID: 35 2026-10-12 07:47:02.957 | Mapping MNGJ27_FUT_CME to MNGJ27. Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Starting real-time market data updates for: MNGJ27_FUT_CME (MNGJ27). ID: 36 Service code: nymex 2026-10-12 07:47:02.957 | Denali Data Feed | Requesting security definition data for: MNGJ27_FUT_CME (MNGJ27). ID: 36 2026-10-12 07:47:02.957 | Mapping MES to MES. Service code: us_equities_utp_cta_exchange.data 2026-10-12 07:47:02.957 | Delayed Data Feed | Starting real-time market data updates for: MES (MES). ID: 37 Service code: us_equities_utp_cta_exchange.data 2026-10-12 07:47:02.958 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2026-10-12 07:47:02.958 | Delayed Data Feed | Requesting security definition data for: MES (MES). ID: 37 2026-10-12 07:47:02.980 | DTC Client socket (3) | Creating socket. 2026-10-12 07:47:02.980 | DTC Client socket (3) | New receive buffer size: 0 2026-10-12 07:47:02.980 | DTC Client socket (3) | Connecting to IP: 69.39.70.245 Port: 10043. 2026-10-12 07:47:02.985 | MESZ26_FUT_CME Weekly #2 | Chart data loading complete. 2026-10-12 07:47:02.992 | MESZ26_FUT_CME Daily #3 | Chart data loading complete. 2026-10-12 07:47:02.997 | MESZ26_FUT_CME [CV] Monthly #1 | Chart data loading complete. 2026-10-12 07:47:03.022 | MESZ26_FUT_CME Daily #11 | Chart data loading complete. 2026-10-12 07:47:03.032 | MYMZ26_FUT_CME Daily #12 | Chart data loading complete. 2026-10-12 07:47:03.050 | MYMZ26_FUT_CME 120 Min #13 | Chart data loading complete. 2026-10-12 07:47:03.063 | MYMZ26_FUT_CME 15 Min #14 | Chart data loading complete. 2026-10-12 07:47:03.075 | M2KZ26_FUT_CME Daily #17 | Chart data loading complete. 2026-10-12 07:47:03.085 | MYMZ26_FUT_CME 1 Min #15 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.090 | MYMZ26_FUT_CME 1 Min #15 | Chart data loading complete. 2026-10-12 07:47:03.105 | M2KZ26_FUT_CME 120 Min #18 | Chart data loading complete. 2026-10-12 07:47:03.118 | M2KZ26_FUT_CME 15 Min #19 | Chart data loading complete. 2026-10-12 07:47:03.128 | M2KZ26_FUT_CME 1 Min #20 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.133 | M2KZ26_FUT_CME 1 Min #20 | Chart data loading complete. 2026-10-12 07:47:03.135 | MESZ26_FUT_CME 240 Min #4 | Chart data loading complete. 2026-10-12 07:47:03.150 | MESZ26_FUT_CME 15 Min #8 | Chart data loading complete. 2026-10-12 07:47:03.159 | MESZ26_FUT_CME 1 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.164 | MESZ26_FUT_CME 1 Min #9 | Chart data loading complete. 2026-10-12 07:47:03.176 | MYMZ26_FUT_CME 15 Trades #16 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.185 | MYMZ26_FUT_CME 15 Trades #16 | Chart data loading complete. 2026-10-12 07:47:03.194 | M2KZ26_FUT_CME 15 Trades #21 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.201 | M2KZ26_FUT_CME 15 Trades #21 | Chart data loading complete. 2026-10-12 07:47:03.209 | MESZ26_FUT_CME 240 Min #5 | Chart data loading complete. 2026-10-12 07:47:03.216 | MESZ26_FUT_CME 15 Min #6 | Chart data loading complete. 2026-10-12 07:47:03.230 | MCLX26_FUT_CME Daily #26 | Chart data loading complete. 2026-10-12 07:47:03.244 | MCLX26_FUT_CME 15 Min #23 | Chart data loading complete. 2026-10-12 07:47:03.257 | MESZ26_FUT_CME 120 Min #7 | Chart data loading complete. 2026-10-12 07:47:03.265 | MCLX26_FUT_CME 1 Min #22 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.270 | MCLX26_FUT_CME 1 Min #22 | Chart data loading complete. 2026-10-12 07:47:03.270 | Delayed Data Feed | Network connection to server complete. 2026-10-12 07:47:03.270 | Delayed Data Feed | Starting socket receive thread. 2026-10-12 07:47:03.270 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-10-12 07:47:03.270 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ26_FUT_CME 2026-10-12 07:47:03.270 | Teton CME Routing | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-10-12 07:47:03.270 | Teton CME Routing | Received security definition for symbol MESZ26_FUT_CME 2026-10-12 07:47:03.270 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH27_FUT_CME 2026-10-12 07:47:03.270 | Teton CME Routing | Setting external service identifier for symbol MESH27_FUT_CME to 42003945 2026-10-12 07:47:03.270 | Teton CME Routing | Received security definition for symbol MESH27_FUT_CME 2026-10-12 07:47:03.270 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESM27_FUT_CME 2026-10-12 07:47:03.270 | Teton CME Routing | Setting external service identifier for symbol MESM27_FUT_CME to 3959 2026-10-12 07:47:03.270 | Teton CME Routing | Received security definition for symbol MESM27_FUT_CME 2026-10-12 07:47:03.321 | MCLX26_FUT_CME 60 Min #25 | Chart data loading complete. 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MESZ26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MESH27_FUT_CME to 42003945 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MESH27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MESM27_FUT_CME to 42023308 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MESM27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MESU27_FUT_CME to 42005735 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MESU27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MESZ27_FUT_CME to 42031405 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MESZ27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MYMZ26_FUT_CME to 42003082 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MYMZ26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MYMH27_FUT_CME to 42011748 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MYMH27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MYMM27_FUT_CME to 42046791 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MYMM27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MYMU27_FUT_CME to 42023363 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MYMU27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Real-time data for symbol MYMZ27_FUT_CME is currently unavailable. 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MYMZ27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol M2KZ26_FUT_CME to 42004535 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol M2KZ26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol M2KH27_FUT_CME to 42017384 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol M2KH27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol M2KM27_FUT_CME to 42020143 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol M2KM27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol M2KU27_FUT_CME to 42046788 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol M2KU27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol M2KZ27_FUT_CME to 42013685 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol M2KZ27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MCLX26_FUT_CME to 42025985 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MCLX26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MCLZ26_FUT_CME to 42026453 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MCLZ26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MCLF27_FUT_CME to 42001996 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MCLF27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MCLG27_FUT_CME to 42002509 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MCLG27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MCLH27_FUT_CME to 42000135 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MCLH27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MCLJ27_FUT_CME to 42001385 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MCLJ27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MCLK27_FUT_CME to 42000141 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MCLK27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MGCZ26_FUT_CME to 42031754 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MGCZ26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MGCG27_FUT_CME to 42020059 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MGCG27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MGCJ27_FUT_CME to 42001702 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MGCJ27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MGCM27_FUT_CME to 42024149 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MGCM27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MGCQ27_FUT_CME to 42010090 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MGCQ27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MNGX26_FUT_CME to 42005173 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MNGX26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MNGZ26_FUT_CME to 42039601 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MNGZ26_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MNGF27_FUT_CME to 42029134 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MNGF27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MNGG27_FUT_CME to 42001341 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MNGG27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MNGH27_FUT_CME to 42001299 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MNGH27_FUT_CME 2026-10-12 07:47:03.322 | Denali Data Feed | Setting external service identifier for symbol MNGJ27_FUT_CME to 42011199 2026-10-12 07:47:03.322 | Denali Data Feed | Received security definition for symbol MNGJ27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESU27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MESU27_FUT_CME to 3985 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MESU27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MESZ27_FUT_CME to 4011 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MESZ27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMZ26_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MYMZ26_FUT_CME to 42003082 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MYMZ26_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMH27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MYMH27_FUT_CME to 42011748 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MYMH27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMM27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MYMM27_FUT_CME to 4260 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MYMM27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMU27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MYMU27_FUT_CME to 4261 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MYMU27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MYMZ27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MYMZ27_FUT_CME to 4262 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MYMZ27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M2KZ26_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol M2KZ26_FUT_CME to 42004535 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol M2KZ26_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M2KH27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol M2KH27_FUT_CME to 42017384 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol M2KH27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M2KM27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol M2KM27_FUT_CME to 3105 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol M2KM27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M2KU27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol M2KU27_FUT_CME to 3132 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol M2KU27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: M2KZ27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol M2KZ27_FUT_CME to 3158 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol M2KZ27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLX26_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MCLX26_FUT_CME to 42025985 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MCLX26_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLZ26_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MCLZ26_FUT_CME to 42026453 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MCLZ26_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLF27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MCLF27_FUT_CME to 42001996 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MCLF27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLG27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MCLG27_FUT_CME to 42002509 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MCLG27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLH27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MCLH27_FUT_CME to 3827 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MCLH27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLJ27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MCLJ27_FUT_CME to 3836 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MCLJ27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MCLK27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MCLK27_FUT_CME to 3845 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MCLK27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MGCZ26_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MGCZ26_FUT_CME to 42031754 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MGCZ26_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MGCG27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MGCG27_FUT_CME to 42020059 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MGCG27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MGCJ27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MGCJ27_FUT_CME to 42001702 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MGCJ27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MGCM27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MGCM27_FUT_CME to 4171 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MGCM27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MGCQ27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MGCQ27_FUT_CME to 4189 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MGCQ27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNGX26_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MNGX26_FUT_CME to 4263 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MNGX26_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNGZ26_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MNGZ26_FUT_CME to 4264 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MNGZ26_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNGF27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MNGF27_FUT_CME to 4265 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MNGF27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNGG27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MNGG27_FUT_CME to 4266 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MNGG27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNGH27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MNGH27_FUT_CME to 4267 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MNGH27_FUT_CME 2026-10-12 07:47:03.322 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNGJ27_FUT_CME 2026-10-12 07:47:03.322 | Teton CME Routing | Setting external service identifier for symbol MNGJ27_FUT_CME to 4268 2026-10-12 07:47:03.322 | Teton CME Routing | Received security definition for symbol MNGJ27_FUT_CME 2026-10-12 07:47:03.466 | MCLX26_FUT_CME 20 Trades #24 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.476 | MCLX26_FUT_CME 20 Trades #24 | Chart data loading complete. 2026-10-12 07:47:03.476 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-10-12 07:47:03.476 | Delayed Data Feed | Sending logon request message. 2026-10-12 07:47:03.628 | Delayed Data Feed | Received logon response. 2026-10-12 07:47:03.628 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-10-12 07:47:03.628 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-10-12 07:47:03.628 | Delayed Data Feed | Successfully connected. 2026-10-12 07:47:03.628 | Delayed Data Feed | Trading is not supported. 2026-10-12 07:47:03.628 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-10-12 07:47:03.628 | Delayed Data Feed | Restarting real-time data updates for symbol: MES -> MES 2026-10-12 07:47:03.662 | Starting DelayedDownloadMonitoringTimer 2026-10-12 07:47:03.662 | Starting HDTimeoutTimer 2026-10-12 07:47:03.663 | Added historical Intraday data request for MESZ26_FUT_CME to the queue. 2026-10-12 07:47:03.663 | Intraday data recording state for symbol MESZ26_FUT_CME is set to download 'Pending'. 2026-10-12 07:47:03.663 | Triggering next historical data download in queue. 2026-10-12 07:47:03.663 | Removing historical data download ID 1. 2026-10-12 07:47:03.663 | Delaying start of download for MESZ26_FUT_CME. 2026-10-12 07:47:03.735 | Added historical Intraday data request for MYMZ26_FUT_CME to the queue. 2026-10-12 07:47:03.735 | Intraday data recording state for symbol MYMZ26_FUT_CME is set to download 'Pending'. 2026-10-12 07:47:03.735 | Triggering next historical data download in queue. 2026-10-12 07:47:03.775 | Added historical Intraday data request for M2KZ26_FUT_CME to the queue. 2026-10-12 07:47:03.775 | Intraday data recording state for symbol M2KZ26_FUT_CME is set to download 'Pending'. 2026-10-12 07:47:03.775 | Triggering next historical data download in queue. 2026-10-12 07:47:03.786 | Delayed Data Feed | Real-time data for symbol MES is currently unavailable. 2026-10-12 07:47:03.786 | Delayed Data Feed | Received security definition for symbol MES 2026-10-12 07:47:03.808 | Added historical Intraday data request for MCLX26_FUT_CME to the queue. 2026-10-12 07:47:03.808 | Intraday data recording state for symbol MCLX26_FUT_CME is set to download 'Pending'. 2026-10-12 07:47:03.808 | Triggering next historical data download in queue. 2026-10-12 07:47:03.947 | MESZ26_FUT_CME[M] 100 Trades #10 | StartDateTimeForLoadingOrderFills: 00:00:00 2026-10-12 07:47:03.953 | MESZ26_FUT_CME[M] 100 Trades #10 | Chart data loading complete. 2026-10-12 07:47:03.989 | Starting DelayedDownloadMonitoringTimer 2026-10-12 07:47:03.989 | Starting HDTimeoutTimer 2026-10-12 07:47:03.989 | Added historical Daily data request for MCLX26_FUT_CME to the queue. 2026-10-12 07:47:03.989 | Triggering next historical data download in queue. 2026-10-12 07:47:03.992 | Removing historical data download ID 5. 2026-10-12 07:47:03.993 | HD Request # 1 | Downloading Historical Daily chart data for MCLX26_FUT_CME. Starting date: 2026-10-07. Service: nymex 2026-10-12 07:47:03.993 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150 2026-10-12 07:47:03.994 | Socket (5) | Creating socket. 2026-10-12 07:47:03.994 | Socket (5) | New receive buffer size: 0 2026-10-12 07:47:03.994 | Socket (5) | Connecting to IP: 69.39.70.248 Port: 10150. 2026-10-12 07:47:04.089 | HD Request # 1 | Setting DTC encoding to Binary VLS 2026-10-12 07:47:04.089 | HD Request # 1 | Sending historical data logon request message. 2026-10-12 07:47:04.165 | HD Request # 1 | Requesting historical Daily data starting at 2026-10-07. 2026-10-12 07:47:04.212 | HD Request # 1 | Decompressing data. 2026-10-12 07:47:04.216 | HD Request # 1 | Receiving historical Daily data for MCLX26_FUT_CME starting at 2026-10-07. 2026-10-12 07:47:04.217 | HD Request # 1 | Writing historical Daily data to the file MCLX26_FUT_CME.dly. 2026-10-12 07:47:04.220 | Socket (5) | CloseSocket call. 2026-10-12 07:47:04.221 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-10-12 07:47:04.223 | Historical data download thread signaled to stop. 2026-10-12 07:47:04.223 | HD Request # 1 | Received 3 Daily data records from 2026-10-07 00:00:00 to 2026-10-09 00:00:00 (3.0 days) and wrote 3 records for MCLX26_FUT_CME 2026-10-12 07:47:04.223 | HD Request # 1 | Completion time: 1s. 2026-10-12 07:47:04.223 | HD Request # 1 | Daily data download complete for MCLX26_FUT_CME. Unique request ID: 5 2026-10-12 07:47:04.223 | Removing historical data download ID 5. 2026-10-12 07:47:04.223 | 2026-10-12 07:47:04.223 | No download requests in the queue to start downloads for. 2026-10-12 07:47:04.264 | MCLX26_FUT_CME[M] Daily #26 | Reloading chart. 2026-10-12 07:47:04.268 | Socket (5) | Socket gracefully closed by remote side. 2026-10-12 07:47:04.268 | Socket (5) | Closed. 2026-10-12 07:47:04.272 | MCLX26_FUT_CME[M] Daily #26 | Chart data loading complete. 2026-10-12 07:47:08.703 | HD Request # 2 | Downloading Intraday chart data for MESZ26_FUT_CME to the file MESZ26_FUT_CME.scid. Service: cme 2026-10-12 07:47:08.703 | HD Request # 2 | Download start date-time: 2026-10-12 07:45:30.000000. File last date-time: 2026-10-12 07:45:30.321001 2026-10-12 07:47:08.704 | HD Request # 2 | Using server: ds37.sierracharts.com port 10150 2026-10-12 07:47:08.704 | Socket (4) | Creating socket. 2026-10-12 07:47:08.704 | Socket (4) | New receive buffer size: 0 2026-10-12 07:47:08.704 | Socket (4) | Connecting to IP: 4.8.175.92 Port: 10150. 2026-10-12 07:47:08.780 | HD Request # 2 | Setting DTC encoding to Binary VLS 2026-10-12 07:47:08.780 | HD Request # 2 | Sending historical data logon request message. 2026-10-12 07:47:08.886 | HD Request # 2 | Requesting Intraday data. Start date-time: 2026-10-12 07:45:30. Record interval: 0. Symbol: MESZ26 2026-10-12 07:47:08.924 | HD Request # 2 | Decompressing data. 2026-10-12 07:47:08.962 | HD Request # 2 | Receiving Intraday data for MESZ26_FUT_CME starting at 2026-10-12 07:45:30.321000 2026-10-12 07:47:08.963 | Socket (4) | CloseSocket call. 2026-10-12 07:47:08.963 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-10-12 07:47:08.963 | Historical data download thread signaled to stop. 2026-10-12 07:47:08.963 | HD Request # 2 | Timestamp of first Intraday data file record written: 2026-10-12 07:45:31.732000. 2026-10-12 07:47:08.963 | HD Request # 2 | Received 145 Intraday data records from 2026-10-12 07:45:30.321000 to 2026-10-12 07:45:59.668000 (29.3 seconds. Delay: 69.3 seconds) and wrote 143 records for MESZ26_FUT_CME 2026-10-12 07:47:08.963 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2026-10-12 12:45:59.668000 2026-10-12 07:47:08.963 | Added 9 Time and Sales records to Intraday data file for MESZ26_FUT_CME after download. 2026-10-12 07:47:08.963 | HD Request # 2 | Completion time: 0s. 2026-10-12 07:47:08.963 | HD Request # 2 | Intraday data download complete for MESZ26_FUT_CME. Unique request ID: 1 2026-10-12 07:47:08.963 | Real-time Intraday chart data file updates started for MESZ26_FUT_CME 2026-10-12 07:47:08.963 | Intraday chart data file opened for MESZ26_FUT_CME 2026-10-12 07:47:08.963 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2026-10-12 07:47:08.963 | Removing historical data download ID 1. 2026-10-12 07:47:08.963 | 2026-10-12 07:47:08.963 | Triggering next historical data download in queue. 2026-10-12 07:47:08.963 | Removing historical data download ID 2. 2026-10-12 07:47:08.963 | HD Request # 3 | Downloading Intraday chart data for MYMZ26_FUT_CME to the file MYMZ26_FUT_CME.scid. Service: cbot 2026-10-12 07:47:08.964 | HD Request # 3 | Download start date-time: 2026-10-12 07:45:29.000000. File last date-time: 2026-10-12 07:45:29.113000 2026-10-12 07:47:08.964 | HD Request # 3 | Using server: ds28.sierracharts.com port 10149 2026-10-12 07:47:08.964 | Socket (5) | Creating socket. 2026-10-12 07:47:08.964 | Socket (5) | New receive buffer size: 0 2026-10-12 07:47:08.964 | Socket (5) | Connecting to IP: 67.214.125.5 Port: 10149. 2026-10-12 07:47:09.000 | Socket (4) | Socket gracefully closed by remote side. 2026-10-12 07:47:09.000 | Socket (4) | Closed. 2026-10-12 07:47:09.061 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-10-12 07:47:09.061 | HD Request # 3 | Sending historical data logon request message. 2026-10-12 07:47:09.145 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-10-12 07:45:29. Record interval: 0. Symbol: MYMZ26 2026-10-12 07:47:09.189 | HD Request # 3 | Decompressing data. 2026-10-12 07:47:09.234 | HD Request # 3 | Receiving Intraday data for MYMZ26_FUT_CME starting at 2026-10-12 07:45:29.113000 2026-10-12 07:47:09.234 | Socket (5) | CloseSocket call. 2026-10-12 07:47:09.234 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-10-12 07:47:09.235 | Historical data download thread signaled to stop. 2026-10-12 07:47:09.235 | HD Request # 3 | Timestamp of first Intraday data file record written: 2026-10-12 07:45:31.732000. 2026-10-12 07:47:09.235 | HD Request # 3 | Received 72 Intraday data records from 2026-10-12 07:45:29.113000 to 2026-10-12 07:45:58.899001 (29.8 seconds. Delay: 70.3 seconds) and wrote 71 records for MYMZ26_FUT_CME 2026-10-12 07:47:09.235 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-10-12 12:45:58.899001 2026-10-12 07:47:09.235 | Added 2 Time and Sales records to Intraday data file for MYMZ26_FUT_CME after download. 2026-10-12 07:47:09.235 | HD Request # 3 | Completion time: 1s. 2026-10-12 07:47:09.235 | HD Request # 3 | Intraday data download complete for MYMZ26_FUT_CME. Unique request ID: 2 2026-10-12 07:47:09.235 | Real-time Intraday chart data file updates started for MYMZ26_FUT_CME 2026-10-12 07:47:09.235 | Intraday chart data file opened for MYMZ26_FUT_CME 2026-10-12 07:47:09.235 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-10-12 07:47:09.235 | Removing historical data download ID 2. 2026-10-12 07:47:09.235 | 2026-10-12 07:47:09.235 | Triggering next historical data download in queue. 2026-10-12 07:47:09.235 | Removing historical data download ID 3. 2026-10-12 07:47:09.235 | HD Request # 4 | Downloading Intraday chart data for M2KZ26_FUT_CME to the file M2KZ26_FUT_CME.scid. Service: cme 2026-10-12 07:47:09.235 | HD Request # 4 | Download start date-time: 2026-10-12 07:45:27.000000. File last date-time: 2026-10-12 07:45:27.590000 2026-10-12 07:47:09.235 | HD Request # 4 | Using server: ds32.sierracharts.com port 10150 2026-10-12 07:47:09.235 | Socket (4) | Creating socket. 2026-10-12 07:47:09.235 | Socket (4) | New receive buffer size: 0 2026-10-12 07:47:09.235 | Socket (4) | Connecting to IP: 69.39.70.248 Port: 10150. 2026-10-12 07:47:09.280 | Socket (5) | Socket gracefully closed by remote side. 2026-10-12 07:47:09.280 | Socket (5) | Closed. 2026-10-12 07:47:09.335 | HD Request # 4 | Setting DTC encoding to Binary VLS 2026-10-12 07:47:09.335 | HD Request # 4 | Sending historical data logon request message. 2026-10-12 07:47:09.379 | HD Request # 4 | Requesting Intraday data. Start date-time: 2026-10-12 07:45:27. Record interval: 0. Symbol: M2KZ26 2026-10-12 07:47:09.425 | HD Request # 4 | Decompressing data. 2026-10-12 07:47:09.469 | HD Request # 4 | Receiving Intraday data for M2KZ26_FUT_CME starting at 2026-10-12 07:45:27.590000 2026-10-12 07:47:09.469 | Socket (4) | CloseSocket call. 2026-10-12 07:47:09.469 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-10-12 07:47:09.473 | Historical data download thread signaled to stop. 2026-10-12 07:47:09.473 | HD Request # 4 | Timestamp of first Intraday data file record written: 2026-10-12 07:45:38.302000. 2026-10-12 07:47:09.473 | HD Request # 4 | Received 10 Intraday data records from 2026-10-12 07:45:27.590000 to 2026-10-12 07:45:57.956001 (30.4 seconds. Delay: 71.5 seconds) and wrote 9 records for M2KZ26_FUT_CME 2026-10-12 07:47:09.473 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2026-10-12 12:45:57.956001 2026-10-12 07:47:09.473 | Added 1 Time and Sales records to Intraday data file for M2KZ26_FUT_CME after download. 2026-10-12 07:47:09.473 | HD Request # 4 | Completion time: 0s. 2026-10-12 07:47:09.473 | HD Request # 4 | Intraday data download complete for M2KZ26_FUT_CME. Unique request ID: 3 2026-10-12 07:47:09.473 | Real-time Intraday chart data file updates started for M2KZ26_FUT_CME 2026-10-12 07:47:09.473 | Intraday chart data file opened for M2KZ26_FUT_CME 2026-10-12 07:47:09.473 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2026-10-12 07:47:09.473 | Removing historical data download ID 3. 2026-10-12 07:47:09.473 | 2026-10-12 07:47:09.473 | Triggering next historical data download in queue. 2026-10-12 07:47:09.473 | Removing historical data download ID 4. 2026-10-12 07:47:09.473 | HD Request # 5 | Downloading Intraday chart data for MCLX26_FUT_CME to the file MCLX26_FUT_CME.scid. Service: nymex 2026-10-12 07:47:09.473 | HD Request # 5 | Download start date-time: 2026-10-12 07:45:30.000000. File last date-time: 2026-10-12 07:45:30.868004 2026-10-12 07:47:09.473 | HD Request # 5 | Using server: ds37.sierracharts.com port 10149 2026-10-12 07:47:09.474 | Socket (5) | Creating socket. 2026-10-12 07:47:09.474 | Socket (5) | New receive buffer size: 0 2026-10-12 07:47:09.474 | Socket (5) | Connecting to IP: 4.8.175.92 Port: 10149. 2026-10-12 07:47:09.513 | Socket (4) | Socket gracefully closed by remote side. 2026-10-12 07:47:09.513 | Socket (4) | Closed. 2026-10-12 07:47:09.556 | HD Request # 5 | Setting DTC encoding to Binary VLS 2026-10-12 07:47:09.556 | HD Request # 5 | Sending historical data logon request message. 2026-10-12 07:47:09.654 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-10-12 07:45:30. Record interval: 0. Symbol: MCLX26 2026-10-12 07:47:09.696 | HD Request # 5 | Decompressing data. 2026-10-12 07:47:09.733 | HD Request # 5 | Receiving Intraday data for MCLX26_FUT_CME starting at 2026-10-12 07:45:30.068000 2026-10-12 07:47:09.734 | Socket (5) | CloseSocket call. 2026-10-12 07:47:09.734 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-10-12 07:47:09.734 | Historical data download thread signaled to stop. 2026-10-12 07:47:09.734 | HD Request # 5 | Timestamp of first Intraday data file record written: 2026-10-12 07:45:33.285000. 2026-10-12 07:47:09.734 | HD Request # 5 | Received 90 Intraday data records from 2026-10-12 07:45:30.068000 to 2026-10-12 07:45:58.876004 (28.8 seconds. Delay: 70.9 seconds) and wrote 76 records for MCLX26_FUT_CME 2026-10-12 07:47:09.734 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-10-12 12:45:58.876004 2026-10-12 07:47:09.734 | Added 5 Time and Sales records to Intraday data file for MCLX26_FUT_CME after download. 2026-10-12 07:47:09.734 | HD Request # 5 | Completion time: 0s. 2026-10-12 07:47:09.734 | HD Request # 5 | Intraday data download complete for MCLX26_FUT_CME. Unique request ID: 4 2026-10-12 07:47:09.734 | Real-time Intraday chart data file updates started for MCLX26_FUT_CME 2026-10-12 07:47:09.734 | Intraday chart data file opened for MCLX26_FUT_CME 2026-10-12 07:47:09.734 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2026-10-12 07:47:09.734 | Removing historical data download ID 4. 2026-10-12 07:47:09.734 | 2026-10-12 07:47:09.734 | No download requests in the queue to start downloads for. 2026-10-12 07:47:09.773 | Socket (5) | Socket gracefully closed by remote side. 2026-10-12 07:47:09.773 | Socket (5) | Closed. 2026-10-12 07:47:13.605 | Opened cached Intraday file: C:\SierraChart\Data\MESZ26_FUT_CME.scid. Thread ID: 7432 2026-10-12 07:47:13.605 | Opened cached Intraday file: C:\SierraChart\Data\MYMZ26_FUT_CME.scid. Thread ID: 7432 2026-10-12 07:47:13.605 | Opened cached Intraday file: C:\SierraChart\Data\MCLX26_FUT_CME.scid. Thread ID: 7432 2026-10-12 07:47:18.402 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-10-12 07:47:18.609 | Opened cached Intraday file: C:\SierraChart\Data\M2KZ26_FUT_CME.scid. Thread ID: 7432 2026-10-12 07:47:18.817 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-11-08"}. Success=true 2026-10-12 07:52:51.147 | MESZ26_FUT_CME[M] 60 Min #5 | Reloading chart. 2026-10-12 07:52:51.889 | MESZ26_FUT_CME[M] 60 Min #5 | Chart data loading complete. 2026-10-12 07:53:22.051 | MESZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:53:22.789 | MESZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:53:23.620 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:53:23.650 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol MYMM19_FUT_CME starting at 2019-03-10. 2026-10-12 07:53:23.650 | Starting DelayedDownloadMonitoringTimer 2026-10-12 07:53:23.650 | Starting HDTimeoutTimer 2026-10-12 07:53:23.650 | Added historical Daily data request for MYMM19_FUT_CME to the queue. 2026-10-12 07:53:23.650 | Triggering next historical data download in queue. 2026-10-12 07:53:23.934 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MYMM19_FUT_CME * 2026-10-12 07:53:23.934 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Waiting for historical downloads to complete with the IDs: 6, 2026-10-12 07:53:23.937 | MYMZ26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 07:53:23.939 | MYMZ26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 07:53:23.940 | MYMZ26_FUT_CME[M] 240 Min #4 | Reloading chart. 2026-10-12 07:53:23.941 | MYMZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:53:23.942 | MYMZ26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 07:53:23.943 | Removing historical data download ID 6. 2026-10-12 07:53:23.943 | Mapping MYMM19_FUT_CME to MYMM19. Service code: cbot 2026-10-12 07:53:23.943 | HD Request # 6 | Downloading Historical Daily chart data for MYMM19_FUT_CME. Starting date: 2019-03-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:53:23.947 | MYMZ26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 07:53:23.952 | MYMZ26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 07:53:24.088 | MYMZ26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-10-12 07:53:24.093 | MYMZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:53:24.102 | MYMZ26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 07:53:24.374 | HD Request # 6 | Requesting historical Daily data for YRM19 starting at 2019-03-09. SC External HD service. 2026-10-12 07:53:24.624 | HD Request # 6 | Receiving historical Daily data for MYMM19_FUT_CME starting at 2019-05-01. 2026-10-12 07:53:24.624 | HD Request # 6 | Writing historical Daily data to the file MYMM19_FUT_CME.dly. 2026-10-12 07:53:24.625 | HD Request # 6 | Bytes received: 1907 2026-10-12 07:53:24.625 | HD Request # 6 | Received 37 Daily data records from 2019-05-01 00:00:00 to 2019-06-21 00:00:00 (52.0 days) and wrote 37 records for MYMM19_FUT_CME 2026-10-12 07:53:24.625 | HD Request # 6 | Completion time: 1s. 2026-10-12 07:53:24.625 | HD Request # 6 | Daily data download complete for MYMM19_FUT_CME. Unique request ID: 6 2026-10-12 07:53:24.625 | Removing historical data download ID 6. 2026-10-12 07:53:24.625 | 2026-10-12 07:53:24.625 | No download requests in the queue to start downloads for. 2026-10-12 07:53:24.638 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-12 07:53:24.638 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:53:24.638 | Unable to determine transition date based on volume from files: MYMU05_FUT_CME.dly, MYMZ05_FUT_CME.dly 2026-10-12 07:53:24.638 | The MYMZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.638 | Unable to determine transition date based on volume from files: MYMZ05_FUT_CME.dly, MYMH06_FUT_CME.dly 2026-10-12 07:53:24.638 | The MYMH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMH06_FUT_CME.dly, MYMM06_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMM06_FUT_CME.dly, MYMU06_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMU06_FUT_CME.dly, MYMZ06_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMZ06_FUT_CME.dly, MYMH07_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMH07_FUT_CME.dly, MYMM07_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMM07_FUT_CME.dly, MYMU07_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMU07_FUT_CME.dly, MYMZ07_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMZ07_FUT_CME.dly, MYMH08_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMH08_FUT_CME.dly, MYMM08_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.639 | Unable to determine transition date based on volume from files: MYMM08_FUT_CME.dly, MYMU08_FUT_CME.dly 2026-10-12 07:53:24.639 | The MYMU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMU08_FUT_CME.dly, MYMZ08_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMZ08_FUT_CME.dly, MYMH09_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMH09_FUT_CME.dly, MYMM09_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMM09_FUT_CME.dly, MYMU09_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMU09_FUT_CME.dly, MYMZ09_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMZ09_FUT_CME.dly, MYMH10_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMH10_FUT_CME.dly, MYMM10_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMM10_FUT_CME.dly, MYMU10_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMU10_FUT_CME.dly, MYMZ10_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMZ10_FUT_CME.dly, MYMH11_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.640 | Unable to determine transition date based on volume from files: MYMH11_FUT_CME.dly, MYMM11_FUT_CME.dly 2026-10-12 07:53:24.640 | The MYMM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMM11_FUT_CME.dly, MYMU11_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMU11_FUT_CME.dly, MYMZ11_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMZ11_FUT_CME.dly, MYMH12_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMH12_FUT_CME.dly, MYMM12_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMM12_FUT_CME.dly, MYMU12_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMU12_FUT_CME.dly, MYMZ12_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMZ12_FUT_CME.dly, MYMH13_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMH13_FUT_CME.dly, MYMM13_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMM13_FUT_CME.dly, MYMU13_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMU13_FUT_CME.dly, MYMZ13_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.641 | Unable to determine transition date based on volume from files: MYMZ13_FUT_CME.dly, MYMH14_FUT_CME.dly 2026-10-12 07:53:24.641 | The MYMH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMH14_FUT_CME.dly, MYMM14_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMM14_FUT_CME.dly, MYMU14_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMU14_FUT_CME.dly, MYMZ14_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMZ14_FUT_CME.dly, MYMH15_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMH15_FUT_CME.dly, MYMM15_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMM15_FUT_CME.dly, MYMU15_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMU15_FUT_CME.dly, MYMZ15_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMZ15_FUT_CME.dly, MYMH16_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMH16_FUT_CME.dly, MYMM16_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMM16_FUT_CME.dly, MYMU16_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMU16_FUT_CME.dly, MYMZ16_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.642 | Unable to determine transition date based on volume from files: MYMZ16_FUT_CME.dly, MYMH17_FUT_CME.dly 2026-10-12 07:53:24.642 | The MYMH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMH17_FUT_CME.dly, MYMM17_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMM17_FUT_CME.dly, MYMU17_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMU17_FUT_CME.dly, MYMZ17_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMZ17_FUT_CME.dly, MYMH18_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMH18_FUT_CME.dly, MYMM18_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMM18_FUT_CME.dly, MYMU18_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMU18_FUT_CME.dly, MYMZ18_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.643 | Unable to determine transition date based on volume from files: MYMZ18_FUT_CME.dly, MYMH19_FUT_CME.dly 2026-10-12 07:53:24.643 | The MYMH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:24.747 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 07:53:24.778 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:53:25.063 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MYMM19_FUT_CME * 2026-10-12 07:53:25.063 | Unable to determine transition date based on volume from files: MYMU05_FUT_CME.dly, MYMZ05_FUT_CME.dly 2026-10-12 07:53:25.063 | The MYMZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.063 | Unable to determine transition date based on volume from files: MYMZ05_FUT_CME.dly, MYMH06_FUT_CME.dly 2026-10-12 07:53:25.063 | The MYMH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.063 | Unable to determine transition date based on volume from files: MYMH06_FUT_CME.dly, MYMM06_FUT_CME.dly 2026-10-12 07:53:25.063 | The MYMM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMM06_FUT_CME.dly, MYMU06_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMU06_FUT_CME.dly, MYMZ06_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMZ06_FUT_CME.dly, MYMH07_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMH07_FUT_CME.dly, MYMM07_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMM07_FUT_CME.dly, MYMU07_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMU07_FUT_CME.dly, MYMZ07_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMZ07_FUT_CME.dly, MYMH08_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMH08_FUT_CME.dly, MYMM08_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMM08_FUT_CME.dly, MYMU08_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMU08_FUT_CME.dly, MYMZ08_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMZ08_FUT_CME.dly, MYMH09_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.064 | Unable to determine transition date based on volume from files: MYMH09_FUT_CME.dly, MYMM09_FUT_CME.dly 2026-10-12 07:53:25.064 | The MYMM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMM09_FUT_CME.dly, MYMU09_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMU09_FUT_CME.dly, MYMZ09_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMZ09_FUT_CME.dly, MYMH10_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMH10_FUT_CME.dly, MYMM10_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMM10_FUT_CME.dly, MYMU10_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMU10_FUT_CME.dly, MYMZ10_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMZ10_FUT_CME.dly, MYMH11_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMH11_FUT_CME.dly, MYMM11_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMM11_FUT_CME.dly, MYMU11_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMU11_FUT_CME.dly, MYMZ11_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMZ11_FUT_CME.dly, MYMH12_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.065 | Unable to determine transition date based on volume from files: MYMH12_FUT_CME.dly, MYMM12_FUT_CME.dly 2026-10-12 07:53:25.065 | The MYMM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMM12_FUT_CME.dly, MYMU12_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMU12_FUT_CME.dly, MYMZ12_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMZ12_FUT_CME.dly, MYMH13_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMH13_FUT_CME.dly, MYMM13_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMM13_FUT_CME.dly, MYMU13_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMU13_FUT_CME.dly, MYMZ13_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMZ13_FUT_CME.dly, MYMH14_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMH14_FUT_CME.dly, MYMM14_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMM14_FUT_CME.dly, MYMU14_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMU14_FUT_CME.dly, MYMZ14_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMZ14_FUT_CME.dly, MYMH15_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMH15_FUT_CME.dly, MYMM15_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.066 | Unable to determine transition date based on volume from files: MYMM15_FUT_CME.dly, MYMU15_FUT_CME.dly 2026-10-12 07:53:25.066 | The MYMU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMU15_FUT_CME.dly, MYMZ15_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMZ15_FUT_CME.dly, MYMH16_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMH16_FUT_CME.dly, MYMM16_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMM16_FUT_CME.dly, MYMU16_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMU16_FUT_CME.dly, MYMZ16_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMZ16_FUT_CME.dly, MYMH17_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMH17_FUT_CME.dly, MYMM17_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMM17_FUT_CME.dly, MYMU17_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMU17_FUT_CME.dly, MYMZ17_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMZ17_FUT_CME.dly, MYMH18_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMH18_FUT_CME.dly, MYMM18_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.067 | Unable to determine transition date based on volume from files: MYMM18_FUT_CME.dly, MYMU18_FUT_CME.dly 2026-10-12 07:53:25.067 | The MYMU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.068 | Unable to determine transition date based on volume from files: MYMU18_FUT_CME.dly, MYMZ18_FUT_CME.dly 2026-10-12 07:53:25.068 | The MYMZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.068 | Unable to determine transition date based on volume from files: MYMZ18_FUT_CME.dly, MYMH19_FUT_CME.dly 2026-10-12 07:53:25.068 | The MYMH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:53:25.172 | MYMZ26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 07:54:05.713 | MYMZ26_FUT_CME[M] 60 Min #5 | Reloading chart. 2026-10-12 07:54:05.863 | MYMZ26_FUT_CME[M] 60 Min #5 | Chart data loading complete. 2026-10-12 07:54:54.142 | MYMZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:54:54.294 | MYMZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:54:56.082 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:54:56.099 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM09_FUT_CME starting at last date in file. 2026-10-12 07:54:56.099 | Added historical Daily data request for M2KM09_FUT_CME to the queue. 2026-10-12 07:54:56.099 | Triggering next historical data download in queue. 2026-10-12 07:54:56.100 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU09_FUT_CME starting at last date in file. 2026-10-12 07:54:56.100 | Added historical Daily data request for M2KU09_FUT_CME to the queue. 2026-10-12 07:54:56.100 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ09_FUT_CME starting at last date in file. 2026-10-12 07:54:56.100 | Added historical Daily data request for M2KZ09_FUT_CME to the queue. 2026-10-12 07:54:56.101 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH10_FUT_CME starting at last date in file. 2026-10-12 07:54:56.101 | Added historical Daily data request for M2KH10_FUT_CME to the queue. 2026-10-12 07:54:56.102 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM10_FUT_CME starting at last date in file. 2026-10-12 07:54:56.102 | Added historical Daily data request for M2KM10_FUT_CME to the queue. 2026-10-12 07:54:56.102 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU10_FUT_CME starting at last date in file. 2026-10-12 07:54:56.102 | Added historical Daily data request for M2KU10_FUT_CME to the queue. 2026-10-12 07:54:56.103 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ10_FUT_CME starting at last date in file. 2026-10-12 07:54:56.103 | Added historical Daily data request for M2KZ10_FUT_CME to the queue. 2026-10-12 07:54:56.103 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH11_FUT_CME starting at last date in file. 2026-10-12 07:54:56.103 | Added historical Daily data request for M2KH11_FUT_CME to the queue. 2026-10-12 07:54:56.104 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM11_FUT_CME starting at last date in file. 2026-10-12 07:54:56.104 | Added historical Daily data request for M2KM11_FUT_CME to the queue. 2026-10-12 07:54:56.104 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU11_FUT_CME starting at last date in file. 2026-10-12 07:54:56.105 | Added historical Daily data request for M2KU11_FUT_CME to the queue. 2026-10-12 07:54:56.105 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ11_FUT_CME starting at last date in file. 2026-10-12 07:54:56.105 | Added historical Daily data request for M2KZ11_FUT_CME to the queue. 2026-10-12 07:54:56.106 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH12_FUT_CME starting at last date in file. 2026-10-12 07:54:56.106 | Added historical Daily data request for M2KH12_FUT_CME to the queue. 2026-10-12 07:54:56.106 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM12_FUT_CME starting at last date in file. 2026-10-12 07:54:56.106 | Added historical Daily data request for M2KM12_FUT_CME to the queue. 2026-10-12 07:54:56.107 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU12_FUT_CME starting at last date in file. 2026-10-12 07:54:56.107 | Added historical Daily data request for M2KU12_FUT_CME to the queue. 2026-10-12 07:54:56.108 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ12_FUT_CME starting at last date in file. 2026-10-12 07:54:56.108 | Added historical Daily data request for M2KZ12_FUT_CME to the queue. 2026-10-12 07:54:56.108 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH13_FUT_CME starting at last date in file. 2026-10-12 07:54:56.108 | Added historical Daily data request for M2KH13_FUT_CME to the queue. 2026-10-12 07:54:56.109 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM13_FUT_CME starting at last date in file. 2026-10-12 07:54:56.109 | Added historical Daily data request for M2KM13_FUT_CME to the queue. 2026-10-12 07:54:56.109 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU13_FUT_CME starting at last date in file. 2026-10-12 07:54:56.109 | Added historical Daily data request for M2KU13_FUT_CME to the queue. 2026-10-12 07:54:56.110 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ13_FUT_CME starting at last date in file. 2026-10-12 07:54:56.110 | Added historical Daily data request for M2KZ13_FUT_CME to the queue. 2026-10-12 07:54:56.111 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH14_FUT_CME starting at last date in file. 2026-10-12 07:54:56.111 | Added historical Daily data request for M2KH14_FUT_CME to the queue. 2026-10-12 07:54:56.111 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM14_FUT_CME starting at last date in file. 2026-10-12 07:54:56.111 | Added historical Daily data request for M2KM14_FUT_CME to the queue. 2026-10-12 07:54:56.112 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU14_FUT_CME starting at last date in file. 2026-10-12 07:54:56.112 | Added historical Daily data request for M2KU14_FUT_CME to the queue. 2026-10-12 07:54:56.112 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ14_FUT_CME starting at last date in file. 2026-10-12 07:54:56.112 | Added historical Daily data request for M2KZ14_FUT_CME to the queue. 2026-10-12 07:54:56.113 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH15_FUT_CME starting at last date in file. 2026-10-12 07:54:56.113 | Added historical Daily data request for M2KH15_FUT_CME to the queue. 2026-10-12 07:54:56.114 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM15_FUT_CME starting at last date in file. 2026-10-12 07:54:56.114 | Added historical Daily data request for M2KM15_FUT_CME to the queue. 2026-10-12 07:54:56.114 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU15_FUT_CME starting at last date in file. 2026-10-12 07:54:56.114 | Added historical Daily data request for M2KU15_FUT_CME to the queue. 2026-10-12 07:54:56.115 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ15_FUT_CME starting at last date in file. 2026-10-12 07:54:56.115 | Added historical Daily data request for M2KZ15_FUT_CME to the queue. 2026-10-12 07:54:56.116 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH16_FUT_CME starting at last date in file. 2026-10-12 07:54:56.116 | Added historical Daily data request for M2KH16_FUT_CME to the queue. 2026-10-12 07:54:56.116 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM16_FUT_CME starting at last date in file. 2026-10-12 07:54:56.116 | Added historical Daily data request for M2KM16_FUT_CME to the queue. 2026-10-12 07:54:56.117 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU16_FUT_CME starting at last date in file. 2026-10-12 07:54:56.117 | Added historical Daily data request for M2KU16_FUT_CME to the queue. 2026-10-12 07:54:56.117 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ16_FUT_CME starting at last date in file. 2026-10-12 07:54:56.117 | Added historical Daily data request for M2KZ16_FUT_CME to the queue. 2026-10-12 07:54:56.118 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH17_FUT_CME starting at last date in file. 2026-10-12 07:54:56.118 | Added historical Daily data request for M2KH17_FUT_CME to the queue. 2026-10-12 07:54:56.119 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM17_FUT_CME starting at last date in file. 2026-10-12 07:54:56.119 | Added historical Daily data request for M2KM17_FUT_CME to the queue. 2026-10-12 07:54:56.119 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU17_FUT_CME starting at last date in file. 2026-10-12 07:54:56.119 | Added historical Daily data request for M2KU17_FUT_CME to the queue. 2026-10-12 07:54:56.120 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ17_FUT_CME starting at last date in file. 2026-10-12 07:54:56.120 | Added historical Daily data request for M2KZ17_FUT_CME to the queue. 2026-10-12 07:54:56.121 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH18_FUT_CME starting at last date in file. 2026-10-12 07:54:56.121 | Added historical Daily data request for M2KH18_FUT_CME to the queue. 2026-10-12 07:54:56.121 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM18_FUT_CME starting at last date in file. 2026-10-12 07:54:56.121 | Added historical Daily data request for M2KM18_FUT_CME to the queue. 2026-10-12 07:54:56.122 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KU18_FUT_CME starting at last date in file. 2026-10-12 07:54:56.122 | Added historical Daily data request for M2KU18_FUT_CME to the queue. 2026-10-12 07:54:56.123 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KZ18_FUT_CME starting at last date in file. 2026-10-12 07:54:56.123 | Added historical Daily data request for M2KZ18_FUT_CME to the queue. 2026-10-12 07:54:56.123 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KH19_FUT_CME starting at last date in file. 2026-10-12 07:54:56.123 | Added historical Daily data request for M2KH19_FUT_CME to the queue. 2026-10-12 07:54:56.124 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol M2KM19_FUT_CME starting at 2019-03-10. 2026-10-12 07:54:56.124 | Added historical Daily data request for M2KM19_FUT_CME to the queue. 2026-10-12 07:54:56.416 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. M2KM19_FUT_CME * 2026-10-12 07:54:56.416 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 2026-10-12 07:54:56.418 | M2KZ26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 07:54:56.420 | M2KZ26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 07:54:56.421 | M2KZ26_FUT_CME[M] 240 Min #4 | Reloading chart. 2026-10-12 07:54:56.422 | M2KZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:54:56.423 | M2KZ26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 07:54:56.424 | Removing historical data download ID 7. 2026-10-12 07:54:56.424 | Mapping M2KM09_FUT_CME to M2KM09. Service code: cme 2026-10-12 07:54:56.425 | HD Request # 7 | Downloading Historical Daily chart data for M2KM09_FUT_CME. Starting date: 2008-09-26. Service: sc_futures_direct.dtc.trading 2026-10-12 07:54:56.430 | M2KZ26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 07:54:56.436 | M2KZ26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 07:54:56.515 | M2KZ26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-10-12 07:54:56.520 | M2KZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:54:56.524 | M2KZ26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 07:54:56.865 | HD Request # 7 | Requesting historical Daily data for RXM09 starting at 2008-09-25. SC External HD service. 2026-10-12 07:54:57.074 | HD Request # 7 | Receiving historical Daily data for M2KM09_FUT_CME starting at 2008-09-26. 2026-10-12 07:54:57.074 | HD Request # 7 | Writing historical Daily data to the file M2KM09_FUT_CME.dly. 2026-10-12 07:54:57.075 | HD Request # 7 | Bytes received: 180 2026-10-12 07:54:57.075 | HD Request # 7 | Received 4 Daily data records from 2008-09-26 00:00:00 to 2008-09-30 00:00:00 (5.0 days) and wrote 3 records for M2KM09_FUT_CME 2026-10-12 07:54:57.075 | HD Request # 7 | Completion time: 1s. 2026-10-12 07:54:57.075 | HD Request # 7 | Daily data download complete for M2KM09_FUT_CME. Unique request ID: 7 2026-10-12 07:54:57.075 | Removing historical data download ID 7. 2026-10-12 07:54:57.075 | 2026-10-12 07:54:57.075 | Triggering next historical data download in queue. 2026-10-12 07:54:57.075 | Removing historical data download ID 8. 2026-10-12 07:54:57.075 | Mapping M2KU09_FUT_CME to M2KU09. Service code: cme 2026-10-12 07:54:57.076 | HD Request # 8 | Downloading Historical Daily chart data for M2KU09_FUT_CME. Starting date: 2008-09-26. Service: sc_futures_direct.dtc.trading 2026-10-12 07:54:57.493 | HD Request # 8 | Requesting historical Daily data for RXU09 starting at 2008-09-25. SC External HD service. 2026-10-12 07:54:57.704 | HD Request # 8 | Receiving historical Daily data for M2KU09_FUT_CME starting at 2008-09-26. 2026-10-12 07:54:57.704 | HD Request # 8 | Writing historical Daily data to the file M2KU09_FUT_CME.dly. 2026-10-12 07:54:57.705 | HD Request # 8 | Bytes received: 180 2026-10-12 07:54:57.705 | HD Request # 8 | Received 4 Daily data records from 2008-09-26 00:00:00 to 2008-09-30 00:00:00 (5.0 days) and wrote 3 records for M2KU09_FUT_CME 2026-10-12 07:54:57.705 | HD Request # 8 | Completion time: 0s. 2026-10-12 07:54:57.705 | HD Request # 8 | Daily data download complete for M2KU09_FUT_CME. Unique request ID: 8 2026-10-12 07:54:57.705 | Removing historical data download ID 8. 2026-10-12 07:54:57.705 | 2026-10-12 07:54:57.705 | Triggering next historical data download in queue. 2026-10-12 07:54:57.705 | Removing historical data download ID 9. 2026-10-12 07:54:57.705 | Mapping M2KZ09_FUT_CME to M2KZ09. Service code: cme 2026-10-12 07:54:57.705 | HD Request # 9 | Downloading Historical Daily chart data for M2KZ09_FUT_CME. Starting date: 1970-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:54:58.124 | HD Request # 9 | Requesting historical Daily data for RXZ09 starting at 1970-01-09. SC External HD service. 2026-10-12 07:54:58.275 | HD Request # 9 | Bytes received: 1 2026-10-12 07:54:58.275 | HD Request # 9 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ09_FUT_CME 2026-10-12 07:54:58.275 | HD Request # 9 | Completion time: 1s. 2026-10-12 07:54:58.275 | HD Request # 9 | Daily data download complete for M2KZ09_FUT_CME. Unique request ID: 9 2026-10-12 07:54:58.275 | Removing historical data download ID 9. 2026-10-12 07:54:58.275 | 2026-10-12 07:54:58.275 | Triggering next historical data download in queue. 2026-10-12 07:54:58.275 | Removing historical data download ID 10. 2026-10-12 07:54:58.275 | Mapping M2KH10_FUT_CME to M2KH10. Service code: cme 2026-10-12 07:54:58.276 | HD Request # 10 | Downloading Historical Daily chart data for M2KH10_FUT_CME. Starting date: 1970-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:54:58.698 | HD Request # 10 | Requesting historical Daily data for RXH10 starting at 1970-04-09. SC External HD service. 2026-10-12 07:54:58.837 | HD Request # 10 | Bytes received: 1 2026-10-12 07:54:58.837 | HD Request # 10 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH10_FUT_CME 2026-10-12 07:54:58.837 | HD Request # 10 | Completion time: 0s. 2026-10-12 07:54:58.837 | HD Request # 10 | Daily data download complete for M2KH10_FUT_CME. Unique request ID: 10 2026-10-12 07:54:58.837 | Removing historical data download ID 10. 2026-10-12 07:54:58.837 | 2026-10-12 07:54:58.837 | Triggering next historical data download in queue. 2026-10-12 07:54:58.837 | Removing historical data download ID 11. 2026-10-12 07:54:58.837 | Mapping M2KM10_FUT_CME to M2KM10. Service code: cme 2026-10-12 07:54:58.837 | HD Request # 11 | Downloading Historical Daily chart data for M2KM10_FUT_CME. Starting date: 1970-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:54:59.274 | HD Request # 11 | Requesting historical Daily data for RXM10 starting at 1970-07-09. SC External HD service. 2026-10-12 07:54:59.385 | HD Request # 11 | Bytes received: 1 2026-10-12 07:54:59.385 | HD Request # 11 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM10_FUT_CME 2026-10-12 07:54:59.385 | HD Request # 11 | Completion time: 1s. 2026-10-12 07:54:59.385 | HD Request # 11 | Daily data download complete for M2KM10_FUT_CME. Unique request ID: 11 2026-10-12 07:54:59.385 | Removing historical data download ID 11. 2026-10-12 07:54:59.385 | 2026-10-12 07:54:59.385 | Triggering next historical data download in queue. 2026-10-12 07:54:59.385 | Removing historical data download ID 12. 2026-10-12 07:54:59.385 | Mapping M2KU10_FUT_CME to M2KU10. Service code: cme 2026-10-12 07:54:59.385 | HD Request # 12 | Downloading Historical Daily chart data for M2KU10_FUT_CME. Starting date: 1970-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:54:59.814 | HD Request # 12 | Requesting historical Daily data for RXU10 starting at 1970-10-09. SC External HD service. 2026-10-12 07:54:59.934 | HD Request # 12 | Bytes received: 1 2026-10-12 07:54:59.934 | HD Request # 12 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU10_FUT_CME 2026-10-12 07:54:59.934 | HD Request # 12 | Completion time: 0s. 2026-10-12 07:54:59.934 | HD Request # 12 | Daily data download complete for M2KU10_FUT_CME. Unique request ID: 12 2026-10-12 07:54:59.934 | Removing historical data download ID 12. 2026-10-12 07:54:59.934 | 2026-10-12 07:54:59.934 | Triggering next historical data download in queue. 2026-10-12 07:54:59.934 | Removing historical data download ID 13. 2026-10-12 07:54:59.934 | Mapping M2KZ10_FUT_CME to M2KZ10. Service code: cme 2026-10-12 07:54:59.934 | HD Request # 13 | Downloading Historical Daily chart data for M2KZ10_FUT_CME. Starting date: 1971-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:00.362 | HD Request # 13 | Requesting historical Daily data for RXZ10 starting at 1971-01-09. SC External HD service. 2026-10-12 07:55:00.486 | HD Request # 13 | Bytes received: 1 2026-10-12 07:55:00.486 | HD Request # 13 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ10_FUT_CME 2026-10-12 07:55:00.486 | HD Request # 13 | Completion time: 1s. 2026-10-12 07:55:00.486 | HD Request # 13 | Daily data download complete for M2KZ10_FUT_CME. Unique request ID: 13 2026-10-12 07:55:00.486 | Removing historical data download ID 13. 2026-10-12 07:55:00.486 | 2026-10-12 07:55:00.486 | Triggering next historical data download in queue. 2026-10-12 07:55:00.486 | Removing historical data download ID 14. 2026-10-12 07:55:00.486 | Mapping M2KH11_FUT_CME to M2KH11. Service code: cme 2026-10-12 07:55:00.486 | HD Request # 14 | Downloading Historical Daily chart data for M2KH11_FUT_CME. Starting date: 1971-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:00.907 | HD Request # 14 | Requesting historical Daily data for RXH11 starting at 1971-04-09. SC External HD service. 2026-10-12 07:55:01.022 | HD Request # 14 | Bytes received: 1 2026-10-12 07:55:01.022 | HD Request # 14 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH11_FUT_CME 2026-10-12 07:55:01.022 | HD Request # 14 | Completion time: 1s. 2026-10-12 07:55:01.022 | HD Request # 14 | Daily data download complete for M2KH11_FUT_CME. Unique request ID: 14 2026-10-12 07:55:01.022 | Removing historical data download ID 14. 2026-10-12 07:55:01.022 | 2026-10-12 07:55:01.022 | Triggering next historical data download in queue. 2026-10-12 07:55:01.022 | Removing historical data download ID 15. 2026-10-12 07:55:01.022 | Mapping M2KM11_FUT_CME to M2KM11. Service code: cme 2026-10-12 07:55:01.023 | HD Request # 15 | Downloading Historical Daily chart data for M2KM11_FUT_CME. Starting date: 1971-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:01.447 | HD Request # 15 | Requesting historical Daily data for RXM11 starting at 1971-07-09. SC External HD service. 2026-10-12 07:55:01.569 | HD Request # 15 | Bytes received: 1 2026-10-12 07:55:01.569 | HD Request # 15 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM11_FUT_CME 2026-10-12 07:55:01.569 | HD Request # 15 | Completion time: 0s. 2026-10-12 07:55:01.569 | HD Request # 15 | Daily data download complete for M2KM11_FUT_CME. Unique request ID: 15 2026-10-12 07:55:01.569 | Removing historical data download ID 15. 2026-10-12 07:55:01.569 | 2026-10-12 07:55:01.569 | Triggering next historical data download in queue. 2026-10-12 07:55:01.569 | Removing historical data download ID 16. 2026-10-12 07:55:01.569 | Mapping M2KU11_FUT_CME to M2KU11. Service code: cme 2026-10-12 07:55:01.570 | HD Request # 16 | Downloading Historical Daily chart data for M2KU11_FUT_CME. Starting date: 1971-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:01.984 | HD Request # 16 | Requesting historical Daily data for RXU11 starting at 1971-10-09. SC External HD service. 2026-10-12 07:55:02.093 | HD Request # 16 | Bytes received: 1 2026-10-12 07:55:02.093 | HD Request # 16 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU11_FUT_CME 2026-10-12 07:55:02.093 | HD Request # 16 | Completion time: 1s. 2026-10-12 07:55:02.093 | HD Request # 16 | Daily data download complete for M2KU11_FUT_CME. Unique request ID: 16 2026-10-12 07:55:02.093 | Removing historical data download ID 16. 2026-10-12 07:55:02.093 | 2026-10-12 07:55:02.093 | Triggering next historical data download in queue. 2026-10-12 07:55:02.094 | Removing historical data download ID 17. 2026-10-12 07:55:02.094 | Mapping M2KZ11_FUT_CME to M2KZ11. Service code: cme 2026-10-12 07:55:02.094 | HD Request # 17 | Downloading Historical Daily chart data for M2KZ11_FUT_CME. Starting date: 1972-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:02.517 | HD Request # 17 | Requesting historical Daily data for RXZ11 starting at 1972-01-09. SC External HD service. 2026-10-12 07:55:02.636 | HD Request # 17 | Bytes received: 1 2026-10-12 07:55:02.636 | HD Request # 17 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ11_FUT_CME 2026-10-12 07:55:02.636 | HD Request # 17 | Completion time: 0s. 2026-10-12 07:55:02.636 | HD Request # 17 | Daily data download complete for M2KZ11_FUT_CME. Unique request ID: 17 2026-10-12 07:55:02.636 | Removing historical data download ID 17. 2026-10-12 07:55:02.636 | 2026-10-12 07:55:02.637 | Triggering next historical data download in queue. 2026-10-12 07:55:02.637 | Removing historical data download ID 18. 2026-10-12 07:55:02.637 | Mapping M2KH12_FUT_CME to M2KH12. Service code: cme 2026-10-12 07:55:02.637 | HD Request # 18 | Downloading Historical Daily chart data for M2KH12_FUT_CME. Starting date: 1972-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:03.078 | HD Request # 18 | Requesting historical Daily data for RXH12 starting at 1972-04-09. SC External HD service. 2026-10-12 07:55:03.192 | HD Request # 18 | Bytes received: 1 2026-10-12 07:55:03.192 | HD Request # 18 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH12_FUT_CME 2026-10-12 07:55:03.192 | HD Request # 18 | Completion time: 1s. 2026-10-12 07:55:03.192 | HD Request # 18 | Daily data download complete for M2KH12_FUT_CME. Unique request ID: 18 2026-10-12 07:55:03.192 | Removing historical data download ID 18. 2026-10-12 07:55:03.192 | 2026-10-12 07:55:03.192 | Triggering next historical data download in queue. 2026-10-12 07:55:03.192 | Removing historical data download ID 19. 2026-10-12 07:55:03.192 | Mapping M2KM12_FUT_CME to M2KM12. Service code: cme 2026-10-12 07:55:03.192 | HD Request # 19 | Downloading Historical Daily chart data for M2KM12_FUT_CME. Starting date: 1972-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:03.633 | HD Request # 19 | Requesting historical Daily data for RXM12 starting at 1972-07-09. SC External HD service. 2026-10-12 07:55:03.749 | HD Request # 19 | Bytes received: 1 2026-10-12 07:55:03.749 | HD Request # 19 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM12_FUT_CME 2026-10-12 07:55:03.749 | HD Request # 19 | Completion time: 0s. 2026-10-12 07:55:03.749 | HD Request # 19 | Daily data download complete for M2KM12_FUT_CME. Unique request ID: 19 2026-10-12 07:55:03.749 | Removing historical data download ID 19. 2026-10-12 07:55:03.749 | 2026-10-12 07:55:03.749 | Triggering next historical data download in queue. 2026-10-12 07:55:03.749 | Removing historical data download ID 20. 2026-10-12 07:55:03.749 | Mapping M2KU12_FUT_CME to M2KU12. Service code: cme 2026-10-12 07:55:03.749 | HD Request # 20 | Downloading Historical Daily chart data for M2KU12_FUT_CME. Starting date: 1972-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:04.166 | HD Request # 20 | Requesting historical Daily data for RXU12 starting at 1972-10-09. SC External HD service. 2026-10-12 07:55:04.277 | HD Request # 20 | Bytes received: 1 2026-10-12 07:55:04.277 | HD Request # 20 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU12_FUT_CME 2026-10-12 07:55:04.277 | HD Request # 20 | Completion time: 1s. 2026-10-12 07:55:04.277 | HD Request # 20 | Daily data download complete for M2KU12_FUT_CME. Unique request ID: 20 2026-10-12 07:55:04.277 | Removing historical data download ID 20. 2026-10-12 07:55:04.277 | 2026-10-12 07:55:04.277 | Triggering next historical data download in queue. 2026-10-12 07:55:04.277 | Removing historical data download ID 21. 2026-10-12 07:55:04.277 | Mapping M2KZ12_FUT_CME to M2KZ12. Service code: cme 2026-10-12 07:55:04.278 | HD Request # 21 | Downloading Historical Daily chart data for M2KZ12_FUT_CME. Starting date: 1973-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:04.697 | HD Request # 21 | Requesting historical Daily data for RXZ12 starting at 1973-01-09. SC External HD service. 2026-10-12 07:55:04.808 | HD Request # 21 | Bytes received: 1 2026-10-12 07:55:04.808 | HD Request # 21 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ12_FUT_CME 2026-10-12 07:55:04.808 | HD Request # 21 | Completion time: 0s. 2026-10-12 07:55:04.808 | HD Request # 21 | Daily data download complete for M2KZ12_FUT_CME. Unique request ID: 21 2026-10-12 07:55:04.808 | Removing historical data download ID 21. 2026-10-12 07:55:04.808 | 2026-10-12 07:55:04.808 | Triggering next historical data download in queue. 2026-10-12 07:55:04.808 | Removing historical data download ID 22. 2026-10-12 07:55:04.808 | Mapping M2KH13_FUT_CME to M2KH13. Service code: cme 2026-10-12 07:55:04.809 | HD Request # 22 | Downloading Historical Daily chart data for M2KH13_FUT_CME. Starting date: 1973-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:05.230 | HD Request # 22 | Requesting historical Daily data for RXH13 starting at 1973-04-09. SC External HD service. 2026-10-12 07:55:05.337 | HD Request # 22 | Bytes received: 1 2026-10-12 07:55:05.337 | HD Request # 22 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH13_FUT_CME 2026-10-12 07:55:05.337 | HD Request # 22 | Completion time: 1s. 2026-10-12 07:55:05.337 | HD Request # 22 | Daily data download complete for M2KH13_FUT_CME. Unique request ID: 22 2026-10-12 07:55:05.337 | Removing historical data download ID 22. 2026-10-12 07:55:05.337 | 2026-10-12 07:55:05.337 | Triggering next historical data download in queue. 2026-10-12 07:55:05.337 | Removing historical data download ID 23. 2026-10-12 07:55:05.337 | Mapping M2KM13_FUT_CME to M2KM13. Service code: cme 2026-10-12 07:55:05.338 | HD Request # 23 | Downloading Historical Daily chart data for M2KM13_FUT_CME. Starting date: 1973-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:05.769 | HD Request # 23 | Requesting historical Daily data for RXM13 starting at 1973-07-09. SC External HD service. 2026-10-12 07:55:05.882 | HD Request # 23 | Bytes received: 1 2026-10-12 07:55:05.882 | HD Request # 23 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM13_FUT_CME 2026-10-12 07:55:05.882 | HD Request # 23 | Completion time: 0s. 2026-10-12 07:55:05.882 | HD Request # 23 | Daily data download complete for M2KM13_FUT_CME. Unique request ID: 23 2026-10-12 07:55:05.882 | Removing historical data download ID 23. 2026-10-12 07:55:05.882 | 2026-10-12 07:55:05.882 | Triggering next historical data download in queue. 2026-10-12 07:55:05.882 | Removing historical data download ID 24. 2026-10-12 07:55:05.882 | Mapping M2KU13_FUT_CME to M2KU13. Service code: cme 2026-10-12 07:55:05.883 | HD Request # 24 | Downloading Historical Daily chart data for M2KU13_FUT_CME. Starting date: 1973-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:06.307 | HD Request # 24 | Requesting historical Daily data for RXU13 starting at 1973-10-09. SC External HD service. 2026-10-12 07:55:06.335 | M2KZ26_FUT_CME[M] 60 Min #5 | Reloading chart. 2026-10-12 07:55:06.426 | HD Request # 24 | Bytes received: 1 2026-10-12 07:55:06.426 | HD Request # 24 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU13_FUT_CME 2026-10-12 07:55:06.426 | HD Request # 24 | Completion time: 1s. 2026-10-12 07:55:06.426 | HD Request # 24 | Daily data download complete for M2KU13_FUT_CME. Unique request ID: 24 2026-10-12 07:55:06.426 | Removing historical data download ID 24. 2026-10-12 07:55:06.426 | 2026-10-12 07:55:06.426 | Triggering next historical data download in queue. 2026-10-12 07:55:06.431 | M2KZ26_FUT_CME[M] 60 Min #5 | Chart data loading complete. 2026-10-12 07:55:06.431 | Removing historical data download ID 25. 2026-10-12 07:55:06.431 | Mapping M2KZ13_FUT_CME to M2KZ13. Service code: cme 2026-10-12 07:55:06.432 | HD Request # 25 | Downloading Historical Daily chart data for M2KZ13_FUT_CME. Starting date: 1974-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:06.860 | HD Request # 25 | Requesting historical Daily data for RXZ13 starting at 1974-01-09. SC External HD service. 2026-10-12 07:55:06.967 | HD Request # 25 | Bytes received: 1 2026-10-12 07:55:06.967 | HD Request # 25 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ13_FUT_CME 2026-10-12 07:55:06.967 | HD Request # 25 | Completion time: 0s. 2026-10-12 07:55:06.967 | HD Request # 25 | Daily data download complete for M2KZ13_FUT_CME. Unique request ID: 25 2026-10-12 07:55:06.967 | Removing historical data download ID 25. 2026-10-12 07:55:06.967 | 2026-10-12 07:55:06.967 | Triggering next historical data download in queue. 2026-10-12 07:55:06.967 | Removing historical data download ID 26. 2026-10-12 07:55:06.967 | Mapping M2KH14_FUT_CME to M2KH14. Service code: cme 2026-10-12 07:55:06.967 | HD Request # 26 | Downloading Historical Daily chart data for M2KH14_FUT_CME. Starting date: 1974-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:07.391 | HD Request # 26 | Requesting historical Daily data for RXH14 starting at 1974-04-09. SC External HD service. 2026-10-12 07:55:07.508 | HD Request # 26 | Bytes received: 1 2026-10-12 07:55:07.508 | HD Request # 26 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH14_FUT_CME 2026-10-12 07:55:07.508 | HD Request # 26 | Completion time: 1s. 2026-10-12 07:55:07.508 | HD Request # 26 | Daily data download complete for M2KH14_FUT_CME. Unique request ID: 26 2026-10-12 07:55:07.508 | Removing historical data download ID 26. 2026-10-12 07:55:07.508 | 2026-10-12 07:55:07.508 | Triggering next historical data download in queue. 2026-10-12 07:55:07.508 | Removing historical data download ID 27. 2026-10-12 07:55:07.508 | Mapping M2KM14_FUT_CME to M2KM14. Service code: cme 2026-10-12 07:55:07.508 | HD Request # 27 | Downloading Historical Daily chart data for M2KM14_FUT_CME. Starting date: 1974-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:07.934 | HD Request # 27 | Requesting historical Daily data for RXM14 starting at 1974-07-09. SC External HD service. 2026-10-12 07:55:08.049 | HD Request # 27 | Bytes received: 1 2026-10-12 07:55:08.049 | HD Request # 27 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM14_FUT_CME 2026-10-12 07:55:08.049 | HD Request # 27 | Completion time: 1s. 2026-10-12 07:55:08.049 | HD Request # 27 | Daily data download complete for M2KM14_FUT_CME. Unique request ID: 27 2026-10-12 07:55:08.049 | Removing historical data download ID 27. 2026-10-12 07:55:08.049 | 2026-10-12 07:55:08.049 | Triggering next historical data download in queue. 2026-10-12 07:55:08.050 | Removing historical data download ID 28. 2026-10-12 07:55:08.050 | Mapping M2KU14_FUT_CME to M2KU14. Service code: cme 2026-10-12 07:55:08.050 | HD Request # 28 | Downloading Historical Daily chart data for M2KU14_FUT_CME. Starting date: 1974-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:08.483 | HD Request # 28 | Requesting historical Daily data for RXU14 starting at 1974-10-09. SC External HD service. 2026-10-12 07:55:08.594 | HD Request # 28 | Bytes received: 1 2026-10-12 07:55:08.594 | HD Request # 28 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU14_FUT_CME 2026-10-12 07:55:08.594 | HD Request # 28 | Completion time: 0s. 2026-10-12 07:55:08.594 | HD Request # 28 | Daily data download complete for M2KU14_FUT_CME. Unique request ID: 28 2026-10-12 07:55:08.594 | Removing historical data download ID 28. 2026-10-12 07:55:08.594 | 2026-10-12 07:55:08.594 | Triggering next historical data download in queue. 2026-10-12 07:55:08.594 | Removing historical data download ID 29. 2026-10-12 07:55:08.594 | Mapping M2KZ14_FUT_CME to M2KZ14. Service code: cme 2026-10-12 07:55:08.595 | HD Request # 29 | Downloading Historical Daily chart data for M2KZ14_FUT_CME. Starting date: 1975-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:09.015 | HD Request # 29 | Requesting historical Daily data for RXZ14 starting at 1975-01-09. SC External HD service. 2026-10-12 07:55:09.130 | HD Request # 29 | Bytes received: 1 2026-10-12 07:55:09.130 | HD Request # 29 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ14_FUT_CME 2026-10-12 07:55:09.130 | HD Request # 29 | Completion time: 1s. 2026-10-12 07:55:09.130 | HD Request # 29 | Daily data download complete for M2KZ14_FUT_CME. Unique request ID: 29 2026-10-12 07:55:09.130 | Removing historical data download ID 29. 2026-10-12 07:55:09.130 | 2026-10-12 07:55:09.130 | Triggering next historical data download in queue. 2026-10-12 07:55:09.130 | Removing historical data download ID 30. 2026-10-12 07:55:09.130 | Mapping M2KH15_FUT_CME to M2KH15. Service code: cme 2026-10-12 07:55:09.130 | HD Request # 30 | Downloading Historical Daily chart data for M2KH15_FUT_CME. Starting date: 1975-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:09.556 | HD Request # 30 | Requesting historical Daily data for RXH15 starting at 1975-04-09. SC External HD service. 2026-10-12 07:55:09.672 | HD Request # 30 | Bytes received: 1 2026-10-12 07:55:09.672 | HD Request # 30 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH15_FUT_CME 2026-10-12 07:55:09.672 | HD Request # 30 | Completion time: 0s. 2026-10-12 07:55:09.672 | HD Request # 30 | Daily data download complete for M2KH15_FUT_CME. Unique request ID: 30 2026-10-12 07:55:09.672 | Removing historical data download ID 30. 2026-10-12 07:55:09.672 | 2026-10-12 07:55:09.672 | Triggering next historical data download in queue. 2026-10-12 07:55:09.672 | Removing historical data download ID 31. 2026-10-12 07:55:09.673 | Mapping M2KM15_FUT_CME to M2KM15. Service code: cme 2026-10-12 07:55:09.673 | HD Request # 31 | Downloading Historical Daily chart data for M2KM15_FUT_CME. Starting date: 1975-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:10.097 | HD Request # 31 | Requesting historical Daily data for RXM15 starting at 1975-07-09. SC External HD service. 2026-10-12 07:55:10.213 | HD Request # 31 | Bytes received: 1 2026-10-12 07:55:10.213 | HD Request # 31 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM15_FUT_CME 2026-10-12 07:55:10.213 | HD Request # 31 | Completion time: 1s. 2026-10-12 07:55:10.213 | HD Request # 31 | Daily data download complete for M2KM15_FUT_CME. Unique request ID: 31 2026-10-12 07:55:10.213 | Removing historical data download ID 31. 2026-10-12 07:55:10.213 | 2026-10-12 07:55:10.213 | Triggering next historical data download in queue. 2026-10-12 07:55:10.213 | Removing historical data download ID 32. 2026-10-12 07:55:10.213 | Mapping M2KU15_FUT_CME to M2KU15. Service code: cme 2026-10-12 07:55:10.213 | HD Request # 32 | Downloading Historical Daily chart data for M2KU15_FUT_CME. Starting date: 1975-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:10.649 | HD Request # 32 | Requesting historical Daily data for RXU15 starting at 1975-10-09. SC External HD service. 2026-10-12 07:55:10.756 | HD Request # 32 | Bytes received: 1 2026-10-12 07:55:10.756 | HD Request # 32 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU15_FUT_CME 2026-10-12 07:55:10.756 | HD Request # 32 | Completion time: 0s. 2026-10-12 07:55:10.756 | HD Request # 32 | Daily data download complete for M2KU15_FUT_CME. Unique request ID: 32 2026-10-12 07:55:10.756 | Removing historical data download ID 32. 2026-10-12 07:55:10.756 | 2026-10-12 07:55:10.756 | Triggering next historical data download in queue. 2026-10-12 07:55:10.756 | Removing historical data download ID 33. 2026-10-12 07:55:10.756 | Mapping M2KZ15_FUT_CME to M2KZ15. Service code: cme 2026-10-12 07:55:10.757 | HD Request # 33 | Downloading Historical Daily chart data for M2KZ15_FUT_CME. Starting date: 1976-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:11.197 | HD Request # 33 | Requesting historical Daily data for RXZ15 starting at 1976-01-09. SC External HD service. 2026-10-12 07:55:11.307 | HD Request # 33 | Bytes received: 1 2026-10-12 07:55:11.307 | HD Request # 33 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ15_FUT_CME 2026-10-12 07:55:11.307 | HD Request # 33 | Completion time: 1s. 2026-10-12 07:55:11.307 | HD Request # 33 | Daily data download complete for M2KZ15_FUT_CME. Unique request ID: 33 2026-10-12 07:55:11.307 | Removing historical data download ID 33. 2026-10-12 07:55:11.307 | 2026-10-12 07:55:11.307 | Triggering next historical data download in queue. 2026-10-12 07:55:11.307 | Removing historical data download ID 34. 2026-10-12 07:55:11.307 | Mapping M2KH16_FUT_CME to M2KH16. Service code: cme 2026-10-12 07:55:11.307 | HD Request # 34 | Downloading Historical Daily chart data for M2KH16_FUT_CME. Starting date: 1976-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:11.732 | HD Request # 34 | Requesting historical Daily data for RXH16 starting at 1976-04-09. SC External HD service. 2026-10-12 07:55:11.843 | HD Request # 34 | Bytes received: 1 2026-10-12 07:55:11.843 | HD Request # 34 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH16_FUT_CME 2026-10-12 07:55:11.843 | HD Request # 34 | Completion time: 0s. 2026-10-12 07:55:11.843 | HD Request # 34 | Daily data download complete for M2KH16_FUT_CME. Unique request ID: 34 2026-10-12 07:55:11.843 | Removing historical data download ID 34. 2026-10-12 07:55:11.843 | 2026-10-12 07:55:11.843 | Triggering next historical data download in queue. 2026-10-12 07:55:11.843 | Removing historical data download ID 35. 2026-10-12 07:55:11.843 | Mapping M2KM16_FUT_CME to M2KM16. Service code: cme 2026-10-12 07:55:11.844 | HD Request # 35 | Downloading Historical Daily chart data for M2KM16_FUT_CME. Starting date: 1976-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:12.266 | HD Request # 35 | Requesting historical Daily data for RXM16 starting at 1976-07-09. SC External HD service. 2026-10-12 07:55:12.383 | HD Request # 35 | Bytes received: 1 2026-10-12 07:55:12.383 | HD Request # 35 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM16_FUT_CME 2026-10-12 07:55:12.383 | HD Request # 35 | Completion time: 1s. 2026-10-12 07:55:12.383 | HD Request # 35 | Daily data download complete for M2KM16_FUT_CME. Unique request ID: 35 2026-10-12 07:55:12.383 | Removing historical data download ID 35. 2026-10-12 07:55:12.383 | 2026-10-12 07:55:12.383 | Triggering next historical data download in queue. 2026-10-12 07:55:12.383 | Removing historical data download ID 36. 2026-10-12 07:55:12.383 | Mapping M2KU16_FUT_CME to M2KU16. Service code: cme 2026-10-12 07:55:12.384 | HD Request # 36 | Downloading Historical Daily chart data for M2KU16_FUT_CME. Starting date: 1976-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:12.807 | HD Request # 36 | Requesting historical Daily data for RXU16 starting at 1976-10-09. SC External HD service. 2026-10-12 07:55:12.910 | HD Request # 36 | Bytes received: 1 2026-10-12 07:55:12.910 | HD Request # 36 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU16_FUT_CME 2026-10-12 07:55:12.910 | HD Request # 36 | Completion time: 0s. 2026-10-12 07:55:12.910 | HD Request # 36 | Daily data download complete for M2KU16_FUT_CME. Unique request ID: 36 2026-10-12 07:55:12.910 | Removing historical data download ID 36. 2026-10-12 07:55:12.910 | 2026-10-12 07:55:12.910 | Triggering next historical data download in queue. 2026-10-12 07:55:12.910 | Removing historical data download ID 37. 2026-10-12 07:55:12.910 | Mapping M2KZ16_FUT_CME to M2KZ16. Service code: cme 2026-10-12 07:55:12.911 | HD Request # 37 | Downloading Historical Daily chart data for M2KZ16_FUT_CME. Starting date: 1977-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:13.341 | HD Request # 37 | Requesting historical Daily data for RXZ16 starting at 1977-01-09. SC External HD service. 2026-10-12 07:55:13.457 | HD Request # 37 | Bytes received: 1 2026-10-12 07:55:13.457 | HD Request # 37 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ16_FUT_CME 2026-10-12 07:55:13.457 | HD Request # 37 | Completion time: 1s. 2026-10-12 07:55:13.457 | HD Request # 37 | Daily data download complete for M2KZ16_FUT_CME. Unique request ID: 37 2026-10-12 07:55:13.457 | Removing historical data download ID 37. 2026-10-12 07:55:13.457 | 2026-10-12 07:55:13.457 | Triggering next historical data download in queue. 2026-10-12 07:55:13.457 | Removing historical data download ID 38. 2026-10-12 07:55:13.457 | Mapping M2KH17_FUT_CME to M2KH17. Service code: cme 2026-10-12 07:55:13.457 | HD Request # 38 | Downloading Historical Daily chart data for M2KH17_FUT_CME. Starting date: 1977-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:13.877 | HD Request # 38 | Requesting historical Daily data for RXH17 starting at 1977-04-09. SC External HD service. 2026-10-12 07:55:13.988 | HD Request # 38 | Bytes received: 1 2026-10-12 07:55:13.988 | HD Request # 38 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH17_FUT_CME 2026-10-12 07:55:13.988 | HD Request # 38 | Completion time: 0s. 2026-10-12 07:55:13.988 | HD Request # 38 | Daily data download complete for M2KH17_FUT_CME. Unique request ID: 38 2026-10-12 07:55:13.988 | Removing historical data download ID 38. 2026-10-12 07:55:13.988 | 2026-10-12 07:55:13.988 | Triggering next historical data download in queue. 2026-10-12 07:55:13.988 | Removing historical data download ID 39. 2026-10-12 07:55:13.988 | Mapping M2KM17_FUT_CME to M2KM17. Service code: cme 2026-10-12 07:55:13.989 | HD Request # 39 | Downloading Historical Daily chart data for M2KM17_FUT_CME. Starting date: 1977-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:14.422 | HD Request # 39 | Requesting historical Daily data for RXM17 starting at 1977-07-09. SC External HD service. 2026-10-12 07:55:14.528 | HD Request # 39 | Bytes received: 1 2026-10-12 07:55:14.528 | HD Request # 39 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM17_FUT_CME 2026-10-12 07:55:14.528 | HD Request # 39 | Completion time: 1s. 2026-10-12 07:55:14.528 | HD Request # 39 | Daily data download complete for M2KM17_FUT_CME. Unique request ID: 39 2026-10-12 07:55:14.528 | Removing historical data download ID 39. 2026-10-12 07:55:14.528 | 2026-10-12 07:55:14.528 | Triggering next historical data download in queue. 2026-10-12 07:55:14.528 | Removing historical data download ID 40. 2026-10-12 07:55:14.528 | Mapping M2KU17_FUT_CME to M2KU17. Service code: cme 2026-10-12 07:55:14.528 | HD Request # 40 | Downloading Historical Daily chart data for M2KU17_FUT_CME. Starting date: 1977-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:14.945 | HD Request # 40 | Requesting historical Daily data for RXU17 starting at 1977-10-09. SC External HD service. 2026-10-12 07:55:15.056 | HD Request # 40 | Bytes received: 1 2026-10-12 07:55:15.056 | HD Request # 40 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU17_FUT_CME 2026-10-12 07:55:15.056 | HD Request # 40 | Completion time: 1s. 2026-10-12 07:55:15.056 | HD Request # 40 | Daily data download complete for M2KU17_FUT_CME. Unique request ID: 40 2026-10-12 07:55:15.056 | Removing historical data download ID 40. 2026-10-12 07:55:15.056 | 2026-10-12 07:55:15.056 | Triggering next historical data download in queue. 2026-10-12 07:55:15.056 | Removing historical data download ID 41. 2026-10-12 07:55:15.056 | Mapping M2KZ17_FUT_CME to M2KZ17. Service code: cme 2026-10-12 07:55:15.057 | HD Request # 41 | Downloading Historical Daily chart data for M2KZ17_FUT_CME. Starting date: 1978-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:15.483 | HD Request # 41 | Requesting historical Daily data for RXZ17 starting at 1978-01-09. SC External HD service. 2026-10-12 07:55:15.591 | HD Request # 41 | Bytes received: 1 2026-10-12 07:55:15.591 | HD Request # 41 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ17_FUT_CME 2026-10-12 07:55:15.591 | HD Request # 41 | Completion time: 0s. 2026-10-12 07:55:15.591 | HD Request # 41 | Daily data download complete for M2KZ17_FUT_CME. Unique request ID: 41 2026-10-12 07:55:15.591 | Removing historical data download ID 41. 2026-10-12 07:55:15.591 | 2026-10-12 07:55:15.591 | Triggering next historical data download in queue. 2026-10-12 07:55:15.591 | Removing historical data download ID 42. 2026-10-12 07:55:15.591 | Mapping M2KH18_FUT_CME to M2KH18. Service code: cme 2026-10-12 07:55:15.592 | HD Request # 42 | Downloading Historical Daily chart data for M2KH18_FUT_CME. Starting date: 1978-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:16.022 | HD Request # 42 | Requesting historical Daily data for RXH18 starting at 1978-04-09. SC External HD service. 2026-10-12 07:55:16.129 | HD Request # 42 | Bytes received: 1 2026-10-12 07:55:16.129 | HD Request # 42 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH18_FUT_CME 2026-10-12 07:55:16.129 | HD Request # 42 | Completion time: 1s. 2026-10-12 07:55:16.129 | HD Request # 42 | Daily data download complete for M2KH18_FUT_CME. Unique request ID: 42 2026-10-12 07:55:16.129 | Removing historical data download ID 42. 2026-10-12 07:55:16.129 | 2026-10-12 07:55:16.129 | Triggering next historical data download in queue. 2026-10-12 07:55:16.129 | Removing historical data download ID 43. 2026-10-12 07:55:16.129 | Mapping M2KM18_FUT_CME to M2KM18. Service code: cme 2026-10-12 07:55:16.130 | HD Request # 43 | Downloading Historical Daily chart data for M2KM18_FUT_CME. Starting date: 1978-07-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:16.558 | HD Request # 43 | Requesting historical Daily data for RXM18 starting at 1978-07-09. SC External HD service. 2026-10-12 07:55:16.665 | HD Request # 43 | Bytes received: 1 2026-10-12 07:55:16.665 | HD Request # 43 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KM18_FUT_CME 2026-10-12 07:55:16.665 | HD Request # 43 | Completion time: 0s. 2026-10-12 07:55:16.665 | HD Request # 43 | Daily data download complete for M2KM18_FUT_CME. Unique request ID: 43 2026-10-12 07:55:16.665 | Removing historical data download ID 43. 2026-10-12 07:55:16.665 | 2026-10-12 07:55:16.665 | Triggering next historical data download in queue. 2026-10-12 07:55:16.665 | Removing historical data download ID 44. 2026-10-12 07:55:16.665 | Mapping M2KU18_FUT_CME to M2KU18. Service code: cme 2026-10-12 07:55:16.665 | HD Request # 44 | Downloading Historical Daily chart data for M2KU18_FUT_CME. Starting date: 1978-10-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:17.091 | HD Request # 44 | Requesting historical Daily data for RXU18 starting at 1978-10-09. SC External HD service. 2026-10-12 07:55:17.198 | HD Request # 44 | Bytes received: 1 2026-10-12 07:55:17.198 | HD Request # 44 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KU18_FUT_CME 2026-10-12 07:55:17.198 | HD Request # 44 | Completion time: 1s. 2026-10-12 07:55:17.198 | HD Request # 44 | Daily data download complete for M2KU18_FUT_CME. Unique request ID: 44 2026-10-12 07:55:17.198 | Removing historical data download ID 44. 2026-10-12 07:55:17.198 | 2026-10-12 07:55:17.198 | Triggering next historical data download in queue. 2026-10-12 07:55:17.198 | Removing historical data download ID 45. 2026-10-12 07:55:17.198 | Mapping M2KZ18_FUT_CME to M2KZ18. Service code: cme 2026-10-12 07:55:17.198 | HD Request # 45 | Downloading Historical Daily chart data for M2KZ18_FUT_CME. Starting date: 1979-01-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:17.638 | HD Request # 45 | Requesting historical Daily data for RXZ18 starting at 1979-01-09. SC External HD service. 2026-10-12 07:55:17.763 | HD Request # 45 | Bytes received: 1 2026-10-12 07:55:17.763 | HD Request # 45 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KZ18_FUT_CME 2026-10-12 07:55:17.763 | HD Request # 45 | Completion time: 0s. 2026-10-12 07:55:17.763 | HD Request # 45 | Daily data download complete for M2KZ18_FUT_CME. Unique request ID: 45 2026-10-12 07:55:17.763 | Removing historical data download ID 45. 2026-10-12 07:55:17.763 | 2026-10-12 07:55:17.763 | Triggering next historical data download in queue. 2026-10-12 07:55:17.763 | Removing historical data download ID 46. 2026-10-12 07:55:17.763 | Mapping M2KH19_FUT_CME to M2KH19. Service code: cme 2026-10-12 07:55:17.763 | HD Request # 46 | Downloading Historical Daily chart data for M2KH19_FUT_CME. Starting date: 1979-04-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:18.191 | HD Request # 46 | Requesting historical Daily data for RXH19 starting at 1979-04-09. SC External HD service. 2026-10-12 07:55:18.301 | HD Request # 46 | Bytes received: 1 2026-10-12 07:55:18.301 | HD Request # 46 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for M2KH19_FUT_CME 2026-10-12 07:55:18.301 | HD Request # 46 | Completion time: 1s. 2026-10-12 07:55:18.301 | HD Request # 46 | Daily data download complete for M2KH19_FUT_CME. Unique request ID: 46 2026-10-12 07:55:18.301 | Removing historical data download ID 46. 2026-10-12 07:55:18.301 | 2026-10-12 07:55:18.301 | Triggering next historical data download in queue. 2026-10-12 07:55:18.301 | Removing historical data download ID 47. 2026-10-12 07:55:18.301 | Mapping M2KM19_FUT_CME to M2KM19. Service code: cme 2026-10-12 07:55:18.301 | HD Request # 47 | Downloading Historical Daily chart data for M2KM19_FUT_CME. Starting date: 2019-03-10. Service: sc_futures_direct.dtc.trading 2026-10-12 07:55:18.728 | HD Request # 47 | Requesting historical Daily data for RXM19 starting at 2019-03-09. SC External HD service. 2026-10-12 07:55:18.839 | HD Request # 47 | Receiving historical Daily data for M2KM19_FUT_CME starting at 2019-05-01. 2026-10-12 07:55:18.839 | HD Request # 47 | Writing historical Daily data to the file M2KM19_FUT_CME.dly. 2026-10-12 07:55:18.840 | HD Request # 47 | Bytes received: 2037 2026-10-12 07:55:18.840 | HD Request # 47 | Received 37 Daily data records from 2019-05-01 00:00:00 to 2019-06-21 00:00:00 (52.0 days) and wrote 37 records for M2KM19_FUT_CME 2026-10-12 07:55:18.840 | HD Request # 47 | Completion time: 0s. 2026-10-12 07:55:18.840 | HD Request # 47 | Daily data download complete for M2KM19_FUT_CME. Unique request ID: 47 2026-10-12 07:55:18.840 | Removing historical data download ID 47. 2026-10-12 07:55:18.840 | 2026-10-12 07:55:18.840 | No download requests in the queue to start downloads for. 2026-10-12 07:55:18.910 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-12 07:55:18.911 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:55:18.911 | Unable to determine transition date based on volume from files: M2KU05_FUT_CME.dly, M2KZ05_FUT_CME.dly 2026-10-12 07:55:18.911 | The M2KZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.911 | Unable to determine transition date based on volume from files: M2KZ05_FUT_CME.dly, M2KH06_FUT_CME.dly 2026-10-12 07:55:18.911 | The M2KH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.911 | Unable to determine transition date based on volume from files: M2KH06_FUT_CME.dly, M2KM06_FUT_CME.dly 2026-10-12 07:55:18.911 | The M2KM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KM06_FUT_CME.dly, M2KU06_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KU06_FUT_CME.dly, M2KZ06_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KZ06_FUT_CME.dly, M2KH07_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KH07_FUT_CME.dly, M2KM07_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KM07_FUT_CME.dly, M2KU07_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KU07_FUT_CME.dly, M2KZ07_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KZ07_FUT_CME.dly, M2KH08_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KH08_FUT_CME.dly, M2KM08_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KM08_FUT_CME.dly, M2KU08_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.912 | Unable to determine transition date based on volume from files: M2KU08_FUT_CME.dly, M2KZ08_FUT_CME.dly 2026-10-12 07:55:18.912 | The M2KZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.913 | Unable to determine transition date based on volume from files: M2KZ08_FUT_CME.dly, M2KH09_FUT_CME.dly 2026-10-12 07:55:18.913 | The M2KH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.913 | Unable to determine transition date based on volume from files: M2KH09_FUT_CME.dly, M2KM09_FUT_CME.dly 2026-10-12 07:55:18.913 | The M2KM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.913 | Unable to determine transition date based on volume from files: M2KM09_FUT_CME.dly, M2KU09_FUT_CME.dly 2026-10-12 07:55:18.913 | The M2KU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KU09_FUT_CME.dly, M2KZ09_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KZ09_FUT_CME.dly, M2KH10_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KH10_FUT_CME.dly, M2KM10_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KM10_FUT_CME.dly, M2KU10_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KU10_FUT_CME.dly, M2KZ10_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KZ10_FUT_CME.dly, M2KH11_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KH11_FUT_CME.dly, M2KM11_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KM11_FUT_CME.dly, M2KU11_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KU11_FUT_CME.dly, M2KZ11_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KZ11_FUT_CME.dly, M2KH12_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.914 | Unable to determine transition date based on volume from files: M2KH12_FUT_CME.dly, M2KM12_FUT_CME.dly 2026-10-12 07:55:18.914 | The M2KM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KM12_FUT_CME.dly, M2KU12_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KU12_FUT_CME.dly, M2KZ12_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KZ12_FUT_CME.dly, M2KH13_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KH13_FUT_CME.dly, M2KM13_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KM13_FUT_CME.dly, M2KU13_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KU13_FUT_CME.dly, M2KZ13_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KZ13_FUT_CME.dly, M2KH14_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KH14_FUT_CME.dly, M2KM14_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KM14_FUT_CME.dly, M2KU14_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KU14_FUT_CME.dly, M2KZ14_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.915 | Unable to determine transition date based on volume from files: M2KZ14_FUT_CME.dly, M2KH15_FUT_CME.dly 2026-10-12 07:55:18.915 | The M2KH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KH15_FUT_CME.dly, M2KM15_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KM15_FUT_CME.dly, M2KU15_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KU15_FUT_CME.dly, M2KZ15_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KZ15_FUT_CME.dly, M2KH16_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KH16_FUT_CME.dly, M2KM16_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KM16_FUT_CME.dly, M2KU16_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KU16_FUT_CME.dly, M2KZ16_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KZ16_FUT_CME.dly, M2KH17_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KH17_FUT_CME.dly, M2KM17_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KM17_FUT_CME.dly, M2KU17_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KU17_FUT_CME.dly, M2KZ17_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.916 | Unable to determine transition date based on volume from files: M2KZ17_FUT_CME.dly, M2KH18_FUT_CME.dly 2026-10-12 07:55:18.916 | The M2KH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.917 | Unable to determine transition date based on volume from files: M2KH18_FUT_CME.dly, M2KM18_FUT_CME.dly 2026-10-12 07:55:18.917 | The M2KM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.917 | Unable to determine transition date based on volume from files: M2KM18_FUT_CME.dly, M2KU18_FUT_CME.dly 2026-10-12 07:55:18.917 | The M2KU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.917 | Unable to determine transition date based on volume from files: M2KU18_FUT_CME.dly, M2KZ18_FUT_CME.dly 2026-10-12 07:55:18.917 | The M2KZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:18.917 | Unable to determine transition date based on volume from files: M2KZ18_FUT_CME.dly, M2KH19_FUT_CME.dly 2026-10-12 07:55:18.917 | The M2KH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.002 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:55:19.304 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. M2KM19_FUT_CME * 2026-10-12 07:55:19.304 | Unable to determine transition date based on volume from files: M2KU05_FUT_CME.dly, M2KZ05_FUT_CME.dly 2026-10-12 07:55:19.304 | The M2KZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.304 | Unable to determine transition date based on volume from files: M2KZ05_FUT_CME.dly, M2KH06_FUT_CME.dly 2026-10-12 07:55:19.304 | The M2KH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.304 | Unable to determine transition date based on volume from files: M2KH06_FUT_CME.dly, M2KM06_FUT_CME.dly 2026-10-12 07:55:19.304 | The M2KM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.304 | Unable to determine transition date based on volume from files: M2KM06_FUT_CME.dly, M2KU06_FUT_CME.dly 2026-10-12 07:55:19.304 | The M2KU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KU06_FUT_CME.dly, M2KZ06_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KZ06_FUT_CME.dly, M2KH07_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KH07_FUT_CME.dly, M2KM07_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KM07_FUT_CME.dly, M2KU07_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KU07_FUT_CME.dly, M2KZ07_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KZ07_FUT_CME.dly, M2KH08_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KH08_FUT_CME.dly, M2KM08_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KM08_FUT_CME.dly, M2KU08_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KU08_FUT_CME.dly, M2KZ08_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.305 | Unable to determine transition date based on volume from files: M2KZ08_FUT_CME.dly, M2KH09_FUT_CME.dly 2026-10-12 07:55:19.305 | The M2KH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.306 | Unable to determine transition date based on volume from files: M2KH09_FUT_CME.dly, M2KM09_FUT_CME.dly 2026-10-12 07:55:19.306 | The M2KM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.306 | Unable to determine transition date based on volume from files: M2KM09_FUT_CME.dly, M2KU09_FUT_CME.dly 2026-10-12 07:55:19.306 | The M2KU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.306 | Unable to determine transition date based on volume from files: M2KU09_FUT_CME.dly, M2KZ09_FUT_CME.dly 2026-10-12 07:55:19.306 | The M2KZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.306 | Unable to determine transition date based on volume from files: M2KZ09_FUT_CME.dly, M2KH10_FUT_CME.dly 2026-10-12 07:55:19.306 | The M2KH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.306 | Unable to determine transition date based on volume from files: M2KH10_FUT_CME.dly, M2KM10_FUT_CME.dly 2026-10-12 07:55:19.306 | The M2KM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.306 | Unable to determine transition date based on volume from files: M2KM10_FUT_CME.dly, M2KU10_FUT_CME.dly 2026-10-12 07:55:19.306 | The M2KU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.306 | Unable to determine transition date based on volume from files: M2KU10_FUT_CME.dly, M2KZ10_FUT_CME.dly 2026-10-12 07:55:19.306 | The M2KZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KZ10_FUT_CME.dly, M2KH11_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KH11_FUT_CME.dly, M2KM11_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KM11_FUT_CME.dly, M2KU11_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KU11_FUT_CME.dly, M2KZ11_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KZ11_FUT_CME.dly, M2KH12_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KH12_FUT_CME.dly, M2KM12_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KM12_FUT_CME.dly, M2KU12_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KU12_FUT_CME.dly, M2KZ12_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KZ12_FUT_CME.dly, M2KH13_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KH13_FUT_CME.dly, M2KM13_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KM13_FUT_CME.dly, M2KU13_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.307 | Unable to determine transition date based on volume from files: M2KU13_FUT_CME.dly, M2KZ13_FUT_CME.dly 2026-10-12 07:55:19.307 | The M2KZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KZ13_FUT_CME.dly, M2KH14_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KH14_FUT_CME.dly, M2KM14_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KM14_FUT_CME.dly, M2KU14_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KU14_FUT_CME.dly, M2KZ14_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KZ14_FUT_CME.dly, M2KH15_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KH15_FUT_CME.dly, M2KM15_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KM15_FUT_CME.dly, M2KU15_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KU15_FUT_CME.dly, M2KZ15_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KZ15_FUT_CME.dly, M2KH16_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KH16_FUT_CME.dly, M2KM16_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KM16_FUT_CME.dly, M2KU16_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KU16_FUT_CME.dly, M2KZ16_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.308 | Unable to determine transition date based on volume from files: M2KZ16_FUT_CME.dly, M2KH17_FUT_CME.dly 2026-10-12 07:55:19.308 | The M2KH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KH17_FUT_CME.dly, M2KM17_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KM17_FUT_CME.dly, M2KU17_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KU17_FUT_CME.dly, M2KZ17_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KZ17_FUT_CME.dly, M2KH18_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KH18_FUT_CME.dly, M2KM18_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KM18_FUT_CME.dly, M2KU18_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KU18_FUT_CME.dly, M2KZ18_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.309 | Unable to determine transition date based on volume from files: M2KZ18_FUT_CME.dly, M2KH19_FUT_CME.dly 2026-10-12 07:55:19.309 | The M2KH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:19.376 | Restarting the loading process. 2026-10-12 07:55:19.428 | M2KZ26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 07:55:38.763 | M2KZ26_FUT_CME[M] 120 Min #5 | Reloading chart. 2026-10-12 07:55:38.857 | M2KZ26_FUT_CME[M] 120 Min #5 | Chart data loading complete. 2026-10-12 07:55:41.012 | M2KZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:55:41.108 | M2KZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:55:43.576 | MCLX26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:55:43.859 | MCLX26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MCLQ21_FUT_CME * 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLQ05_FUT_CME.dly, MCLU05_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLU05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLU05_FUT_CME.dly, MCLV05_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLV05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLV05_FUT_CME.dly, MCLX05_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLX05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLX05_FUT_CME.dly, MCLZ05_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLZ05_FUT_CME.dly, MCLF06_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLF06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLF06_FUT_CME.dly, MCLG06_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLG06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLG06_FUT_CME.dly, MCLH06_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLH06_FUT_CME.dly, MCLJ06_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLJ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLJ06_FUT_CME.dly, MCLK06_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLK06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLK06_FUT_CME.dly, MCLM06_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.859 | Unable to determine transition date based on volume from files: MCLM06_FUT_CME.dly, MCLN06_FUT_CME.dly 2026-10-12 07:55:43.859 | The MCLN06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLN06_FUT_CME.dly, MCLQ06_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLQ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLQ06_FUT_CME.dly, MCLU06_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLU06_FUT_CME.dly, MCLV06_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLV06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLV06_FUT_CME.dly, MCLX06_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLX06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLX06_FUT_CME.dly, MCLZ06_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLZ06_FUT_CME.dly, MCLF07_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLF07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLF07_FUT_CME.dly, MCLG07_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLG07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLG07_FUT_CME.dly, MCLH07_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLH07_FUT_CME.dly, MCLJ07_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLJ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLJ07_FUT_CME.dly, MCLK07_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLK07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLK07_FUT_CME.dly, MCLM07_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.860 | Unable to determine transition date based on volume from files: MCLM07_FUT_CME.dly, MCLN07_FUT_CME.dly 2026-10-12 07:55:43.860 | The MCLN07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLN07_FUT_CME.dly, MCLQ07_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLQ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLQ07_FUT_CME.dly, MCLU07_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLU07_FUT_CME.dly, MCLV07_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLV07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLV07_FUT_CME.dly, MCLX07_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLX07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLX07_FUT_CME.dly, MCLZ07_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLZ07_FUT_CME.dly, MCLF08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLF08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLF08_FUT_CME.dly, MCLG08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLG08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLG08_FUT_CME.dly, MCLH08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLH08_FUT_CME.dly, MCLJ08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLJ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLJ08_FUT_CME.dly, MCLK08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLK08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLK08_FUT_CME.dly, MCLM08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLM08_FUT_CME.dly, MCLN08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLN08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.861 | Unable to determine transition date based on volume from files: MCLN08_FUT_CME.dly, MCLQ08_FUT_CME.dly 2026-10-12 07:55:43.861 | The MCLQ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLQ08_FUT_CME.dly, MCLU08_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLU08_FUT_CME.dly, MCLV08_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLV08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLV08_FUT_CME.dly, MCLX08_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLX08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLX08_FUT_CME.dly, MCLZ08_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLZ08_FUT_CME.dly, MCLF09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLF09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLF09_FUT_CME.dly, MCLG09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLG09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLG09_FUT_CME.dly, MCLH09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLH09_FUT_CME.dly, MCLJ09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLJ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLJ09_FUT_CME.dly, MCLK09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLK09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLK09_FUT_CME.dly, MCLM09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLM09_FUT_CME.dly, MCLN09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLN09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.862 | Unable to determine transition date based on volume from files: MCLN09_FUT_CME.dly, MCLQ09_FUT_CME.dly 2026-10-12 07:55:43.862 | The MCLQ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLQ09_FUT_CME.dly, MCLU09_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLU09_FUT_CME.dly, MCLV09_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLV09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLV09_FUT_CME.dly, MCLX09_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLX09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLX09_FUT_CME.dly, MCLZ09_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLZ09_FUT_CME.dly, MCLF10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLF10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLF10_FUT_CME.dly, MCLG10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLG10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLG10_FUT_CME.dly, MCLH10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLH10_FUT_CME.dly, MCLJ10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLJ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLJ10_FUT_CME.dly, MCLK10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLK10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLK10_FUT_CME.dly, MCLM10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLM10_FUT_CME.dly, MCLN10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLN10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.863 | Unable to determine transition date based on volume from files: MCLN10_FUT_CME.dly, MCLQ10_FUT_CME.dly 2026-10-12 07:55:43.863 | The MCLQ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLQ10_FUT_CME.dly, MCLU10_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLU10_FUT_CME.dly, MCLV10_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLV10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLV10_FUT_CME.dly, MCLX10_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLX10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLX10_FUT_CME.dly, MCLZ10_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLZ10_FUT_CME.dly, MCLF11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLF11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLF11_FUT_CME.dly, MCLG11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLG11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLG11_FUT_CME.dly, MCLH11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLH11_FUT_CME.dly, MCLJ11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLJ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLJ11_FUT_CME.dly, MCLK11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLK11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLK11_FUT_CME.dly, MCLM11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLM11_FUT_CME.dly, MCLN11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLN11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.864 | Unable to determine transition date based on volume from files: MCLN11_FUT_CME.dly, MCLQ11_FUT_CME.dly 2026-10-12 07:55:43.864 | The MCLQ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLQ11_FUT_CME.dly, MCLU11_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLU11_FUT_CME.dly, MCLV11_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLV11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLV11_FUT_CME.dly, MCLX11_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLX11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLX11_FUT_CME.dly, MCLZ11_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLZ11_FUT_CME.dly, MCLF12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLF12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLF12_FUT_CME.dly, MCLG12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLG12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLG12_FUT_CME.dly, MCLH12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLH12_FUT_CME.dly, MCLJ12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLJ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLJ12_FUT_CME.dly, MCLK12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLK12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLK12_FUT_CME.dly, MCLM12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLM12_FUT_CME.dly, MCLN12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLN12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLN12_FUT_CME.dly, MCLQ12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLQ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.865 | Unable to determine transition date based on volume from files: MCLQ12_FUT_CME.dly, MCLU12_FUT_CME.dly 2026-10-12 07:55:43.865 | The MCLU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLU12_FUT_CME.dly, MCLV12_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLV12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLV12_FUT_CME.dly, MCLX12_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLX12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLX12_FUT_CME.dly, MCLZ12_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLZ12_FUT_CME.dly, MCLF13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLF13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLF13_FUT_CME.dly, MCLG13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLG13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLG13_FUT_CME.dly, MCLH13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLH13_FUT_CME.dly, MCLJ13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLJ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLJ13_FUT_CME.dly, MCLK13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLK13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLK13_FUT_CME.dly, MCLM13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLM13_FUT_CME.dly, MCLN13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLN13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLN13_FUT_CME.dly, MCLQ13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLQ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.866 | Unable to determine transition date based on volume from files: MCLQ13_FUT_CME.dly, MCLU13_FUT_CME.dly 2026-10-12 07:55:43.866 | The MCLU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLU13_FUT_CME.dly, MCLV13_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLV13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLV13_FUT_CME.dly, MCLX13_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLX13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLX13_FUT_CME.dly, MCLZ13_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLZ13_FUT_CME.dly, MCLF14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLF14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLF14_FUT_CME.dly, MCLG14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLG14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLG14_FUT_CME.dly, MCLH14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLH14_FUT_CME.dly, MCLJ14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLJ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLJ14_FUT_CME.dly, MCLK14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLK14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLK14_FUT_CME.dly, MCLM14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLM14_FUT_CME.dly, MCLN14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLN14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLN14_FUT_CME.dly, MCLQ14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLQ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.867 | Unable to determine transition date based on volume from files: MCLQ14_FUT_CME.dly, MCLU14_FUT_CME.dly 2026-10-12 07:55:43.867 | The MCLU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLU14_FUT_CME.dly, MCLV14_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLV14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLV14_FUT_CME.dly, MCLX14_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLX14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLX14_FUT_CME.dly, MCLZ14_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLZ14_FUT_CME.dly, MCLF15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLF15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLF15_FUT_CME.dly, MCLG15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLG15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLG15_FUT_CME.dly, MCLH15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLH15_FUT_CME.dly, MCLJ15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLJ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLJ15_FUT_CME.dly, MCLK15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLK15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLK15_FUT_CME.dly, MCLM15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLM15_FUT_CME.dly, MCLN15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLN15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLN15_FUT_CME.dly, MCLQ15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLQ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLQ15_FUT_CME.dly, MCLU15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.868 | Unable to determine transition date based on volume from files: MCLU15_FUT_CME.dly, MCLV15_FUT_CME.dly 2026-10-12 07:55:43.868 | The MCLV15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLV15_FUT_CME.dly, MCLX15_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLX15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLX15_FUT_CME.dly, MCLZ15_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLZ15_FUT_CME.dly, MCLF16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLF16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLF16_FUT_CME.dly, MCLG16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLG16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLG16_FUT_CME.dly, MCLH16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLH16_FUT_CME.dly, MCLJ16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLJ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLJ16_FUT_CME.dly, MCLK16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLK16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLK16_FUT_CME.dly, MCLM16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLM16_FUT_CME.dly, MCLN16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLN16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLN16_FUT_CME.dly, MCLQ16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLQ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLQ16_FUT_CME.dly, MCLU16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.869 | Unable to determine transition date based on volume from files: MCLU16_FUT_CME.dly, MCLV16_FUT_CME.dly 2026-10-12 07:55:43.869 | The MCLV16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLV16_FUT_CME.dly, MCLX16_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLX16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLX16_FUT_CME.dly, MCLZ16_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLZ16_FUT_CME.dly, MCLF17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLF17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLF17_FUT_CME.dly, MCLG17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLG17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLG17_FUT_CME.dly, MCLH17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLH17_FUT_CME.dly, MCLJ17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLJ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLJ17_FUT_CME.dly, MCLK17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLK17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLK17_FUT_CME.dly, MCLM17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLM17_FUT_CME.dly, MCLN17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLN17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLN17_FUT_CME.dly, MCLQ17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLQ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLQ17_FUT_CME.dly, MCLU17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.870 | Unable to determine transition date based on volume from files: MCLU17_FUT_CME.dly, MCLV17_FUT_CME.dly 2026-10-12 07:55:43.870 | The MCLV17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLV17_FUT_CME.dly, MCLX17_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLX17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLX17_FUT_CME.dly, MCLZ17_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLZ17_FUT_CME.dly, MCLF18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLF18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLF18_FUT_CME.dly, MCLG18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLG18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLG18_FUT_CME.dly, MCLH18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLH18_FUT_CME.dly, MCLJ18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLJ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLJ18_FUT_CME.dly, MCLK18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLK18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLK18_FUT_CME.dly, MCLM18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLM18_FUT_CME.dly, MCLN18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLN18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLN18_FUT_CME.dly, MCLQ18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLQ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLQ18_FUT_CME.dly, MCLU18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLU18_FUT_CME.dly, MCLV18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLV18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.871 | Unable to determine transition date based on volume from files: MCLV18_FUT_CME.dly, MCLX18_FUT_CME.dly 2026-10-12 07:55:43.871 | The MCLX18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLX18_FUT_CME.dly, MCLZ18_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLZ18_FUT_CME.dly, MCLF19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLF19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLF19_FUT_CME.dly, MCLG19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLG19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLG19_FUT_CME.dly, MCLH19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLH19_FUT_CME.dly, MCLJ19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLJ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLJ19_FUT_CME.dly, MCLK19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLK19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLK19_FUT_CME.dly, MCLM19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLM19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLM19_FUT_CME.dly, MCLN19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLN19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLN19_FUT_CME.dly, MCLQ19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLQ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLQ19_FUT_CME.dly, MCLU19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLU19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLU19_FUT_CME.dly, MCLV19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLV19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.872 | Unable to determine transition date based on volume from files: MCLV19_FUT_CME.dly, MCLX19_FUT_CME.dly 2026-10-12 07:55:43.872 | The MCLX19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLX19_FUT_CME.dly, MCLZ19_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLZ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLZ19_FUT_CME.dly, MCLF20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLF20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLF20_FUT_CME.dly, MCLG20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLG20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLG20_FUT_CME.dly, MCLH20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLH20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLH20_FUT_CME.dly, MCLJ20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLJ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLJ20_FUT_CME.dly, MCLK20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLK20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLK20_FUT_CME.dly, MCLM20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLM20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLM20_FUT_CME.dly, MCLN20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLN20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLN20_FUT_CME.dly, MCLQ20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLQ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLQ20_FUT_CME.dly, MCLU20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLU20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLU20_FUT_CME.dly, MCLV20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLV20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.873 | Unable to determine transition date based on volume from files: MCLV20_FUT_CME.dly, MCLX20_FUT_CME.dly 2026-10-12 07:55:43.873 | The MCLX20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLX20_FUT_CME.dly, MCLZ20_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLZ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLZ20_FUT_CME.dly, MCLF21_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLF21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLF21_FUT_CME.dly, MCLG21_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLG21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLG21_FUT_CME.dly, MCLH21_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLH21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLH21_FUT_CME.dly, MCLJ21_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLJ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLJ21_FUT_CME.dly, MCLK21_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLK21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLK21_FUT_CME.dly, MCLM21_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLM21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:43.874 | Unable to determine transition date based on volume from files: MCLM21_FUT_CME.dly, MCLN21_FUT_CME.dly 2026-10-12 07:55:43.874 | The MCLN21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:55:44.060 | MCLX26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 07:55:44.062 | MCLX26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 07:55:44.063 | MCLX26_FUT_CME[M] 240 Min #4 | Reloading chart. 2026-10-12 07:55:44.064 | MCLX26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:55:44.066 | MCLX26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 07:55:44.071 | MCLX26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 07:55:44.076 | MCLX26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 07:55:44.191 | MCLX26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 07:55:44.254 | MCLX26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-10-12 07:55:44.271 | MCLX26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:55:44.276 | MCLX26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 07:55:53.482 | MCLX26_FUT_CME[M] 60 Min #5 | Reloading chart. 2026-10-12 07:55:53.677 | MCLX26_FUT_CME[M] 60 Min #5 | Chart data loading complete. 2026-10-12 07:56:36.397 | MCLX26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:56:36.591 | MCLX26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:57:10.236 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:57:10.247 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol MGCZ10_FUT_CME starting at 2010-07-28. 2026-10-12 07:57:10.247 | Added historical Daily data request for MGCZ10_FUT_CME to the queue. 2026-10-12 07:57:10.247 | Triggering next historical data download in queue. 2026-10-12 07:57:10.328 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Performing continuous chart historical Daily data download for symbol MGCZ26_FUT_CME starting at last date in file. 2026-10-12 07:57:10.328 | Added historical Daily data request for MGCZ26_FUT_CME to the queue. 2026-10-12 07:57:11.017 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MGCZ10_FUT_CME * 2026-10-12 07:57:11.017 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Waiting for historical downloads to complete with the IDs: 48, 49, 2026-10-12 07:57:11.019 | MGCZ26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 07:57:11.030 | MGCZ26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 07:57:11.039 | MGCZ26_FUT_CME[M] 240 Min #4 | Reloading chart. 2026-10-12 07:57:11.040 | MGCZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:57:11.059 | MGCZ26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 07:57:11.060 | Removing historical data download ID 48. 2026-10-12 07:57:11.060 | Mapping MGCZ10_FUT_CME to MGCZ10. Service code: comex 2026-10-12 07:57:11.060 | HD Request # 48 | Downloading Historical Daily chart data for MGCZ10_FUT_CME. Starting date: 2010-07-28. Service: sc_futures_direct.dtc.trading 2026-10-12 07:57:11.067 | MGCZ26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 07:57:11.072 | MGCZ26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 07:57:11.182 | Added historical Intraday data request for MGCZ26_FUT_CME to the queue. 2026-10-12 07:57:11.182 | Intraday data recording state for symbol MGCZ26_FUT_CME is set to download 'Pending'. 2026-10-12 07:57:11.182 | Triggering next historical data download in queue. 2026-10-12 07:57:11.182 | Removing historical data download ID 50. 2026-10-12 07:57:11.182 | HD Request # 49 | Downloading Intraday chart data for MGCZ26_FUT_CME to the file MGCZ26_FUT_CME.scid. Service: comex 2026-10-12 07:57:11.182 | HD Request # 49 | Download start date-time: 2026-10-09 15:59:59.000000. File last date-time: 2026-10-09 15:59:59.856001 2026-10-12 07:57:11.182 | HD Request # 49 | Using server: ds28.sierracharts.com port 10150 2026-10-12 07:57:11.182 | Socket (5) | Creating socket. 2026-10-12 07:57:11.182 | Socket (5) | New receive buffer size: 0 2026-10-12 07:57:11.182 | Socket (5) | Connecting to IP: 67.214.125.5 Port: 10150. 2026-10-12 07:57:11.279 | HD Request # 49 | Setting DTC encoding to Binary VLS 2026-10-12 07:57:11.279 | HD Request # 49 | Sending historical data logon request message. 2026-10-12 07:57:11.361 | HD Request # 49 | Requesting Intraday data. Start date-time: 2026-10-09 15:59:59. Record interval: 0. Symbol: MGCZ26 2026-10-12 07:57:11.405 | HD Request # 49 | Decompressing data. 2026-10-12 07:57:11.491 | HD Request # 48 | Requesting historical Daily data for GRZ10 starting at 2010-07-27. SC External HD service. 2026-10-12 07:57:11.518 | HD Request # 49 | Receiving Intraday data for MGCZ26_FUT_CME starting at 2026-10-09 15:59:59.856000 2026-10-12 07:57:11.646 | HD Request # 49 | Timestamp of first Intraday data file record written: 2026-10-11 17:00:00.000000. 2026-10-12 07:57:11.730 | HD Request # 48 | Receiving historical Daily data for MGCZ10_FUT_CME starting at 2010-10-01. 2026-10-12 07:57:11.730 | HD Request # 48 | Writing historical Daily data to the file MGCZ10_FUT_CME.dly. 2026-10-12 07:57:11.731 | HD Request # 48 | Bytes received: 3096 2026-10-12 07:57:11.731 | HD Request # 48 | Received 62 Daily data records from 2010-10-01 00:00:00 to 2010-12-29 00:00:00 (90.0 days) and wrote 62 records for MGCZ10_FUT_CME 2026-10-12 07:57:11.731 | HD Request # 48 | Completion time: 0s. 2026-10-12 07:57:11.731 | HD Request # 48 | Daily data download complete for MGCZ10_FUT_CME. Unique request ID: 48 2026-10-12 07:57:11.731 | Removing historical data download ID 48. 2026-10-12 07:57:11.731 | 2026-10-12 07:57:11.731 | Triggering next historical data download in queue. 2026-10-12 07:57:11.731 | Removing historical data download ID 49. 2026-10-12 07:57:11.732 | HD Request # 50 | Downloading Historical Daily chart data for MGCZ26_FUT_CME. Starting date: 2026-10-07. Service: sc_futures_direct.dtc.trading 2026-10-12 07:57:11.958 | Socket (5) | CloseSocket call. 2026-10-12 07:57:11.958 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-10-12 07:57:11.961 | Historical data download thread signaled to stop. 2026-10-12 07:57:11.963 | HD Request # 49 | Received 136187 Intraday data records from 2026-10-09 15:59:59.856000 to 2026-10-12 07:56:04.166001 (2.7 days. Delay: 67.8 seconds) and wrote 136185 records for MGCZ26_FUT_CME 2026-10-12 07:57:11.964 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2026-10-12 12:56:04.166001 2026-10-12 07:57:11.964 | HD Request # 49 | Completion time: 0s. 2026-10-12 07:57:11.964 | HD Request # 49 | Intraday data download complete for MGCZ26_FUT_CME. Unique request ID: 50 2026-10-12 07:57:11.964 | Real-time Intraday chart data file updates started for MGCZ26_FUT_CME 2026-10-12 07:57:11.964 | Intraday chart data file opened for MGCZ26_FUT_CME 2026-10-12 07:57:11.964 | HD Request # 49 | Enabling Intraday chart updating for symbol. 2026-10-12 07:57:11.964 | Removing historical data download ID 50. 2026-10-12 07:57:11.964 | 2026-10-12 07:57:11.964 | No download requests in the queue to start downloads for. 2026-10-12 07:57:12.007 | Socket (5) | Socket gracefully closed by remote side. 2026-10-12 07:57:12.007 | Socket (5) | Closed. 2026-10-12 07:57:12.155 | HD Request # 50 | Requesting historical Daily data for GRZ26 starting at 2026-10-06. SC External HD service. 2026-10-12 07:57:12.244 | MGCZ26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-10-12 07:57:12.249 | MGCZ26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 07:57:12.258 | MGCZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:57:12.454 | HD Request # 50 | Receiving historical Daily data for MGCZ26_FUT_CME starting at 2026-10-07. 2026-10-12 07:57:12.455 | HD Request # 50 | Writing historical Daily data to the file MGCZ26_FUT_CME.dly. 2026-10-12 07:57:12.457 | HD Request # 50 | Bytes received: 278 2026-10-12 07:57:12.457 | HD Request # 50 | Received 5 Daily data records from 2026-10-07 00:00:00 to 2026-10-12 00:00:00 (6.0 days) and wrote 4 records for MGCZ26_FUT_CME 2026-10-12 07:57:12.457 | HD Request # 50 | Completion time: 1s. 2026-10-12 07:57:12.457 | HD Request # 50 | Daily data download complete for MGCZ26_FUT_CME. Unique request ID: 49 2026-10-12 07:57:12.457 | Removing historical data download ID 49. 2026-10-12 07:57:12.457 | 2026-10-12 07:57:12.457 | No download requests in the queue to start downloads for. 2026-10-12 07:57:12.465 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-10-12 07:57:12.466 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCQ05_FUT_CME.dly, MGCZ05_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCZ05_FUT_CME.dly, MGCG06_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCG06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCG06_FUT_CME.dly, MGCJ06_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCJ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCJ06_FUT_CME.dly, MGCM06_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCM06_FUT_CME.dly, MGCQ06_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCQ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCQ06_FUT_CME.dly, MGCZ06_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCZ06_FUT_CME.dly, MGCG07_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCG07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.466 | Unable to determine transition date based on volume from files: MGCG07_FUT_CME.dly, MGCJ07_FUT_CME.dly 2026-10-12 07:57:12.466 | The MGCJ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCJ07_FUT_CME.dly, MGCM07_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCM07_FUT_CME.dly, MGCQ07_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCQ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCQ07_FUT_CME.dly, MGCZ07_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCZ07_FUT_CME.dly, MGCG08_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCG08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCG08_FUT_CME.dly, MGCJ08_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCJ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCJ08_FUT_CME.dly, MGCM08_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCM08_FUT_CME.dly, MGCQ08_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCQ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCQ08_FUT_CME.dly, MGCZ08_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCZ08_FUT_CME.dly, MGCG09_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCG09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCG09_FUT_CME.dly, MGCJ09_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCJ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCJ09_FUT_CME.dly, MGCM09_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.467 | Unable to determine transition date based on volume from files: MGCM09_FUT_CME.dly, MGCQ09_FUT_CME.dly 2026-10-12 07:57:12.467 | The MGCQ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.468 | Unable to determine transition date based on volume from files: MGCQ09_FUT_CME.dly, MGCZ09_FUT_CME.dly 2026-10-12 07:57:12.468 | The MGCZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.468 | Unable to determine transition date based on volume from files: MGCZ09_FUT_CME.dly, MGCG10_FUT_CME.dly 2026-10-12 07:57:12.468 | The MGCG10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.468 | Unable to determine transition date based on volume from files: MGCG10_FUT_CME.dly, MGCJ10_FUT_CME.dly 2026-10-12 07:57:12.468 | The MGCJ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.468 | Unable to determine transition date based on volume from files: MGCJ10_FUT_CME.dly, MGCM10_FUT_CME.dly 2026-10-12 07:57:12.468 | The MGCM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.468 | Unable to determine transition date based on volume from files: MGCM10_FUT_CME.dly, MGCQ10_FUT_CME.dly 2026-10-12 07:57:12.468 | The MGCQ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:12.765 | MGCZ26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 07:57:12.768 | MGCZ26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 07:57:12.773 | MGCZ26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 07:57:12.777 | MGCZ26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 07:57:12.784 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:57:13.528 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MGCZ10_FUT_CME * 2026-10-12 07:57:13.528 | Unable to determine transition date based on volume from files: MGCQ05_FUT_CME.dly, MGCZ05_FUT_CME.dly 2026-10-12 07:57:13.528 | The MGCZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.528 | Unable to determine transition date based on volume from files: MGCZ05_FUT_CME.dly, MGCG06_FUT_CME.dly 2026-10-12 07:57:13.528 | The MGCG06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCG06_FUT_CME.dly, MGCJ06_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCJ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCJ06_FUT_CME.dly, MGCM06_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCM06_FUT_CME.dly, MGCQ06_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCQ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCQ06_FUT_CME.dly, MGCZ06_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCZ06_FUT_CME.dly, MGCG07_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCG07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCG07_FUT_CME.dly, MGCJ07_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCJ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCJ07_FUT_CME.dly, MGCM07_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCM07_FUT_CME.dly, MGCQ07_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCQ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCQ07_FUT_CME.dly, MGCZ07_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCZ07_FUT_CME.dly, MGCG08_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCG08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.529 | Unable to determine transition date based on volume from files: MGCG08_FUT_CME.dly, MGCJ08_FUT_CME.dly 2026-10-12 07:57:13.529 | The MGCJ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCJ08_FUT_CME.dly, MGCM08_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCM08_FUT_CME.dly, MGCQ08_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCQ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCQ08_FUT_CME.dly, MGCZ08_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCZ08_FUT_CME.dly, MGCG09_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCG09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCG09_FUT_CME.dly, MGCJ09_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCJ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCJ09_FUT_CME.dly, MGCM09_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCM09_FUT_CME.dly, MGCQ09_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCQ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCQ09_FUT_CME.dly, MGCZ09_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCZ09_FUT_CME.dly, MGCG10_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCG10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCG10_FUT_CME.dly, MGCJ10_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCJ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCJ10_FUT_CME.dly, MGCM10_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.530 | Unable to determine transition date based on volume from files: MGCM10_FUT_CME.dly, MGCQ10_FUT_CME.dly 2026-10-12 07:57:13.530 | The MGCQ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:57:13.816 | Restarting the loading process. 2026-10-12 07:57:13.984 | MGCZ26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 07:57:14.520 | Opened cached Intraday file: C:\SierraChart\Data\MGCZ26_FUT_CME.scid. Thread ID: 7432 2026-10-12 07:58:32.929 | MGCZ26_FUT_CME[M] 60 Min #5 | Reloading chart. 2026-10-12 07:58:33.909 | MGCZ26_FUT_CME[M] 60 Min #5 | Chart data loading complete. 2026-10-12 07:58:54.706 | MGCZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:58:55.686 | MGCZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:58:56.821 | MNGX26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:58:57.023 | MNGX26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MNGZ23_FUT_CME * 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGQ05_FUT_CME.dly, MNGU05_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGU05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGU05_FUT_CME.dly, MNGV05_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGV05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGV05_FUT_CME.dly, MNGX05_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGX05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGX05_FUT_CME.dly, MNGZ05_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGZ05_FUT_CME.dly, MNGF06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGF06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGF06_FUT_CME.dly, MNGG06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGG06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGG06_FUT_CME.dly, MNGH06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGH06_FUT_CME.dly, MNGJ06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGJ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGJ06_FUT_CME.dly, MNGK06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGK06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGK06_FUT_CME.dly, MNGM06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGM06_FUT_CME.dly, MNGN06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGN06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.024 | Unable to determine transition date based on volume from files: MNGN06_FUT_CME.dly, MNGQ06_FUT_CME.dly 2026-10-12 07:58:57.024 | The MNGQ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGQ06_FUT_CME.dly, MNGU06_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGU06_FUT_CME.dly, MNGV06_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGV06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGV06_FUT_CME.dly, MNGX06_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGX06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGX06_FUT_CME.dly, MNGZ06_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGZ06_FUT_CME.dly, MNGF07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGF07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGF07_FUT_CME.dly, MNGG07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGG07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGG07_FUT_CME.dly, MNGH07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGH07_FUT_CME.dly, MNGJ07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGJ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGJ07_FUT_CME.dly, MNGK07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGK07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGK07_FUT_CME.dly, MNGM07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGM07_FUT_CME.dly, MNGN07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGN07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.025 | Unable to determine transition date based on volume from files: MNGN07_FUT_CME.dly, MNGQ07_FUT_CME.dly 2026-10-12 07:58:57.025 | The MNGQ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGQ07_FUT_CME.dly, MNGU07_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGU07_FUT_CME.dly, MNGV07_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGV07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGV07_FUT_CME.dly, MNGX07_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGX07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGX07_FUT_CME.dly, MNGZ07_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGZ07_FUT_CME.dly, MNGF08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGF08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGF08_FUT_CME.dly, MNGG08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGG08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGG08_FUT_CME.dly, MNGH08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGH08_FUT_CME.dly, MNGJ08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGJ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGJ08_FUT_CME.dly, MNGK08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGK08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGK08_FUT_CME.dly, MNGM08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGM08_FUT_CME.dly, MNGN08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGN08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.026 | Unable to determine transition date based on volume from files: MNGN08_FUT_CME.dly, MNGQ08_FUT_CME.dly 2026-10-12 07:58:57.026 | The MNGQ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGQ08_FUT_CME.dly, MNGU08_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGU08_FUT_CME.dly, MNGV08_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGV08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGV08_FUT_CME.dly, MNGX08_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGX08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGX08_FUT_CME.dly, MNGZ08_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGZ08_FUT_CME.dly, MNGF09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGF09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGF09_FUT_CME.dly, MNGG09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGG09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGG09_FUT_CME.dly, MNGH09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGH09_FUT_CME.dly, MNGJ09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGJ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGJ09_FUT_CME.dly, MNGK09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGK09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGK09_FUT_CME.dly, MNGM09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGM09_FUT_CME.dly, MNGN09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGN09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.027 | Unable to determine transition date based on volume from files: MNGN09_FUT_CME.dly, MNGQ09_FUT_CME.dly 2026-10-12 07:58:57.027 | The MNGQ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGQ09_FUT_CME.dly, MNGU09_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGU09_FUT_CME.dly, MNGV09_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGV09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGV09_FUT_CME.dly, MNGX09_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGX09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGX09_FUT_CME.dly, MNGZ09_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGZ09_FUT_CME.dly, MNGF10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGF10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGF10_FUT_CME.dly, MNGG10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGG10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGG10_FUT_CME.dly, MNGH10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGH10_FUT_CME.dly, MNGJ10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGJ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGJ10_FUT_CME.dly, MNGK10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGK10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGK10_FUT_CME.dly, MNGM10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGM10_FUT_CME.dly, MNGN10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGN10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGN10_FUT_CME.dly, MNGQ10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGQ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.028 | Unable to determine transition date based on volume from files: MNGQ10_FUT_CME.dly, MNGU10_FUT_CME.dly 2026-10-12 07:58:57.028 | The MNGU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGU10_FUT_CME.dly, MNGV10_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGV10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGV10_FUT_CME.dly, MNGX10_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGX10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGX10_FUT_CME.dly, MNGZ10_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGZ10_FUT_CME.dly, MNGF11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGF11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGF11_FUT_CME.dly, MNGG11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGG11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGG11_FUT_CME.dly, MNGH11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGH11_FUT_CME.dly, MNGJ11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGJ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGJ11_FUT_CME.dly, MNGK11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGK11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGK11_FUT_CME.dly, MNGM11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGM11_FUT_CME.dly, MNGN11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGN11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGN11_FUT_CME.dly, MNGQ11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGQ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.029 | Unable to determine transition date based on volume from files: MNGQ11_FUT_CME.dly, MNGU11_FUT_CME.dly 2026-10-12 07:58:57.029 | The MNGU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGU11_FUT_CME.dly, MNGV11_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGV11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGV11_FUT_CME.dly, MNGX11_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGX11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGX11_FUT_CME.dly, MNGZ11_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGZ11_FUT_CME.dly, MNGF12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGF12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGF12_FUT_CME.dly, MNGG12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGG12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGG12_FUT_CME.dly, MNGH12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGH12_FUT_CME.dly, MNGJ12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGJ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGJ12_FUT_CME.dly, MNGK12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGK12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGK12_FUT_CME.dly, MNGM12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGM12_FUT_CME.dly, MNGN12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGN12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGN12_FUT_CME.dly, MNGQ12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGQ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGQ12_FUT_CME.dly, MNGU12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.030 | Unable to determine transition date based on volume from files: MNGU12_FUT_CME.dly, MNGV12_FUT_CME.dly 2026-10-12 07:58:57.030 | The MNGV12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGV12_FUT_CME.dly, MNGX12_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGX12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGX12_FUT_CME.dly, MNGZ12_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGZ12_FUT_CME.dly, MNGF13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGF13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGF13_FUT_CME.dly, MNGG13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGG13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGG13_FUT_CME.dly, MNGH13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGH13_FUT_CME.dly, MNGJ13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGJ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGJ13_FUT_CME.dly, MNGK13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGK13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGK13_FUT_CME.dly, MNGM13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGM13_FUT_CME.dly, MNGN13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGN13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGN13_FUT_CME.dly, MNGQ13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGQ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGQ13_FUT_CME.dly, MNGU13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.031 | Unable to determine transition date based on volume from files: MNGU13_FUT_CME.dly, MNGV13_FUT_CME.dly 2026-10-12 07:58:57.031 | The MNGV13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGV13_FUT_CME.dly, MNGX13_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGX13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGX13_FUT_CME.dly, MNGZ13_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGZ13_FUT_CME.dly, MNGF14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGF14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGF14_FUT_CME.dly, MNGG14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGG14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGG14_FUT_CME.dly, MNGH14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGH14_FUT_CME.dly, MNGJ14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGJ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGJ14_FUT_CME.dly, MNGK14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGK14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGK14_FUT_CME.dly, MNGM14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGM14_FUT_CME.dly, MNGN14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGN14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGN14_FUT_CME.dly, MNGQ14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGQ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGQ14_FUT_CME.dly, MNGU14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGU14_FUT_CME.dly, MNGV14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGV14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.032 | Unable to determine transition date based on volume from files: MNGV14_FUT_CME.dly, MNGX14_FUT_CME.dly 2026-10-12 07:58:57.032 | The MNGX14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGX14_FUT_CME.dly, MNGZ14_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGZ14_FUT_CME.dly, MNGF15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGF15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGF15_FUT_CME.dly, MNGG15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGG15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGG15_FUT_CME.dly, MNGH15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGH15_FUT_CME.dly, MNGJ15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGJ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGJ15_FUT_CME.dly, MNGK15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGK15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGK15_FUT_CME.dly, MNGM15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGM15_FUT_CME.dly, MNGN15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGN15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGN15_FUT_CME.dly, MNGQ15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGQ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGQ15_FUT_CME.dly, MNGU15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGU15_FUT_CME.dly, MNGV15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGV15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.033 | Unable to determine transition date based on volume from files: MNGV15_FUT_CME.dly, MNGX15_FUT_CME.dly 2026-10-12 07:58:57.033 | The MNGX15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGX15_FUT_CME.dly, MNGZ15_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGZ15_FUT_CME.dly, MNGF16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGF16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGF16_FUT_CME.dly, MNGG16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGG16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGG16_FUT_CME.dly, MNGH16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGH16_FUT_CME.dly, MNGJ16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGJ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGJ16_FUT_CME.dly, MNGK16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGK16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGK16_FUT_CME.dly, MNGM16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGM16_FUT_CME.dly, MNGN16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGN16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGN16_FUT_CME.dly, MNGQ16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGQ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGQ16_FUT_CME.dly, MNGU16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGU16_FUT_CME.dly, MNGV16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGV16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGV16_FUT_CME.dly, MNGX16_FUT_CME.dly 2026-10-12 07:58:57.034 | The MNGX16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.034 | Unable to determine transition date based on volume from files: MNGX16_FUT_CME.dly, MNGZ16_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGZ16_FUT_CME.dly, MNGF17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGF17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGF17_FUT_CME.dly, MNGG17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGG17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGG17_FUT_CME.dly, MNGH17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGH17_FUT_CME.dly, MNGJ17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGJ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGJ17_FUT_CME.dly, MNGK17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGK17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGK17_FUT_CME.dly, MNGM17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGM17_FUT_CME.dly, MNGN17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGN17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGN17_FUT_CME.dly, MNGQ17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGQ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGQ17_FUT_CME.dly, MNGU17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGU17_FUT_CME.dly, MNGV17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGV17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGV17_FUT_CME.dly, MNGX17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGX17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.035 | Unable to determine transition date based on volume from files: MNGX17_FUT_CME.dly, MNGZ17_FUT_CME.dly 2026-10-12 07:58:57.035 | The MNGZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGZ17_FUT_CME.dly, MNGF18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGF18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGF18_FUT_CME.dly, MNGG18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGG18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGG18_FUT_CME.dly, MNGH18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGH18_FUT_CME.dly, MNGJ18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGJ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGJ18_FUT_CME.dly, MNGK18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGK18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGK18_FUT_CME.dly, MNGM18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGM18_FUT_CME.dly, MNGN18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGN18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGN18_FUT_CME.dly, MNGQ18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGQ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGQ18_FUT_CME.dly, MNGU18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGU18_FUT_CME.dly, MNGV18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGV18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGV18_FUT_CME.dly, MNGX18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGX18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.036 | Unable to determine transition date based on volume from files: MNGX18_FUT_CME.dly, MNGZ18_FUT_CME.dly 2026-10-12 07:58:57.036 | The MNGZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGZ18_FUT_CME.dly, MNGF19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGF19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGF19_FUT_CME.dly, MNGG19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGG19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGG19_FUT_CME.dly, MNGH19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGH19_FUT_CME.dly, MNGJ19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGJ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGJ19_FUT_CME.dly, MNGK19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGK19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGK19_FUT_CME.dly, MNGM19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGM19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGM19_FUT_CME.dly, MNGN19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGN19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGN19_FUT_CME.dly, MNGQ19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGQ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGQ19_FUT_CME.dly, MNGU19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGU19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGU19_FUT_CME.dly, MNGV19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGV19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGV19_FUT_CME.dly, MNGX19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGX19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGX19_FUT_CME.dly, MNGZ19_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGZ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.037 | Unable to determine transition date based on volume from files: MNGZ19_FUT_CME.dly, MNGF20_FUT_CME.dly 2026-10-12 07:58:57.037 | The MNGF20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGF20_FUT_CME.dly, MNGG20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGG20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGG20_FUT_CME.dly, MNGH20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGH20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGH20_FUT_CME.dly, MNGJ20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGJ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGJ20_FUT_CME.dly, MNGK20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGK20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGK20_FUT_CME.dly, MNGM20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGM20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGM20_FUT_CME.dly, MNGN20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGN20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGN20_FUT_CME.dly, MNGQ20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGQ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGQ20_FUT_CME.dly, MNGU20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGU20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGU20_FUT_CME.dly, MNGV20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGV20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGV20_FUT_CME.dly, MNGX20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGX20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGX20_FUT_CME.dly, MNGZ20_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGZ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.038 | Unable to determine transition date based on volume from files: MNGZ20_FUT_CME.dly, MNGF21_FUT_CME.dly 2026-10-12 07:58:57.038 | The MNGF21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGF21_FUT_CME.dly, MNGG21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGG21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGG21_FUT_CME.dly, MNGH21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGH21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGH21_FUT_CME.dly, MNGJ21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGJ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGJ21_FUT_CME.dly, MNGK21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGK21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGK21_FUT_CME.dly, MNGM21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGM21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGM21_FUT_CME.dly, MNGN21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGN21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGN21_FUT_CME.dly, MNGQ21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGQ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGQ21_FUT_CME.dly, MNGU21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGU21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGU21_FUT_CME.dly, MNGV21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGV21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGV21_FUT_CME.dly, MNGX21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGX21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGX21_FUT_CME.dly, MNGZ21_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGZ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGZ21_FUT_CME.dly, MNGF22_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGF22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.039 | Unable to determine transition date based on volume from files: MNGF22_FUT_CME.dly, MNGG22_FUT_CME.dly 2026-10-12 07:58:57.039 | The MNGG22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGG22_FUT_CME.dly, MNGH22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGH22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGH22_FUT_CME.dly, MNGJ22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGJ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGJ22_FUT_CME.dly, MNGK22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGK22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGK22_FUT_CME.dly, MNGM22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGM22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGM22_FUT_CME.dly, MNGN22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGN22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGN22_FUT_CME.dly, MNGQ22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGQ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGQ22_FUT_CME.dly, MNGU22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGU22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGU22_FUT_CME.dly, MNGV22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGV22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGV22_FUT_CME.dly, MNGX22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGX22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGX22_FUT_CME.dly, MNGZ22_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGZ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGZ22_FUT_CME.dly, MNGF23_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGF23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGF23_FUT_CME.dly, MNGG23_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGG23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.040 | Unable to determine transition date based on volume from files: MNGG23_FUT_CME.dly, MNGH23_FUT_CME.dly 2026-10-12 07:58:57.040 | The MNGH23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGH23_FUT_CME.dly, MNGJ23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGJ23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGJ23_FUT_CME.dly, MNGK23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGK23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGK23_FUT_CME.dly, MNGM23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGM23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGM23_FUT_CME.dly, MNGN23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGN23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGN23_FUT_CME.dly, MNGQ23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGQ23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGQ23_FUT_CME.dly, MNGU23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGU23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGU23_FUT_CME.dly, MNGV23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGV23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.041 | Unable to determine transition date based on volume from files: MNGV23_FUT_CME.dly, MNGX23_FUT_CME.dly 2026-10-12 07:58:57.041 | The MNGX23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.153 | MNGX26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 07:58:57.155 | MNGX26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 07:58:57.156 | MNGX26_FUT_CME[M] 240 Min #4 | Reloading chart. 2026-10-12 07:58:57.158 | MNGX26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 07:58:57.159 | MNGX26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 07:58:57.165 | MNGX26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 07:58:57.169 | MNGX26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 07:58:57.169 | MNGX26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-10-12 07:58:57.175 | MNGX26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 07:58:57.179 | MNGX26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 07:58:57.239 | MNGX26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 07:58:57.262 | Added historical Intraday data request for MNGX26_FUT_CME to the queue. 2026-10-12 07:58:57.262 | Intraday data recording state for symbol MNGX26_FUT_CME is set to download 'Pending'. 2026-10-12 07:58:57.262 | Triggering next historical data download in queue. 2026-10-12 07:58:57.267 | Removing historical data download ID 51. 2026-10-12 07:58:57.267 | HD Request # 51 | Downloading Intraday chart data for MNGX26_FUT_CME to the file MNGX26_FUT_CME.scid. Service: nymex 2026-10-12 07:58:57.268 | HD Request # 51 | Download start date-time: 2026-10-12 07:44:00.000000. File last date-time: 2026-10-12 07:44:00.708000 2026-10-12 07:58:57.268 | HD Request # 51 | Using server: ds32.sierracharts.com port 10149 2026-10-12 07:58:57.268 | Socket (4) | Creating socket. 2026-10-12 07:58:57.268 | Socket (4) | New receive buffer size: 0 2026-10-12 07:58:57.268 | Socket (4) | Connecting to IP: 69.39.70.248 Port: 10149. 2026-10-12 07:58:57.282 | Added historical Daily data request for MNGX26_FUT_CME to the queue. 2026-10-12 07:58:57.282 | Triggering next historical data download in queue. 2026-10-12 07:58:57.286 | Removing historical data download ID 52. 2026-10-12 07:58:57.287 | HD Request # 52 | Downloading Historical Daily chart data for MNGX26_FUT_CME. Starting date: 2026-10-07. Service: nymex 2026-10-12 07:58:57.287 | HD Request # 52 | Using server: ds37.sierracharts.com port 10149 2026-10-12 07:58:57.287 | Socket (5) | Creating socket. 2026-10-12 07:58:57.287 | Socket (5) | New receive buffer size: 0 2026-10-12 07:58:57.287 | Socket (5) | Connecting to IP: 4.8.175.92 Port: 10149. 2026-10-12 07:58:57.363 | HD Request # 51 | Setting DTC encoding to Binary VLS 2026-10-12 07:58:57.363 | HD Request # 51 | Sending historical data logon request message. 2026-10-12 07:58:57.365 | HD Request # 52 | Setting DTC encoding to Binary VLS 2026-10-12 07:58:57.365 | HD Request # 52 | Sending historical data logon request message. 2026-10-12 07:58:57.440 | HD Request # 51 | Requesting Intraday data. Start date-time: 2026-10-12 07:44:00. Record interval: 0. Symbol: MNGX26 2026-10-12 07:58:57.466 | HD Request # 52 | Requesting historical Daily data starting at 2026-10-07. 2026-10-12 07:58:57.485 | HD Request # 51 | Decompressing data. 2026-10-12 07:58:57.504 | HD Request # 52 | Decompressing data. 2026-10-12 07:58:57.507 | HD Request # 52 | Receiving historical Daily data for MNGX26_FUT_CME starting at 2026-10-07. 2026-10-12 07:58:57.507 | HD Request # 52 | Writing historical Daily data to the file MNGX26_FUT_CME.dly. 2026-10-12 07:58:57.509 | Socket (5) | CloseSocket call. 2026-10-12 07:58:57.509 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-10-12 07:58:57.509 | Historical data download thread signaled to stop. 2026-10-12 07:58:57.509 | HD Request # 52 | Received 4 Daily data records from 2026-10-07 00:00:00 to 2026-10-12 00:00:00 (6.0 days) and wrote 4 records for MNGX26_FUT_CME 2026-10-12 07:58:57.509 | HD Request # 52 | Completion time: 0s. 2026-10-12 07:58:57.509 | HD Request # 52 | Daily data download complete for MNGX26_FUT_CME. Unique request ID: 52 2026-10-12 07:58:57.509 | Removing historical data download ID 52. 2026-10-12 07:58:57.509 | 2026-10-12 07:58:57.509 | No download requests in the queue to start downloads for. 2026-10-12 07:58:57.523 | MNGX26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 07:58:57.526 | MNGX26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 07:58:57.530 | HD Request # 51 | Receiving Intraday data for MNGX26_FUT_CME starting at 2026-10-12 07:44:00.708000 2026-10-12 07:58:57.530 | Socket (4) | CloseSocket call. 2026-10-12 07:58:57.530 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-10-12 07:58:57.531 | MNGX26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 07:58:57.535 | MNGX26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 07:58:57.535 | Historical data download thread signaled to stop. 2026-10-12 07:58:57.535 | HD Request # 51 | Timestamp of first Intraday data file record written: 2026-10-12 07:44:47.436000. 2026-10-12 07:58:57.535 | HD Request # 51 | Received 156 Intraday data records from 2026-10-12 07:44:00.708000 to 2026-10-12 07:57:30.984000 (13.5 minutes. Delay: 86.6 seconds) and wrote 155 records for MNGX26_FUT_CME 2026-10-12 07:58:57.535 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2026-10-12 12:57:30.984000 2026-10-12 07:58:57.535 | HD Request # 51 | Completion time: 0s. 2026-10-12 07:58:57.535 | HD Request # 51 | Intraday data download complete for MNGX26_FUT_CME. Unique request ID: 51 2026-10-12 07:58:57.535 | Real-time Intraday chart data file updates started for MNGX26_FUT_CME 2026-10-12 07:58:57.535 | Intraday chart data file opened for MNGX26_FUT_CME 2026-10-12 07:58:57.535 | HD Request # 51 | Enabling Intraday chart updating for symbol. 2026-10-12 07:58:57.535 | Removing historical data download ID 51. 2026-10-12 07:58:57.535 | 2026-10-12 07:58:57.535 | No download requests in the queue to start downloads for. 2026-10-12 07:58:57.545 | MNGX26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 07:58:57.550 | Socket (5) | Socket gracefully closed by remote side. 2026-10-12 07:58:57.550 | Socket (5) | Closed. 2026-10-12 07:58:57.575 | Socket (4) | Socket gracefully closed by remote side. 2026-10-12 07:58:57.575 | Socket (4) | Closed. 2026-10-12 07:58:57.742 | MNGX26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MNGZ23_FUT_CME * 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGQ05_FUT_CME.dly, MNGU05_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGU05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGU05_FUT_CME.dly, MNGV05_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGV05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGV05_FUT_CME.dly, MNGX05_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGX05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGX05_FUT_CME.dly, MNGZ05_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGZ05_FUT_CME.dly, MNGF06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGF06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGF06_FUT_CME.dly, MNGG06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGG06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGG06_FUT_CME.dly, MNGH06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGH06_FUT_CME.dly, MNGJ06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGJ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGJ06_FUT_CME.dly, MNGK06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGK06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGK06_FUT_CME.dly, MNGM06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGM06_FUT_CME.dly, MNGN06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGN06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGN06_FUT_CME.dly, MNGQ06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGQ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.743 | Unable to determine transition date based on volume from files: MNGQ06_FUT_CME.dly, MNGU06_FUT_CME.dly 2026-10-12 07:58:57.743 | The MNGU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGU06_FUT_CME.dly, MNGV06_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGV06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGV06_FUT_CME.dly, MNGX06_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGX06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGX06_FUT_CME.dly, MNGZ06_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGZ06_FUT_CME.dly, MNGF07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGF07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGF07_FUT_CME.dly, MNGG07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGG07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGG07_FUT_CME.dly, MNGH07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGH07_FUT_CME.dly, MNGJ07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGJ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGJ07_FUT_CME.dly, MNGK07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGK07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGK07_FUT_CME.dly, MNGM07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGM07_FUT_CME.dly, MNGN07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGN07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGN07_FUT_CME.dly, MNGQ07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGQ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.744 | Unable to determine transition date based on volume from files: MNGQ07_FUT_CME.dly, MNGU07_FUT_CME.dly 2026-10-12 07:58:57.744 | The MNGU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGU07_FUT_CME.dly, MNGV07_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGV07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGV07_FUT_CME.dly, MNGX07_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGX07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGX07_FUT_CME.dly, MNGZ07_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGZ07_FUT_CME.dly, MNGF08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGF08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGF08_FUT_CME.dly, MNGG08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGG08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGG08_FUT_CME.dly, MNGH08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGH08_FUT_CME.dly, MNGJ08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGJ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGJ08_FUT_CME.dly, MNGK08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGK08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGK08_FUT_CME.dly, MNGM08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGM08_FUT_CME.dly, MNGN08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGN08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGN08_FUT_CME.dly, MNGQ08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGQ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.745 | Unable to determine transition date based on volume from files: MNGQ08_FUT_CME.dly, MNGU08_FUT_CME.dly 2026-10-12 07:58:57.745 | The MNGU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGU08_FUT_CME.dly, MNGV08_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGV08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGV08_FUT_CME.dly, MNGX08_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGX08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGX08_FUT_CME.dly, MNGZ08_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGZ08_FUT_CME.dly, MNGF09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGF09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGF09_FUT_CME.dly, MNGG09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGG09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGG09_FUT_CME.dly, MNGH09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGH09_FUT_CME.dly, MNGJ09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGJ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGJ09_FUT_CME.dly, MNGK09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGK09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGK09_FUT_CME.dly, MNGM09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGM09_FUT_CME.dly, MNGN09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGN09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGN09_FUT_CME.dly, MNGQ09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGQ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGQ09_FUT_CME.dly, MNGU09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.746 | Unable to determine transition date based on volume from files: MNGU09_FUT_CME.dly, MNGV09_FUT_CME.dly 2026-10-12 07:58:57.746 | The MNGV09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGV09_FUT_CME.dly, MNGX09_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGX09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGX09_FUT_CME.dly, MNGZ09_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGZ09_FUT_CME.dly, MNGF10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGF10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGF10_FUT_CME.dly, MNGG10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGG10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGG10_FUT_CME.dly, MNGH10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGH10_FUT_CME.dly, MNGJ10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGJ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGJ10_FUT_CME.dly, MNGK10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGK10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGK10_FUT_CME.dly, MNGM10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGM10_FUT_CME.dly, MNGN10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGN10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGN10_FUT_CME.dly, MNGQ10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGQ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGQ10_FUT_CME.dly, MNGU10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.747 | Unable to determine transition date based on volume from files: MNGU10_FUT_CME.dly, MNGV10_FUT_CME.dly 2026-10-12 07:58:57.747 | The MNGV10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGV10_FUT_CME.dly, MNGX10_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGX10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGX10_FUT_CME.dly, MNGZ10_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGZ10_FUT_CME.dly, MNGF11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGF11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGF11_FUT_CME.dly, MNGG11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGG11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGG11_FUT_CME.dly, MNGH11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGH11_FUT_CME.dly, MNGJ11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGJ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGJ11_FUT_CME.dly, MNGK11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGK11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGK11_FUT_CME.dly, MNGM11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGM11_FUT_CME.dly, MNGN11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGN11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGN11_FUT_CME.dly, MNGQ11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGQ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGQ11_FUT_CME.dly, MNGU11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGU11_FUT_CME.dly, MNGV11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGV11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.748 | Unable to determine transition date based on volume from files: MNGV11_FUT_CME.dly, MNGX11_FUT_CME.dly 2026-10-12 07:58:57.748 | The MNGX11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGX11_FUT_CME.dly, MNGZ11_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGZ11_FUT_CME.dly, MNGF12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGF12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGF12_FUT_CME.dly, MNGG12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGG12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGG12_FUT_CME.dly, MNGH12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGH12_FUT_CME.dly, MNGJ12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGJ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGJ12_FUT_CME.dly, MNGK12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGK12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGK12_FUT_CME.dly, MNGM12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGM12_FUT_CME.dly, MNGN12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGN12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGN12_FUT_CME.dly, MNGQ12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGQ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGQ12_FUT_CME.dly, MNGU12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGU12_FUT_CME.dly, MNGV12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGV12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.749 | Unable to determine transition date based on volume from files: MNGV12_FUT_CME.dly, MNGX12_FUT_CME.dly 2026-10-12 07:58:57.749 | The MNGX12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGX12_FUT_CME.dly, MNGZ12_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGZ12_FUT_CME.dly, MNGF13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGF13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGF13_FUT_CME.dly, MNGG13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGG13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGG13_FUT_CME.dly, MNGH13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGH13_FUT_CME.dly, MNGJ13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGJ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGJ13_FUT_CME.dly, MNGK13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGK13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGK13_FUT_CME.dly, MNGM13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGM13_FUT_CME.dly, MNGN13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGN13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGN13_FUT_CME.dly, MNGQ13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGQ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGQ13_FUT_CME.dly, MNGU13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGU13_FUT_CME.dly, MNGV13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGV13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGV13_FUT_CME.dly, MNGX13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGX13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.750 | Unable to determine transition date based on volume from files: MNGX13_FUT_CME.dly, MNGZ13_FUT_CME.dly 2026-10-12 07:58:57.750 | The MNGZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGZ13_FUT_CME.dly, MNGF14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGF14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGF14_FUT_CME.dly, MNGG14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGG14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGG14_FUT_CME.dly, MNGH14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGH14_FUT_CME.dly, MNGJ14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGJ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGJ14_FUT_CME.dly, MNGK14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGK14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGK14_FUT_CME.dly, MNGM14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGM14_FUT_CME.dly, MNGN14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGN14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGN14_FUT_CME.dly, MNGQ14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGQ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGQ14_FUT_CME.dly, MNGU14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGU14_FUT_CME.dly, MNGV14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGV14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGV14_FUT_CME.dly, MNGX14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGX14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGX14_FUT_CME.dly, MNGZ14_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.751 | Unable to determine transition date based on volume from files: MNGZ14_FUT_CME.dly, MNGF15_FUT_CME.dly 2026-10-12 07:58:57.751 | The MNGF15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGF15_FUT_CME.dly, MNGG15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGG15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGG15_FUT_CME.dly, MNGH15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGH15_FUT_CME.dly, MNGJ15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGJ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGJ15_FUT_CME.dly, MNGK15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGK15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGK15_FUT_CME.dly, MNGM15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGM15_FUT_CME.dly, MNGN15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGN15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGN15_FUT_CME.dly, MNGQ15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGQ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGQ15_FUT_CME.dly, MNGU15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGU15_FUT_CME.dly, MNGV15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGV15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGV15_FUT_CME.dly, MNGX15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGX15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGX15_FUT_CME.dly, MNGZ15_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.752 | Unable to determine transition date based on volume from files: MNGZ15_FUT_CME.dly, MNGF16_FUT_CME.dly 2026-10-12 07:58:57.752 | The MNGF16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGF16_FUT_CME.dly, MNGG16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGG16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGG16_FUT_CME.dly, MNGH16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGH16_FUT_CME.dly, MNGJ16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGJ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGJ16_FUT_CME.dly, MNGK16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGK16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGK16_FUT_CME.dly, MNGM16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGM16_FUT_CME.dly, MNGN16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGN16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGN16_FUT_CME.dly, MNGQ16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGQ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGQ16_FUT_CME.dly, MNGU16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGU16_FUT_CME.dly, MNGV16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGV16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGV16_FUT_CME.dly, MNGX16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGX16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGX16_FUT_CME.dly, MNGZ16_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGZ16_FUT_CME.dly, MNGF17_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGF17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.753 | Unable to determine transition date based on volume from files: MNGF17_FUT_CME.dly, MNGG17_FUT_CME.dly 2026-10-12 07:58:57.753 | The MNGG17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGG17_FUT_CME.dly, MNGH17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGH17_FUT_CME.dly, MNGJ17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGJ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGJ17_FUT_CME.dly, MNGK17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGK17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGK17_FUT_CME.dly, MNGM17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGM17_FUT_CME.dly, MNGN17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGN17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGN17_FUT_CME.dly, MNGQ17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGQ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGQ17_FUT_CME.dly, MNGU17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGU17_FUT_CME.dly, MNGV17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGV17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGV17_FUT_CME.dly, MNGX17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGX17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGX17_FUT_CME.dly, MNGZ17_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGZ17_FUT_CME.dly, MNGF18_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGF18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGF18_FUT_CME.dly, MNGG18_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGG18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.754 | Unable to determine transition date based on volume from files: MNGG18_FUT_CME.dly, MNGH18_FUT_CME.dly 2026-10-12 07:58:57.754 | The MNGH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGH18_FUT_CME.dly, MNGJ18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGJ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGJ18_FUT_CME.dly, MNGK18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGK18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGK18_FUT_CME.dly, MNGM18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGM18_FUT_CME.dly, MNGN18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGN18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGN18_FUT_CME.dly, MNGQ18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGQ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGQ18_FUT_CME.dly, MNGU18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGU18_FUT_CME.dly, MNGV18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGV18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGV18_FUT_CME.dly, MNGX18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGX18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGX18_FUT_CME.dly, MNGZ18_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGZ18_FUT_CME.dly, MNGF19_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGF19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGF19_FUT_CME.dly, MNGG19_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGG19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.755 | Unable to determine transition date based on volume from files: MNGG19_FUT_CME.dly, MNGH19_FUT_CME.dly 2026-10-12 07:58:57.755 | The MNGH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGH19_FUT_CME.dly, MNGJ19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGJ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGJ19_FUT_CME.dly, MNGK19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGK19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGK19_FUT_CME.dly, MNGM19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGM19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGM19_FUT_CME.dly, MNGN19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGN19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGN19_FUT_CME.dly, MNGQ19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGQ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGQ19_FUT_CME.dly, MNGU19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGU19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGU19_FUT_CME.dly, MNGV19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGV19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGV19_FUT_CME.dly, MNGX19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGX19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGX19_FUT_CME.dly, MNGZ19_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGZ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGZ19_FUT_CME.dly, MNGF20_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGF20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGF20_FUT_CME.dly, MNGG20_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGG20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGG20_FUT_CME.dly, MNGH20_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGH20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.756 | Unable to determine transition date based on volume from files: MNGH20_FUT_CME.dly, MNGJ20_FUT_CME.dly 2026-10-12 07:58:57.756 | The MNGJ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGJ20_FUT_CME.dly, MNGK20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGK20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGK20_FUT_CME.dly, MNGM20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGM20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGM20_FUT_CME.dly, MNGN20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGN20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGN20_FUT_CME.dly, MNGQ20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGQ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGQ20_FUT_CME.dly, MNGU20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGU20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGU20_FUT_CME.dly, MNGV20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGV20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGV20_FUT_CME.dly, MNGX20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGX20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGX20_FUT_CME.dly, MNGZ20_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGZ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGZ20_FUT_CME.dly, MNGF21_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGF21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGF21_FUT_CME.dly, MNGG21_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGG21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGG21_FUT_CME.dly, MNGH21_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGH21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGH21_FUT_CME.dly, MNGJ21_FUT_CME.dly 2026-10-12 07:58:57.757 | The MNGJ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.757 | Unable to determine transition date based on volume from files: MNGJ21_FUT_CME.dly, MNGK21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGK21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGK21_FUT_CME.dly, MNGM21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGM21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGM21_FUT_CME.dly, MNGN21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGN21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGN21_FUT_CME.dly, MNGQ21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGQ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGQ21_FUT_CME.dly, MNGU21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGU21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGU21_FUT_CME.dly, MNGV21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGV21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGV21_FUT_CME.dly, MNGX21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGX21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGX21_FUT_CME.dly, MNGZ21_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGZ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGZ21_FUT_CME.dly, MNGF22_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGF22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGF22_FUT_CME.dly, MNGG22_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGG22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGG22_FUT_CME.dly, MNGH22_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGH22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGH22_FUT_CME.dly, MNGJ22_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGJ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.758 | Unable to determine transition date based on volume from files: MNGJ22_FUT_CME.dly, MNGK22_FUT_CME.dly 2026-10-12 07:58:57.758 | The MNGK22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGK22_FUT_CME.dly, MNGM22_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGM22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGM22_FUT_CME.dly, MNGN22_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGN22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGN22_FUT_CME.dly, MNGQ22_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGQ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGQ22_FUT_CME.dly, MNGU22_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGU22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGU22_FUT_CME.dly, MNGV22_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGV22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGV22_FUT_CME.dly, MNGX22_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGX22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGX22_FUT_CME.dly, MNGZ22_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGZ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGZ22_FUT_CME.dly, MNGF23_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGF23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGF23_FUT_CME.dly, MNGG23_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGG23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGG23_FUT_CME.dly, MNGH23_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGH23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGH23_FUT_CME.dly, MNGJ23_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGJ23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGJ23_FUT_CME.dly, MNGK23_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGK23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.759 | Unable to determine transition date based on volume from files: MNGK23_FUT_CME.dly, MNGM23_FUT_CME.dly 2026-10-12 07:58:57.759 | The MNGM23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.760 | Unable to determine transition date based on volume from files: MNGM23_FUT_CME.dly, MNGN23_FUT_CME.dly 2026-10-12 07:58:57.760 | The MNGN23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.760 | Unable to determine transition date based on volume from files: MNGN23_FUT_CME.dly, MNGQ23_FUT_CME.dly 2026-10-12 07:58:57.760 | The MNGQ23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.760 | Unable to determine transition date based on volume from files: MNGQ23_FUT_CME.dly, MNGU23_FUT_CME.dly 2026-10-12 07:58:57.760 | The MNGU23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.760 | Unable to determine transition date based on volume from files: MNGU23_FUT_CME.dly, MNGV23_FUT_CME.dly 2026-10-12 07:58:57.760 | The MNGV23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.760 | Unable to determine transition date based on volume from files: MNGV23_FUT_CME.dly, MNGX23_FUT_CME.dly 2026-10-12 07:58:57.760 | The MNGX23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 07:58:57.950 | MNGX26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 07:59:09.679 | Opened cached Intraday file: C:\SierraChart\Data\MNGX26_FUT_CME.scid. Thread ID: 7432 2026-10-12 07:59:56.954 | MNGX26_FUT_CME[M] 5 Min #6 | Reloading chart. 2026-10-12 07:59:56.974 | MNGX26_FUT_CME[M] 5 Min #6 | Chart data loading complete. 2026-10-12 07:59:58.579 | MNGX26_FUT_CME[M] 1 Min #6 | Reloading chart. 2026-10-12 07:59:58.607 | MNGX26_FUT_CME[M] 1 Min #6 | Chart data loading complete. 2026-10-12 08:00:01.356 | MNGX26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 08:00:01.372 | MNGX26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 08:00:18.929 | Saved Chartbook: Anton.cht. Time: 0.0152 seconds. 2026-10-12 08:00:21.130 | MESZ26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 08:00:21.432 | MESZ26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MESM19_FUT_CME * 2026-10-12 08:00:21.432 | Unable to determine transition date based on volume from files: MESU05_FUT_CME.dly, MESZ05_FUT_CME.dly 2026-10-12 08:00:21.432 | The MESZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.432 | Unable to determine transition date based on volume from files: MESZ05_FUT_CME.dly, MESH06_FUT_CME.dly 2026-10-12 08:00:21.432 | The MESH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.432 | Unable to determine transition date based on volume from files: MESH06_FUT_CME.dly, MESM06_FUT_CME.dly 2026-10-12 08:00:21.432 | The MESM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.432 | Unable to determine transition date based on volume from files: MESM06_FUT_CME.dly, MESU06_FUT_CME.dly 2026-10-12 08:00:21.432 | The MESU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.432 | Unable to determine transition date based on volume from files: MESU06_FUT_CME.dly, MESZ06_FUT_CME.dly 2026-10-12 08:00:21.432 | The MESZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESZ06_FUT_CME.dly, MESH07_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESH07_FUT_CME.dly, MESM07_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESM07_FUT_CME.dly, MESU07_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESU07_FUT_CME.dly, MESZ07_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESZ07_FUT_CME.dly, MESH08_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESH08_FUT_CME.dly, MESM08_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESM08_FUT_CME.dly, MESU08_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESU08_FUT_CME.dly, MESZ08_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESZ08_FUT_CME.dly, MESH09_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESH09_FUT_CME.dly, MESM09_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.433 | Unable to determine transition date based on volume from files: MESM09_FUT_CME.dly, MESU09_FUT_CME.dly 2026-10-12 08:00:21.433 | The MESU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESU09_FUT_CME.dly, MESZ09_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESZ09_FUT_CME.dly, MESH10_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESH10_FUT_CME.dly, MESM10_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESM10_FUT_CME.dly, MESU10_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESU10_FUT_CME.dly, MESZ10_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESZ10_FUT_CME.dly, MESH11_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESH11_FUT_CME.dly, MESM11_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESM11_FUT_CME.dly, MESU11_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESU11_FUT_CME.dly, MESZ11_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESZ11_FUT_CME.dly, MESH12_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESH12_FUT_CME.dly, MESM12_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.434 | Unable to determine transition date based on volume from files: MESM12_FUT_CME.dly, MESU12_FUT_CME.dly 2026-10-12 08:00:21.434 | The MESU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESU12_FUT_CME.dly, MESZ12_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESZ12_FUT_CME.dly, MESH13_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESH13_FUT_CME.dly, MESM13_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESM13_FUT_CME.dly, MESU13_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESU13_FUT_CME.dly, MESZ13_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESZ13_FUT_CME.dly, MESH14_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESH14_FUT_CME.dly, MESM14_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESM14_FUT_CME.dly, MESU14_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.435 | Unable to determine transition date based on volume from files: MESU14_FUT_CME.dly, MESZ14_FUT_CME.dly 2026-10-12 08:00:21.435 | The MESZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.436 | Unable to determine transition date based on volume from files: MESZ14_FUT_CME.dly, MESH15_FUT_CME.dly 2026-10-12 08:00:21.436 | The MESH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.436 | Unable to determine transition date based on volume from files: MESH15_FUT_CME.dly, MESM15_FUT_CME.dly 2026-10-12 08:00:21.436 | The MESM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.436 | Unable to determine transition date based on volume from files: MESM15_FUT_CME.dly, MESU15_FUT_CME.dly 2026-10-12 08:00:21.436 | The MESU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.436 | Unable to determine transition date based on volume from files: MESU15_FUT_CME.dly, MESZ15_FUT_CME.dly 2026-10-12 08:00:21.436 | The MESZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.436 | Unable to determine transition date based on volume from files: MESZ15_FUT_CME.dly, MESH16_FUT_CME.dly 2026-10-12 08:00:21.436 | The MESH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.436 | Unable to determine transition date based on volume from files: MESH16_FUT_CME.dly, MESM16_FUT_CME.dly 2026-10-12 08:00:21.436 | The MESM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESM16_FUT_CME.dly, MESU16_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESU16_FUT_CME.dly, MESZ16_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESZ16_FUT_CME.dly, MESH17_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESH17_FUT_CME.dly, MESM17_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESM17_FUT_CME.dly, MESU17_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESU17_FUT_CME.dly, MESZ17_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESZ17_FUT_CME.dly, MESH18_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESH18_FUT_CME.dly, MESM18_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESM18_FUT_CME.dly, MESU18_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESU18_FUT_CME.dly, MESZ18_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.437 | Unable to determine transition date based on volume from files: MESZ18_FUT_CME.dly, MESH19_FUT_CME.dly 2026-10-12 08:00:21.437 | The MESH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:00:21.513 | MESZ26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 08:00:21.515 | MESZ26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 08:00:21.516 | MESZ26_FUT_CME[M] 240 Min #4 | Reloading chart. 2026-10-12 08:00:21.517 | MESZ26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 08:00:21.518 | MESZ26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 08:00:21.523 | MESZ26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 08:00:21.527 | MESZ26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 08:00:21.571 | MESZ26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 08:00:22.264 | MESZ26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-10-12 08:00:22.278 | MESZ26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 08:00:22.282 | MESZ26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 08:07:31.916 | MNGX26_FUT_CME [CV][M] Monthly #1 | Reloading chart. 2026-10-12 08:07:32.115 | MNGX26_FUT_CME [CV][M] Monthly #1 | Dates not found while checking for invalid data in continuous contract data files. MNGZ23_FUT_CME * 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGQ05_FUT_CME.dly, MNGU05_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGU05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGU05_FUT_CME.dly, MNGV05_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGV05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGV05_FUT_CME.dly, MNGX05_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGX05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGX05_FUT_CME.dly, MNGZ05_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGZ05_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGZ05_FUT_CME.dly, MNGF06_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGF06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGF06_FUT_CME.dly, MNGG06_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGG06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGG06_FUT_CME.dly, MNGH06_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGH06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGH06_FUT_CME.dly, MNGJ06_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGJ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGJ06_FUT_CME.dly, MNGK06_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGK06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.115 | Unable to determine transition date based on volume from files: MNGK06_FUT_CME.dly, MNGM06_FUT_CME.dly 2026-10-12 08:07:32.115 | The MNGM06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGM06_FUT_CME.dly, MNGN06_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGN06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGN06_FUT_CME.dly, MNGQ06_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGQ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGQ06_FUT_CME.dly, MNGU06_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGU06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGU06_FUT_CME.dly, MNGV06_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGV06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGV06_FUT_CME.dly, MNGX06_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGX06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGX06_FUT_CME.dly, MNGZ06_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGZ06_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGZ06_FUT_CME.dly, MNGF07_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGF07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGF07_FUT_CME.dly, MNGG07_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGG07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGG07_FUT_CME.dly, MNGH07_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGH07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGH07_FUT_CME.dly, MNGJ07_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGJ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGJ07_FUT_CME.dly, MNGK07_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGK07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.116 | Unable to determine transition date based on volume from files: MNGK07_FUT_CME.dly, MNGM07_FUT_CME.dly 2026-10-12 08:07:32.116 | The MNGM07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGM07_FUT_CME.dly, MNGN07_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGN07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGN07_FUT_CME.dly, MNGQ07_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGQ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGQ07_FUT_CME.dly, MNGU07_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGU07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGU07_FUT_CME.dly, MNGV07_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGV07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGV07_FUT_CME.dly, MNGX07_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGX07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGX07_FUT_CME.dly, MNGZ07_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGZ07_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGZ07_FUT_CME.dly, MNGF08_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGF08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGF08_FUT_CME.dly, MNGG08_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGG08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGG08_FUT_CME.dly, MNGH08_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGH08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGH08_FUT_CME.dly, MNGJ08_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGJ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGJ08_FUT_CME.dly, MNGK08_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGK08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.117 | Unable to determine transition date based on volume from files: MNGK08_FUT_CME.dly, MNGM08_FUT_CME.dly 2026-10-12 08:07:32.117 | The MNGM08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGM08_FUT_CME.dly, MNGN08_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGN08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGN08_FUT_CME.dly, MNGQ08_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGQ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGQ08_FUT_CME.dly, MNGU08_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGU08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGU08_FUT_CME.dly, MNGV08_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGV08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGV08_FUT_CME.dly, MNGX08_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGX08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGX08_FUT_CME.dly, MNGZ08_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGZ08_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGZ08_FUT_CME.dly, MNGF09_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGF09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGF09_FUT_CME.dly, MNGG09_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGG09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGG09_FUT_CME.dly, MNGH09_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGH09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGH09_FUT_CME.dly, MNGJ09_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGJ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.118 | Unable to determine transition date based on volume from files: MNGJ09_FUT_CME.dly, MNGK09_FUT_CME.dly 2026-10-12 08:07:32.118 | The MNGK09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGK09_FUT_CME.dly, MNGM09_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGM09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGM09_FUT_CME.dly, MNGN09_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGN09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGN09_FUT_CME.dly, MNGQ09_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGQ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGQ09_FUT_CME.dly, MNGU09_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGU09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGU09_FUT_CME.dly, MNGV09_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGV09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGV09_FUT_CME.dly, MNGX09_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGX09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGX09_FUT_CME.dly, MNGZ09_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGZ09_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGZ09_FUT_CME.dly, MNGF10_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGF10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGF10_FUT_CME.dly, MNGG10_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGG10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGG10_FUT_CME.dly, MNGH10_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGH10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGH10_FUT_CME.dly, MNGJ10_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGJ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.119 | Unable to determine transition date based on volume from files: MNGJ10_FUT_CME.dly, MNGK10_FUT_CME.dly 2026-10-12 08:07:32.119 | The MNGK10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGK10_FUT_CME.dly, MNGM10_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGM10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGM10_FUT_CME.dly, MNGN10_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGN10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGN10_FUT_CME.dly, MNGQ10_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGQ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGQ10_FUT_CME.dly, MNGU10_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGU10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGU10_FUT_CME.dly, MNGV10_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGV10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGV10_FUT_CME.dly, MNGX10_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGX10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGX10_FUT_CME.dly, MNGZ10_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGZ10_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGZ10_FUT_CME.dly, MNGF11_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGF11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGF11_FUT_CME.dly, MNGG11_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGG11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGG11_FUT_CME.dly, MNGH11_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGH11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGH11_FUT_CME.dly, MNGJ11_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGJ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.120 | Unable to determine transition date based on volume from files: MNGJ11_FUT_CME.dly, MNGK11_FUT_CME.dly 2026-10-12 08:07:32.120 | The MNGK11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGK11_FUT_CME.dly, MNGM11_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGM11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGM11_FUT_CME.dly, MNGN11_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGN11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGN11_FUT_CME.dly, MNGQ11_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGQ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGQ11_FUT_CME.dly, MNGU11_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGU11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGU11_FUT_CME.dly, MNGV11_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGV11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGV11_FUT_CME.dly, MNGX11_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGX11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGX11_FUT_CME.dly, MNGZ11_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGZ11_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGZ11_FUT_CME.dly, MNGF12_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGF12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGF12_FUT_CME.dly, MNGG12_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGG12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGG12_FUT_CME.dly, MNGH12_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGH12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGH12_FUT_CME.dly, MNGJ12_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGJ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.121 | Unable to determine transition date based on volume from files: MNGJ12_FUT_CME.dly, MNGK12_FUT_CME.dly 2026-10-12 08:07:32.121 | The MNGK12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGK12_FUT_CME.dly, MNGM12_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGM12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGM12_FUT_CME.dly, MNGN12_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGN12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGN12_FUT_CME.dly, MNGQ12_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGQ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGQ12_FUT_CME.dly, MNGU12_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGU12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGU12_FUT_CME.dly, MNGV12_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGV12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGV12_FUT_CME.dly, MNGX12_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGX12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGX12_FUT_CME.dly, MNGZ12_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGZ12_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGZ12_FUT_CME.dly, MNGF13_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGF13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGF13_FUT_CME.dly, MNGG13_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGG13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGG13_FUT_CME.dly, MNGH13_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGH13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGH13_FUT_CME.dly, MNGJ13_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGJ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.122 | Unable to determine transition date based on volume from files: MNGJ13_FUT_CME.dly, MNGK13_FUT_CME.dly 2026-10-12 08:07:32.122 | The MNGK13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGK13_FUT_CME.dly, MNGM13_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGM13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGM13_FUT_CME.dly, MNGN13_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGN13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGN13_FUT_CME.dly, MNGQ13_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGQ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGQ13_FUT_CME.dly, MNGU13_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGU13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGU13_FUT_CME.dly, MNGV13_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGV13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGV13_FUT_CME.dly, MNGX13_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGX13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGX13_FUT_CME.dly, MNGZ13_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGZ13_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGZ13_FUT_CME.dly, MNGF14_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGF14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGF14_FUT_CME.dly, MNGG14_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGG14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGG14_FUT_CME.dly, MNGH14_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGH14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGH14_FUT_CME.dly, MNGJ14_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGJ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.123 | Unable to determine transition date based on volume from files: MNGJ14_FUT_CME.dly, MNGK14_FUT_CME.dly 2026-10-12 08:07:32.123 | The MNGK14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGK14_FUT_CME.dly, MNGM14_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGM14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGM14_FUT_CME.dly, MNGN14_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGN14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGN14_FUT_CME.dly, MNGQ14_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGQ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGQ14_FUT_CME.dly, MNGU14_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGU14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGU14_FUT_CME.dly, MNGV14_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGV14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGV14_FUT_CME.dly, MNGX14_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGX14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGX14_FUT_CME.dly, MNGZ14_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGZ14_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGZ14_FUT_CME.dly, MNGF15_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGF15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGF15_FUT_CME.dly, MNGG15_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGG15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGG15_FUT_CME.dly, MNGH15_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGH15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGH15_FUT_CME.dly, MNGJ15_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGJ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.124 | Unable to determine transition date based on volume from files: MNGJ15_FUT_CME.dly, MNGK15_FUT_CME.dly 2026-10-12 08:07:32.124 | The MNGK15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGK15_FUT_CME.dly, MNGM15_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGM15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGM15_FUT_CME.dly, MNGN15_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGN15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGN15_FUT_CME.dly, MNGQ15_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGQ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGQ15_FUT_CME.dly, MNGU15_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGU15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGU15_FUT_CME.dly, MNGV15_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGV15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGV15_FUT_CME.dly, MNGX15_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGX15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGX15_FUT_CME.dly, MNGZ15_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGZ15_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGZ15_FUT_CME.dly, MNGF16_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGF16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGF16_FUT_CME.dly, MNGG16_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGG16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGG16_FUT_CME.dly, MNGH16_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGH16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGH16_FUT_CME.dly, MNGJ16_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGJ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.125 | Unable to determine transition date based on volume from files: MNGJ16_FUT_CME.dly, MNGK16_FUT_CME.dly 2026-10-12 08:07:32.125 | The MNGK16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGK16_FUT_CME.dly, MNGM16_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGM16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGM16_FUT_CME.dly, MNGN16_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGN16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGN16_FUT_CME.dly, MNGQ16_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGQ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGQ16_FUT_CME.dly, MNGU16_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGU16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGU16_FUT_CME.dly, MNGV16_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGV16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGV16_FUT_CME.dly, MNGX16_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGX16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGX16_FUT_CME.dly, MNGZ16_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGZ16_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGZ16_FUT_CME.dly, MNGF17_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGF17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGF17_FUT_CME.dly, MNGG17_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGG17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGG17_FUT_CME.dly, MNGH17_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGH17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGH17_FUT_CME.dly, MNGJ17_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGJ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.126 | Unable to determine transition date based on volume from files: MNGJ17_FUT_CME.dly, MNGK17_FUT_CME.dly 2026-10-12 08:07:32.126 | The MNGK17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGK17_FUT_CME.dly, MNGM17_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGM17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGM17_FUT_CME.dly, MNGN17_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGN17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGN17_FUT_CME.dly, MNGQ17_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGQ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGQ17_FUT_CME.dly, MNGU17_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGU17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGU17_FUT_CME.dly, MNGV17_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGV17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGV17_FUT_CME.dly, MNGX17_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGX17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGX17_FUT_CME.dly, MNGZ17_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGZ17_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGZ17_FUT_CME.dly, MNGF18_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGF18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGF18_FUT_CME.dly, MNGG18_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGG18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGG18_FUT_CME.dly, MNGH18_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGH18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGH18_FUT_CME.dly, MNGJ18_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGJ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGJ18_FUT_CME.dly, MNGK18_FUT_CME.dly 2026-10-12 08:07:32.127 | The MNGK18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGK18_FUT_CME.dly, MNGM18_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGM18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGM18_FUT_CME.dly, MNGN18_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGN18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGN18_FUT_CME.dly, MNGQ18_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGQ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGQ18_FUT_CME.dly, MNGU18_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGU18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGU18_FUT_CME.dly, MNGV18_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGV18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGV18_FUT_CME.dly, MNGX18_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGX18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGX18_FUT_CME.dly, MNGZ18_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGZ18_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGZ18_FUT_CME.dly, MNGF19_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGF19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGF19_FUT_CME.dly, MNGG19_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGG19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGG19_FUT_CME.dly, MNGH19_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGH19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGH19_FUT_CME.dly, MNGJ19_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGJ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.128 | Unable to determine transition date based on volume from files: MNGJ19_FUT_CME.dly, MNGK19_FUT_CME.dly 2026-10-12 08:07:32.128 | The MNGK19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGK19_FUT_CME.dly, MNGM19_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGM19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGM19_FUT_CME.dly, MNGN19_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGN19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGN19_FUT_CME.dly, MNGQ19_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGQ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGQ19_FUT_CME.dly, MNGU19_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGU19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGU19_FUT_CME.dly, MNGV19_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGV19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGV19_FUT_CME.dly, MNGX19_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGX19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGX19_FUT_CME.dly, MNGZ19_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGZ19_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGZ19_FUT_CME.dly, MNGF20_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGF20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGF20_FUT_CME.dly, MNGG20_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGG20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGG20_FUT_CME.dly, MNGH20_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGH20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGH20_FUT_CME.dly, MNGJ20_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGJ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.129 | Unable to determine transition date based on volume from files: MNGJ20_FUT_CME.dly, MNGK20_FUT_CME.dly 2026-10-12 08:07:32.129 | The MNGK20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGK20_FUT_CME.dly, MNGM20_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGM20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGM20_FUT_CME.dly, MNGN20_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGN20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGN20_FUT_CME.dly, MNGQ20_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGQ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGQ20_FUT_CME.dly, MNGU20_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGU20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGU20_FUT_CME.dly, MNGV20_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGV20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGV20_FUT_CME.dly, MNGX20_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGX20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGX20_FUT_CME.dly, MNGZ20_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGZ20_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGZ20_FUT_CME.dly, MNGF21_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGF21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGF21_FUT_CME.dly, MNGG21_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGG21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGG21_FUT_CME.dly, MNGH21_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGH21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGH21_FUT_CME.dly, MNGJ21_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGJ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.130 | Unable to determine transition date based on volume from files: MNGJ21_FUT_CME.dly, MNGK21_FUT_CME.dly 2026-10-12 08:07:32.130 | The MNGK21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGK21_FUT_CME.dly, MNGM21_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGM21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGM21_FUT_CME.dly, MNGN21_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGN21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGN21_FUT_CME.dly, MNGQ21_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGQ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGQ21_FUT_CME.dly, MNGU21_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGU21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGU21_FUT_CME.dly, MNGV21_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGV21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGV21_FUT_CME.dly, MNGX21_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGX21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGX21_FUT_CME.dly, MNGZ21_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGZ21_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGZ21_FUT_CME.dly, MNGF22_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGF22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGF22_FUT_CME.dly, MNGG22_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGG22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGG22_FUT_CME.dly, MNGH22_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGH22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGH22_FUT_CME.dly, MNGJ22_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGJ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.131 | Unable to determine transition date based on volume from files: MNGJ22_FUT_CME.dly, MNGK22_FUT_CME.dly 2026-10-12 08:07:32.131 | The MNGK22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGK22_FUT_CME.dly, MNGM22_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGM22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGM22_FUT_CME.dly, MNGN22_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGN22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGN22_FUT_CME.dly, MNGQ22_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGQ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGQ22_FUT_CME.dly, MNGU22_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGU22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGU22_FUT_CME.dly, MNGV22_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGV22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGV22_FUT_CME.dly, MNGX22_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGX22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGX22_FUT_CME.dly, MNGZ22_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGZ22_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGZ22_FUT_CME.dly, MNGF23_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGF23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGF23_FUT_CME.dly, MNGG23_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGG23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGG23_FUT_CME.dly, MNGH23_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGH23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGH23_FUT_CME.dly, MNGJ23_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGJ23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.132 | Unable to determine transition date based on volume from files: MNGJ23_FUT_CME.dly, MNGK23_FUT_CME.dly 2026-10-12 08:07:32.132 | The MNGK23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.133 | Unable to determine transition date based on volume from files: MNGK23_FUT_CME.dly, MNGM23_FUT_CME.dly 2026-10-12 08:07:32.133 | The MNGM23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.133 | Unable to determine transition date based on volume from files: MNGM23_FUT_CME.dly, MNGN23_FUT_CME.dly 2026-10-12 08:07:32.133 | The MNGN23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.133 | Unable to determine transition date based on volume from files: MNGN23_FUT_CME.dly, MNGQ23_FUT_CME.dly 2026-10-12 08:07:32.133 | The MNGQ23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.133 | Unable to determine transition date based on volume from files: MNGQ23_FUT_CME.dly, MNGU23_FUT_CME.dly 2026-10-12 08:07:32.133 | The MNGU23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.133 | Unable to determine transition date based on volume from files: MNGU23_FUT_CME.dly, MNGV23_FUT_CME.dly 2026-10-12 08:07:32.133 | The MNGV23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.133 | Unable to determine transition date based on volume from files: MNGV23_FUT_CME.dly, MNGX23_FUT_CME.dly 2026-10-12 08:07:32.133 | The MNGX23_FUT_CME.dly symbol may not be the active contract month. 2026-10-12 08:07:32.244 | MNGX26_FUT_CME[M] Weekly #2 | Reloading chart. 2026-10-12 08:07:32.246 | MNGX26_FUT_CME[M] Daily #3 | Reloading chart. 2026-10-12 08:07:32.247 | MNGX26_FUT_CME[M] 240 Min #4 | Reloading chart. 2026-10-12 08:07:32.248 | MNGX26_FUT_CME[M] 240 Min #5 | Reloading chart. 2026-10-12 08:07:32.249 | MNGX26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 08:07:32.254 | MNGX26_FUT_CME[M] Weekly #2 | Chart data loading complete. 2026-10-12 08:07:32.259 | MNGX26_FUT_CME[M] Daily #3 | Chart data loading complete. 2026-10-12 08:07:32.260 | MNGX26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-10-12 08:07:32.265 | MNGX26_FUT_CME[M] 240 Min #5 | Chart data loading complete. 2026-10-12 08:07:32.269 | MNGX26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 08:07:32.329 | MNGX26_FUT_CME [CV][M] Monthly #1 | Chart data loading complete. 2026-10-12 08:08:22.541 | Saved Chartbook: Anton.cht. Time: 0.0143 seconds. 2026-10-12 08:08:34.713 | MNGX26_FUT_CME[M] 5 Min #6 | Reloading chart. 2026-10-12 08:08:34.734 | MNGX26_FUT_CME[M] 5 Min #6 | Chart data loading complete. 2026-10-12 08:08:37.144 | MNGX26_FUT_CME[M] 1 Min #6 | Reloading chart. 2026-10-12 08:08:37.175 | MNGX26_FUT_CME[M] 1 Min #6 | Chart data loading complete. 2026-10-12 08:08:52.296 | MNGX26_FUT_CME[M] 15 Min #6 | Reloading chart. 2026-10-12 08:08:52.312 | MNGX26_FUT_CME[M] 15 Min #6 | Chart data loading complete. 2026-10-12 08:32:13.778 | MCLX26_FUT_CME[M] 120 Min #25 | Reloading chart. 2026-10-12 08:32:13.971 | MCLX26_FUT_CME[M] 120 Min #25 | Chart data loading complete. 2026-10-12 09:50:19.270 | MYMZ26_FUT_CME[M] 60 Min #13 | Reloading chart. 2026-10-12 09:50:19.422 | MYMZ26_FUT_CME[M] 60 Min #13 | Chart data loading complete. 2026-10-12 09:50:23.352 | MYMZ26_FUT_CME[M] 240 Min #13 | Reloading chart. 2026-10-12 09:50:23.502 | MYMZ26_FUT_CME[M] 240 Min #13 | Chart data loading complete. 2026-10-12 09:50:26.106 | MYMZ26_FUT_CME[M] 120 Min #13 | Reloading chart. 2026-10-12 09:50:26.257 | MYMZ26_FUT_CME[M] 120 Min #13 | Chart data loading complete. 2026-10-12 11:05:50.944 | Saved Chartbook: Anton.cht. Time: 0.0146 seconds. 2026-10-12 11:07:37.699 | MESZ26_FUT_CME 1 Min #1 | Reloading chart. 2026-10-12 11:07:38.476 | MESZ26_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2026-10-12 11:07:49.142 | File >> Disconnect selected. 2026-10-12 11:07:49.142 | Teton CME Routing | Waiting for socket receive thread to end 2026-10-12 11:07:49.142 | DTC Client socket (1) | CloseSocket call. 2026-10-12 11:07:49.142 | DTC Client socket (1) | Max send buffers used during socket life: 3 2026-10-12 11:07:49.142 | DTC Client socket (1) | Max send buffer size during socket life: 1242 2026-10-12 11:07:49.143 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-10-12 11:07:49.143 | Denali Data Feed | Waiting for socket receive thread to end 2026-10-12 11:07:49.143 | DTC Client socket (2) | CloseSocket call. 2026-10-12 11:07:49.143 | DTC Client socket (2) | Max send buffers used during socket life: 3 2026-10-12 11:07:49.143 | DTC Client socket (2) | Max send buffer size during socket life: 2392 2026-10-12 11:07:49.143 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-10-12 11:07:49.143 | Denali Data Feed | Disconnected from the server. 2026-10-12 11:07:49.143 | Delayed Data Feed | Waiting for socket receive thread to end 2026-10-12 11:07:49.143 | DTC Client socket (3) | CloseSocket call. 2026-10-12 11:07:49.143 | Delayed Data Feed | Disconnected from the server. 2026-10-12 11:07:49.143 | Teton CME Routing | Disconnected. 2026-10-12 11:07:49.143 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-10-12 11:07:49.180 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-10-12 11:07:49.180 | DTC Client socket (1) | Closed. 2026-10-12 11:07:49.195 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-10-12 11:07:49.195 | DTC Client socket (3) | Closed. 2026-10-12 11:07:49.238 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-10-12 11:07:49.238 | DTC Client socket (2) | Closed. 2026-10-12 11:08:01.961 | 2026-10-12 11:08:01.962 | Teton CME Routing | Firm: Phillip Capital 2026-10-12 11:08:01.962 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 2026-10-12 11:08:01.965 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-10-12 11:08:01.965 | DTC Client socket (1) | New receive buffer size: 0 2026-10-12 11:08:01.965 | DTC Client socket (1) | Connecting to IP: 216.200.108.154 Port: 11089. 2026-10-12 11:08:02.001 | Teton CME Routing | Network connection to server complete. 2026-10-12 11:08:02.001 | Teton CME Routing | Starting socket receive thread. 2026-10-12 11:08:02.001 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-10-12 11:08:02.130 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-10-12 11:08:02.130 | Teton CME Routing | Sending logon request message. 2026-10-12 11:08:02.216 | Teton CME Routing | Received logon response. 2026-10-12 11:08:02.216 | Teton CME Routing | Server Name: SC DTC Server. Build=58073. 2026-10-12 11:08:02.216 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-10-12 11:08:02.216 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-10-12 11:08:02.216 | Teton CME Routing | Trading is supported. 2026-10-12 11:08:02.216 | Teton CME Routing | Order cancel and replace is supported. 2026-10-12 11:08:02.216 | Teton CME Routing | OCO Orders supported. 2026-10-12 11:08:02.216 | Teton CME Routing | Bracket Orders supported. 2026-10-12 11:08:02.216 | Teton CME Routing | MarketDepthIsSupported: 1 2026-10-12 11:08:02.216 | Teton CME Routing | Connection to server complete. 2026-10-12 11:08:02.219 | No download requests in the queue to start downloads for. | Number times message added: 4 2026-10-12 11:08:02.219 | Subscribing to symbol for symbol alert. CLV25_FUT_CME 2026-10-12 11:08:02.219 | Mapping CLV25_FUT_CME to CLV25. Service code: nymex 2026-10-12 11:08:02.219 | Using symbol data fast lookup vector 2026-10-12 11:08:02.219 | Denali Data Feed | Starting real-time market data updates for: CLV25_FUT_CME (CLV25). ID: 1 Service code: nymex 2026-10-12 11:08:02.219 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2026-10-12 11:08:02.219 | Denali Data Feed | Requesting security definition data for: CLV25_FUT_CME (CLV25). ID: 1 2026-10-12 11:08:02.219 | Subscribing to symbol for symbol alert. RTYZ25_FUT_CME 2026-10-12 11:08:02.219 | Mapping RTYZ25_FUT_CME to RTYZ25. Service code: cme 2026-10-12 11:08:02.219 | Denali Data Feed | Starting real-time market data updates for: RTYZ25_FUT_CME (RTYZ25). ID: 2 Service code: cme 2026-10-12 11:08:02.219 | Denali Data Feed | Requesting security definition data for: RTYZ25_FUT_CME (RTYZ25). ID: 2 2026-10-12 11:08:02.219 | Subscribing to symbol for symbol alert. YMZ25_FUT_CME 2026-10-12 11:08:02.219 | Mapping YMZ25_FUT_CME to YMZ25. Service code: cbot 2026-10-12 11:08:02.219 | Denali Data Feed | Starting real-time market data updates for: YMZ25_FUT_CME (YMZ25). ID: 3 Service code: cbot 2026-10-12 11:08:02.219 | Denali Data Feed | Requesting security definition data for: YMZ25_FUT_CME (YMZ25). ID: 3 2026-10-12 11:08:02.219 | Updated verified funded futures trading account ending date to: 2026-11-11 16:08:02 2026-10-12 11:08:02.219 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-10-12 11:08:02.219 | DTC Client socket (2) | Creating socket. 2026-10-12 11:08:02.219 | DTC Client socket (2) | New receive buffer size: 0 2026-10-12 11:08:02.219 | DTC Client socket (2) | Connecting to IP: 67.214.125.6 Port: 443. 2026-10-12 11:08:02.220 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2026-10-12 14:56:14.889468 2026-10-12 11:08:02.232 | Mapping MESZ26_FUT_CME to MESZ26. Service code: cme 2026-10-12 11:08:02.232 | Denali Data Feed | Starting real-time market data updates for: MESZ26_FUT_CME (MESZ26). ID: 4 Service code: cme 2026-10-12 11:08:02.232 | Denali Data Feed | Requesting security definition data for: MESZ26_FUT_CME (MESZ26). ID: 4 2026-10-12 11:08:02.232 | Added historical Intraday data request for MESZ26_FUT_CME to the queue. 2026-10-12 11:08:02.232 | Intraday data recording state for symbol MESZ26_FUT_CME is set to download 'Pending'. 2026-10-12 11:08:02.232 | Triggering next historical data download in queue. 2026-10-12 11:08:02.243 | Removing historical data download ID 53. 2026-10-12 11:08:02.243 | Delaying start of download for MESZ26_FUT_CME. 2026-10-12 11:08:02.264 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLV25_FUT_CME 2026-10-12 11:08:02.264 | Teton CME Routing | Setting external service identifier for symbol CLV25_FUT_CME to 4257 2026-10-12 11:08:02.264 | Teton CME Routing | Received security definition for symbol CLV25_FUT_CME 2026-10-12 11:08:02.264 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYZ25_FUT_CME 2026-10-12 11:08:02.264 | Teton CME Routing | Setting external service identifier for symbol RTYZ25_FUT_CME to 4258 2026-10-12 11:08:02.264 | Teton CME Routing | Received security definition for symbol RTYZ25_FUT_CME 2026-10-12 11:08:02.264 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMZ25_FUT_CME 2026-10-12 11:08:02.264 | Teton CME Routing | Setting external service identifier for symbol YMZ25_FUT_CME to 4259 2026-10-12 11:08:02.264 | Teton CME Routing | Received security definition for symbol YMZ25_FUT_CME 2026-10-12 11:08:02.265 | Denali Data Feed | Network connection to server complete. 2026-10-12 11:08:02.265 | Denali Data Feed | Starting socket receive thread. 2026-10-12 11:08:02.265 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-10-12 11:08:02.309 | Updated verified funded futures trading account ending date to: 2026-11-11 16:08:02 2026-10-12 11:08:02.309 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ26_FUT_CME 2026-10-12 11:08:02.309 | Teton CME Routing | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-10-12 11:08:02.309 | Teton CME Routing | Received security definition for symbol MESZ26_FUT_CME 2026-10-12 11:08:02.330 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-10-12 11:08:02.330 | Denali Data Feed | Sending logon request message. 2026-10-12 11:08:02.798 | Denali Data Feed | Received logon response. 2026-10-12 11:08:02.798 | Denali Data Feed | Server Name: SC Realtime Server. 2026-10-12 11:08:02.798 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-10-12 11:08:02.798 | Denali Data Feed | Successfully connected. 2026-10-12 11:08:02.798 | Denali Data Feed | Trading is not supported. 2026-10-12 11:08:02.798 | Denali Data Feed | MarketDepthIsSupported: 1 2026-10-12 11:08:02.798 | Denali Data Feed | Restarting real-time data updates for symbol: CLV25_FUT_CME -> CLV25 2026-10-12 11:08:02.798 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ26_FUT_CME -> MESZ26 2026-10-12 11:08:02.798 | Denali Data Feed | Restarting real-time data updates for symbol: RTYZ25_FUT_CME -> RTYZ25 2026-10-12 11:08:02.798 | Denali Data Feed | Restarting real-time data updates for symbol: YMZ25_FUT_CME -> YMZ25 2026-10-12 11:08:02.924 | Denali Data Feed | Real-time data for symbol CLV25_FUT_CME is currently unavailable. 2026-10-12 11:08:02.924 | Denali Data Feed | Received security definition for symbol CLV25_FUT_CME 2026-10-12 11:08:02.924 | Denali Data Feed | Setting external service identifier for symbol MESZ26_FUT_CME to 42001581 2026-10-12 11:08:02.924 | Denali Data Feed | Received security definition for symbol MESZ26_FUT_CME 2026-10-12 11:08:02.924 | Denali Data Feed | Real-time data for symbol RTYZ25_FUT_CME is currently unavailable. 2026-10-12 11:08:02.924 | Denali Data Feed | Received security definition for symbol RTYZ25_FUT_CME 2026-10-12 11:08:02.924 | Denali Data Feed | Real-time data for symbol YMZ25_FUT_CME is currently unavailable. 2026-10-12 11:08:02.924 | Denali Data Feed | Received security definition for symbol YMZ25_FUT_CME 2026-10-12 11:08:07.735 | HD Request # 53 | Downloading Intraday chart data for MESZ26_FUT_CME to the file MESZ26_FUT_CME.scid. Service: cme 2026-10-12 11:08:07.735 | HD Request # 53 | Download start date-time: 2026-10-12 11:06:43.000000. File last date-time: 2026-10-12 11:06:43.149000 2026-10-12 11:08:07.735 | HD Request # 53 | Using server: ds28.sierracharts.com port 10150 2026-10-12 11:08:07.736 | Socket (3) | Creating socket. 2026-10-12 11:08:07.736 | Socket (3) | New receive buffer size: 0 2026-10-12 11:08:07.736 | Socket (3) | Connecting to IP: 67.214.125.5 Port: 10150. 2026-10-12 11:08:07.838 | HD Request # 53 | Setting DTC encoding to Binary VLS 2026-10-12 11:08:07.838 | HD Request # 53 | Sending historical data logon request message. 2026-10-12 11:08:07.915 | HD Request # 53 | Requesting Intraday data. Start date-time: 2026-10-12 11:06:43. Record interval: 0. Symbol: MESZ26 2026-10-12 11:08:07.960 | HD Request # 53 | Decompressing data. 2026-10-12 11:08:08.005 | HD Request # 53 | Receiving Intraday data for MESZ26_FUT_CME starting at 2026-10-12 11:06:43.149000 2026-10-12 11:08:08.005 | Socket (3) | CloseSocket call. 2026-10-12 11:08:08.005 | Socket (3) | Shutdown started. Waiting for graceful close. 2026-10-12 11:08:08.005 | Historical data download thread signaled to stop. 2026-10-12 11:08:08.005 | HD Request # 53 | Timestamp of first Intraday data file record written: 2026-10-12 11:06:43.259000. 2026-10-12 11:08:08.005 | HD Request # 53 | Received 112 Intraday data records from 2026-10-12 11:06:43.149000 to 2026-10-12 11:07:01.554000 (18.4 seconds. Delay: 66.5 seconds) and wrote 111 records for MESZ26_FUT_CME 2026-10-12 11:08:08.006 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2026-10-12 16:07:01.554000 2026-10-12 11:08:08.006 | HD Request # 53 | Completion time: 1s. 2026-10-12 11:08:08.006 | HD Request # 53 | Intraday data download complete for MESZ26_FUT_CME. Unique request ID: 53 2026-10-12 11:08:08.006 | Real-time Intraday chart data file updates started for MESZ26_FUT_CME 2026-10-12 11:08:08.006 | Intraday chart data file opened for MESZ26_FUT_CME 2026-10-12 11:08:08.006 | HD Request # 53 | Enabling Intraday chart updating for symbol. 2026-10-12 11:08:08.006 | Removing historical data download ID 53. 2026-10-12 11:08:08.006 | 2026-10-12 11:08:08.006 | No download requests in the queue to start downloads for. 2026-10-12 11:08:08.051 | Socket (3) | Socket gracefully closed by remote side. 2026-10-12 11:08:08.051 | Socket (3) | Closed. 2026-10-12 11:08:12.124 | Opened cached Intraday file: C:\SierraChart\Data\MESZ26_FUT_CME.scid. Thread ID: 7432 |
| [2026-10-12 16:39:41] |
We do not see anything in your log indicating you would not be getting the real-time data. What is one symbol for which you are having an issue? For that symbol, what are you seeing that makes you think you are getting delayed data? If you can get us an image of what you are seeing, that would be helpful. Follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) -- The one thing we do see in your log are issues related to finding the transition date for continuous contract charts. Refer to the following regarding those messages: Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-12 16:48:18] |
| ANTARES - Posts: 15 |
here what I see on my screen
| [2026-10-12 16:54:37] |
in message log, you asked me to show you, it says: "Real time data for symbol is currently unavailable".
| [2026-10-12 21:50:13] |
The note in your Message Log that states "Denali Data Feed | Real-time data for symbol [symbol] is currently unavailable." only means that the data has not started yet for that symbol. It is not an indicator that you are getting delayed data, or that you will not get the real-time data. What does not make any sense is why you are getting the message "(delayed)" in your Chart Header when the "Data Delay" is only showing as 1 minute 5 seconds and some milliseconds (such as the .839 for MCLX26_FUT_CME). A delay that small just indicates a difference between your computer clock and the exchange. It should not show the word "Delayed" unless you are more than 10 minutes delayed. We will have Engineering look at this and see if they can understand why you are getting that message. In the meantime, if you want to synchronize your computer clock to a national standard (the same thing the exchanges do), then you can do this using Sierra Chart. Refer to the following: Network Time Protocol Client For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-12 22:39:24] |
I did internet time synchronization in my PC (windows) and now its not delayed anymore, seems it was my PC glitch. Thank you very much for your help, there is no need to bother the engineers. |
| [2026-10-13 14:57:09] |
| Sierra_Chart Engineering - Posts: 25523 |
Use the NTP client in Sierra Chart: Network Time Protocol Client You have a large number of messages like these: 2026-10-12 08:07:32.127 | Unable to determine transition date based on volume from files: MNGU17_FUT_CME.dly, MNGV17_FUT_CME.dly
You have your Continuous Futures Contract Charts attempting to load too many days of data that does not exist. You must reduce that. Refer to the documentation here:2026-10-12 08:07:32.127 | The MNGV17_FUT_CME.dly symbol may not be the active contract month. Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart The messages about market data unavailable are completely normal for expired futures contracts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-10-13 14:59:29
