Date/Time: Fri, 20 Nov 2026 11:17:26 +0000
Trial Package Active but SC Data Not Enabled
View Count: 461
[2026-10-04 23:34:20]
User213061 - Posts: 2
Hello Sierra Chart Support, my Trial Package is active until October 25, 2026. I have already verified my email address and logged in again, but SC Data still shows "Not enabled on package". The Message Log says: "Service Package does not support this function or account is expired". Could you please check and enable the trial data entitlement for my account Yeshua? Thank you.
[2026-10-04 23:46:03]
Sierra_Chart Engineering - Posts: 25447
We show that your email address is still not verified. Go through the process again:
https://www.sierrachart.com/UserControlPanel.php?page=EmailVerification
Let us know if you still have a problem.
[2026-10-05 15:14:30]
Hello, my email address is now verified, but Sierra Chart still cannot connect to the data feed. I still receive the message: “Service Package does not support this function or account is expired.” My Trial Package is active until October 25, 2026. Please check whether my account is still restricted and enable the trial data access. Thank you.
[2026-10-05 20:59:35]
John - SC Support - Posts: 48597
We can attest to the fact that you did verify your email address. So that is no longer the issue.
Keep in mind that while on a Trial, you are not able to connect to data and trading services. So other than the "SC Data" and "Trading Evaluator" options in the "Current Selected Service", everything else will show as "Not Available", and if you do select one, you will get the message you are getting in your Message Log.
Additionally, while on a trial, you have limited data available. Refer to the following:
Sierra Chart Trial Account
If the above does not resolve your issue, then we would need to see your "Message Log" by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2026-10-13 12:54:18]
User733122 - Posts: 3
I experience the same issue. I tried to send the email verification, but the email never seems to have been sent after 10 trials. Is the email sending service down? Thank you.
[2026-10-13 13:47:32]
User733122:
You are not receiving the emails because you have an @yahoo.com email address. Yahoo, for some reason, removes our automated emails, so you will never receive them.
We have taken care of this for you, so you can now use the trial.
[2026-10-13 14:02:56]
Thank you so much! The "(Restricted)" text disappeared from the account. However, after I close and restart Sierra Chart, when I open "Data/Trade Service Settings", "SC Data (Not enabled on package)" is still present.
I have followed the instruction above to clear the log, use only one symbol "AAPL" from "_Free_Trial_Symbols". "Service Package does not support this function or account is expired" still shows up. The following is the message log:
2026-10-13 16:38:42.494 | Software version: 2970 64-bit
2026-10-13 16:38:42.494 | Primary Thread ID: 872
2026-10-13 16:38:42.494 | Usage end date: 2026-10-27
2026-10-13 16:38:42.494 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-10-13 16:38:42.494 | Current selected Data/Trading service: SC Data
2026-10-13 16:38:42.494 | Custom symbol settings values: enabled
2026-10-13 16:38:42.494 | Chart Update Interval: 400
2026-10-13 16:38:42.494 | Intraday Data Storage Time Unit: 1
2026-10-13 16:38:42.494 | Time Zone: +00:00:00 (UTC+00)
2026-10-13 16:38:42.494 | 2026-10-13 16:38:42 Local computer time in UTC
2026-10-13 16:38:42.494 | 2026-10-13 16:38:42 Local computer time in SC Time Zone
2026-10-13 16:38:42.494 | Program path: c:\sierra_chart\
2026-10-13 16:38:42.494 | Data Files path: c:\sierra_chart\Data\
2026-10-13 16:38:42.494 | OS Version Number: 10.0
2026-10-13 16:38:42.494 | Locale Setting: C
2026-10-13 16:38:42.494 | Crash reporter started: true
2026-10-13 16:39:37.020 | File compression not supported on file system. c:\sierra_chart\Data\AAPL.dly. Windows error code 50: Request not supported. | Number times message added: 2
2026-10-13 16:39:37.022 | AAPL Daily #1 | Reloading chart.
2026-10-13 16:39:37.023 | File compression not supported on file system. c:\sierra_chart\Data\AAPL.dly. Windows error code 50: Request not supported.
2026-10-13 16:39:37.026 | AAPL Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: c:\sierra_chart\Data\AAPL.dly
2026-10-13 16:39:37.032 | AAPL Daily #1 | Chart data loading complete.
2026-10-13 16:39:37.427 | Starting DelayedDownloadMonitoringTimer
2026-10-13 16:39:37.427 | Starting HDTimeoutTimer
2026-10-13 16:39:37.427 | Historical data service client indicated that downloads are not enabled. Symbol: AAPL. Data Type: Daily data.
2026-10-13 16:39:37.480 | File compression not supported on file system. c:\sierra_chart\Data\AAPL.dly. Windows error code 50: Request not supported. | Number times message added: 1
2026-10-13 16:39:37.487 | AAPL Daily #1 | Reloading chart.
2026-10-13 16:39:37.489 | File compression not supported on file system. c:\sierra_chart\Data\AAPL.dly. Windows error code 50: Request not supported.
2026-10-13 16:39:37.499 | AAPL Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: c:\sierra_chart\Data\AAPL.dly
2026-10-13 16:39:37.502 | AAPL Daily #1 | Chart data loading complete.
2026-10-13 16:40:15.678 | Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. *
Date Time Of Last Edit: 2026-10-13 16:49:58
[2026-10-13 16:50:15]
Please try logging in using the "Forced Login" to ensure that your local copy has the updated information from our servers. Follow these instructions for this:
Sierra Chart - Software Login Instructions: Forced Login
We are also checking on why there might be an issue with the override we are using.
[2026-10-13 17:10:44]
Thank you so much John. "Forced Login" seemed to have resolved the issue. I am able to load AAPL historical data and connect to delayed data feed now.
