Date/Time: Tue, 24 Nov 2026 02:24:56 +0000
Server issue
View Count: 446
[2026-06-24 12:52:00]
User608696 - Posts: 13
Please can you help
I am having problems connecting to Rithmic Direct DTC. I have followed the instructions in the connection set up guide but unfortunately I am still having issues connecting using my Apex account details.
I am happy to send the message log when requested. Currently the log is displaying “Rithmic Direct-DTC|Remote address is not Set” when I attempt to connect.
Best regards
Michael Walsh
[2026-06-24 13:19:41]
User135243 - Posts: 337
enter username and password and click Apply All and restart SC, now you should see the apex-servers, now enter username/password 3times if you want the data from Rithmic, if you've Denali realtime-data just enter it once.
[2026-06-24 13:25:18]
Thanks for your response. Unfortunately I’ve already tried this to no avail. Thanks again.
[2026-06-24 14:28:38]
John - SC Support - Posts: 48633
Please follow the instructions at the following link from Steps 8 through 11. You need to have a server selected and those steps tell you how to do this.
Rithmic Trading Platform Service: Setup Instructions
[2026-06-24 14:40:19]
Hello John, thanks for your answer. Unfortunately I have already done this. I have selected Rithmict Direct DTC from the server list and have input my Apex details 3 times for
logging in, Market data and historical data
Maybe that is an issue?
Happy to send message logs if requested. Thanks again.
[2026-06-24 16:34:13]
Per the instructions, after you select "Rithmic Direct - DTC" for the "Current Selected Service", you need to select "OK" to close that window.
Then select "Global Settings >> Data/Trade Service Settings" again to open the window. Then select the item list for the "Server List" to bring up the list of servers. Select the server you need in that list. Refer to the following for how to use that list item if you are not familiar with it:
Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options)
[2026-06-24 16:56:37]
Hi John,
I’ve done this but still getting the “Remote address is not set” message unfortunately.
[2026-06-24 17:41:54]
Please get us an image of your "Data/Trade Service Settings" window.
[2026-06-24 18:32:17]
Thanks, that should be with you now
[2026-06-24 18:43:16]
There is no image attached, nor was anything sent to our image server.
Please attach an image to this thread by following these instructions:
[2026-06-24 19:00:18]
File attached
Private File
[2026-06-24 19:00:46]
Think that should be it now
[2026-06-24 19:24:31]
You have not selected a Rithmic "Server".
There is a field on that window named "Server (List)". You need to select the black space to the right of that in order to bring up the list of servers. Then select the appropriate server for what you are waning to connect to.
Refer to the instructions at Steps 10 and 11 at the following link:
Since the last udpate(s) I cannot use UP_BAVWAP and DW_BAVWAP
And again, if you are not familiar with how to use that field, then refer to the following:
[2026-06-24 19:31:45]
Great stuff, thank you for your help. I’ll ask Rithmic which server to use, thanks for your help once again.
