Date/Time: Thu, 26 Nov 2026 04:11:43 +0000
WINDOWS SETTINGS and DENALI
View Count: 463
[2026-04-24 00:33:57]
User166249 - Posts: 28
hi
- ive click on "hide windows" : how can i see it again because it has desapeared ?
- i want to create a seconde main windows : is it possible?
- ive ask support to modify denali without depth : is it done?
best regards
[2026-04-24 13:11:36]
Select the "CW" menu and select the chart, this will open the chart again and make it the active chart.
Not within a single instance of Sierra Chart. Although this is something that is being worked on, but we can not say when we would have this available.
The best option for this is to start a sub-instance by using the options under "File >> New Instance". Refer to the following:
File Menu: New Instance (File)
You can also have separate Sierra Chart installations to do this, but you have to be careful about the data feed, as you can only have 3 separate installations accessing the data at the same time. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
Denali Exchange Data Feed: Denali Exchange Data Feed Connections on Same Computer Simultaneously
We are not finding any recent posts asking us to make changes to the exchange selections you have. Refer to the following for how to change your exchange selections:
Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections
[2026-04-24 16:14:05]
ok thanks
- is it possible to REPLACE alt + H by scroll wheel button of mouse?
- is it possible to replace alt + 3 by 2 click on left mouse button ?
- for ZN symbol i cannot set close line in subgraph setting for study price overlay?
- what type of candle ZN is displayed?
- is it possible to synchronise time beetween 2 windows?
best regards
[2026-04-24 18:31:13]
There are no tools to do this directly within Sierra Chart.
Your mouse manufacturer may have the ability to map mouse options to certain actions - so you should see if you can do it using their software.
There are third party tools that may allow you to do this.
What is the study you are overlaying and from a chart of what symbol?
The Study/Price Overlay, by default, is set to use the subgraph settings from the source study. You would need to change the appropriate Input to allow you to change the particular item you want to change. Refer to the following and the three Inputs below it:
Study/Price Overlay Study: Use Subgraph Name/Value Related Display Settings from Source Study
We do not understand this question.
You can display the candles in one of many formats. Refer to the following:
Chart Settings: Graph Draw Type (Chart >> Chart Settings >> Bar Period >> Graph Draw Type menu)
The times for the bars come from the exchanges. So the time between two windows will be "synchronized" automatically due to this.
