Date/Time: Thu, 26 Nov 2026 04:11:47 +0000
Trade/Quote Symbol unexpectedly changed without warning, triggering Daily Loss Limit
View Count: 633
[2026-04-21 15:13:15]
soranthous - Posts: 8
I have experienced either an undocumented issue or an issue that is not made clear in the documentation for the pertinent topics. Though I am trading on a prop firm account via Rithmic, the problem I am describing below is not Rithmic data/trade execution related. It is strictly a Sierra Chart issue.
For months, I have been using the Trade and Current Quote Symbol setting to Chart NQ and trade on MNQ. This is because I prefer the lower risk/leverage of trading MNQ micros vs. the amplified risk of trading minis on the NQ. I have many charts on my chartbook, the majority of which are configured in this manner. Today (4/21) I placed several trades during premarket using this configuration, as is my usual habit. I did not place any trades between 8:44:55 and 9:31:03 (Eastern times). The only activity that I did wherein I actively changed something in the chartbook is copying a drawing from one chart to another.
I have sent Message Log via the "Send for Analysis" option. The issue occurs exactly at 9:17:33. You will see that the symbol suddenly changes from the expected NQM6.CME/MNQM6.CME to just NQM6.CME. At no point did I go into chart settings/symbol settings to change this. To confirm this for myself before typing this message, I re-watched a video recording of my screen (I video record my main monitor that contains the main sierra chart window/control bar/DOM every trading session) and saw that the symbol on my DOM changed exactly at this time.
Trade activity log confirms that all trades placed prior to 9:31:03 were executed on MNQ, as expected and habitual. However, due to the sudden and unexplained change from MNQ to NQ, all trades placed at 9:31:03 were done on the NQ, which was not desired at all. Because I trade with P&L hidden (a personal choice), I did not notice that my P&L was fluctuating by a much larger degree than expected. What happened is that each trade I executed was done using NQ minis instead of MNQ micros. This resulted in a Daily Loss Limit being triggered on my evaluation account, resulting in weeks of lost time. Again, this is not a Rithmic/prop firm account issue.
Something occurred within Sierra chart to cause the chart/trading symbol to change unexpectedly, presumably when I copied one drawing from a chart to another. There is some kind of interaction between chart drawing copying, chart linking, and the trade/quote symbol "yes/no" toggle within chart linking that is causing this issue. I am 99% certain this is not user error on my part. If it is an error on my part, I do not think that the catastrophic result of the trade/quote symbol being changed without warning is adequately documented. Again, never once did I manually go into Chart Settings-->Symbol and manually delete the "Trade and Current Quote Symbol (Action)" field.
As I mentioned above, I have many charts in my chartbook. Most experienced this catastrophic error of surreptitiously changing from MNQ execution to NQ execution. A few charts did not (i.e., they maintained the correct NQM6.CME/MNQM6.CME configuration). I do not know why this has happened. Most of my charts are linked within the same group. Yet, most charts within this linked group experienced the change; some did not. I do not understand why this happened. And this has caused my prop firm account to experience a Daily Loss Limit breach. As I mentioned, I trade exclusively on the MNQ micros. For Sierra Chart to suddenly change symbol settings, this meant that every trade was executed on NQ minis. This sudden change will cost me weeks of work. This is incredibly frustrating. Please look into this ASAP. As this issue is not able to be illustrated by attaching a single chart, for now I have only sent the Message Log for Analysis. I am saving the chartbook with the issue I described above under a different name, so that these unexpected changes will not affect my day-to-day chartbook. I can provide the chartbook with the issue if need be. I can also provide the video of my screen that shows I did not gone into chart settings to change the symbol.
[2026-04-21 19:05:50]
Sierra_Chart Engineering - Posts: 25489
We cannot say for sure, why there was a change of the Trade and Current Quote Symbol. There is no logging which gives any clear indication of that. We would think it would be most likely due to using Chart Linking and linking the Symbol and/or the Trade/Quote Symbol:
Chart Settings: Chart Linking (Chart >> Chart Settings >> Linking menu)
So we recommend never linking the symbol. Disable both of these linking options in every chart.
This is also another setting to check:
Chart Settings: Clear Trade and Current Quote Symbol on Symbol Change (Chart >> Chart Settings >> Trading menu)
It definitely could not be related to this:
This is the log at the time you mentioned:
2026-04-21 09:17:33.775 | Chart #17 has tagged chart #26 for full recalculation. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 09:17:33.775 | Chart #17 has tagged chart #3 for full recalculation. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 09:17:33.806 | NQM6.CME/MNQM6.CME[M] #3 | Performing a full recalculation because it has been tagged. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 09:17:34.091 | NQM6.CME/MNQM6.CME [CBV][M] 15.00 Range #26 | Performing a full recalculation because it has been tagged. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 09:17:34.772 | Chart #17 has tagged chart #26 for full recalculation. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 09:17:34.772 | Chart #17 has tagged chart #3 for full recalculation. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 09:17:34.794 | NQM6.CME[M] #3 | Performing a full recalculation because it has been tagged. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 09:17:34.958 | NQM6.CME [CBV][M] 15.00 Range #26 | Performing a full recalculation because it has been tagged. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint.Cht
2026-04-21 10:17:53.195 | NQM6.CME [CBV][M] 15.00 Range #26 | StartDateTimeForLoadingOrderFills: 2025-04-14 00:00:00 | Number times message added: 1
2026-04-21 10:33:50.909 | NQM6.CME/MNQM6.CME #3 | Reloading chart.
2026-04-21 10:33:51.074 | NQM6.CME 1 Min #4 | Reloading chart.
2026-04-21 10:33:51.105 | NQM6.CME 15 Min #7 | Reloading chart.
2026-04-21 10:33:51.134 | NQM6.CME/MNQM6.CME 30 Min #8 | Reloading chart.
2026-04-21 10:33:51.161 | NQM6.CME [CBV] Daily #9 | Reloading chart.
2026-04-21 10:33:51.237 | NQM6.CME Weekly #10 | Reloading chart.
2026-04-21 10:33:51.264 | NQM6.CME Monthly #11 | Reloading chart.
2026-04-21 10:33:51.282 | NQM6.CME/MNQM6.CME 5 Min #12 | Reloading chart.
2026-04-21 10:33:51.295 | NQM6.CME 3 Min #13 | Reloading chart.
2026-04-21 10:33:51.342 | NQM6.CME 60 Min #14 | Reloading chart.
2026-04-21 10:33:51.381 | NQM6.CME 240 Min #17 | Reloading chart.
2026-04-21 10:33:51.406 | NQM6.CME Monthly #20 | Reloading chart.
2026-04-21 10:33:51.451 | ESH6.CME Monthly #21 | Reloading chart.
2026-04-21 10:33:51.504 | NQM6.CME/MNQM6.CME [CBV] #23 | Reloading chart.
2026-04-21 10:33:51.573 | NQM6.CME 15.00 Range #22 | Reloading chart.
2026-04-21 10:33:51.616 | NQM6.CME [CBV] #24 | Reloading chart.
2026-04-21 10:33:51.710 | NQM6.CME/MNQM6.CME [CBV] 15.00 Range #26 | Reloading chart.
2026-04-21 10:33:51.805 | NQM6.CME/MNQM6.CME [CBV] 15.00 Range #1 | Reloading chart.
2026-04-21 10:33:51.904 | NQM6.CME 5 Min #2 | Reloading chart.
2026-04-21 10:33:51.938 | NQM6.CME/MNQM6.CME 0.50 Range #5 | Reloading chart.
2026-04-21 10:33:51.974 | NQM6.CME/MNQM6.CME [CBV] 15.00 Range #15 | Reloading chart.
2026-04-21 10:33:52.124 | NQM6.CME [CBV] Daily #9 | Chart data loading complete.
2026-04-21 10:33:52.139 | NQM6.CME Weekly #10 | Chart data loading complete.
2026-04-21 10:33:52.147 | NQM6.CME Monthly #11 | Chart data loading complete.
2026-04-21 10:33:52.183 | NQM6.CME Monthly #20 | Chart data loading complete.
2026-04-21 10:33:52.203 | ESH6.CME Monthly #21 | Chart data loading complete.
2026-04-21 10:33:52.206 | NQM6.CME 3 Min #13 | StartDateTimeForLoadingOrderFills: 2026-04-20 18:00:00
2026-04-21 10:33:52.207 | NQM6.CME 3 Min #13 | Chart data loading complete.
2026-04-21 10:33:52.282 | NQM6.CME 1 Min #4 | StartDateTimeForLoadingOrderFills: 2025-04-14 00:00:00
2026-04-21 10:33:52.321 | Chart #4 has tagged chart #13 for full recalculation. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint - Copy.Cht
2026-04-21 10:33:52.321 | NQM6.CME 1 Min #4 | Chart data loading complete.
2026-04-21 10:33:52.333 | Loading market depth data.
2026-04-21 10:33:52.333 | Loaded depth data records for NQM6.CME 2026-04-18 from 00:00:00.000000 to 00:00:00.000000.
2026-04-21 10:33:52.556 | Loaded depth data records for NQM6.CME 2026-04-19 from 2026-04-19 10:46:04.616000 to 2026-04-19 19:59:59.972000.
2026-04-21 10:33:52.583 | NQM6.CME 240 Min #17 | Chart data loading complete.
2026-04-21 10:33:52.726 | NQM6.CME 60 Min #14 | Chart data loading complete.
2026-04-21 10:33:53.861 | NQM6.CME/MNQM6.CME[M] #3 | StartDateTimeForLoadingOrderFills: 2025-04-14 00:00:00
2026-04-21 10:33:53.890 | NQM6.CME/MNQM6.CME[M] #3 | Chart data loading complete.
2026-04-21 10:33:54.397 | NQM6.CME/MNQM6.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2026-04-20 18:00:00
2026-04-21 10:33:54.449 | NQM6.CME/MNQM6.CME[M] 5 Min #12 | Chart data loading complete.
2026-04-21 10:33:54.506 | NQM6.CME/MNQM6.CME [CBV][M] 15.00 Range #1 | StartDateTimeForLoadingOrderFills: 2025-04-14 00:00:00
2026-04-21 10:33:54.507 | NQM6.CME/MNQM6.CME [CBV][M] 15.00 Range #1 | Chart data loading complete.
2026-04-21 10:33:54.512 | NQM6.CME/MNQM6.CME[M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 2026-04-20 18:00:00
2026-04-21 10:33:54.541 | NQM6.CME/MNQM6.CME[M] 30 Min #8 | Chart data loading complete.
2026-04-21 10:33:54.563 | NQM6.CME[M] 15 Min #7 | StartDateTimeForLoadingOrderFills: 2025-04-14 00:00:00
2026-04-21 10:33:54.577 | Chart #7 has tagged chart #3 for full recalculation. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint - Copy.Cht
2026-04-21 10:33:54.577 | Chart #7 has tagged chart #4 for full recalculation. Chartbook: MNQ(continuous) v2 still 60tick with 5min Footprint - Copy.Cht
2026-04-21 10:33:54.583 | NQM6.CME[M] 15 Min #7 | Chart data loading complete.
2026-04-21 10:33:54.883 | NQM6.CME/MNQM6.CME [CBV][M] 15.00 Range #15 | StartDateTimeForLoadingOrderFills: 2025-04-14 00:00:00
2026-04-21 10:33:54.884 | NQM6.CME/MNQM6.CME [CBV][M] 15.00 Range #15 | Chart
Date Time Of Last Edit: 2026-04-21 19:13:02
[2026-04-22 01:06:06]
I have replicated the issue and it most definitely occurred when copying one drawing from a chart to another. I am attaching 2 chartbooks. I have removed all studies etc. as per the instructions for attaching chartbooks.
The file named "MNQ(continuous) - Copy" is a copy (with all studies removed) of a chartbook last modified on April 13th. That was the last time I opened Sierra chart, prior to today (April 21). I was able to replicate the issue because the only things I did this morning to change anything on the chartbook (aside from the automatic chart updates due to new trading data) was to add chart drawings, and specifically, copy a particular drawing from one specific chart to another. Note how in the chartbook named "Symbol Issue" there is a chart drawing (a horizontal ray) on chart #24 at price 26885.25. I wanted this horizontal ray to be copied over to chart #17, so under chart settings-->chart drawings, I had added 24 to the field "Copy Chart Drawings From Chart #'s"
I then replicated this exact procedure on the file named "Copy", which did not have the chart drawing in question (as it is a copy of my chartbook last modified on April 13th-just altered to remove all studies). Lo and behold, the symbol on my DOM surreptitiously changed from NQM6/MNQM6 to just NQ.
My chartbook has had the setting for linking the symbol enabled for months with no issue. There is some interaction between adding an additional chart to the "Copy Chart Drawings From Chart #" field, and the toggles for Chart Settings-->Linking->Symbol, and possibly Trade Window and/or Trade/Quote Symbol.
In the attached Chartbook named "Copy", please try placing a chart drawing in chart #24, then going to chart #17 and within the field "Copy Chart Drawings From Chart #", add 24 to that list. Please confirm whether or not the Symbol on the DOM changes as a result of this action, because that is what happened to me and it is how I replicated the issue.
Private File
Private File
[2026-04-22 06:24:17]
It is definitely not related to Chart Drawings.
It is simply the result of Chart Linking functioning exactly as it should. Opening the Chart Settings window and pressing OK or Apply, will apply the settings related to the enabled Chart Linking options to other charts with the same link number.
What chart number is the trading DOM?:
We counted 8 charts that had the Trade/Quote Symbol set, and just going to chart number 17 Chart Settings, and pressing OK, reduced that number to 6. This behavior is expected.
Understand Chart Linking:
We see you have this set on chart number 3:
Chart Settings >> Linking >> Trade/Quote Symbol : Yes
We are planning to work on much more advanced Chart Linking, which gives you a finer degree of control, but right now that is not supported.
Date Time Of Last Edit: 2026-04-22 06:29:45
