Date/Time: Thu, 26 Nov 2026 04:21:37 +0000
Bracket TP order internally canceled but not canceled at exchange — caused unintended open
View Count: 524
| [2026-04-09 02:09:40] |
| User871314 - Posts: 32 |
I manually flattened a position via market order at 20:39:12 on 3/30/2026 on MESM6. My bracket take-profit limit sell at 6392.75 (InternalOrderID 726841, ServiceOrderID 2493802490) was still working on Rithmic. At 20:41:40, Sierra internally canceled this order with the log entry: "Internally marking as canceled. No order update from server. For Trade Account: (not specified). Internal cancel" No cancel was sent to Rithmic. The order remained live on the exchange and filled at 20:44:08 at 6392.75, creating an unintended short position. Sierra did not log this fill. My Trade Activity Log confirms: Position updated to 0 at 20:39:12 Internal cancel at 20:41:40 with no server communication No fill entry for the 6392.75 execution Position synced to -1 from Rithmic on 04/01 at 01:31:35 Is this expected behavior? When a position is manually flattened, should Sierra not send an actual cancel to the exchange for remaining bracket orders? |
Attachment Deleted. Private File |
| [2026-04-09 08:37:07] |
| Sierra_Chart Engineering - Posts: 25489 |
Yes there are certainly lots of issues when using Rithmic. None of this is unusual when using Rithmic. This would be the result, when Sierra Chart is requesting open orders, and Rithmic does not provide any order information for the order: "Internally marking as canceled. No order update from server. For Trade Account: (not specified). Internal cancel" So this is a Rithmic issue. Nothing we can do about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-09 08:38:11
| [2026-05-01 18:42:23] |
Thanks for the reply. I realized the local Trade Service Log on my machine was not being saved to disk at the time. Does Sierra Chart retain any server-side or backend log of the DTC message traffic for orders routed through Rithmic Direct, or is the Trade Service Log entirely client-side? I'm trying to determine whether the protocol-level messages between my Sierra installation and Rithmic's gateway for that order are recoverable. Specifically, the cancel-transmission attempt for order 2493802490 around 20:41:40 EDT. |
| [2026-05-01 19:03:07] |
We only store informational messages in the "Trade >> Trade Service Log". And that information is NOT persistent - so if you restart Sierra Chart, the information that was in that log is gone. I'm trying to determine whether the protocol-level messages between my Sierra installation and Rithmic's gateway for that order are recoverable. Specifically, the cancel-transmission attempt for order 2493802490 around 20:41:40 EDT.
You should ask Rithmic this question. They own the interface between Sierra Chart and Rithmic. So any logging would be on their end. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
