Date/Time: Tue, 20 Oct 2026 18:29:31 +0000
this is for John at support
View Count: 475
| [2026-04-07 11:32:04] |
| User849502 - Posts: 483 |
John, I sent a message yesterday, and a nice guy replied saying he could see all the login info. I had thought it was going just to you at support. Will you contact me as I cannot log in and as you can see Apex said that all the log in info was correct, so it is something I am doing, or is a glitch with SC. karen |
| [2026-04-07 15:52:54] |
| John - SC Support - Posts: 48273 |
If you post on this Support Board, then you should assume that any information you supply is publicly available. So you should not post anything that contains private information. And in general, we do not need anything of the sort. We saw another thread where you deleted the post, and in that it showed that you were getting a "Permission Denied" error from Rithmic. If this is the case, then refer to the following: Rithmic Trading Platform Service: Permission Denied Resolution Procedure For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-07 16:02:34] |
mate, you know I have done all of this, step by step, and still it won't connect. I have googled and watched every video I can find and I have done exactly what your written, and their video steps say to. I don't get it as I am connected at home on my pc no issue, but I can't get this laptop to connect. You had me send you the message log, did that tell you anything? Here it is again. I swear on my dog's life I have done every step in every info you have, apex has, and on you tube. Karen 2026-04-07 15:59:28.828 | Trade activity files set size: 1 2026-04-07 15:59:28.836 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-04-07 15:59:28.879 | Reading Internal Order ID file. 2026-04-07 15:59:28.880 | Reading Trade Orders file. 2026-04-07 15:59:28.880 | Reading Trade Positions file. 2026-04-07 15:59:28.880 | Reading Trade Account Data files. 2026-04-07 15:59:28.886 | Software version: 2891 64-bit 2026-04-07 15:59:28.886 | Primary Thread ID: 29848 2026-04-07 15:59:28.886 | Usage end date: 2026-05-01 2026-04-07 15:59:28.886 | Enabled for: Advanced Features 2. 2026-04-07 15:59:28.886 | Enabled for: Sierra Chart Historical Data Service. 2026-04-07 15:59:28.886 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-04-07 15:59:28.886 | Enabled for: Delayed Denali Exchange Data Feed. 2026-04-07 15:59:28.886 | Enabled for exchange2: CME (Trading Account Required) 2026-04-07 15:59:28.886 | Enabled for exchange2: CBOT (Trading Account Required) 2026-04-07 15:59:28.886 | Enabled for exchange2: COMEX (Trading Account Required) 2026-04-07 15:59:28.886 | Enabled for exchange2: NYMEX (Trading Account Required) 2026-04-07 15:59:28.886 | Enabled for exchange2: CBOE Global Indexes 2026-04-07 15:59:28.886 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-04-07 15:59:28.886 | Current selected Data/Trading service: Rithmic Direct - DTC 2026-04-07 15:59:28.886 | Custom symbol settings values: enabled 2026-04-07 15:59:28.886 | Chart Update Interval: 400 2026-04-07 15:59:28.886 | Intraday Data Storage Time Unit: 0 2026-04-07 15:59:28.886 | Time Zone: +00:00:00 (UTC+00) 2026-04-07 15:59:28.886 | 2026-04-07 15:59:28 Local computer time in UTC 2026-04-07 15:59:28.886 | 2026-04-07 15:59:28 Local computer time in SC Time Zone 2026-04-07 15:59:28.886 | 2026-04-07 15:59:25 Server time in UTC 2026-04-07 15:59:28.886 | Local computer UTC time and Server UTC time difference: 3 seconds. 2026-04-07 15:59:28.886 | Program path: C:\rythmic\ 2026-04-07 15:59:28.886 | Data Files path: C:\rythmic\Data\ 2026-04-07 15:59:28.886 | OS Version Number: 10.0 2026-04-07 15:59:28.886 | Locale Setting: C 2026-04-07 15:59:28.886 | Crash reporter started: true 2026-04-07 15:59:28.886 | 2026-04-07 15:59:28.905 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:28.905 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2026-04-07 15:59:28.905 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. 2026-04-07 15:59:28.911 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2026-04-07 15:59:28.913 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:28.948 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:28.948 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-04-07 15:59:29.049 | Received 5 login tokens. 2026-04-07 15:59:29.138 | Symbol settings MD5 received. Request ID: 1. 2026-04-07 15:59:29.138 | Symbol settings are up-to-date for rithmic_v2.trading. 2026-04-07 15:59:29.235 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1 2026-04-07 15:59:29.235 | Rithmic Direct - DTC | Wrote file: C:\rythmic\RithmicConnections.json. Size: 115600 2026-04-07 15:59:29.236 | Rithmic Direct - DTC | Processed connection points. Count: 496 2026-04-07 15:59:29.236 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2026-04-07 15:59:29.236 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-04-07 15:59:29.236 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2026-04-07 15:59:31.433 | Requested user files to download. 2026-04-07 15:59:31.736 | File to download: prop_alpha_pro_vanta_studies_64.dll. Action: 1 2026-04-07 15:59:31.738 | File to download: prop_alpha_pro_64.dll. Action: 1 2026-04-07 15:59:31.749 | File to download: prop_alpha_basic_vanta_studies_64.dll. Action: 1 2026-04-07 15:59:31.751 | File to download: prop_alpha_fvg_64.dll. Action: 1 2026-04-07 15:59:31.753 | File to download: prop_alpha_basic_64.dll. Action: 1 2026-04-07 15:59:31.758 | File to download: prop_alpha_gelber_64.dll. Action: 1 2026-04-07 15:59:31.760 | File to download: bduffy_kk_64.dll. Action: 1 2026-04-07 15:59:31.762 | File to download: kk_lvls_64.dll. Action: 1 2026-04-07 15:59:31.764 | User files to download complete 2026-04-07 15:59:33.449 | 2026-04-07 15:59:33.449 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 15:59:33.449 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 15:59:33.449 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 15:59:33.475 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:33.475 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 15:59:33.475 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 15:59:33.506 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 15:59:33.506 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 15:59:33.506 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 15:59:33.506 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 15:59:33.712 | Rithmic Direct - DTC | Received logon response. 2026-04-07 15:59:33.712 | Rithmic Direct - DTC | Server Name: . 2026-04-07 15:59:33.712 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 15:59:33.712 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 15:59:33.712 | Rithmic Direct - DTC | Failed connections: 1 2026-04-07 15:59:33.712 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 15:59:33.712 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:33.735 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 15:59:33.735 | DTC Client socket (1) | CloseSocket call. 2026-04-07 15:59:33.735 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:33.735 | Rithmic Direct - DTC | Disconnected. 2026-04-07 15:59:33.735 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:33.767 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:33.767 | DTC Client socket (1) | Closed. 2026-04-07 15:59:36.672 | Files to Open on Startup | File does not exist: C:\rythmic\Data\ExampleChartbook.cht 2026-04-07 15:59:37.750 | 2026-04-07 15:59:37.750 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 15:59:37.750 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 15:59:37.750 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 15:59:37.751 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:37.751 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 15:59:37.751 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 15:59:37.795 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 15:59:37.795 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 15:59:37.795 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 15:59:37.795 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 15:59:37.900 | Rithmic Direct - DTC | Received logon response. 2026-04-07 15:59:37.900 | Rithmic Direct - DTC | Server Name: . 2026-04-07 15:59:37.900 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 15:59:37.900 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 15:59:37.900 | Rithmic Direct - DTC | Failed connections: 2 2026-04-07 15:59:37.900 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 15:59:37.900 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:37.924 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 15:59:37.925 | DTC Client socket (1) | CloseSocket call. 2026-04-07 15:59:37.925 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:37.926 | Rithmic Direct - DTC | Disconnected. 2026-04-07 15:59:37.926 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:37.959 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:37.959 | DTC Client socket (1) | Closed. 2026-04-07 15:59:41.936 | 2026-04-07 15:59:41.936 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 15:59:41.936 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 15:59:41.936 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 15:59:41.937 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:41.937 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 15:59:41.937 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 15:59:41.970 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 15:59:41.970 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 15:59:41.970 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 15:59:41.970 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 15:59:42.068 | Rithmic Direct - DTC | Received logon response. 2026-04-07 15:59:42.068 | Rithmic Direct - DTC | Server Name: . 2026-04-07 15:59:42.068 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 15:59:42.068 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 15:59:42.068 | Rithmic Direct - DTC | Failed connections: 3 2026-04-07 15:59:42.068 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 15:59:42.068 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:42.079 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 15:59:42.080 | DTC Client socket (1) | CloseSocket call. 2026-04-07 15:59:42.080 | Rithmic Direct - DTC | Disconnected. 2026-04-07 15:59:42.080 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:42.080 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:42.110 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:42.110 | DTC Client socket (1) | Closed. 2026-04-07 15:59:46.083 | 2026-04-07 15:59:46.083 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 15:59:46.083 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 15:59:46.083 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 15:59:46.086 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:46.086 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 15:59:46.086 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 15:59:46.118 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 15:59:46.118 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 15:59:46.118 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 15:59:46.118 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 15:59:46.224 | Rithmic Direct - DTC | Received logon response. 2026-04-07 15:59:46.224 | Rithmic Direct - DTC | Server Name: . 2026-04-07 15:59:46.224 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 15:59:46.224 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 15:59:46.224 | Rithmic Direct - DTC | Failed connections: 4 2026-04-07 15:59:46.224 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 15:59:46.224 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:46.241 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 15:59:46.242 | DTC Client socket (1) | CloseSocket call. 2026-04-07 15:59:46.242 | Rithmic Direct - DTC | Disconnected. 2026-04-07 15:59:46.242 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:46.242 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:46.273 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:46.273 | DTC Client socket (1) | Closed. 2026-04-07 15:59:50.249 | 2026-04-07 15:59:50.250 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 15:59:50.250 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 15:59:50.250 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 15:59:50.250 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:50.250 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 15:59:50.250 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 15:59:50.287 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 15:59:50.287 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 15:59:50.287 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 15:59:50.287 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 15:59:50.404 | Rithmic Direct - DTC | Received logon response. 2026-04-07 15:59:50.404 | Rithmic Direct - DTC | Server Name: . 2026-04-07 15:59:50.404 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 15:59:50.404 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 15:59:50.404 | Rithmic Direct - DTC | Failed connections: 5 2026-04-07 15:59:50.404 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 15:59:50.404 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:50.424 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 15:59:50.424 | DTC Client socket (1) | CloseSocket call. 2026-04-07 15:59:50.424 | Rithmic Direct - DTC | Disconnected. 2026-04-07 15:59:50.424 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:50.424 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:50.454 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:50.454 | DTC Client socket (1) | Closed. 2026-04-07 15:59:54.432 | 2026-04-07 15:59:54.433 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 15:59:54.433 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 15:59:54.433 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 15:59:54.433 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:54.434 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 15:59:54.434 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 15:59:54.463 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 15:59:54.463 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 15:59:54.463 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 15:59:54.463 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 15:59:54.568 | Rithmic Direct - DTC | Received logon response. 2026-04-07 15:59:54.568 | Rithmic Direct - DTC | Server Name: . 2026-04-07 15:59:54.568 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 15:59:54.568 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 15:59:54.568 | Rithmic Direct - DTC | Failed connections: 6 2026-04-07 15:59:54.568 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 15:59:54.568 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:54.591 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 15:59:54.591 | DTC Client socket (1) | CloseSocket call. 2026-04-07 15:59:54.592 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:54.592 | Rithmic Direct - DTC | Disconnected. 2026-04-07 15:59:54.592 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:54.622 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:54.622 | DTC Client socket (1) | Closed. 2026-04-07 15:59:58.600 | 2026-04-07 15:59:58.600 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 15:59:58.600 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 15:59:58.600 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 15:59:58.600 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 15:59:58.600 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 15:59:58.600 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 15:59:58.633 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 15:59:58.633 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 15:59:58.633 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 15:59:58.633 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 15:59:58.746 | Rithmic Direct - DTC | Received logon response. 2026-04-07 15:59:58.746 | Rithmic Direct - DTC | Server Name: . 2026-04-07 15:59:58.746 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 15:59:58.746 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 15:59:58.746 | Rithmic Direct - DTC | Failed connections: 7 2026-04-07 15:59:58.746 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 15:59:58.746 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:58.760 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 15:59:58.760 | DTC Client socket (1) | CloseSocket call. 2026-04-07 15:59:58.761 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 15:59:58.761 | Rithmic Direct - DTC | Disconnected. 2026-04-07 15:59:58.761 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 15:59:58.792 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 15:59:58.792 | DTC Client socket (1) | Closed. 2026-04-07 16:00:02.774 | 2026-04-07 16:00:02.774 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:02.774 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:02.774 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:02.776 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:02.777 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:02.777 | DTC Client socket (1) | Connecting to IP: 184.105.22.231. 2026-04-07 16:00:02.811 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:02.811 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:02.811 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:02.811 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:02.915 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:02.915 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:02.915 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:02.915 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:02.915 | Rithmic Direct - DTC | Failed connections: 8 2026-04-07 16:00:02.915 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:02.915 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:02.932 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:02.933 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:02.933 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:02.933 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:02.933 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:02.962 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:02.962 | DTC Client socket (1) | Closed. 2026-04-07 16:00:06.947 | 2026-04-07 16:00:06.948 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:06.948 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:06.948 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:07.504 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:07.504 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:07.504 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:07.534 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:07.534 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:07.534 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:07.534 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:07.634 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:07.634 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:07.634 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:07.634 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:07.634 | Rithmic Direct - DTC | Failed connections: 9 2026-04-07 16:00:07.634 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:07.634 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:07.645 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:07.645 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:07.645 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:07.645 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:07.645 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:07.683 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:07.683 | DTC Client socket (1) | Closed. 2026-04-07 16:00:11.657 | 2026-04-07 16:00:11.658 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:11.658 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:11.658 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:11.658 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:11.658 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:11.658 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:11.691 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:11.691 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:11.691 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:11.691 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:11.801 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:11.801 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:11.801 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:11.801 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:11.801 | Rithmic Direct - DTC | Failed connections: 10 2026-04-07 16:00:11.801 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:11.801 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:11.816 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:11.817 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:11.817 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:11.817 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:11.817 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:11.851 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:11.851 | DTC Client socket (1) | Closed. 2026-04-07 16:00:15.820 | 2026-04-07 16:00:15.820 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:15.820 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:15.820 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:15.820 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:15.820 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:15.820 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:15.853 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:15.853 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:15.853 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:15.853 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:15.961 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:15.961 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:15.961 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:15.961 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:15.961 | Rithmic Direct - DTC | Failed connections: 11 2026-04-07 16:00:15.961 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:15.961 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:15.974 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:15.975 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:15.975 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:15.975 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:15.975 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:16.006 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:16.006 | DTC Client socket (1) | Closed. 2026-04-07 16:00:19.980 | 2026-04-07 16:00:19.980 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:19.980 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:19.980 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:19.983 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:19.983 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:19.983 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:20.029 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:20.029 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:20.029 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:20.029 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:20.131 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:20.131 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:20.131 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:20.131 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:20.131 | Rithmic Direct - DTC | Failed connections: 12 2026-04-07 16:00:20.131 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:20.131 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:20.156 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:20.156 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:20.156 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:20.156 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:20.156 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:20.189 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:20.189 | DTC Client socket (1) | Closed. 2026-04-07 16:00:24.168 | 2026-04-07 16:00:24.168 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:24.168 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:24.168 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:24.168 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:24.169 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:24.169 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:24.203 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:24.203 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:24.203 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:24.203 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:24.311 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:24.311 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:24.311 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:24.311 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:24.311 | Rithmic Direct - DTC | Failed connections: 13 2026-04-07 16:00:24.311 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:24.311 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:24.326 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:24.326 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:24.327 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:24.327 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:24.327 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:24.358 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:24.358 | DTC Client socket (1) | Closed. 2026-04-07 16:00:28.341 | 2026-04-07 16:00:28.341 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:28.341 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:28.341 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:28.342 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:28.342 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:28.342 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:28.373 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:28.373 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:28.373 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:28.373 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:28.483 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:28.483 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:28.483 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:28.483 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:28.483 | Rithmic Direct - DTC | Failed connections: 14 2026-04-07 16:00:28.483 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:28.483 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:28.498 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:28.499 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:28.499 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:28.499 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:28.499 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:28.531 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:28.531 | DTC Client socket (1) | Closed. 2026-04-07 16:00:30.501 | The message log has been sent to support. * 2026-04-07 16:00:30.501 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:30.501 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 0 2026-04-07 16:00:30.501 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 64.152.155.19. 2026-04-07 16:00:30.761 | The Message Log was sent. Result: Message Log received. * 2026-04-07 16:00:31.025 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. 2026-04-07 16:00:31.025 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:31.063 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:31.063 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-04-07 16:00:32.501 | 2026-04-07 16:00:32.501 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:32.501 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:32.501 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:32.502 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:32.502 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:32.502 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:32.534 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:32.534 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:32.534 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:32.534 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:32.634 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:32.634 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:32.634 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:32.634 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:32.634 | Rithmic Direct - DTC | Failed connections: 15 2026-04-07 16:00:32.634 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:32.634 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:32.659 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:32.659 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:32.660 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:32.660 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:32.660 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:32.689 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:32.689 | DTC Client socket (1) | Closed. 2026-04-07 16:00:36.666 | 2026-04-07 16:00:36.666 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:36.666 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:36.666 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:36.668 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:36.668 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:36.668 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:36.701 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:36.701 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:36.701 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:36.701 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:36.811 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:36.811 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:36.811 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:36.811 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:36.811 | Rithmic Direct - DTC | Failed connections: 16 2026-04-07 16:00:36.811 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:36.811 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:36.822 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:36.823 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:36.823 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:36.823 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:36.823 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:36.853 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:36.853 | DTC Client socket (1) | Closed. 2026-04-07 16:00:40.831 | 2026-04-07 16:00:40.831 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:40.831 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:40.831 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:40.831 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:40.831 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:40.831 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:40.862 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:40.862 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:40.862 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:40.862 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:40.968 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:40.968 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:40.968 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:40.968 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:40.968 | Rithmic Direct - DTC | Failed connections: 17 2026-04-07 16:00:40.968 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:40.968 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:40.988 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:40.989 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:40.989 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:40.989 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:40.989 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:41.021 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:41.022 | DTC Client socket (1) | Closed. 2026-04-07 16:00:44.991 | 2026-04-07 16:00:44.992 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:44.992 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:44.992 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:44.992 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:44.992 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:44.992 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:45.027 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:45.027 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:45.027 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:45.027 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:45.134 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:45.134 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:45.134 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:45.134 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:45.134 | Rithmic Direct - DTC | Failed connections: 18 2026-04-07 16:00:45.134 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:45.134 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:45.152 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:45.154 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:45.154 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:45.155 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:45.155 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:45.186 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:45.186 | DTC Client socket (1) | Closed. 2026-04-07 16:00:49.166 | 2026-04-07 16:00:49.167 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:49.167 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:49.167 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:49.167 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:49.167 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:49.167 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:49.201 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:49.201 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:49.201 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:49.201 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:49.308 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:49.308 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:49.308 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:49.308 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:49.308 | Rithmic Direct - DTC | Failed connections: 19 2026-04-07 16:00:49.308 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:49.308 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:49.327 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:49.328 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:49.328 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:49.328 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:49.328 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:49.361 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:49.361 | DTC Client socket (1) | Closed. 2026-04-07 16:00:53.341 | 2026-04-07 16:00:53.342 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:53.343 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:53.343 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:53.346 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:53.346 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:53.346 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:53.378 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:53.378 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:53.378 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:53.378 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:53.484 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:53.484 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:53.484 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:53.484 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:53.484 | Rithmic Direct - DTC | Failed connections: 20 2026-04-07 16:00:53.484 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:53.484 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:53.499 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:53.499 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:53.499 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:53.499 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:53.499 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:53.529 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:53.529 | DTC Client socket (1) | Closed. 2026-04-07 16:00:57.504 | 2026-04-07 16:00:57.504 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:00:57.504 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:00:57.504 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:00:57.505 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:00:57.505 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:00:57.505 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:00:57.536 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:00:57.536 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:00:57.536 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:00:57.536 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:00:57.638 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:00:57.638 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:00:57.638 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:00:57.638 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:00:57.638 | Rithmic Direct - DTC | Failed connections: 21 2026-04-07 16:00:57.638 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:00:57.638 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:57.663 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:00:57.663 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:00:57.663 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:00:57.663 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:00:57.663 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:00:57.694 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:00:57.694 | DTC Client socket (1) | Closed. 2026-04-07 16:01:01.678 | 2026-04-07 16:01:01.678 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2026-04-07 16:01:01.678 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2026-04-07 16:01:01.678 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2026-04-07 16:01:01.679 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-04-07 16:01:01.679 | DTC Client socket (1) | New receive buffer size: 0 2026-04-07 16:01:01.679 | DTC Client socket (1) | Connecting to IP: 208.97.247.101. 2026-04-07 16:01:01.714 | Rithmic Direct - DTC | Network connection to server complete. 2026-04-07 16:01:01.714 | Rithmic Direct - DTC | Starting socket receive thread. 2026-04-07 16:01:01.714 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-04-07 16:01:01.714 | Rithmic Direct - DTC | Sending logon request message. 2026-04-07 16:01:01.818 | Rithmic Direct - DTC | Received logon response. 2026-04-07 16:01:01.818 | Rithmic Direct - DTC | Server Name: . 2026-04-07 16:01:01.818 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-04-07 16:01:01.818 | Rithmic Direct - DTC | Logon error received from server: permission denied 2026-04-07 16:01:01.818 | Rithmic Direct - DTC | Failed connections: 22 2026-04-07 16:01:01.818 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-04-07 16:01:01.818 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:01:01.835 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-04-07 16:01:01.836 | DTC Client socket (1) | CloseSocket call. 2026-04-07 16:01:01.836 | Rithmic Direct - DTC | Disconnected. 2026-04-07 16:01:01.836 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-04-07 16:01:01.836 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-04-07 16:01:01.866 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-04-07 16:01:01.866 | DTC Client socket (1) | Closed. |
| [2026-04-07 17:16:03] |
The following is the issue: 2026-04-07 15:59:33.712 | Rithmic Direct - DTC | Logon error received from server: permission denied
One thing to keep in mind is that you can only have 1 connection to Rithmic at a time with Sierra Chart. So if your home computer is connected, then you will NOT be able to connect from your laptop. If not the above, then everything we know about how to resolve the "Permission Denied" error from Rithmic is covered at the following link: Rithmic Trading Platform Service: Permission Denied Resolution Procedure As noted in the section linked above, the error is from Rithmic. We have no control over it. The suggestions in that section come from what we have heard from our customers on different things that have worked for them. But, in the end, the error is with Rithmic to fix. We have told them they have a continuing issue with this, but they have not fixed it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-08 00:28:36] |
ok mate thanks for this. The home pc is not connected so that's not the issue. I went over your link earlier today ( I promise you John I exhaust everything before I write to you). I have been with my mom who is ill, so I will try again tomo morning to go over that permission denied. I knew I had set it up ok, but was hoping I had made a dumb mistake so it could be easily solved. thanks for all your help. karen |
| [2026-04-08 11:17:47] |
mate, there was a missing space in log in you could hardly notice it. Only when I pushed again at Apex did they run a scan on the error message and it showed invalid log in. The guy admitted it was hard to see when looking at login details, and only showed up when they read their own logs. So if you want to add something to you great info you could put to be very careful about an odd blank space. Sorry I took up your time. karen
