Date/Time: Thu, 26 Nov 2026 04:01:37 +0000
Feature request: Load/Save Study Settings
View Count: 703
[2026-04-02 16:31:27]
User512353 - Posts: 198
For any study, in the Study Settings window, add a Load button, a Save button, and a corresponding name field.
The functionality is obvious.
Enhanced version:
Let the user choose to selectively load the settings for:
a) Settings and Inputs
b) Subgraphs
c) Alerts
d) Scale settings
[2026-04-02 17:38:23]
The "Study Collections" can do exactly this. You would save a Study Collection for a single study and enable the option for "Prompt to Remove Existing Studies" in order to be able to add that study to existing studies on the chart. Refer to the following:
Study Collections
Also, there is the ability to set a custom default for each study. So if there is a particular setup that you use most often, then you can set this as the default. Refer to the following:
Chart Studies: Using Custom Default Study Settings
[2026-04-02 18:56:55]
I am aware of these features.
Study Collections with the optional 'Prompt to Remove Existing Studies' can only add a new study to the existing set. This necessarily assigns a new ID to the added study. If for any reason (e.g. reference in a spreadsheet) you need keep the ID, you cannot use this, unless you are willing to keep multiple copies of the study in the same chart. This is a poor solution.
Custom Default Study Settings only apply when adding a new study. It has no effect on existing studies in a chart.
In summary, these are no real solutions, not even workarounds.
My requested feature should not be difficult to implement. This is a pretty simple to code marshalling/unmarshalling operation.
[2026-04-02 20:26:51]
So what you are wanting is a way to update an existing study on a chart with a pre-set configuration?
[2026-04-02 21:37:28]
Depends on your definition of "pre-set configuration".
I want to save the settings of a study to a file, copy the file to another SC installation's data folder, and then load it from there into another study.
You necessarily already have all the code to extract and load the settings, because that is what necessarily must be done when loading/saving a chartbook.
You only need to create the interface in the Study Settings window, hook your file selector to it, and call the already existing function to load/save the settings.
This should be almost trivial.
[2026-04-02 21:58:31]
For the workflow you are stating, the Study Collection will do what you want. The only "extra" step in this case is the need to delete the other copy of the study on the system that you loaded the study onto.
[2026-04-02 22:15:41]
As I already wrote:
I do NOT want to delete the existing study, because it is referenced by a spreadsheet.
