Date/Time: Thu, 26 Nov 2026 03:41:37 +0000
scott bernard support board #457292
View Count: 342
| [2026-03-16 20:50:01] |
| User457292 - Posts: 5 |
Hi, I'm new I set up an account scott * **. how do I start trial and download software! Date Time Of Last Edit: 2026-03-17 13:23:38
| [2026-03-17 06:08:45] |
can you tell me how to make my posts public? ** I have sent 4 messages to your support board have not had any response Date Time Of Last Edit: 2026-03-17 13:22:00
| [2026-03-17 13:23:20] |
| Sierra_Chart Engineering - Posts: 25489 |
Your posts are public. Install the software from here: Software Download Login to Sierra Chart following these instructions: Sierra Chart - Software Login Instructions: Software Login Instructions Then follow through these instructions: Getting Started, Opening Charts and Basic Trading Your trial is active but there is a limited set of symbols you can use during a trial. Refer to: Sierra Chart Trial Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-17 13:24:24
