Date/Time: Tue, 03 Nov 2026 17:43:58 +0000
AMP logins not wokring
View Count: 424
| [2026-03-03 21:44:09] |
| MIA2026 - Posts: 2 |
Hello, I am new to this platfrom. I have a verified AMP boker account with $100 funded. They gave me CQG login username and password. Also, I am planning to get the denali Feed. I have installed the software. But No Knowledge or tutorials to use it. Can you please help me to get on board with Broker login + data purchase and tutorials video links to I can start the trading and purchase the data. |
| [2026-03-03 22:48:00] |
| John - SC Support - Posts: 48408 |
You are currently on a Trial. When on a trial you can not connect to data or trading services. We see that you have only used 2 days of the trial and you had 9 days remaining. Therefore, we have added the 10 days of trial time that you have not used. We recommend using the system in the Trial so you can determine whether the system is a good fit for you without having to expend any funds. During the trial, you have the full capabilities of the system, but you are limited in what data you have available. Refer to the following: Sierra Chart Trial Account And go through the items at the following link for how to setup and get started with Sierra Chart: Getting Started, Opening Charts and Basic Trading Our documentation that covers all aspects of the system can be found starting here: https://www.sierrachart.com/index.php?page=doc/Contents.php We have some videos that you can access here: Video Library Although we really recommend searching YouTube for videos as there are a lot of third party videos out there for how to use Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-05 21:15:42] |
Son, It does not answer my question if AMP CQG credentials would be accepted by you. Also, I was really disappointed by your SO CALLED "TRAIL" which has 0 usecase. Thus I stopped on 2nd time using. As I see you tryna be the Big guy quoting "Therefore, we have added the 10 days of trial time that you have not used", Not a big fan of Junk as you already sensed like others. Here's what I was looking for: 1. Do you guys accept/allow AMP clients? 2. IF Yes, then I would get Denali feed and try. I am non professional trader, how much that would for me? and monthly subs start 1st of the month or the day i purchase, that the billing date? |
| [2026-03-05 21:58:57] |
Yes, you can be with AMP and use Sierra Chart. They offer order routing with CQG, Rithmic, and our own Teton service. We can work with any of these, but if you are just trading the CME Group, then we recommend our Teton Order Routing Service. Refer to the following: Sierra Chart Teton Futures Order Routing 2. IF Yes, then I would get Denali feed and try. I am non professional trader, how much that would for me? and monthly subs start 1st of the month or the day i purchase, that the billing date?
The pricing depends on what you need for your charting. To start with, you need to be on one of the "Integrated" packages in order to be able to connect to data and trading services. Refer to the information for the packages at the following link: Description of Service Packages and Pricing: Packages As to the exchange fees, you will find the list of exchanges and their cost at the following link: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) The Sierra Chart packages work on a rolling 31-day cycle. So each month is really 31 days of Usage Time. So if you activate a package on March 17, 2026 for 1 month (for example), then the renewal will be 31 days later on April 17, 2026. Since not all months have 31 days, the actual day of the month will change over time. The exchanges, however, work on a calendar month basis and they are not pro-rated. So whenever you activate an exchange, you pay the full price for the remaining time in the month in which you activate it. Then you would have to pay again on the first day of the following month. For example, if you activate an exchange that costs $13.50 on March 17, 2026, you will get the real-time data for that exchange through the end of March. Then you will need to pay $13.50 again on April 1, 2026, in order to get the real-time data in April. -- I was really disappointed by your SO CALLED "TRAIL" which has 0 usecase
We do not understand why you would state this. The trial gives you the full capabilities of the system, apart from being able to connect to trading services and having limited data. In terms of the available data, refer to the following: Sierra Chart Trial Account This is a decent cross-section of data that should allow for most people to be able to use the system to learn how it works. That is the whole point of the Trial - to determine if Sierra Chart is a good fit for your trading or not, so that you feel comfortable paying actual money to use the system. And our Delayed Streaming data acts like the real-time data in all aspects, including the ability to use it with our Simulated Futures Trading Service. So you can use the system for trading to see how it will act in a near-real environment. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
