Date/Time: Sun, 22 Nov 2026 14:39:58 +0000
Version 2813 Still OK??
View Count: 860
| [2026-02-12 01:32:21] |
| User450463 - Posts: 149 |
I noticed in this thread: Notice: Solution to: Chart/Chartbook Tabs Visibility Issues, Portions of Chart Window Cut Off You noted we could go back to 2813 before all the windowing stuff was redone, but there were some additional posts on that thread after the 2813 suggestion. Is it still valid to go back to 2813? My windowing issues continue. Constant flashing of minimized windows in the middle of my charts when I change chartbooks, windows not left in the state they were in, minimized windows not really "minimized" as a child MDI window should be (appears as a small box in addition to the normal tab of a minimized child window) etc. I'd rather just go back if I can. It's become a real annoyance rearranging things and having to click to bring the chart I'm interested in up from behind the spurious junk. It's probably just my particular combination of hardware and software. I'd just like it to work like it used to. I surely hope you will get this ported to Linux ASAP. I abandoned Windows long, long ago. Thanks Date Time Of Last Edit: 2026-02-12 01:44:57
| [2026-02-12 05:03:18] |
| Sierra_Chart Engineering - Posts: 25458 |
This has been fixed in recent releases: windows not left in the state they were in,
We can help you with this: . Constant flashing of minimized windows in the middle of my charts when I change chartbooks,
We specifically designed the changes so it is no problem going back to 2813 and earlier. So window position and sizes are maintained identically as they should be. Although, as we think about this some more, the minimized and maximized states, will not be properly restored when downgrading to 2813. This is something we need to resolve. So we want you to wait and we will put out a new release, to solve this. And also though we do think that your issues can be resolved. But anyway downgrading is fine but wait until 2882 which you will need to update to save your Chartbooks and you will need to downgrade. And there are also backup Chartbooks available: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-12 05:04:48
| [2026-02-12 08:21:15] |
Ok will wait, thanks. Also, I found your thread regarding a port to Linux. Glad to hear there may be something soon using the Wine system call abstraction layer. I was a developer for years, and worked in QA as well before I retired. If you will need beta testers for the port, I would be happy to help! Thanks 👍 |
| [2026-02-12 13:05:49] |
We have the changes made. We will have a new version out this evening.
| [2026-02-12 14:23:33] |
We could not get the exact minimized position correct, going from a new version to an old version (2813) but what you want to do, is after opening a Chartbook select Window >> Arrange Minimize Windows.
| [2026-02-12 17:28:59] |
Great thank you. Which version number should I look for to confirm the changes are what I'm downloading? 2882?
| [2026-02-13 17:05:21] |
Version 2882 is now available. It is a prerelease. Instructions to update: Software Download: Fast Update Once you update to this version, open your Chartbooks and save them. After this you can then go back to version 2813 and the chart layout will be the same. If you have minimized charts, when you open your Chartbooks in 2813, select Window >> Arrange Minimized Windows. This is actually something you can do in the current version. Set this setting to Minimize to Bottom: General Settings Window: MDI Child Window Minimize Method (List) (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) And then select Window >> Arrange Minimized Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-13 17:08:30
| [2026-10-17 14:50:23] |
Reading the post regarding upcoming requirement to update to latest version no later than Dec 2026: I have been on 2813 for months for the windowing issues on my setup. I updated today to the "Current" version, and now my footprint charts do not appear. The data loads, and then nothing. There's not even an X and Y axis displayed. I have three instances of Sierra I run. The first instance contains my TPO profile charts. The second instance contains normal bar charts. The third instance is where I run my footprint charts. Instance 1 and 2 seem to work fine. But again, the footprint charts in instance 3 are absolutely "empty". The context menu doesn't even appear when I right click. It's like it's hung up somewhere. The last thing it does is "Downloading Historical Data" then "Download Complete"... then it's dead. Wonder if some chart file format has changed between 2813 and current? I did this on a backup drive, so I'm not out of business, but I need to get this fixed before I dare to upgrade my daily working installation. I've attached one of the footprint chart collections. Thanks |
Private File |
| [2026-10-17 22:07:17] |
The problem relates to this setting: Chart Settings >> Chart Data >> Chart Data >> Trades Combining Method : "Combine Trades Into Original Summary Trade (Data Feed and Exchange Specific)" This is a new issue. We are looking into it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-18 00:32:59] |
We should have a new release out, by the morning to resolve this. We apologize for this issue.
| [2026-10-18 04:40:05] |
We have released version 2975. Let us know that the issue is resolved for you. This issue arose, when this feature was implemented: Trades Combining Method: "Combine Trades with Same Price and Type (Bid/Ask)" And only occurs when the Intraday Data Storage Time Unit is 1 Second or higher. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-10-19 13:40:17] |
Apologies for the late response I was out of town for over the weekend. This appears to have solved it. I'll run it today and see how everything goes but it comes up initially so that's further than it was. Thanks for the quick response!
