Date/Time: Wed, 25 Nov 2026 23:00:08 +0000
Teton/Denali Data Flow Issue - Calculations stuck at 1-5 FPS
View Count: 604
[2026-02-03 21:40:56]
User550319 - Posts: 2
I have upgraded my account to 'Package 10 - Integrated Standard' and activated the 'CME with Market Depth for non-professional Trading accounts' data feed. I am using 'Teton Order Routing' with Dorman Trading.
Despite this, I am not receiving tick-by-tick data. My DOM is sluggish and the performance metrics indicate a lack of incoming data packets.
        Technical Details:
        1. Symbol: MESH26_FUT_CME (Also tried NQH26)",
        2. Global Chart Update Interval: Set to 10ms.",
        3. Performance Window Metrics:",
         - Chart Drawing Time: 1ms (Hardware is capable)",
         - Calculations Per Second: Fluctuates 1-5 (Indicates no data flow)",
         - Draws Per Second: Fluctuates 1-5",
        Troubleshooting Performed:",
        - Restarted Sierra Chart multiple times since payment.",
        - Confirmed Exchange Agreements are signed (Non-Pro).",
        - Confirmed 'Data/Trade Service Settings' is set to 'Teton Order Routing'.",
        - Confirmed 'Allow Support for Sierra Chart Data Feeds' is Yes.",
Question:
Is there a provisioning hold on my account, or is the symbol format 'MESH26_FUT_CME' incorrect for the Teton feed? Please advise why the data stream is throttled.
[2026-02-03 22:01:51]
There is no such thing in Sierra Chart.
That is the correct symbol for MES when connected to Teton.
It is not throttled. There is nothing in Sierra Chart, either on our servers or in the software itself that controls any kind of throttling, with the exception of the "Chart Update Interval", which you have control over.
This does not give us enough information to understand what is occurring. Why do you state that the DOM is sluggish? What exactly is occurring?
There is definitely not a lack of incoming data packets, at least not due to anything on our end. If there is an issue related to this specifically, then it would be an issue with your Internet connectivity.
Everything we know to do in relation to improving performance is at the following link. You need to go through the items on that page and see how you can improve your system:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
[2026-02-09 23:43:12]
@John - SC Support: Thank you for the clarification, it helped me to find the cause.
Solution:
Set /Global Settings > General Settings > Charts > Use Controlled Order Chart Updating to No.
Comment:
This setting is a major source of confusion for the user. It disables 'Chart Update Interval in Milliseconds', despite being located apart from other update-governing settings.
Date Time Of Last Edit: 2026-02-09 23:45:02
