Date/Time: Tue, 27 Oct 2026 17:54:25 +0000
ERROR IN DOWNLOADING HISTORICAL DATA
View Count: 481
[2026-01-12 13:41:48]
User731030 - Posts: 3
Dear Sierra Chart Support Team,
I am facing an issue where no CME charts are downloading in Sierra Chart. This problem occurs across all CME chart types, and the same error appears on every CME-related chart.
Details:
Sierra Chart version: Latest version downloaded from Help Center
Current Service Package: Package 5
Issue scope: All CME group charts
Behavior: Charts fail to download and show the same error message consistently
I have already:
Updated Sierra Chart to the latest version
Restarted the platform and system
Re-attempted opening multiple CME symbols and chart types
Despite this, the issue persists. I have attached a screenshot showing the error message that appears on every CME chart for your reference.
Looking forward to your guidance on resolving this issue.
Thank you for your support.
Best regards
shiv verma
Private File
[2026-01-12 17:38:15]
John - SC Support - Posts: 48342
What is "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" set to?
This should be set to "SC Data" or "Trading Evaluator - Delayed". Any other option will cause a problem and should not be selected.
[2026-01-12 17:49:27]
it is on SC Data only, but still charts are not loading
imageScreenshot 2026-01-12 231609.png / V - Attached On 2026-01-12 17:49:05 UTC - Size: 33.74 KB - 223 views
[2026-01-12 19:06:10]
From the image you provided, it looks like there are no charts in that chartbook. If you select the "CW" menu at the top, can you select a chart in that menu? If so, select it and then let us know if you are able to view everything properly or not.
If nothing shows in the CW menu, then you have no charts in that chartbook, so there is nothing to show. Select "File >> Find Symbol" to find the symbol you want and open a chart. Refer to the following:
Getting Started, Opening Charts and Basic Trading: Open A Chart
[2026-01-12 19:27:23]
hi there
please check the attached file. whenever i open my chart it starts download historical data, then some error comes in
regards
shiv
imageScreenshot 2026-01-13 005454.png / V - Attached On 2026-01-12 19:26:52 UTC - Size: 32.38 KB - 205 views
[2026-01-31 17:52:02]
Sierra_Chart Engineering - Posts: 25297
Refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server
