Date/Time: Tue, 17 Nov 2026 18:08:51 +0000
Queries before finalizing subscription
View Count: 528
[2025-12-08 15:56:04]
User226197 - Posts: 7
Hi - My free trial is ending. So, I have few questions before I finalize the subscription.
1. If I want Number bar & related studies and external data feed like IQFEED or GLOBAL DATA FEED, which package to choose?
2. Is there any other option than GLOBAL DATA FEED for indian stock markets?
3. I want to analyze only Crude oil. Is Denali the perfect choice? If yes, do I have to subscribe Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for non-professional Trading accounts for 39 USD/month or NYMEX with Market Depth for non-professional Trading accounts for 13 USD/month?
4. When Sierra chart is installed on the desktop in C:\SierraChart, is there any other folder in C drive where any other related file is installed. Idea is, can I install SC in external drive and use it on any machine like plug n play?
5. Suppose at the same time I want to use 3 datafeeds, it looks like I have to install SC 3 times with 3 different names like C:\SierraChart1, C:\SierraChart2, C:\SierraChart3 and then run them! Is my understanding correct?
6. Then, how many instances of SC can I open simultaneously? If its 3 or 4, can it be done in 2 to 3 different machines. E.g. For 4 instances, 1 instance * 4 machines or 2 instances * 2 machines!!
[2025-12-08 17:07:39]
John - SC Support - Posts: 48555
1. To be able to connect to data (and trading) services, you need to be on one of the "Integrated" packages. Refer to the information for the packages at the following link:
Description of Service Packages and Pricing
2. There is no other option. Global Data Feeds is the only connectivity we have for Indian markets
3. It depends on what you want. If you really only need charts for Crude Oil and you need the Market Depth data, then you can activate the "NYMEX with Market Depth for Non-Professional Trading Accounts". But if you also want to be able to view charts for other symbols traded on the CME Group, then you may want the "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for Non-Professional Trading Accounts".
But, if you want to be able to get charts for other symbols on the CME Group, but only need market depth for Crude Oil, then you could activate the following exchange options:
- Full CME Group (CME, CBOT, COMEX, NYMEX) for Non-Professional Trading Accounts
- NYMEX with Market Depth for Non-Professional Trading Accounts
And other options are available if you do not need Market Depth data.
4. You do NOT want to use Sierra Chart on an external drive. There is a lot of reading an writing of information, so you want to have Sierra Chart on as fast a drive as you can. Preferably even an NVME drive of its own.
5. If you are really wanting 3 different data feed, then you would need 3 different installations where each installation is connecting to a specfic data feed. Refer to the following:
Using Multiple Data and Trading Services at the Same Time
6. You can have as many instances open on a single computer as you want. This is not limited. You are limited to using Sierra Chart on multiple computers based on the package you are using. For Package 11 and 12, you can use Sierra Chart on up to 3 computers simultaneously. For other packages, the limit is 2.
But, keep in mind that the exchanges have different rules, so for our Denali Exchange Data Feed, if you are wanting to get the data to multiple installations on a single computer, or to different computers, then refer to the following:
Denali Exchange Data Feed: Connections
[2025-12-09 00:26:17]
Few clarifications still needed.
Wrt point 1. So to connect IQFEED or GLOBAL DATA FEED, I need Service Package 11 (as I need TPO, Number bars etc.)? Would this also include access to:
Sierra Chart FOREX and CFD Data Service
Real-Time data enabled through the Sierra Chart Exchange Data Feed
Sierra Chart Market Statistics Data Feed
Cryptocurrency / Bitcoin Data and Trading Services
Delayed Streaming Exchange Data Feed
Simulated Trading Service
Wrt point 4. If I have external NVME SSD. Is it still OK then to install SC on it and use it on any system?
Also, wrt Market Depth Data. If data doesnt have it, I believe all the mkt depth related studies, DOM etc. cant be used. But TPO, number bars, delta etc. can still be used? Right?
[2025-12-09 15:40:00]
1. An installation of Sierra Chart connected to IQFeed and Global Data Feeds does not give you access to the other data available from Sierra Chart, as there are conflicts with symbols in these cases.
The way around this is to have another installation of Sierra Chart set to connect to "SC Data". You will then have access to the free data we have available.
4. We still do not recommend this. You are still connecting through a slower bus system than what would be the case with a built-in drive.
The DOM can be used, but you will not have any Market Depth data in it. TPO, Numbers Bars, Delta, and other studies of this sort, are built on actual trades, not the Market Depth data, so you are fine without the Market Depth for these.
[2025-12-15 05:04:03]
Thanks for clearing doubts!
Meanwhile, I tried getting in touch with Global Data Feed for free trial but couldnot get it in time on Friday.
GDFL team has said they couldnot initiate trial because GDFL isnt enabled in DTS. (screenshot attached)
Also, my SC free trial is getting over today on 15th Dec.
So, I request you please extend my SC free trial by 5 days so that I can check and understand how Global Data Feed works.
Date Time Of Last Edit: 2025-12-15 12:18:45
imagescreenshot.png / V - Attached On 2025-12-15 12:17:30 UTC - Size: 25.88 KB - 181 views
[2025-12-15 14:37:48]
Hi - any update on the same?
Please do the needful as GDFL would initiate the trial from tom onwards.
[2025-12-15 16:59:02]
We can not extend the trial, as you have used all the trial time available. To change to a paid package, follow these instructions:
Sierra Chart Purchase and License Information: Instructions
Also, we are not understanding this statement:
From what you show, this is due to being on a Trial. As we stated, you need to be on one of the Integrated packages to be able to connect to data and trading services. So you would need to change to a paid package first.
