Date/Time: Tue, 27 Oct 2026 17:54:01 +0000
Inaccurate SPX Data
View Count: 541
| [2025-11-18 17:31:42] |
| noface - Posts: 1 |
My current SPX data is off by about 5pts, meaning the open, high, low and current price displayed on a chart are 5pts higher than they actually are. I'm not exactly sure why this would happen, I assume the issue is based off the data feed, but I believe I'm using the Denali Exchange Data. I have SP11. I thought at first having delayed equity data would cause the SPX calculation to be off but would not explain the discrepancy in price. The ticker I'm using is SPX500. The other recommended SPX ticker (SPX_CGI) does not load a chart. Steps taken: - deleted + downloaded data from chart - disconnected + reconnected to data feed I posted a chart below with the only study being the high + low of today's session (11/18) as a reference point. Times are PST. https://www.sierrachart.com/image.php?Image=1763486424393.png Date Time Of Last Edit: 2025-11-18 17:34:34
| [2025-12-31 19:47:23] |
| User753526 - Posts: 86 |
I had the same question... received this response and use this Spreadsheet Formula (bar) study to correct it to the SPX_CGI so I keep the overnight data also. Offset/Shift/Adjust Chart Candlestick Price |
| [2026-01-01 07:20:47] |
| Sierra_Chart Engineering - Posts: 25297 |
SPX500 is a CFD. Do not use that. Instead use SPX_CGI. You just need to activate that exchange to be able to receive data for it: Denali Exchange Data Feed: CBOE Global Indexes Data Feed Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-01 07:21:38
