Date/Time: Tue, 27 Oct 2026 18:33:24 +0000
Offset/Shift/Adjust Chart Candlestick Price
View Count: 378
[2025-11-11 18:16:33]
User753526 - Posts: 86
I am using the SPX500 Instrument so that I can see overnight price movement however I use Options Data based on what would be the SPX_CGI Instrument, although they are really the same asset, SPX500 prints approxiamtely 6 pts higher than SPX_CGI does at any time.
To align with the Options Data I use whilst trading futures, I wanted to adjust the SPX500 Instrument price on my Chart by those 6 pts.
Is there a way to do that within Sierra Chart?
[2025-11-11 18:24:21]
Sierra_Chart Engineering - Posts: 25297
You can add an additional study to the chart to perform this calculation:
Using the Basic Arithmetic Studies
[2025-11-11 18:31:43]
I used the Subgraph Subtract study as I am wanting to subtract from the SPX500 instrument but from what I can see the only output is a Line. Is it possible to do this so that the candlesticks are displayed after the subtraction?
[2025-11-11 19:23:18]
John - SC Support - Posts: 48342
You would need to use the "Spreadsheet Formula - Bar" and enter the formula you need for each item in the bar. In general, this would be formulas like the following for the Open:
=O - 6
Refer to the following:
Spreadsheet Formula (Bar)
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
