Date/Time: Wed, 25 Nov 2026 21:06:18 +0000
Data export options
View Count: 454
| [2025-11-12 01:15:07] |
| User417481 - Posts: 1 |
Hello - I am looking for historical intraday futures data that I can export. But after looking at the documentation I'm confused as to if Sierra Chart can help with what I'm looking for. I am looking for at least a couple years of sub-minute price and volume data if possible (preferably 1 second data) for ES, NQ, GC, etc. I am also looking for VWAP and the market internals ($TICK, $UVOL, $DVOL, $ADD, etc.) which can be 1 or 5-minute data. If sub-minute data is not available for price and volume I can still work with it. Can Sierra help with this? Thanks!
| [2025-11-12 14:56:23] |
| John - SC Support - Posts: 48659 |
You have access to all our historical data when you are on a paid package. Refer to the following for what is available: Sierra Chart Historical Data Service: What is Included Right now, you are on a Trial, so you have limited data available. Refer to the following: Sierra Chart Trial Account To export data and study information, refer to the following: Edit Menu: Edit >> Export Bar and Study Data to Text File For the Market Statistics refer to the following: Sierra Chart Market Statistics For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
