Date/Time: Wed, 25 Nov 2026 16:38:55 +0000
suddenly no bid/ask data
View Count: 528
| [2025-10-20 20:10:41] |
| ruby_kinetix - Posts: 29 |
Hi, Dudley I don't have bid/ask data. but have last traded and mbo. it worked fine last week. and it happened before, but it came back after reconnect / restart.. any suggestion how to fix it ?
| [2025-10-20 20:11:24] |
Make sure you have the proper columns displayed. Refer to the following for this and other things to check: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-22 03:58:45] |
hi I already read your message and I didn't change anything, and it was fully working before. any other advice ?
Attachment Deleted. |
| [2025-10-22 14:32:48] |
Select "File >> Open Market Depth Window" and let us know if you are seeing the market depth in there or if you only have 1 level. If you only see 1 level (or none), then refer to the following: File Menu: Not Receiving the Full Number of Market Depth Levels If you see the full market depth, then get us your chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-23 13:14:59] |
hi I got full Market Depth levels on ES and MGC , I attached here. Please advise, and I put my Chartbook here. thank you
| [2025-10-23 17:10:16] |
The chartbook you attached does not have a DOM displayed. We need the DOM as you have it setup so we can see your setup. Please get us another chartbook with a chart/Trading DOM that has the issue you are having, by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-10-27 15:43:35] |
hi, here is the Dom setup .. and one more thing, the DOM suddenly have chart in it. I never know about it. how does it happen ? I gonna use it futures.
| [2025-10-27 16:03:50] |
As we mentioned in Post #2, you do not have the proper columns displayed. You have the "Buy Column" and "Sell Column", but not the "Bid Size" or "Ask Size". Refer to the following: Global Trade Settings Windows: Buy Order Column - Left/Center/Right Aligned Global Trade Settings Windows: Bid Size - Left/Center/Right Aligned Global Trade Settings Windows: Bid Size/Buy Column - Left/Center/Right Aligned -- The reason the bars are showing in the DOM is that you have a "Study/Price Overlay" study on that chart, and it is set to overlay the Main Price Graph. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
