Date/Time: Wed, 25 Nov 2026 16:03:00 +0000
Need /ES Historical 1 Minute Intraday Data
View Count: 1638
| [2025-08-25 20:21:24] |
| User178945 - Posts: 2 |
Hello. Am I able to get this for the last 24 months and if so how do I get it? I have the $26 package and hope it is included. If not /ES then how about SPX? Thanks.
| [2025-08-25 21:25:35] |
You have access to this data for just the ES. We have this data at the tick level, but if you want to export it as 1 minute then you can do so. You can also bring it in and store it in 1 minute increments if you want - refer to the following for this: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) Refer to the following for what historical data is available in general: Sierra Chart Historical Data Service: What is Included The SPX is part of the CBOE Global Indices, and this data is not available unless you pay for it. To do this, you would need to be on one of the Integrated packages and setup and pay for that exchange. If you need more information related to this, let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-08-26 11:55:19] |
Thank you. A couple of questions. 1. For /ES symbol the only symbols found were for June 2025, Sept 2025 and Dec 2025 options so I chose Dec 2025, is this correct to get the historical data back 24 months on /ES 2. I want to then export the data to a csv file am I able to do that, and if so, how? Thanks. |
| [2025-08-26 13:43:30] |
1. The Find Symbol window only shows a few of the current contracts. If you want to go further back, you need to type in the specific contract you want to open in the "Selected Symbol" field. There is also the option for a "Continuous Futures Contract Chart". Refer to the following: Continuous Futures Contract Charts 2. Refer to the following: Edit Menu: Edit >> Export Bar Data to Text File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
