Date/Time: Wed, 25 Nov 2026 16:39:20 +0000
Platform Questions
View Count: 518
| [2025-07-11 17:15:44] |
| User57180 - Posts: 14 |
Just getting started and had some platform questions: How can I very quickly add all Crude Contracts to a chart Can I change the corner radius for my candlestick charts? Can I put a permanent line for the region separator instead of just when I hover? How can I make it adjust smoother when dragging the time scale left and right Enable Vertical and Horizontal Gridlines for all charts and set default colors *Spreadsheet Questions:* I frequently track 10-15 forward contracts in a spreadsheet and create statistics from them. How can I get last price data into blank spreadsheet by referencing each symbol and not having to open 10-15 charts? When I type =(F3 + G3) into a cell, how do I drag that down to the cells below? In excel there is a tiny handle you can grab. If I create a calculation on a spreadsheet, Is there an indicator that would write that data to an scid file? If not, can a custom study access a value from a particular cell on a spreadsheet? Shawn Cooke |
| [2025-07-11 17:36:08] |
We are not certain what you are wanting to do here exactly, but refer to the following: Continuous Futures Contract Charts Add Additional Symbol Can I change the corner radius for my candlestick charts?
These are drawn as rectangles, so the corners are 90 degrees. There is not a way to change this. If you are asking about something different, then let us know. Can I put a permanent line for the region separator instead of just when I
hover? Refer to the following: Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu) How can I make it adjust smoother when dragging the time scale left and
right Refer to the following: General Settings Window: Scroll Multiplier (Global Settings >> General Settings >> GUI >> Scroll) Enable Vertical and Horizontal Gridlines for all charts and set default
colors Start by referring to the following for how to create/use a chart template: Using Chart Templates: Duplicating Charts / Template Charts Refer to the following regarding the grid lines: Chart Menu: Horizontal Grid (Chart menu) Chart Menu: Vertical Grid (Chart menu) Refer to the following for colors of the grid: Graphics Settings: Chart Grid I frequently track 10-15 forward contracts in a spreadsheet and create
statistics from them. How can I get last price data into blank spreadsheet by referencing each symbol and not having to open 10-15 charts? One thing you can use is the "Quote Spreadsheet". Refer to the following: Getting Quotes: Quotes on Spreadsheets Otherwise, you would need to have the symbols on a chart somewhere/somehow (you could have 1 chart and use the "Add Additional Symbol" to get the other symbols on the same chart). Keep in mind that the "Spreadsheet Study" automatically shows the data for studies that are on that same chart. Refer to the following: Using the Spreadsheet Study When I type =(F3 + G3) into a cell, how do I drag that down to the cells
below? In excel there is a tiny handle you can grab. If you are using the Spreadsheet Study, then there are special "Formula Columns" that automatically copy down the information that is entered in cells in Row 3. If you are using a standard Sierra Chart spreadsheet (opened with "File >> New Spreadsheet"), then to copy down, you need to select the cell and the range to which you want to copy to, then select "Spreadsheet >> Copy Down". If I create a calculation on a spreadsheet, Is there an indicator that
would write that data to an scid file? If not, can a custom study access a value from a particular cell on a spreadsheet? We are not certain what you are really wanting in terms of writing data to a .scid file. The .scid files are the raw data. These do not hold any indicator values. The indicators are calculated whenever you load the chart - the actual values are not stored. Refer to the information above for the Spreadsheet Study, as this might be what you are looking for. You can interact with the spreadsheets using a custom study. Refer to the following for a start: ACSIL Programming Concepts: Referencing Data from a Sheet within a Spreadsheet For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
