Date/Time: Wed, 02 Jul 2025 00:24:37 +0000
Data Provider Issue
View Count: 1270
[2014-10-04 10:39:17] |
User42384 - Posts: 4 |
Hi, I just signed up for your service and I'm having an issue with a message that comes up saying I do not qualify as a non-professional when based on the answers it's clear that I am not. Although this message was displayed the system allowed me to continue and sign up for non-professional data for Eurex with market depth. After completion I signed the agreement with Barchart, but no log in details were provided. I'm now trying to connect to receive the data and Barchart is not one of the available connections and the ones that have 'trading' written next to it won't allow me to connect. Can you please help me get this set up correctly? Thanks, Reis |
[2014-10-04 13:26:31] |
Software version: 1199 | 2014-10-04 13:09:42 Usage end date: 2014-11-18 | 2014-10-04 13:09:42 Enabled for: Advanced Features. | 2014-10-04 13:09:42 Enabled for: Advanced Features 2. | 2014-10-04 13:09:42 Enabled for: Sierra Chart Historical Data Service. | 2014-10-04 13:09:42 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2014-10-04 13:09:42 Enabled for: EUREX exchange. | 2014-10-04 13:09:42 Received 1 data feed usernames. | 2014-10-04 13:09:42 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-10-04 13:09:42 Active service: Barchart | 2014-10-04 13:09:42 Time Zone: +00:00:00 (UTC+00) | 2014-10-04 13:09:42 2014-10-04 14:09:42 Local computer clock time | 2014-10-04 13:09:42 2014-10-04 13:09:42 GMT time | 2014-10-04 13:09:42 2014-10-04 13:09:42 Time zone adjusted time | 2014-10-04 13:09:42 Time difference to server time: 0 seconds. | 2014-10-04 13:09:42 Program path: C:\SierraChart\ | 2014-10-04 13:09:42 Data Files path: C:\SierraChart\Data\ | 2014-10-04 13:09:42 OS Version Number: 6.2 | 2014-10-04 13:09:42 Checking for new symbol settings for ddf | 2014-10-04 13:09:42 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-10-04 13:09:42 HTTP connection to www.sierrachart.com:80 (1124) | Connected. | 2014-10-04 13:09:42 Symbol settings are up-to-date for ddf | 2014-10-04 13:09:42 Barchart | Verifying status of username. | 2014-10-04 13:09:47 Barchart | Requesting user settings from http://www.ddfplus.com for | 2014-10-04 13:09:47 Barchart | User settings received. | 2014-10-04 13:09:47 Barchart- Login status: fail | 2014-10-04 13:09:47 Barchart | Username or Password is not set correctly or are not currently active. Check these in 'Global Settings >> Data/Trade Service Settings'. | 2014-10-04 13:09:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-10-04 13:09:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-10-04 13:09:47 Barchart | Reset socket. | 2014-10-04 13:09:47 Barchart | Disconnected. | 2014-10-04 13:09:47 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-10-04 13:09:47 HTTP connection to www.sierrachart.com:80 (1124) | Closed. No error. | 2014-10-04 13:09:52 HTTP connection to www.sierrachart.com:80 (1124) | Shutdown and closed. | 2014-10-04 13:09:52 Date Time Of Last Edit: 2014-10-05 00:27:00
[2014-10-04 23:42:15] |
The data connection username and password are automatically given to Sierra Chart and you will not receive those. What you need to do is set Global Settings >> Data/Trade Service Settings >> Service to "SC Exchange Data". You can find all of the available EUREX symbols in File >> Find Symbol. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-10-05 00:27:53] |
I just signed up for your service and I'm having an issue with a message that comes up saying I do not qualify as a non-professional when based on the answers it's clear that I am not. The user is set to be a non-professional, however they are not qualified for the CME exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-05 00:28:19
