Date/Time: Wed, 25 Nov 2026 21:23:57 +0000
lock a chart
View Count: 1032
[2025-06-03 11:09:47]
Rnn - Posts: 84
Is there a way to lock a locked fill space chart? What I mean is to lock it completely so that the chart wont move at all (except move with the current time).
many times charts that I use (which have locked fill space turned on) moving slightly to a previous bar and I miss the current live bar.
if not - can u pls add this feature?
[2025-06-03 14:43:37]
There is not a way to full lock a chart. But there are some things you can do to help alleviate the issue.
- Remove the scroll bar:
Chart Menu: Show Scrollbar (Chart menu)
- Set the scroll wheel on your pointing device to not include a scrolling option:
General Settings Window: Scroll Wheel (Global Settings >> General Settings >> GUI >> Scroll)
- Ensure you are not using the "Hand" tool which can move the chart.
Chart Drawing Tools: Hand
With the above, the only way to then move the chart is with the Control Bar buttons, arrow keys, or Page Up/Down.
