Date/Time: Wed, 25 Nov 2026 21:46:13 +0000
Alert on numbers bar calculated values
View Count: 816
[2025-05-19 20:17:01]
Jimmyy - Posts: 358
How can i set an alert for SG in the numbers bar calculated values
For eg if a specific SG < xxx (the value when it triggers)
I am looking for the if statement for the above. I had done it in the past but i am not able to figure it out now
[2025-05-19 20:32:15]
You do not need an "IF()" statement for true/false tests in the Alerts. So the following statement is the right idea:
=SG < xxx
But, there are some special rules for what you need to do to access the information for some of the Numbers Bars Calculated Values. Refer to the following:
Numbers Bars: Referencing Numbers Bars Calculated Values Subgraphs in Alert Formulas
[2025-05-19 20:37:00]
Jimmyy - Posts: 358
Okay - i will give this a try tomorrow.
Also, i was testing out the alerts just on price conditions. Every time alert triggered , the alert manager and alert log both pop up. How can i not have the alert manager pop up but let only the log pop up
[2025-05-20 17:41:41]
We do not know what you mean by "Alert Manager" and "Alert Log". To us, this is the same thing.
There is a "Compact Alert Pop-Up" window, if maybe this is what you are referring to. This can be set for specific alerts to show in it. By default, alerts do not show in the "Compact Alert Pop-Up".
Also refer to the following setting:
General Settings Window: Show Alerts Log On Study Alert (Global Settings >> General Settings >> Alerts >> Additional Settings)
