Date/Time: Wed, 25 Nov 2026 21:36:09 +0000
Delta footprint chart help
View Count: 5167
| [2025-05-15 04:41:52] |
| User625361 - Posts: 8 |
Hi I am trying to build a delta footprint chart with total volume in middel on left should be delta with blue and red colour and on right total volume bar with 20ticks range as well as dom needs to be there. At the bottom need volume, delta, and cumulative delta.Picture attached. A very famous and successful trader use this name as Carmine rosato. |
Private File Attachment Deleted. Private File |
| [2025-05-15 14:20:17] |
The documentation for the Numbers Bars study is here: Numbers Bars The general idea of what you want to do is to setup 3 columns, each with the item you want in it. The Cumulative Delta study documentation is here: Cumulative Delta Bars - Volume You might also be wanting the "Numbers Bars Calculated Values" studies. Refer to the following: Numbers Bars: Displaying Numeric Information Below Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-15 14:26:24] |
Did you receive the picture that i attached?
Private File |
| [2025-05-15 14:48:23] |
We saw the image. We are not sure the point you are trying to make. The information for everything you want to do is in our documentation. It is your responsibility to go through that documentation and learn how to use the system. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-05-15 14:49:58
| [2025-05-15 18:09:09] |
Thank for you reply. One more thing how incan change tick size to 20ticks or 5 point range like I want each candle formed 20ticks or 5 points
| [2025-05-15 18:13:14] |
Refer to the following: Chart Settings: Range Per Bar - True (in ticks) (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period >> Bar Period Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-17 23:09:14] |
How i can setup this kind of DOM
| [2025-05-19 14:55:22] |
Refer to the following: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-20 15:30:52] |
Hi how i can i choose different instruments like ES instead of MES but with the same setting of chartbook. Do i need to change eveytime when i choose different instruments or is there any other way?
| [2025-05-20 16:43:15] |
Refer to the following: Using Chart Templates: Duplicating Charts / Template Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-21 04:49:42] |
How to reduce the size of the number bar calculated values so that i have more space for top portion
| Attachment Deleted. |
| [2025-05-21 14:20:47] |
Refer to the following: Working With Charts: Chart Window and Regions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
