Date/Time: Mon, 20 May 2024 06:33:29 +0000
Numbers bars calculated values different background color between rows
View Count: 351
[2022-11-03 10:56:18] |
User246799 - Posts: 13 |
Hello, I would like to set different background color logics for each row of the Numbers bars calculated values study. For example : - volume row : different gray colors - delta row : red and blue colors I have seen a picture of that configuration but I am unable to produce it (see attached file). Is there a way to do this ? If the way to do this is to use a second Numbers bars calculated values study, how to have them close together ? I mean no space between the 2 studies, as if it was only one study (see attached file). Thank you. Jerome |
Capture d’écran 2022-11-03 à 11.45.50.png / V - Attached On 2022-11-03 10:52:12 UTC - Size: 173.03 KB - 85 views |
[2022-11-03 15:45:29] |
John - SC Support - Posts: 31734 |
The only way to do this is to use two copies of the Numbers Bars Calculated Values studies. There is not a way to remove the space between the studies.
[2024-04-26 19:35:02] |
Tin43 - Posts: 78 |
I can't change the color of the Numbers Bars Calculated Values. I'm not talking about the coloring method about range up/down. I'm talking about the text color the numbers are displayed. |
[2024-04-26 20:39:34] |
You color the numbers by changing the color of each subgraph. If an item has two selections for the colors, then the specific color used is defined by the "Auto-Coloring" option. Refer to the following: Chart Studies: Subgraphs Tab >> Color Chart Studies: Subgraphs Tab >> Auto Coloring For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
