Date/Time: Mon, 29 Apr 2024 12:26:36 +0000
[Locked] - Notice: New Market Statistics Data Feed
View Count: 9753
[2014-02-14 21:44:33] |
Just to let you all know, we are working on the release of the new market statistics, at this time. Should be done this evening. And be available Monday. There are going to be 60 symbols available and we will be documenting them. They will update 24 hours twice a second. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-15 07:49:45
[2014-02-14 22:25:51] |
One other thing, this will require version 1092 that we are going to be putting out tomorrow.
[2014-02-15 01:14:28] |
Market stats are now released. And we have released version 1092 which is necessary to use for the new market statistics symbols. Update Sierra Chart by selecting Help >> Download Prerelease. You will find the new market stats symbols in File >> Find Symbol >> Market Stats. You just need to open a chart for them from there. We do not have the symbol settings set up yet for the 60 market statistics symbols for the Forex services or Rithmic. We will get this done before Monday. Let us know how they work. ---- In version 1092, although you may see the following symbols listed in File >> Find Symbol >> Market Stats. They will no longer work in 1092 or higher. You need to use the new ones. $NSHF: NYSE Adv Issues - Decl Issues (The number of stocks up minus the number of stocks down on the day.) $NVLF: NYSE Adv Volume - Decl Volume (The total volume of stocks up minus the total volume of stocks down on the day.) $TICK: NYSE Tick $TQCK: NASDAQ Tick $TRIN: NYSE Trin $TRIQ: NASDAQ Trin Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-15 11:01:26
SC Market Stats Find Symbol.png / V - Attached On 2014-02-15 11:01:19 UTC - Size: 15.5 KB - 536 views |
[2014-02-15 06:48:42] |
In regards to cash indexes, we will try to get the major indexes out by February 21. You will be able to access the data for these side-by-side with any of the supported trading services and also with the new "SC Exchange Data " service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-15 06:49:27
[2014-02-15 08:28:10] |
The following old market statistics symbols will be discontinued at the market close of February 28: $NSHF: NYSE Adv Issues - Decl Issues (The number of stocks up minus the number of stocks down on the day.) $NVLF: NYSE Adv Volume - Decl Volume (The total volume of stocks up minus the total volume of stocks down on the day.) $TICK: NYSE Tick $TQCK: NASDAQ Tick $TRIN: NYSE Trin $TRIQ: NASDAQ Trin Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-15 08:53:53] |
The new market statistics symbols have now been set up for the Rithmic Trading service and the SC Forex Data (FXCM) Data service.
[2014-02-15 11:13:16] |
tobi - Posts: 351 |
Thank you for adding the Market Statistics Symbols you have added. Looks like you have put a lot of work in that !! What I can not find is the US Dollar Index and ideally the FX Indices too, that I've described in post #1 here: Market Statistics, US Dollar Index, other/new FX indices Are these still under construction or are you not planing to add these? Date Time Of Last Edit: 2014-02-15 11:13:50
[2014-02-16 21:37:54] |
Dollar index and the other FX indexes, we will be working on next. Hopefully should be out within three weeks.
[2014-02-18 10:43:28] |
AKR - Posts: 523 |
will there some time also come internals for european exchanges? or also via tele trader?
[2014-02-18 10:43:52] |
User54027 - Posts: 128 |
Hello, Is documentation on these indicators available yet? Thanks Justin |
[2014-02-18 13:53:12] |
Handle - Posts: 36 |
I do not see any of the Russell 2000 Market Stats that you indicated in an earlier thread would be added. Is this still in the works?
[2014-02-18 14:35:28] |
maxima120 - Posts: 144 |
no $TICK today! I have ver 1092.
Date Time Of Last Edit: 2014-02-18 14:48:13
[2014-02-18 14:37:53] |
hello support, None of the new market statistic charts are working. None of the old charts are working. Please advise urgently. |
[2014-02-18 14:46:11] |
my error, please ignore my ramblings, all is working fine. Apologies |
[2014-02-18 14:48:47] |
User54027 - could you help? what 'new' symbol do you use?
[2014-02-18 14:58:43] |
Please could you let me know which symbol has replaced the old advance/decline symbol ($NSHF and $NVLF), both for volume and number of issues being traded? Thanks |
[2014-02-18 16:45:34] |
drak33 - Posts: 20 |
Hello, now I use symbol TICK-NYSE instead of $TICK, but I see no data (version 1093). My broker is Interactive Brokers, do I need to pay for data "NYSE Indices" at IB? Thanks. |
[2014-02-18 16:56:01] |
no you dont.. you just need to reset your symbols: https://www.sierrachart.com/SupportBoard.php?PostID=25393#P25393
[2014-02-18 17:11:59] |
I do not see any of the Russell 2000 Market Stats that you indicated in an earlier thread would be added. Is this still in the works? We will have to see about this. We are not sure right now.We will work on documentation for the new markets statistics symbols, today. now I use symbol TICK-NYSE instead of $TICK, but I see no data (version 1093). My broker is Interactive Brokers, do I need to pay for data "NYSE Indices" at IB?
Start a new thread on this Support Board about this and then post a copy of the Message Log in that thread, by following these instructions:https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-19 04:50:10] |
Documentation for new market statistics data feed: https://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php#top Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-19 05:26:09] |
tobi - Posts: 351 |
I see you've already added the US Dollar Index. This is great! Thank you for adding this so quickly.In case you have any questions regarding the calculation of the other FX indexes, please let me know. |
[2014-02-19 05:51:58] |
tobi - Posts: 351 |
US Dollar Index: Would it be possible to add a little more historical data? - for intraday charts ~ 3 month - for historical charts ~ 5 years Maybe you could use / "import" the data from $DXY symbol from your SC Historical Data Service? |
[2014-02-19 06:28:03] |
AKR - Posts: 523 |
is there an answer to post 78? rgrds |
[2014-02-19 06:28:49] |
AKR - Posts: 523 |
sorry, post 9
[2014-02-19 06:31:19] |
AKR - Posts: 523 |
are the new stats available for AMP/TT as well already?
