Date/Time: Tue, 17 Nov 2026 18:16:48 +0000
Historical Intraday Data Download Skipped problem
View Count: 2739
| [2025-05-06 16:02:15] |
| M. GARCIA - Posts: 1 |
Hello, After trying downloading many times data from Denali, i cannot find any solution to get my ES data. I tried to get session times right (NY session), i deleted all data and downloaded again, i trid with another charbootk I would like to know if there are others solutions for my problem ? Thank you. |
| [2025-05-08 12:47:11] |
| Sierra_Chart Engineering - Posts: 25432 |
We see you are using Rithmic and you have also activated a CME nonprofessional exchange but you cannot access the data from that CME nonprofessional exchange for the following reason: The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported Trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
