Date/Time: Wed, 25 Nov 2026 21:56:04 +0000
UNABLE TO CONNECT TO TETON OR TRADING EVALUATOR
View Count: 710
[2025-05-05 11:43:16]
aknsyu71@gmail - Posts: 60
I am having difficulty connecting to either Teton stage five or the trading evaluator real time.
I have an Internet connection just the same as yesterday. Nothing else has changed on my system.
I can connect to Sierra data but I don't get any data on it?!
TETON:
2025-05-05 12:40:45.011 | Teton CME Routing | Firm: Dorman/Stage5
2025-05-05 12:40:45.033 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11092
2025-05-05 12:40:45.035 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2025-05-05 12:40:45.036 | DTC Client socket (3) | New receive buffer size: 0
2025-05-05 12:40:45.036 | DTC Client socket (3) | Connecting to IP: 38.142.127.146.
2025-05-05 12:40:53.068 | MNQM25_FUT_CME[M] Daily #1 | Reloading chart.
2025-05-05 12:40:53.101 | MNQM25_FUT_CME[M] Daily #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: Z:\Users\ak\WINAPPS\SierraChart_AK\Data\MNQM25_FUT_CME.dly
2025-05-05 12:40:53.106 | MNQM25_FUT_CME[M] Daily #1 | Chart data loading complete.
2025-05-05 12:41:09.039 | Teton CME Routing | Timeout connecting to server.
2025-05-05 12:41:09.039 | Teton CME Routing | Failed connections: 1
2025-05-05 12:41:09.039 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-05-05 12:41:09.039 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-05-05 12:41:09.051 | DTC Client socket (3) | CloseSocket call.
2025-05-05 12:41:09.051 | Teton CME Routing | Disconnected.
2025-05-05 12:41:09.052 | DTC Client socket (3) | Closed.
2025-05-05 12:41:09.052 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
TRADING EVALUATOR:
2025-05-05 12:42:04.989 | Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096
2025-05-05 12:42:04.990 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-05-05 12:42:04.991 | DTC Client socket (2) | New receive buffer size: 0
2025-05-05 12:42:04.991 | DTC Client socket (2) | Connecting to IP: 64.152.155.17.
2025-05-05 12:42:13.058 | MNQM25[M] Daily #1 | Reloading chart.
2025-05-05 12:42:13.126 | MNQM25[M] Daily #1 | Chart data loading complete.
2025-05-05 12:42:28.997 | Trading Evaluator | Timeout connecting to server.
2025-05-05 12:42:28.997 | Trading Evaluator | Failed connections: 1
2025-05-05 12:42:28.997 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-05-05 12:42:28.997 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-05-05 12:42:29.011 | DTC Client socket (2) | CloseSocket call.
2025-05-05 12:42:29.011 | DTC Client socket (2) | Closed.
2025-05-05 12:42:29.011 | Trading Evaluator | Disconnected.
2025-05-05 12:42:29.011 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
[2025-05-05 16:41:39]
You are having a general connectivity issue. We cannot say why.
If you are still having an issue, then please get us a full Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
