Date/Time: Wed, 25 Nov 2026 22:08:06 +0000
[User Discussion] - Verified Trading Accounts Ending Date
View Count: 787
| [2025-04-30 04:09:40] |
| Orangutan - Posts: 9 |
Good Evening Team, I saw this in my account stating "Verified Trading Accounts Ending Date:2025-05-30" . What does this mean? Do I have to provide any document? Please advise. |
| [2025-04-30 08:10:08] |
| User135243 - Posts: 337 |
The rule is that you've to connect your live-account once a month, with some connections it works without connection with others you've to connect it once a month, so everything looks fine on your side :)
| [2025-04-30 14:39:02] |
For a bit more context - this is for the Non-Professional requirement from the CME Group. That date needs to be in the future in order for you to get the real-time data at the non-professional rates. If you are always connected to your live, funded, futures trading account, then you do not need to worry about this. That date will keep updating, since you are always connected. Otherwise, as User135243 states, you would need to make a connection to that live, funded, futures trading account at least once a month to update that date. For more information, refer to the following: Denali Exchange Data Feed: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
